Data Infrastructure Insights
Data Infrastructure Insights Data Collector Support Matrix
Contributors netapp-alavoie
The Data Collector Support Matrix provides reference for Data Collectors supported by Data Infrastructure Insights , including vendor and model information.
AFX
Models and versions supported by this data collector:
Models Firmware versions
AFX-1K
NetApp Release 9.19.1: Sat Jul 18 20:33:10 UTC 2026
NetApp Release 9.19.1P2: Wed Aug 19 19:38:56 UTC 2026
NetApp Release 9.19.1P3HF1: Fri Oct 23 18:44:28 UTC 2026
Products supported by this data collector:
Product Category Feature/Attribute Status Protocol Used Additional Information
foundation
Capability
Active
Implemented
HTTPS
Licensed
Implemented
HTTPS
Type
Gap
HTTPS
Used
Implemented
HTTPS
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Uniquely identifies this disk in the array
Group
Implemented
HTTPS
Location
Gap
HTTPS
Where this disk is physically located in the array
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
enum for disk status
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume
Is Shared
Implemented
HTTPS
whether this fileShare has any shares associated with it
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Path of the fileShare
Qtree Id
Implemented
HTTPS
unique id of the qtree
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Is compression enabled on the storage pool
Compression Savings
Implemented
HTTPS
ratio of compression savings in percentage
Data Allocated Capacity
Gap
HTTPS
capacity allocated for data
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Is dedupe enabled on the storage pool
Dedupe Savings
Implemented
HTTPS
ratio of dedupe savings in percentage
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
ratio to convert from usable capacity to raw capacity
Snapshot Allocated Capacity
Gap
HTTPS
Allocated capacity of snapshots in MB
Snapshot Count
Implemented
HTTPS
Number of snapshots on the internal volumes
Snapshot Used Capacity
Implemented
HTTPS
Space Guarantee
Implemented
HTTPS
Space Guatantee policy (file, volume or none)
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Thin Provisioning Supported
Implemented
HTTPS
Whether this internal volume supports thin provisioning for the volume layer on top of it
Total Allocated Capacity
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Total capacity in MB
Total Used Capacity (MB)
Implemented
HTTPS
place holder for the used capacity as read from the device
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Virtual Storage
Implemented
HTTPS
Owning virtual storage (vfiler)
Group Id
Implemented
HTTPS
Group Name
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota HardCapacity Limit (MB)
Implemented
HTTPS
Maximum amount of disk space, allowed for the quota target
Quota SoftCapacity Limit (MB)
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Space in MB currently used
Security Style
Implemented
HTTPS
Security style of the directory: unix, ntfs, or mixed
Status
Implemented
HTTPS
Type
Gap
HTTPS
Quota
Hard Capacity Limit (MB)
Implemented
HTTPS
max amount of disk space, allowed for the quota target (Hard limit)
Hard File Limit
Implemented
HTTPS
max number of files allowed for the quota target
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
unique id of the quota
Soft Capacity Limit (MB)
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Max number of files allowed for the quota target
Threshold (MB)
Implemented
HTTPS
Disk space threshold, for the quota target
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
Number of files currently used
Share
IP Interfaces
Implemented
HTTPS
comma separated list of IP addresses on which this share is exposed
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
enum for share protocol
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Permissions for this particular share
Storage
Cluster
Not Available
HTTPS
Whether this storage is a cluster
Cpu Count
Implemented
HTTPS
Cpu Count of the storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Raw capacity of failed disks (sum of all disks that are failed)
Family
Implemented
HTTPS
The storage Family could be Clariion, Symmetrix, et al
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Total raw capacity (sum of all disks on the array)
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Raw capacity of spare disks (sum of all disks that are spare)
SupportActive Active
Implemented
HTTPS
Specified if the storage supports active-active configurations
Virtual
Implemented
HTTPS
Is this a storage virtualization device?
UUID
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
device cache size in MB
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
free text describing the device state
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
time in milliseconds
Version
Implemented
HTTPS
software version
ManagementIp Addresses
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Include In Dwh Capacity
Implemented
HTTPS
A way from ACQ to control which storage pools are interesting in DWH Capacity
Name
Implemented
HTTPS
Physical Disk Capacity (MB)
Implemented
HTTPS
used as raw capacity for storage pool
Raid Group
Implemented
HTTPS
indicates whether this storagePool is a raid group
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage VirtualMachine
Allocated capacity (MB)
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Guid Key
Implemented
HTTPS
Globally Unique Key of the storage virtual machine
IP Space
Implemented
HTTPS
Name
Implemented
HTTPS
Protocols
Implemented
HTTPS
csv of svm enabled protocols (fcp, iscsi, nfs, cifs…​)
State
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
VirtualMachine Internal Volume Ref
Internal Volume Id
Implemented
HTTPS
VirtualMachine StoragePool lRef
Storage Pool Id
Implemented
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
Number of read IOPs on the disk
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Average disk total rate (read and write across all disks) in MB/s
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total Compression Savings
Implemented
HTTPS
Compression Savings Space
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
deduplicationSavingsPercent.total
Implemented
HTTPS
Deduplication Savings Space
Implemented
HTTPS
File System Capacity Logical Used
Implemented
HTTPS
File System Capacity Physical Available
Implemented
HTTPS
File System Capacity Physical Used
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
QOS Wait
Implemented
HTTPS
Total qos wait time
Server ID
Implemented
HTTPS
Snapshot Reserved Capacity
Implemented
HTTPS
Implemented
HTTPS
Snapshot Used Capacity Ratio
Implemented
HTTPS
Reported as a time series
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Capacity quota hard limit
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Quota Capacity
Implemented
HTTPS
Physical used quota capacity
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
StoragePools Capacity
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Failed Disks
Implemented
HTTPS
Failed Fans
Implemented
HTTPS
Failed Power Units
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Optimal Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Capacity Provisioned
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Over Commit Capacity Ratio
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Management APIs used by this data collector:
API Protocol Used Transport layer protocol used Incoming ports used Outgoing ports used Supports authentication Requires only 'Read-only' credentials Supports Encryption Firewall friendly (static ports)
NetApp AFX API
HTTPS
HTTPS
443
true
true
true
true
Amazon AWS EC2
API versions:
  • 2014-10-01
foundation
Data Store
Capacity
Implemented
HTTPS
Snapshot Used capacity in MB
MOID
