DC/OS Data Collector
Data Infrastructure Insights uses this data collector to gather metrics from DC/OS.
Installation
From Observability > Collectors, click +Data Collector. Choose DC/OS.
If you haven't configured an Agent for collection, you are prompted to install an agent on your tenant.
If you have an agent already configured, select the appropriate Operating System or Platform and click Continue.
Follow the instructions in the DC/OS Configuration screen to configure the data collector. The instructions vary depending on the type of Operating System or Platform you are using to collect data.
Setup
Setup information can be found in the DC/OS documentation.
Objects and Counters
The following objects and their counters are collected:
Object | Identifiers | Attributes | Datapoints |
dcos_node |
dcos_container |
cluster |
system_uptime (float) |
Troubleshooting
Additional information may be found in the Support page.
