Configuring the Amazon EC2 data collector
Data Infrastructure Insights uses the Amazon EC2 data collector to acquire inventory and performance data from EC2 instances.
Requirements
In order to collect data from Amazon EC2 devices, you must have the following information:
You must have one of the following:
The IAM Role for your Amazon EC2 cloud account, if using IAM Role Authentication. IAM Role only applies if your acquisition unit is installed on an AWS instance.
The IAM Access Key ID and Secret Access Key for your Amazon EC2 cloud account, if using IAM Access Key authentication.
You must have the "list organization" privilege
Port 443 HTTPS
EC2 Instances can be reported as a Virtual Machine, or (less naturally) a Host. EBS Volumes can be reported as both a VirtualDisk used by the VM, as well as a DataStore providing the Capacity for the VirtualDisk.
Access keys consist of an access key ID (for example, AKIAIOSFODNN7EXAMPLE) and a secret access key (for example, wJalrXUtnFEMI/K7MDENG/bPxRfiCYEXAMPLEKEY). You use access keys to sign programmatic requests that you make to EC2 if you use the Amazon EC2 SDKs, REST, or Query API operations. These keys are provided with your contract from Amazon.
Configuration
Enter data into the data collector fields according to the table below:
| Field | Description |
AWS Region |
Choose AWS region |
IAM Role |
For use only when acquired on an AU in AWS. See below for more information on IAM Role. |
AWS IAM Access Key ID |
Enter AWS IAM Access Key ID. Required if you do not use IAM Role. |
AWS IAM Secret Access Key |
Enter AWS IAM Secret Access Key. Required if you do not use IAM Role. |
I understand AWS bills me for API requests |
Check this to verify your understanding that AWS bills you for API requests made by Data Infrastructure Insights polling. |
Advanced Configuration
Include Extra Regions |
Specify additional regions to include in polling. |
Cross Account Role |
Role for accessing resources in different AWS accounts. |
Inventory Poll Interval (min) |
The default is 60 |
Choose 'Exclude' or 'Include' to Apply to Filter VMs by Tags |
Specify whether to include or exclude VM's by Tags when collecting data. If ‘Include’ is selected, the Tag Key field can not be empty. |
Tag Keys and Values on which to Filter VMs |
Click + Filter Tag to choose which VMs (and associated disks) to include/exclude by filtering for keys and values that match keys and values of tags on the VM. Tag Key is required, Tag Value is optional. When Tag Value is empty, the VM is filtered as long as it matches the Tag Key. |
Performance Poll Interval (sec) |
The default is 1800 |
CloudWatch Agent Metrics Namespace |
Namespace in EC2/EBS from which to collect data. Note that if the names of the default metrics in this namespace are changed, Data Infrastructure Insights may not be able to collect that renamed data. It is recommended to leave the default metric names. |
IAM Access Key
Access keys are long-term credentials for an IAM user or the AWS account root user. Access keys are used to sign programmatic requests to the AWS CLI or AWS API (directly or using the AWS SDK).
Access keys consist of two parts: an access key ID and a secret access key. When you use IAM Access Key authentication (as opposed to IAM Role authentication), you must use both the access key ID and secret access key together for authentication of requests. For more information, see the Amazon documentation on Access Keys.
IAM Role
When using IAM Role authentication (as opposed to IAM Access Key authentication), you must ensure that the role you create or specify has the appropriate permissions needed to access your resources.
For example, if you create an IAM role named InstanceEc2ReadOnly, you must set up the policy to grant EC2 read-only list access permission to all EC2 resources for this IAM role. Additionally, you must grant STS (Security Token Service) access so that this role is allowed to assume roles cross accounts.
After you create an IAM role, you can attach it when you create a new EC2 instance or any existing EC2 instance.
After you attach the IAM role InstanceEc2ReadOnly to an EC2 instance, you will be able to retrieve the temporary credential through instance metadata by IAM role name and use it to access AWS resources by any application running on this EC2 instance.
For more information see the Amazon documentaiton on IAM Roles.
Note: IAM role can be used only when the Acquisition Unit is running in an AWS instance.
Mapping Amazon tags to Data Infrastructure Insights annotations
The Amazon EC2 data collector includes an option that allows you to populate Data Infrastructure Insights annotations with tags configured on EC2. The annotations must be named exactly as the EC2 tags. Data Infrastructure Insights will always populate same-named text-type annotations, and will make a "best attempt" to populate annotations of other types (number, boolean, etc). If your annotation is of a different type and the data collector fails to populate it, it may be necessary to remove the annotation and re-create it as a text type.
Note that AWS is case-sensitive, while Data Infrastructure Insights is case-insensitive. So if you create an annotation named "OWNER" in Data Infrastructure Insights, and tags named "OWNER", "Owner", and "owner" in EC2, all of the EC2 variations of "owner" will map to Cloud Insight's "OWNER" annotation.
In the AWS Data Collector Advanced Configuration section, you can set the Include extra regions field to include additional regions, separated by comma or semi-colon. By default, this field is set to us-.*, which collects on all US AWS regions. To collect on all regions, set this field to .*.
If the Include extra regions field is empty, the data collector will collect on assets specified in the AWS Region field as specified in the Configuration section.
Collecting from AWS Child Accounts
Data Infrastructure Insights supports collection of child accounts for AWS within a single AWS data collector. Configuration for this collection is performed in the AWS environment:
You must configure each child account to have an AWS Role that allows the main account ID to access EC2 details from the children account.
Each child account must have the role name configured as the same string.
Enter this role name string into the Data Infrastructure Insights AWS Data Collector Advanced Configuration section, in the Cross account role field.
The account where the collector is installed needs to have delegate access administrator privileges. See the AWS Documentation for more information.
Best Practice: It is highly recommended to assign the AWS predefined AmazonEC2ReadOnlyAccess policy to the EC2 main account. Also, the user configured in the data source should have at least the predefined AWSOrganizationsReadOnlyAccess policy assigned, in order to query AWS.
Please see the following for information on configuring your environment to allow Data Infrastructure Insights to collect from AWS child accounts:
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