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Provisioned Capacity
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
subscription Id
Implemented
HTTPS
Server
Cluster
Implemented
HTTPS
Cluster name
DataCenter Name
Implemented
HTTPS
Host OID
Implemented
HTTPS
MOID
Implemented
HTTPS
OID
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
Virtual Disk
Capacity
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Is Chargeable
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
Is Snapshot
Implemented
HTTPS
subscription Id
Implemented
HTTPS
VirtualMachine
Dns Name
Implemented
HTTPS
Guest State
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Host OID
Implemented
HTTPS
IPs
Implemented
HTTPS
MOID
Implemented
HTTPS
Memory
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
OS
Implemented
HTTPS
Power State
Implemented
HTTPS
State Change Time
Implemented
HTTPS
Processors
Implemented
HTTPS
Implemented
HTTPS
Instance Type
Implemented
HTTPS
Launch Time
Implemented
HTTPS
LifeCycle
Implemented
HTTPS
public Ips
Implemented
HTTPS
Security Groups
Implemented
HTTPS
subscription Id
Implemented
HTTPS
VirtualMachine Disk
OID
Implemented
HTTPS
VirtualDisk OID
Implemented
HTTPS
VirtualMachine OID
Implemented
HTTPS
Host
Host OS
Implemented
HTTPS
IPs
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Info
Api Description
Implemented
HTTPS
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
performance
Virtual Disk
Total Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
vm
Total Capacity
Implemented
HTTPS
Total CPU Utilization
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
diskIops.total
Implemented
HTTPS
Disk IOPs write
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Disk Throughput Read
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
total disk throughput read
Disk Throughput Write
Implemented
HTTPS
IP Throughput Read
Implemented
HTTPS
Throughput total
Implemented
HTTPS
IP throughput total
ipThroughput.write
Implemented
HTTPS
Key
Implemented
HTTPS
Total Memory Utilization
Implemented
HTTPS
Server ID
Implemented
HTTPS
EC2 API
HTTPS
HTTPS
443
true
true
true
true
Amazon AWS S3
S3
2010-08-01
foundation
Info
Api Description
Implemented
HTTPS
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Pool
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
performance
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Key
Implemented
HTTPS
Total Objects
Implemented
HTTPS
Server ID
Implemented
HTTPS
Qtree
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
S3 API
HTTPS
HTTPS
443
true
true
true
true
Amazon FSx for NetApp ONTAP
FSx for ONTAP
Data ONTAP
foundation
Capability
Active
Implemented
HTTPS
Licensed
Implemented
HTTPS
Type
Gap
HTTPS
Used
Implemented
HTTPS
Disk Group
Capacity
Implemented
HTTPS
DiskGroup Id
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
Is Oplocks Enabled
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
ISCSI Network Portal
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
ISCSI Network Portal Group
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Security Info
Auth Type
Implemented
HTTPS
Inbound Keyword
Implemented
HTTPS
Initiator Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Outbound Keyword
Implemented
HTTPS
Target Node Name
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Initiator Session Id
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Number Of Connections
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Target Session Id
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Last Known Access Time
Implemented
HTTPS
Name
Implemented
HTTPS
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Gap
HTTPS
Snapshot Count
Implemented
HTTPS
Implemented
HTTPS
Space Guarantee
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Clone Saved Capacity in MB
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Virtual Storage
Implemented
HTTPS
Adaptive Qos Policy
Implemented
HTTPS
Comment
Gap
HTTPS
Group Id
Implemented
HTTPS
Group Name
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
Qos Limit Raw
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Tiering Minimum Cooling Days
Implemented
HTTPS
Storage Synchronization
Source Internal Volume
Implemented
HTTPS
Target Internal Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
QTree
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
GuidKey 3
Implemented
HTTPS
Name
Implemented
HTTPS
Oplocks
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Security Style
Implemented
HTTPS
Status
Implemented
HTTPS
Type
Gap
HTTPS
Quota
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
GuidKey 3
Implemented
HTTPS
Implemented
HTTPS
Hard File Limit
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Threshold (MB)
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
User/Group Target
Implemented
HTTPS
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Cluster
Not Available
HTTPS
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
Memory Size
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
Version
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Reserved Capacity
Implemented
HTTPS
Gap
HTTPS
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Uses FlashPools
Implemented
HTTPS
Virtual
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
UUID
Implemented
HTTPS
Implemented
HTTPS
Comment
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Guid Key
Implemented
HTTPS
IP Space
Implemented
HTTPS
Internal Volume Limit
Implemented
HTTPS
Name
Implemented
HTTPS
Protocols
Implemented
HTTPS
State
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
VirtualMachine Volume Ref
Volume Name
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
DiskGroup
Implemented
HTTPS
Junction Path
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Clone Saved Capacity Total
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Object Store Space Used
Implemented
HTTPS
QOS Wait
Implemented
HTTPS
Total qos wait time
Server ID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Quota Soft Limit
Implemented
HTTPS
Capacity Quota soft Limit
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Cache Hit Ratio Total
Implemented
HTTPS
Total Disk Read Replaced
Implemented
HTTPS
Failed Fans
Implemented
HTTPS
Failed Power Units
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Optimal Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Reserved Capacity
Implemented
HTTPS
Fractional reserved (included in data allocated capacity)
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Object Store Space Physical Space Used
Implemented
HTTPS
Object Store Space Referenced Space
Implemented
HTTPS
Object Store Space SIS Space Saved
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Partial Blocked Ratio
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
NetApp ONTAP API
HTTP/HTTPS
HTTP/HTTPS
80/443
true
true
true
true
ASA
ASA-A1K
ASA-A20
ASA-A30
ASA-A50
ASA-A70
ASA-A90
ASA-C30
NetApp Release 9.16.1P10: Thu Nov 27 17:12:10 UTC 2025
NetApp Release 9.16.1P11: Thu Jan 15 11:21:38 UTC 2026
NetApp Release 9.16.1P3: Thu Apr 24 02:50:10 UTC 2025
NetApp Release 9.16.1P6: Wed Jul 16 03:10:07 UTC 2025
NetApp Release 9.16.1P7: Thu Aug 21 10:29:10 UTC 2025
NetApp Release 9.16.1P8: Sat Oct 04 03:23:15 UTC 2025
NetApp Release 9.17.1P10: Tue Jul 21 21:51:01 UTC 2026
NetApp Release 9.17.1P1: Sat Oct 04 06:37:53 UTC 2025
NetApp Release 9.17.1P2: Fri Nov 07 09:39:01 UTC 2025
NetApp Release 9.17.1P3: Sun Dec 07 04:46:28 UTC 2025
NetApp Release 9.17.1P4: Thu Jan 15 22:33:51 UTC 2026
NetApp Release 9.17.1P6: Wed Mar 25 15:38:10 UTC 2026
NetApp Release 9.17.1P7: Mon Apr 20 13:57:24 UTC 2026
NetApp Release 9.17.1P8: Sun May 17 22:59:03 UTC 2026
NetApp Release 9.17.1P9: Wed Jun 24 13:09:36 UTC 2026
NetApp Release 9.18.1P4: Thu Jun 04 11:38:00 UTC 2026
