Check Kubernetes collector currency
Use this recipe to identify Kubernetes clusters whose DII operator or collection components are outdated, disabled, or stale.
The DII MCP is a Preview feature and is therefore subject to change. |
Prerequisites
Kubernetes collection is configured in the DII tenant.
Access to Kubernetes collector information.
Tools used
OperatorsManagement_getKubernetesCollectors
Optional: AcquisitionUnitsService_getAcquisitionUnits
Optional: CollectorService_getDataSources
Starter prompt
Review DII Kubernetes collector currency. Group clusters by overall status, identify outdated or disabled operators and components, and flag stale last-reported timestamps. Do not display internal addresses or UUIDs.
Agent workflow
List Kubernetes collectors.
Normalize each cluster into:
Up to date
Outdated
Disabled
Unknown
Compare:
Operator version
Network Performance and Map component version
Change Analysis component version
Convert the last-reported timestamp into the requested timezone.
Flag clusters that have not reported within the agreed freshness threshold.
Distinguish
N/Afrom an outdated version:-
N/Acan mean the component is not installed, not enabled, or not applicable.
If reporting is stale, inspect related acquisition-unit and collector status where available.
Return a prioritized upgrade and investigation list.
Interpretation
Outdated: at least one installed component is behind the DII-expected version.
Disabled: collection is intentionally or administratively disabled.
Stale reporting: version data may not reflect the cluster's current state.
N/A: requires context; do not automatically classify it as a failure.
The tool reports versions and status. It does not perform upgrades.
Suggested output
Cluster counts by status
Outdated clusters ranked by reporting freshness
Component-level version differences
Disabled or unavailable components
Recommended verification steps
Limits and privacy
Cluster names can be sensitive; use approved handling when sharing results.
Do not infer vulnerability exposure from version currency alone.
Validate upgrade compatibility and process outside this read-only workflow.
Follow-up prompts
Which clusters have an outdated operator and have not reported in the last hour?
Separate clusters with an outdated Change Analysis component from clusters where that component is unavailable.
For stale clusters, check whether the associated DII collection infrastructure is healthy.