NetApp Release 9.18.1P5: Thu Jul 09 23:05:16 UTC 2026
NetApp Release 9.18.1P6: Fri Aug 07 23:43:59 UTC 2026
NetApp Release 9.18.1P7: Thu Sep 03 20:55:20 UTC 2026
NetApp Release 9.18.1P8HF1: Fri Oct 23 20:43:35 UTC 2026
foundation
Capability
Active
Implemented
HTTPS
Licensed
Implemented
HTTPS
Type
Gap
HTTPS
Used
Implemented
HTTPS
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Security Info
Auth Type
Implemented
HTTPS
Inbound Keyword
Implemented
HTTPS
Initiator Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Outbound Keyword
Implemented
HTTPS
Target Node Name
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Target Session Id
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Technology
Implemented
HTTPS
technology which causes storage efficiency changed
Storage
Cluster
Not Available
HTTPS
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Partner Node UUID
Implemented
HTTPS
HA pair's UUID
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Implemented
HTTPS
Storage Pool
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Implemented
HTTPS
Guid Key
Implemented
HTTPS
IP Space
Implemented
HTTPS
Name
Implemented
HTTPS
Protocols
Implemented
HTTPS
State
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Volume Name
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
DiskGroup
Implemented
HTTPS
Disk Group Type
Disk Size
Implemented
HTTPS
comma seperated list of disk sizes (GB)
Disk Speed
Implemented
HTTPS
comma seperated list of disk speeds (rpm)
Disk Type
Not Available
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Name of the backend lun
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
Failed Fans
Implemented
HTTPS
Failed Power Units
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Optimal Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
NetApp ASA API
HTTPS
HTTPS
443
true
true
true
true
Brocade Fibre Channel Switches
Models
Brocade 300E
Brocade 32Gb Fibre Channel SAN Switch Module for HPE Synergy
Brocade 4024 Embedded
Brocade 4900
Brocade 5000
Brocade 5300
Brocade 5480 Embedded
Brocade 6505
Brocade 6510
Brocade 6520
Brocade 6547 Embedded
Brocade 6548
Brocade 6558
Brocade 7800
Brocade 7810 Extension Switch
Brocade 7840
Brocade 7850 Extension Switch
Brocade DCX
Brocade DCX-4S Backbone
Brocade DCX8510-4
Brocade DCX8510-8
Brocade G610
Brocade G620
Brocade G630
Brocade G710
Brocade G720
Brocade G730
Brocade G820
Brocade M6505
Brocade X6-4
Brocade X6-8
Brocade X7-4
Brocade X7-8
Firmware versions:
  • v10.0.0a1
  • v6.2.2b
  • v6.2.2f
  • v6.2.2f9
  • v6.3.1a
  • v6.3.2b
  • v6.4.1a
  • v6.4.1b
  • v6.4.3
  • v6.4.3c
  • v6.4.3d
  • v6.4.3f3
  • v6.4.3h
  • v7.0.0c
  • v7.0.1b
  • v7.0.2a
  • v7.0.2b1
  • v7.0.2c
  • v7.1.0b
  • v7.1.1
  • v7.2.0d
  • v7.2.1
  • v7.2.1c1
  • v7.2.1g
  • v7.3.1d
  • v7.4.0a
  • v7.4.1d
  • v7.4.2
  • v7.4.2a
  • v7.4.2a4
  • v7.4.2c
  • v7.4.2f
  • v7.4.2g
  • v7.4.2h
  • v8.0.2c
  • v8.0.2d
  • v8.1.2a
  • v8.1.2d
  • v8.1.2g
  • v8.2.0a
  • v8.2.0b
  • v8.2.1a
  • v8.2.1c
  • v8.2.2a
  • v8.2.2b
  • v8.2.2d
  • v8.2.3
  • v8.2.3a
  • v8.2.3a1
  • v8.2.3a_cvr_855776_01
  • v8.2.3b
  • v8.2.3c
  • v8.2.3c1
  • v8.2.3d
  • v8.2.3e
  • v8.2.3e1
  • v8.2.3e2
  • v8.2.3f
  • v9.0.1a
  • v9.0.1b
  • v9.0.1c
  • v9.0.1d
  • v9.1.1
  • v9.1.1b
  • v9.1.1b_lw
  • v9.1.1c
  • v9.1.1d
  • v9.1.1d2
  • v9.1.1d2_lw
  • v9.1.1d7
  • v9.2.0a
  • v9.2.0b
  • v9.2.0b1
  • v9.2.0b1_lw
  • v9.2.0c3
  • v9.2.0c4
  • v9.2.0c5
  • v9.2.1a
  • v9.2.1a1
  • v9.2.1b
  • v9.2.1c
  • v9.2.1c2
  • v9.2.1c3
  • v9.2.2
  • v9.2.2a
  • v9.2.2b
  • v9.2.2c
  • v9.2.2c1
  • v9.2.2c1_cvr_866435_01
  • v9.2.2d
foundation
FC Name Server Entry
FC ID
Implemented
SSH
Nx Port WWN
Implemented
SSH
Physical Port WWN
Implemented
SSH
Switch Port WWN
Implemented
SSH
Fabric
Name
Implemented
Manual Entry
VSAN Enabled
Implemented
SSH
VSANId
Implemented
SSH
WWN
Implemented
SSH
IVR Physical Fabric
IVR Chassis WWNs
Implemented
SSH
Comma seperated list of IVR enabled chassis WWNs
Lowest IVR Chassis WWN
Implemented
SSH
identifier of the IVR fabric
Info
DataSource Name
Implemented
SSH
Info
Date
Implemented
SSH
Originator ID
Implemented
SSH
Originator Key
Implemented
SSH
Logical Switch
Chassis WWN
Implemented
SSH
Domain Id
Implemented
SSH
Firmware Version
Implemented
SSH
IP
Implemented
SSH
Manufacturer
Implemented
SSH
Model
Implemented
SSH
Name
Implemented
Manual Entry
Serial Number
Implemented
SSH
Switch Role
Implemented
SSH
Switch State
Implemented
SSH
Switch Status
Implemented
SSH
Type
Gap
SSH
WWN
Implemented
SSH
Port
Blade
Implemented
SSH
FC4 Protocol
Implemented
SSH
GBIC Type
Implemented
SSH
Generated
Implemented
SSH
Name
Implemented
Manual Entry
Node WWN
Implemented
SSH
Mandatory to report with PortId if WWN is not present
Port ID
Implemented
SSH
Port Number
Implemented
SSH
Port Speed
Implemented
SSH
Port State
Implemented
SSH
Port Status
Implemented
SSH
Port Type
Implemented
SSH
Raw Port Status
Implemented
SSH
Raw Speed GigaBits
Implemented
SSH
Unknown Connectivity
Implemented
SSH
WWN
Implemented
SSH
Switch
Domain Id
Implemented
SSH
Firmware Version
Implemented
SSH
IP
Implemented
SSH
Manage URL
Implemented
SSH
Manufacturer
Implemented
SSH
Model
Implemented
SSH
Name
Implemented
Manual Entry
Serial Number
Implemented
SSH
Switch Role
Implemented
SSH
Switch State
Implemented
SSH
Switch Status
Implemented
SSH
Type
Gap
SSH
VSAN Enabled
Implemented
SSH
WWN
Implemented
SSH
WWN Alias
Host Aliases
Implemented
SSH
Object Type
Implemented
SSH
Source
Implemented
SSH
WWN
Implemented
SSH
Zone
Zone Name
Implemented
SSH
Zone Member
Type
Gap
SSH
WWN
Implemented
SSH
Zoning Capabilities
Active Configuration
Implemented
SSH
Configuration Name
Implemented
SSH
Default Zoning Behavior
Implemented
SSH
WWN
Implemented
SSH
performance
port
BB Credit Zero Received
Implemented
SNMP
BB Credit Zero Total
Implemented
SNMP
BB Credit Zero Transmitted
Implemented
SNMP
BB Credit Zero Ms Transmitted
Implemented
SNMP
Key
Implemented
SNMP
Port Errors Class3 Discard
Implemented
SNMP
Port Errors Crc
Implemented
SNMP
Port Errors Crc
Port Errors Enc In
Implemented
SNMP
Port Errors Enc In
portErrors.encOut
Implemented
SNMP
Port Error Long Frame
Implemented
SNMP
Port errors due to long frame
Port Error Short Frame
Implemented
SNMP
Port errors due to short frame
Port Errors Link Failure
Implemented
SNMP
Port Errors link failure
Port Errors Link Reset Rx
Implemented
SNMP
Port Error Transmit Link Reset
Implemented
SNMP
Port Error due to link reset
Port Error Signal Loss
Implemented
SNMP
Port errors signal loss
Port Error Sync Loss
Implemented
SNMP
Port error sync loss
Port Error Transmit Discard Timeout
Implemented
SNMP
Port errors timeout discard
Total Port Errors
Implemented
SNMP
Total port errors
Server ID
Implemented
SNMP
Traffic Frame Rate
Implemented
SNMP
Total Traffic Frame Rate
Implemented
SNMP
Traffic Frame Rate
Implemented
SNMP
Average Frame Size
Implemented
SNMP
Average Frame size of traffic
TX Frames
Implemented
SNMP
traffic average frame size
Traffic Recieved Rate
Implemented
SNMP
Total Traffic Rate
Implemented
SNMP
Traffic Transmit Rate
Implemented
SNMP
Traffic Recieved Utilization
Implemented
SNMP
Total Traffic Utilization
Implemented
SNMP
Total traffic utilization
Traffic Transmit Utilization
Implemented
SNMP
Brocade SNMP
SNMP
SNMPv1, SNMPv2, SNMPv3
161
true
true
true
true
Brocade SSH
SSH
SSH
22
false
false
true
true
Data source wizard configuration
Manual Entry
true
true
true
true
Brocade FOS REST
Models
202.0
Brocade 6505
Brocade 6510
Brocade 6520
Brocade 6558
Brocade 7840
Brocade DCX8510-4
Brocade DCX8510-8
Brocade G610
Brocade G620
Brocade G630
Brocade G720
Brocade G730
Brocade G820
Brocade X6-4
Brocade X6-8
Brocade X7-4
Brocade X7-8
Brocade X8-8
Firmware versions:
  • v10.0.0a
  • v10.0.0a1
  • v10.0.0a1_cvr_881241_01
  • v10.0.0a_cvr_875417_01
  • v8.2.2d
  • v8.2.3
  • v8.2.3a1
  • v8.2.3b
  • v8.2.3c
  • v8.2.3c1
  • v8.2.3d
  • v8.2.3e
  • v8.2.3e2
  • v8.2.3f
  • v9.0.0b
  • v9.0.1a
  • v9.0.1b
  • v9.0.1c
  • v9.0.1e1
  • v9.1.0b
  • v9.1.1a
  • v9.1.1b
  • v9.1.1c
  • v9.1.1d
  • v9.1.1d2
  • v9.1.1d7
  • v9.2.0a
  • v9.2.0b
  • v9.2.0b1
  • v9.2.0c1
  • v9.2.0c1_lw
  • v9.2.0c3
  • v9.2.0c3_lw
  • v9.2.0c5
  • v9.2.1
  • v9.2.1a
  • v9.2.1b
  • v9.2.1c
  • v9.2.1c2
  • v9.2.1c3
  • v9.2.2
  • v9.2.2a
  • v9.2.2b
  • v9.2.2c
  • v9.2.2c1
  • v9.2.2c1_lw
  • v9.2.2c_lw
  • v9.2.2d
  • v9.2.2d2
  • v9.2.2d_lw
foundation
FC ID
Implemented
HTTPS
Nx Port WWN
Implemented
HTTPS
Physical Port WWN
Implemented
HTTPS
Switch Port WWN
Implemented
HTTPS
Fabric
Name
Implemented
HTTPS
VSAN Enabled
Implemented
HTTPS
VSANId
Implemented
HTTPS
WWN
Implemented
HTTPS
Info
Api Description
Implemented
HTTPS
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Logical Switch
Chassis WWN
Implemented
HTTPS
Domain Id
Implemented
HTTPS
Firmware Version
Implemented
HTTPS
IP
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Switch Role
Implemented
HTTPS
Switch State
Implemented
HTTPS
Switch Status
Implemented
HTTPS
Type
Gap
HTTPS
WWN
Implemented
HTTPS
Port
Blade
Implemented
HTTPS
GBIC Type
Implemented
HTTPS
Generated
Implemented
HTTPS
Name
Implemented
HTTPS
Node WWN
Implemented
HTTPS
Port ID
Implemented
HTTPS
Port Number
Implemented
HTTPS
Port Speed
Implemented
HTTPS
Port State
Implemented
HTTPS
Port Status
Implemented
HTTPS
Port Type
Implemented
HTTPS
Raw Port Status
Implemented
HTTPS
Raw Speed GigaBits
Implemented
HTTPS
Implemented
HTTPS
WWN
Implemented
HTTPS
Implemented
HTTPS
Switch
Domain Id
Implemented
HTTPS
Firmware Version
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Switch Role
Implemented
HTTPS
Switch State
Implemented
HTTPS
Switch Status
Implemented
HTTPS
Type
Gap
HTTPS
VSAN Enabled
Implemented
HTTPS
WWN
Implemented
HTTPS
WWN Alias
Host Aliases
Implemented
HTTPS
Object Type
Implemented
HTTPS
Source
Implemented
HTTPS
WWN
Implemented
HTTPS
Zone
Zone Name
Implemented
HTTPS
Zone Member
Type
Gap
HTTPS
WWN
Implemented
HTTPS
Zoning Capabilities
Implemented
HTTPS
Configuration Name
Implemented
HTTPS
Implemented
HTTPS
WWN
Implemented
HTTPS
performance
port
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Key
Implemented
HTTPS
Implemented
HTTPS
Port Errors Crc
Implemented
HTTPS
Port Errors Crc
Port Errors Enc In
Implemented
HTTPS
Port Errors Enc In
portErrors.encOut
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Port Errors
Implemented
HTTPS
Total port errors
Server ID
Implemented
HTTPS
Traffic Frame Rate
Implemented
HTTPS
Implemented
HTTPS
Traffic Frame Rate
Implemented
HTTPS
Average Frame Size
Implemented
HTTPS
TX Frames
Implemented
HTTPS
Implemented
HTTPS
Total Traffic Rate
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Brocade FOS REST API
HTTPS
443
true
true
true
true
Cisco MDS & Nexus Fabric Switches
Models
8977-T48
8978-E04
8978-E16
DS-C9132T-K9
DS-C9148-16P-K9
DS-C9148-32P-K9
DS-C9148-48P-K9
DS-C9148S-K9
DS-C9148T-K9
DS-C9148V-K9
DS-C9220I-K9
DS-C9250I-K9
DS-C9396S-K9
DS-C9396T-K9
DS-C9396V-K9
DS-C9506
DS-C9509
DS-C9513
DS-C9706
DS-C9710
DS-C9718
DS-HP-8GFC-K9
DS-HP-FC-K9
UCS-FI-6248UP
UCS-FI-6296UP
UCS-FI-6332-16UP
UCS-FI-6454
UCS-FI-6536
Firmware versions:
  • 2.1(2d)
  • 3.3(5b)
  • 4.2(7a)
  • 5.0(1a)
  • 5.0(3)N2(4.21j)
  • 5.0(3)N2(4.21k)
  • 5.0(3)N2(4.22c)
  • 5.0(3)N2(4.36d)
  • 5.2(2d)
  • 5.2(6b)
  • 5.2(8a)
  • 5.2(8b)
  • 5.2(8c)
  • 5.2(8d)
  • 5.2(8h)
  • 5.2(8i)
  • 6.2(11)
  • 6.2(11b)
  • 6.2(13)
  • 6.2(13a)
  • 6.2(17)
  • 6.2(19)
  • 6.2(21)
  • 6.2(23)
  • 6.2(25)
  • 6.2(29)
  • 6.2(31)
  • 6.2(33)
  • 6.2(5a)
  • 6.2(9)
  • 6.2(9a)
  • 7.3(0)DY(1)
  • 8.1(1)
  • 8.3(1)
  • 8.3(2)
  • 8.4(1)
  • 8.4(1a)
  • 8.4(2a)
  • 8.4(2b)
  • 8.4(2c)
  • 8.4(2d)
  • 8.4(2e)
  • 8.4(2f)
  • 8.5(1)
  • 9.2(1)
  • 9.2(1a)
  • 9.2(2)
  • 9.3(1)
  • 9.3(2)
  • 9.3(2a)
  • 9.3(5)I42(1k)
  • 9.3(5)I42(3f)
  • 9.3(5)I42(3j)
  • 9.3(5)I43(4b)
  • 9.3(5)I43(6b)
  • 9.4(1)
  • 9.4(1a)
  • 9.4(2a)
  • 9.4(3)
  • 9.4(3a)
  • 9.4(3b)
  • 9.4(4)
  • 9.4(5)
  • 9.4(5a)
foundation
FC ID
Implemented
SNMP
Nx Port WWN
Implemented
SNMP
Physical Port WWN
Implemented
SNMP
Switch Port WWN
Implemented
SNMP
Fabric
Name
Implemented
SNMP
VSAN Enabled
Implemented
SNMP
VSANId
Implemented
SNMP
WWN
Implemented
SNMP
IVR Physical Fabric
IVR Chassis WWNs
Implemented
SNMP
Implemented
SNMP
Info
DataSource Name
Implemented
SNMP
Info
Date
Implemented
SNMP
Originator ID
Implemented
SNMP
Originator Key
Implemented
SNMP
Logical Switch
Chassis WWN
Implemented
SNMP
Domain Id
Implemented
SNMP
DomainId Type
Implemented
SNMP
IP
Implemented
SNMP
Manufacturer
Implemented
SNMP
Priority
Implemented
SNMP
Switch Role
Implemented
SNMP
Type
Gap
SNMP
WWN
Implemented
SNMP
Port
Blade
Implemented
SNMP
GBIC Type
Implemented
SNMP
Generated
Implemented
SNMP
Name
Implemented
SNMP
Port ID
Implemented
SNMP
Port Number
Implemented
SNMP
Port Speed
Implemented
SNMP
Port State
Implemented
SNMP
Port Status
Implemented
SNMP
Port Type
Implemented
SNMP
Raw Port Status
Implemented
SNMP
Raw Speed GigaBits
Implemented
SNMP
Implemented
SNMP
WWN
Implemented
SNMP
Switch
Firmware Version
Implemented
SNMP
IP
Implemented
SNMP
Manage URL
Implemented
SNMP
Manufacturer
Implemented
SNMP
Model
Implemented
SNMP
Name
Implemented
SNMP
SANRoute Enabled
Implemented
SNMP
Indicates if this chassis is enabled for SAN routing (IVR, etc…​)
Serial Number
Implemented
SNMP
Switch Status
Implemented
SNMP
Type
Gap
SNMP
VSAN Enabled
Implemented
SNMP
WWN
Implemented
SNMP
WWN Alias
Host Aliases
Implemented
SNMP
Object Type
Implemented
SNMP
Source
Implemented
SNMP
WWN
Implemented
SNMP
Zone
Zone Name
Implemented
SNMP
Zone Type
Implemented
SNMP
Zone Member
Type
Gap
SNMP
WWN
Implemented
SNMP
Zoning Capabilities
Implemented
SNMP
Configuration Name
Implemented
SNMP
Implemented
SNMP
Merge Control
Implemented
SNMP
WWN
Implemented
SNMP
performance
port
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Key
Implemented
SNMP
Implemented
SNMP
Port Errors Crc
Implemented
SNMP
Port Errors Crc
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Total Port Errors
Implemented
SNMP
Total port errors
Server ID
Implemented
SNMP
Traffic Frame Rate
Implemented
SNMP
Implemented
SNMP
Traffic Frame Rate
Implemented
SNMP
Average Frame Size
Implemented
SNMP
TX Frames
Implemented
SNMP
Implemented
SNMP
Total Traffic Rate
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Implemented
SNMP
Cisco SNMP
SNMP
SNMPv1 (Inventory only), SNMPv2, SNMPv3
161
true
true
true
true
Cohesity
C4000 Compute Node
C4600
C5036
C5066
C5200 Compute Node
C5212S
C5218
C6025
C6035
C6055
C6208S
C6216S
CX8405
PXG1
7.1.2_u4_release-20250529_205b971c
7.3.2_release-20260123_529553a9
7.4.1_release-20260723_91509e0b
foundation
Disk
Capacity (GB)
Implemented
Used capacity
Disk Id
Implemented
Name
Implemented
File Share
Is InternalVolume
Implemented
Is Shared
Implemented
Name
Implemented
Path
Implemented
Qtree Id
Implemented
Info
Api Name
Implemented
DataSource Name
Implemented
Info
Date
Implemented
Originator ID
Implemented
Originator Key
Implemented
Internal Volume
Compression Enabled
Implemented
Dedupe Enabled
Implemented
Dedupe Savings
Implemented
Internal Volume Id
Implemented
Name
Implemented
Raw to Usable Ratio
Implemented
Storage Pool Id
Implemented
Thin Provisioned
Implemented
Implemented
Implemented
Total Used Capacity
Implemented
Implemented
Type
Gap
QTree
Name
Implemented
Qtree Id
Implemented
Type
Gap
Share
IP Interfaces
Implemented
Name
Implemented
Protocol
Implemented
Storage
Display IP
Implemented
Failed Raw Capacity
Implemented
Family
Implemented
IP
Implemented
Manage URL
Implemented
Manufacturer
Implemented
Microcode Version
Implemented
Model
Implemented
Name
Implemented
Total Raw Capacity
Implemented
Serial Number
Implemented
Spare Raw Capacity
Implemented
Virtual
Implemented
Storage Node
Model
Implemented
Name
Implemented
Serial Number
Implemented
UUID
Implemented
Version
Implemented
software version
Storage Pool
Compression Enabled
Implemented
Dedupe Enabled
Implemented
Dedupe Savings
Implemented
Implemented
Name
Implemented
Implemented
Raid Group
Implemented
Raw to Usable Ratio
Implemented
Status
Implemented
Storage Pool Id
Implemented
Implemented
Implemented
Total Used Capacity
Implemented
Type
Gap
Virtual
Implemented
Encrypted
Implemented
performance
Disk
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
Internal Volume
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
Key
Implemented
Server ID
Implemented
Qtree
Key
Implemented
Server ID
Implemented
Storage
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
Storage Node
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
StoragePool Disk
Implemented
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Implemented
Capacity Used Ratio
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Cohesity REST API
HTTPS
HTTPS
443
true
true
true
true
Dell EMC Isilon & PowerScale Rest
A200
A2000
A300
A3000
A310
F200
F210
F710
F800
F900
F910
H400
H500
H5600
H600
H700
H7000
H710
NL410
SIMULATOR
X210
9.10.1.2
9.10.1.4
9.10.1.5
9.10.1.6
9.10.1.7
9.10.1.8
9.11.0.0
9.12.0.1
9.13.0.0
9.13.1.0
9.13.1.1
9.13.1.2
9.14.0.1
9.2.1.13
9.2.1.8
9.4.0.12
9.4.0.6
9.5.0.6
9.5.0.8
9.7.1.13
9.7.1.16
9.7.1.2
9.7.1.5
9.7.1.6
9.7.1.7
v8.0.0.7
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
Vendor Id
Implemented
HTTPS
Disk Group
Capacity
Implemented
HTTPS
DiskGroup Id
Implemented
HTTPS
unique id of the disk group
Name
Implemented
HTTPS
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Status
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Vendor DiskGroup Type
Implemented
HTTPS
vendor's designation of the disk group type
Vendor Tier
Implemented
HTTPS
Vendor Specific Tier Name
Virtual
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Gap
HTTPS
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Type
Gap
HTTPS
Quota
Implemented
HTTPS
Hard File Limit
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Threshold (MB)
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
User/Group Target
Implemented
HTTPS
user/group target this quota refers to
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Other Allocated Capacity
Gap
HTTPS
Capacity allocated for other (not data and not snapshot)
Other UsedCapacity (MB)
Implemented
HTTPS
Any capacity other than data and snapshot
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Gap
HTTPS
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Quota Soft Limit
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
Key
Implemented
HTTPS
Quota Capacity
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
Number of read IOPs on file system
IOPs Write
Implemented
HTTPS
IOPs write of filesystem
File Throughput Read
Implemented
HTTPS
FileSystem Throughput
Implemented
HTTPS
fileSystem Throughput write
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Other Total Capacity
Implemented
HTTPS
Other Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
EMC Isilon & PowerScale REST API
HTTPS
443
true
true
true
true
Dell EMC Isilon / PowerScale (CLI)
A200
F800
H5600
H700
NL400
NL410
Traceback (most recent call last):
X200
X400
X410
9.10.1.2
9.8.0.2
v8.0.0.7
v8.1.2.0
foundation
Disk
Capacity (GB)
Implemented
SSH
Used capacity
Disk Id
Implemented
SSH
Group
Implemented
SSH
Location
Gap
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Role
Implemented
SSH
Role Enum
Implemented
SSH
enum for disk role
Serial Number
Implemented
SSH
Speed
Implemented
SSH
Speed of disk (RPM)
Status
Implemented
SSH
Status Enum
Implemented
SSH
Type
Gap
SSH
Type Enum
Implemented
SSH
enum for disk type
Vendor
Implemented
SSH
Vendor Id
Implemented
SSH
Disk Group
Capacity
Implemented
SSH
DiskGroup Id
Implemented
SSH
Name
Implemented
SSH
Implemented
SSH
Redundancy
Implemented
SSH
Redundancy level
Status
Implemented
SSH
Used Capacity
Implemented
SSH
Implemented
SSH
Vendor Tier
Implemented
SSH
Virtual
Implemented
SSH
File Share
Is InternalVolume
Implemented
SSH
Is Shared
Implemented
SSH
Name
Implemented
SSH
Path
Implemented
SSH
Qtree Id
Implemented
SSH
Info
DataSource Name
Implemented
SSH
Info
Date
Implemented
SSH
Originator ID
Implemented
SSH
Internal Volume
Gap
SSH
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Internal Volume Id
Implemented
SSH
Name
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
Gap
SSH
Implemented
SSH
Storage Pool Id
Implemented
SSH
Thin Provisioned
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Type
Gap
SSH
QTree
Name
Implemented
SSH
Qtree Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Quota UsedCapacity
Implemented
SSH
Type
Gap
SSH
Quota
Implemented
SSH
Hard File Limit
Implemented
SSH
Internal Volume Id
Implemented
SSH
Qtree Id
Implemented
SSH
Quota Id
Implemented
SSH
Implemented
SSH
Soft File Limit
Implemented
SSH
Threshold (MB)
Implemented
SSH
Type
Gap
SSH
Used Capacity
Implemented
SSH
Used Files
Implemented
SSH
Share
Implemented
SSH
IP Interfaces
Implemented
SSH
Name
Implemented
SSH
Protocol
Implemented
SSH
Share Initiator
Initiator
Implemented
SSH
Permission
Implemented
SSH
Storage
Display IP
Implemented
SSH
Failed Raw Capacity
Implemented
SSH
Family
Implemented
SSH
IP
Implemented
SSH
Manufacturer
Implemented
SSH
Microcode Version
Implemented
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Serial Number
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Virtual
Implemented
SSH
Storage Node
Model
Implemented
SSH
Name
Implemented
SSH
Serial Number
Implemented
SSH
State
Implemented
SSH
UUID
Implemented
SSH
Implemented
SSH
Storage Pool
Gap
SSH
Data Used Capacity
Implemented
SSH
Implemented
SSH
Name
Implemented
SSH
Implemented
SSH
Raid Group
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
Gap
SSH
Implemented
SSH
Storage Pool Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Type
Gap
SSH
Virtual
Implemented
SSH
performance
Internal Volume
Total Capacity
Implemented
SSH
Total Data Capacity
Implemented
SSH
Data Used Capacity
Implemented
SSH
Key
Implemented
SSH
Server ID
Implemented
SSH
Implemented
SSH
Implemented
SSH
Implemented
SSH
Qtree
Quota Hard Limit
Implemented
SSH
Quota Soft Limit
Implemented
SSH
Used Capacity
Implemented
SSH
Total File Count
Implemented
SSH
Key
Implemented
SSH
Quota Capacity
Implemented
SSH
Server ID
Implemented
SSH
Storage
Failed Raw Capacity
Implemented
SSH
Raw Capacity
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Implemented
SSH
IOPs other
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Latency Total
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Storage Node
IOPs Read
Implemented
SSH
IOPs Write
Implemented
SSH
Implemented
SSH
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Latency Total
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Utilization Total
Implemented
SSH
StoragePool Disk
Implemented
SSH
Raw Capacity
Implemented
SSH
Total Capacity
Implemented
SSH
Used Capacity
Implemented
SSH
Implemented
SSH
Capacity Used Ratio
Implemented
SSH
Total Data Capacity
Implemented
SSH
Data Used Capacity
Implemented
SSH
Implemented
SSH
Implemented
SSH
Implemented
SSH
Isilon SSH
SSH
SSH
22
true
false
true
true
Dell Unisphere REST
Models and versions supported by this data collector:
API versions Models
V10.0.0.2
V10.0.1.5
V10.1.0.1
V10.1.0.5
V10.1.0.6
V10.1.0.8
V10.2.0.1
V10.2.0.12
V10.2.0.14
V10.2.0.9
V10.3.0.1
V10.3.0.5
V10.3.0.7
V10.3.0.9
V10.4.0.1
V10.4.0.11
V10.4.0.5
V9.2.3.11
V9.2.4.12
V9.2.4.15
V9.2.4.17
V9.2.4.18
V9.2.4.19
V9.2.4.20
V9.2.4.22
V9.2.4.23
V9.2.4.9
PowerMax_2000
PowerMax_2500
PowerMax_8000
PowerMax_8500
VMAX100K
VMAX200K
VMAX250F
VMAX400K
VMAX450F
VMAX950F
Firmware versions:
  • 5977.1131.1131 build 615
  • 5977.1151.1151 build 60 build 60
  • 5978.711.711 build 436 build 436
  • 5978.711.711 build 484 build 484
  • 5978.714.714 build 101 build 101
  • 5978.714.714 build 117 build 117
  • 5978.714.714 build 137
  • 5978.714.714 build 137 build 137
  • 5978.714.714 build 145
  • 5978.714.714 build 145 build 145
  • 5978.714.714 build 149 build 149
  • 5978.714.714 build 184
  • 5978.714.714 build 184 build 184
  • 5978.714.714 build 185 build 185
  • 5978.714.714 build 252
  • 5978.714.714 build 252 build 252
  • 5978.714.714 build 79 build 79
  • 5978.720.720 build 17
  • 5978.720.720 build 27
  • 5978.720.720 build 27 build 27
  • 5978.720.720 build 32 build 32
  • 5978.720.720 build 33
  • 5978.720.720 build 33 build 33
  • 5978.720.720 build 38 build 38
  • 5978.720.720 build 56
  • 5978.720.720 build 56 build 56
  • 5978.720.720 build 6
  • 5978.720.720 build 69 build 69
  • 5978.720.720 build 77 build 77
  • 5978.720.720 build 79
  • 5978.720.720 build 84
  • 5978.720.720 build 84 build 84
  • 5978.720.720 build 97 build 97
  • 6079.225.0 build 216 build 216
  • 6079.275.0 build 292 build 292
  • 6079.275.0 build 396 build 396
  • 6079.280.0 build 37 build 37
  • 6079.280.0 build 53 build 53
  • 6079.325.0 build 216 build 216
  • 6079.325.0 build 231 build 231
  • 6079.325.0 build 244 build 244
  • 6079.325.0 build 253 build 253
  • 6079.325.0 build 275 build 275
  • 6079.325.0 build 310 build 310
  • 6079.325.0 build 324 build 324
  • 6079.325.0 build 342 build 342
  • 6079.325.0 build 84 build 84
Products supported by this data collector:
Product Category Feature/Attribute Status Protocol Used Additional Information
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Disk Id
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type Enum
Implemented
HTTPS
Vendor
Implemented
HTTPS
Info
Api Description
Implemented
HTTPS
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
Client Api Description
Implemented
HTTPS
Client Api Name
Implemented
HTTPS
Client Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Name
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Pool
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioning Supported
Implemented
HTTPS
Total Allocated Capacity
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Effective Used Capacity Percent
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Mode
Implemented
HTTPS
Mode Enum
Implemented
HTTPS
Source Storage
Implemented
HTTPS
Source Volume
Implemented
HTTPS
State
Implemented
HTTPS
State Enum
Implemented
HTTPS
Target Storage
Implemented
HTTPS
Target Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
Volume
AutoTier Policy Identifier
Implemented
HTTPS
Auto Tiering
Implemented
HTTPS
Capacity
Implemented
HTTPS
Disk Type
Not Available
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Written Capacity
Implemented
HTTPS
Implemented
HTTPS
Compression Enabled
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
storage Groups
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
WWN Alias
Host Aliases
Implemented
HTTPS
Object Type
Implemented
HTTPS
Source
Implemented
HTTPS
WWN
Implemented
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
Number of read IOPs on the disk
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Average disk total rate (read and write across all disks) in MB/s
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Storage
Cache Hit Ratio Read
Implemented
HTTPS
Implemented
HTTPS
Cache Hit Ratio Write
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Raw capacity of spare disks (sum of all disks that are spare)
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Write Pending
Implemented
HTTPS
total write pending
Storage Node
Implemented
HTTPS
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Reported as a time series
Capacity Used Ratio
Implemented
HTTPS
Total Compression Savings
Implemented
HTTPS
Compression Savings Space
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Snapshot Reserved Capacity
Implemented
HTTPS
Snapshot Used Capacity Ratio
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Written Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
CapacityRatio Written
Implemented
HTTPS
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Dell Unisphere API
HTTPS
HTTPS
443
true
true
true
true
EMC Celerra (SSH)
Models Firmware versions
VG8
VNX5200
VNX5300
7.1.76-4
7.1.79-8
8.1.9-155
foundation
File Share
Is InternalVolume
Implemented
SSH
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume
Is Shared
Implemented
SSH
whether this fileShare has any shares associated with it
Name
Implemented
SSH
Path
Implemented
SSH
Path of the fileShare
Qtree Id
Implemented
SSH
unique id of the qtree
Status
Implemented
SSH
Info
Api Name
Implemented
SSH
Api Version
Implemented
SSH
DataSource Name
Implemented
SSH
Info
Date
Implemented
SSH
Originator ID
Implemented
SSH
Originator Key
Implemented
SSH
Internal Volume
Data Allocated Capacity
Gap
SSH
capacity allocated for data
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Is dedupe enabled on the storage pool
Dedupe Savings
Implemented
SSH
ratio of dedupe savings in percentage
GuidKey 1
Implemented
SSH
GuidKey1 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5.
GuidKey 2
Implemented
SSH
GuidKey2 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5.
Internal Volume Id
Implemented
SSH
Last Snapshot Time
Implemented
SSH
time of last snapshot
Name
Implemented
SSH
Gap
SSH
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
ratio to convert from usable capacity to raw capacity
Snapshot Count
Implemented
SSH
Number of snapshots on the internal volumes
Storage Pool Id
Implemented
SSH
Thin Provisioned
Implemented
SSH
Implemented
SSH
Whether this internal volume supports thin provisioning for the volume layer on top of it
Implemented
SSH
Total Used Capacity
Implemented
SSH
Total capacity in MB
Total Used Capacity (MB)
Implemented
SSH
place holder for the used capacity as read from the device
Type
Gap
SSH
Virtual Storage
Implemented
SSH
Owning virtual storage (vfiler)
QTree
GuidKey 1
Implemented
SSH
GuidKey 2
Implemented
SSH
Name
Implemented
SSH
Qtree Id
Implemented
SSH
Quota HardCapacity Limit (MB)
Implemented
SSH
Maximum amount of disk space, allowed for the quota target
Quota SoftCapacity Limit (MB)
Implemented
SSH
Quota UsedCapacity
Implemented
SSH
Space in MB currently used
Type
Gap
SSH
Quota
GuidKey 1
Implemented
SSH
GuidKey 2
Implemented
SSH
Hard Capacity Limit (MB)
Implemented
SSH
max amount of disk space, allowed for the quota target (Hard limit)
Internal Volume Id
Implemented
SSH
Qtree Id
Implemented
SSH
Quota Id
Implemented
SSH
unique id of the quota
Soft Capacity Limit (MB)
Implemented
SSH
Soft File Limit
Implemented
SSH
Max number of files allowed for the quota target
Type
Gap
SSH
Used Capacity
Implemented
SSH
Used Files
Implemented
SSH
Number of files currently used
Share
IP Interfaces
Implemented
SSH
comma separated list of IP addresses on which this share is exposed
Name
Implemented
SSH
Protocol
Implemented
SSH
enum for share protocol
Share Initiator
Initiator
Implemented
SSH
Permission
Implemented
SSH
Permissions for this particular share
Storage
Cpu Count
Implemented
SSH
Cpu Count of the storage
Display IP
Implemented
SSH
Failed Raw Capacity
Implemented
SSH
Raw capacity of failed disks (sum of all disks that are failed)
Family
Implemented
SSH
The storage Family could be Clariion, Symmetrix, et al
IP
Implemented
SSH
Manufacturer
Implemented
SSH
Microcode Version
Implemented
SSH
Model
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Total raw capacity (sum of all disks on the array)
Serial Number
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Virtual
Implemented
SSH
Is this a storage virtualization device?
Storage Pool
Gap
SSH
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Include In Dwh Capacity
Implemented
SSH
A way from ACQ to control which storage pools are interesting in DWH Capacity
Name
Implemented
SSH
Raid Group
Implemented
SSH
indicates whether this storagePool is a raid group
Raw to Usable Ratio
Implemented
SSH
Snapshot Allocated Capacity
Gap
SSH
Allocated capacity of snapshots in MB
Implemented
SSH
Storage Pool Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Type
Gap
SSH
Virtual
Implemented
SSH
Management APIs used by this data collector:
API Protocol Used Transport layer protocol used Incoming ports used Outgoing ports used Supports authentication Requires only 'Read-only' credentials Supports Encryption Firewall friendly (static ports)
Celerra CLI
SSH
SSH
true
false
true
true
EMC CLARiiON (NaviCLI)
API versions Models Firmware versions
7.32
7.33
VNX5100
VNX5200
VNX5300
VNX5400
VNX5500
VNX5600
VNX7600
05.32.000.5.218
05.32.000.5.219
05.32.000.5.221
05.32.000.5.249
05.33.009.5.155
05.33.009.5.184
05.33.009.5.231
05.33.021.5.256
05.33.021.5.266
foundation
Disk
Capacity (GB)
Implemented
CLI
Used capacity
Disk Id
Implemented
CLI
Uniquely identifies this disk in the array
Group
Implemented
CLI
Location
Gap
CLI
Where this disk is physically located in the array
Model
Implemented
CLI
Name
Implemented
CLI
Role
Implemented
CLI
Role Enum
Implemented
CLI
enum for disk role
Serial Number
Implemented
CLI
Status
Implemented
CLI
Status Enum
Implemented
CLI
enum for disk status
Type
Gap
CLI
Type Enum
Implemented
CLI
enum for disk type
Vendor
Implemented
CLI
Info
Api Name
Implemented
CLI
Api Version
Implemented
CLI
Client Api Name
Implemented
CLI
Client Api Version
Implemented
CLI
DataSource Name
Implemented
CLI
Info
Date
Implemented
CLI
Originator ID
Implemented
CLI
Storage
Display IP
Implemented
CLI
Failed Raw Capacity
Implemented
CLI
Family
Implemented
CLI
IP
Implemented
CLI
Manage URL
Implemented
CLI
Manufacturer
Implemented
CLI
Microcode Version
Implemented
CLI
Model
Implemented
CLI
Name
Implemented
CLI
Total Raw Capacity
Implemented
CLI
Serial Number
Implemented
CLI
Spare Raw Capacity
Implemented
CLI
SupportActive Active
Implemented
CLI
Specified if the storage supports active-active configurations
Virtual
Implemented
CLI
Storage Node
Name
Implemented
CLI
Serial Number
Implemented
CLI
UUID
Implemented
CLI
ManagementIp Addresses
Implemented
CLI
Storage Pool
Dedupe Enabled
Implemented
CLI
Implemented
CLI
Name
Implemented
CLI
Gap
CLI
Implemented
CLI
Physical Disk Capacity (MB)
Implemented
CLI
used as raw capacity for storage pool
Raid Group
Implemented
CLI
Raw to Usable Ratio
Implemented
CLI
Redundancy
Implemented
CLI
Redundancy level
Gap
CLI
Implemented
CLI
Status
Implemented
CLI
Storage Pool Id
Implemented
CLI
Implemented
CLI
Implemented
CLI
Total Used Capacity
Implemented
CLI
Type
Gap
CLI
Virtual
Implemented
CLI
Mode
Implemented
CLI
Mode Enum
Implemented
CLI
Source Volume
Implemented
CLI
State
Implemented
CLI
free text describing the device state
State Enum
Implemented
CLI
Target Volume
Implemented
CLI
Technology
Implemented
CLI
Volume
Implemented
CLI
Dynamic Tier Policy identifier
Auto Tiering
Implemented
CLI
indicates if this storagepool is participating in auto tiering with other pools
Capacity
Implemented
CLI
Snapshot Used capacity in MB
DiskGroup
Implemented
CLI
Disk Group Type
Disk Type
Not Available
CLI
Junction Path
Implemented
CLI
Name
Implemented
CLI
Total Raw Capacity
Implemented
CLI
Redundancy
Implemented
CLI
Redundancy level
Replica Source
Implemented
CLI
Replica Target
Implemented
CLI
Storage Pool Id
Implemented
CLI
Thin Provisioned
Implemented
CLI
Type
Gap
CLI
UUID
Implemented
CLI
Used Capacity
Implemented
CLI
Volume Map
LUN
Implemented
CLI
Protocol Controller
Implemented
CLI
Storage Port
Implemented
CLI
Type
Gap
CLI
Volume Mask
Initiator
Implemented
CLI
Protocol Controller
Implemented
CLI
Storage Port
Implemented
CLI
Type
Gap
CLI
WWN Alias
Host Aliases
Implemented
CLI
IP
Implemented
CLI
Object Type
Implemented
CLI
Source
Implemented
CLI
WWN
Implemented
CLI
performance
Disk
IOPs Read
Implemented
CLI
IOPs Total
Implemented
CLI
IOPs Write
Implemented
CLI
Key
Implemented
CLI
Server ID
Implemented
CLI
Throughput Read
Implemented
CLI
Throughput Total
Implemented
CLI
Throughput Write
Implemented
CLI
Read Utilization
Implemented
CLI
Utilization Total
Implemented
CLI
Utilization Write
Implemented
CLI
Storage
Implemented
CLI
Implemented
CLI
Implemented
CLI
Failed Raw Capacity
Implemented
CLI
Raw Capacity
Implemented
CLI
Spare Raw Capacity
Implemented
CLI
StoragePools Capacity
Implemented
CLI
IOPs other
Implemented
CLI
IOPs Read
Implemented
CLI
IOPs Total
Implemented
CLI
IOPs Write
Implemented
CLI
Key
Implemented
CLI
Latency Read
Implemented
CLI
Latency Total
Implemented
CLI
Latency Write
Implemented
CLI
Implemented
CLI
Server ID
Implemented
CLI
Throughput Read
Implemented
CLI
Throughput Total
Implemented
CLI
Throughput Write
Implemented
CLI
Storage Node
IOPs Read
Implemented
CLI
IOPs Total
Implemented
CLI
IOPs Write
Implemented
CLI
Key
Implemented
CLI
Server ID
Implemented
CLI
Utilization Total
Implemented
CLI
StoragePool Disk
Capacity Provisioned
Implemented
CLI
Raw Capacity
Implemented
CLI
Total Capacity
Implemented
CLI
Used Capacity
Implemented
CLI
Over Commit Capacity Ratio
Implemented
CLI
Capacity Used Ratio
Implemented
CLI
IOPs Read
Implemented
CLI
IOPs Total
Implemented
CLI
IOPs Write
Implemented
CLI
Implemented
CLI
Other Used Capacity
Implemented
CLI
Implemented
CLI
Implemented
CLI
Implemented
CLI
Throughput Read
Implemented
CLI
Throughput Total
Implemented
CLI
Throughput Write
Implemented
CLI
Read Utilization
Implemented
CLI
Utilization Total
Implemented
CLI
Utilization Write
Implemented
CLI
Volume
Implemented
CLI
Implemented
CLI
Implemented
CLI
Raw Capacity
Implemented
CLI
Total Capacity
Implemented
CLI
Used Capacity
Implemented
CLI
Capacity Used Ratio
Implemented
CLI
IOPs Read
Implemented
CLI
IOPs Total
Implemented
CLI
IOPs Write
Implemented
CLI
Key
Implemented
CLI
Latency Read
Implemented
CLI
Latency Total
Implemented
CLI
Latency Write
Implemented
CLI
Implemented
CLI
Server ID
Implemented
CLI
Throughput Read
Implemented
CLI
Throughput Total
Implemented
CLI
Throughput Write
Implemented
CLI
Navi CLI
CLI
6389,2162,2163,443(HTTPS)/80(HTTP)
true
true
true
false
EMC Data Domain (SSH)
DD VE
DD2500
DD3300
DD6300
DD6400
DD6410
DD6900
DD9300
DD9400
DD9410
DD9800
DD9900
DD9910
6.2.1.30-663869
7.10.1.15-1078832
7.13.1.40-1186473
7.13.1.80-1246402
7.7.5.25-1078970
8.3.0.15-1161254
8.3.1.0-1175411
8.3.1.10-1194895
8.3.1.30-1226406
8.3.1.40-1247360
8.3.1.45-1261709
8.3.1.50-1268129
8.4.0.0-1175068
8.6.1.20-1246795
foundation
Disk
Capacity (GB)
Implemented
SSH
Used capacity
Disk Id
Implemented
SSH
Group
Implemented
SSH
Location
Gap
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Role
Implemented
SSH
Role Enum
Implemented
SSH
enum for disk role
Serial Number
Implemented
SSH
Speed
Implemented
SSH
Speed of disk (RPM)
Status
Implemented
SSH
Status Enum
Implemented
SSH
Type
Gap
SSH
Type Enum
Implemented
SSH
enum for disk type
File Share
Is InternalVolume
Implemented
SSH
Is Shared
Implemented
SSH
Name
Implemented
SSH
Path
Implemented
SSH
Qtree Id
Implemented
SSH
Info
DataSource Name
Implemented
SSH
Info
Date
Implemented
SSH
Originator ID
Implemented
SSH
Internal Volume
Gap
SSH
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Dedupe Savings
Implemented
SSH
Internal Volume Id
Implemented
SSH
Name
Implemented
SSH
Gap
SSH
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
Storage Pool Id
Implemented
SSH
Thin Provisioned
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Implemented
SSH
Type
Gap
SSH
Encrypted
Implemented
SSH
QTree
Name
Implemented
SSH
Qtree Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Type
Gap
SSH
Quota
Implemented
SSH
Internal Volume Id
Implemented
SSH
Qtree Id
Implemented
SSH
Quota Id
Implemented
SSH
Implemented
SSH
Type
Gap
SSH
Used Capacity
Implemented
SSH
Share
IP Interfaces
Implemented
SSH
Name
Implemented
SSH
Protocol
Implemented
SSH
Share Initiator
Initiator
Implemented
SSH
Permission
Implemented
SSH
Storage
Cpu Count
Implemented
SSH
Display IP
Implemented
SSH
Failed Raw Capacity
Implemented
SSH
Family
Implemented
SSH
IP
Implemented
SSH
Manage URL
Implemented
SSH
Manufacturer
Implemented
SSH
Microcode Version
Implemented
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Serial Number
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Virtual
Implemented
SSH
Storage Node
Model
Implemented
SSH
Name
Implemented
SSH
Processors Count
Implemented
SSH
device CPU
Serial Number
Implemented
SSH
UUID
Implemented
SSH
Version
Implemented
SSH
software version
Implemented
SSH
Storage Pool
Gap
SSH
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Dedupe Savings
Implemented
SSH
Implemented
SSH
Name
Implemented
SSH
Gap
SSH
Implemented
SSH
Implemented
SSH
Raid Group
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
Storage Pool Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Type
Gap
SSH
Virtual
Implemented
SSH
Encrypted
Implemented
SSH
Data Domain CLI
SSH
SSH
22
true
true
true
true
EMC ECS
ECS
3.7.0.0
3.8.0.2
3.8.1.1
3.8.1.3
3.8.1.4
3.8.1.6
3.9.0.0
4.1.0.2
4.1.0.3
4.1.0.4
4.3.0.1
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
Disk Group
Capacity
Implemented
HTTPS
DiskGroup Id
Implemented
HTTPS
Name
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Name
Implemented
HTTPS
UUID
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Node Capacity Utilization Total in MB
Implemented
HTTPS
Node Capacity Utilization Usable in MB
Implemented
HTTPS
Node Capacity Utilization Used in MB
Implemented
HTTPS
Storage Pool
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
performance
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Key
Implemented
HTTPS
Total Objects
Implemented
HTTPS
Server ID
Implemented
HTTPS
Qtree
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
EMC ECS REST API
HTTPS
HTTPS
443
true
true
true
true
EMC PowerStore REST
PowerStore 1000T
PowerStore 1200T
PowerStore 3000T
PowerStore 3200T
PowerStore 5000T
PowerStore 500T
PowerStore 5200Q
PowerStore 5200T
PowerStore 7000T
PowerStore 9000T
PowerStore 9200T
3.2.0.1
4.0.0.2
4.0.1.3
4.1.0.0
4.1.0.1
4.1.0.2
4.1.0.3
4.1.0.4
4.1.0.5
4.3.1.0
4.3.1.1
4.3.1.2
5.0.0.1
5.0.0.2
foundation
Disk
Capacity (GB)
Implemented
Used capacity
Disk Id
Implemented
Location
Gap
Name
Implemented
Serial Number
Implemented
Speed
Implemented
Speed of disk (RPM)
Status
Implemented
Type
Gap
Type Enum
Implemented
enum for disk type
Vendor
Implemented
File Share
Is InternalVolume
Implemented
Is Shared
Implemented
Name
Implemented
Path
Implemented
Qtree Id
Implemented
ISCSI Network Portal
IP
Implemented
Listening Port
Implemented
Nic
Implemented
OID
Implemented
ISCSI Network Portal Group
OID
Implemented
Portal Group Name
Implemented
Portal Group Tag
Implemented
ISCSI Node
Host Aliases
Implemented
Node Name
Implemented
OID
Implemented
Type
Gap
ISCSI Session
Initiator Ips
Implemented
Initiator OID
Implemented
Max Connections
Implemented
Number Of Connections
Implemented
OID
Implemented
Portal Group OID
Implemented
Security
Implemented
Info
Api Name
Implemented
DataSource Name
Implemented
Info
Date
Implemented
Originator ID
Implemented
Originator Key
Implemented
Internal Volume
Dedupe Enabled
Implemented
Internal Volume Id
Implemented
Name
Implemented
Raw to Usable Ratio
Implemented
Storage Pool Id
Implemented
Thin Provisioned
Implemented
Implemented
Implemented
Total Used Capacity
Implemented
Implemented
Type
Gap
Virtual Storage
Implemented
QTree
Name
Implemented
Qtree Id
Implemented
Type
Gap
Share
IP Interfaces
Implemented
Name
Implemented
Protocol
Implemented
Share Initiator
Initiator
Implemented
Permission
Implemented
Storage
Display IP
Implemented
Failed Raw Capacity
Implemented
Family
Implemented
IP
Implemented
Manage URL
Implemented
Manufacturer
Implemented
Microcode Version
Implemented
Model
Implemented
Name
Implemented
Total Raw Capacity
Implemented
Serial Number
Implemented
Spare Raw Capacity
Implemented
Implemented
Virtual
Implemented
Storage Node
Model
Implemented
Name
Implemented
Partner Node UUID
Implemented
HA pair's UUID
UUID
Implemented
Parent Serial Number
Implemented
Storage Pool
Compression Savings
Implemented
ratio of compression savings in percentage
Implemented
Name
Implemented
Implemented
Raid Group
Implemented
Raw to Usable Ratio
Implemented
Storage Pool Id
Implemented
Implemented
Implemented
Total Used Capacity
Implemented
Type
Gap
Virtual
Implemented
Volume
Capacity
Implemented
Junction Path
Implemented
Name
Implemented
Total Raw Capacity
Implemented
Storage Pool Id
Implemented
Thin Provisioned
Implemented
Type
Gap
UUID
Implemented
Used Capacity
Implemented
QoS - Policy
Implemented
Volume Map
LUN
Implemented
Masking Required
Implemented
Protocol Controller
Implemented
Storage Port
Implemented
Type
Gap
Volume Mask
Initiator
Implemented
Protocol Controller
Implemented
Type
Gap
WWN Alias
Host Aliases
Implemented
Object Type
Implemented
Source
Implemented
WWN
Implemented
performance
Internal Volume
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
IOPs other
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Qtree
Key
Implemented
Server ID
Implemented
Storage
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
Implemented
IOPs other
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Storage Node
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
StoragePool Disk
Implemented
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Implemented
Capacity Used Ratio
Implemented
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Volume
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
EMC PowerStore REST API
HTTPS
HTTPS
443
true
true
true
true
EMC RecoverPoint (HTTP)
RecoverPoint
5.1.SP4.P5(h.138)
foundation
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Storage Synchronization
Mode
Implemented
HTTPS
Mode Enum
Implemented
HTTPS
Source Storage
Implemented
HTTPS
Source Volume
Implemented
HTTPS
State
Implemented
HTTPS
State Enum
Implemented
HTTPS
Target Storage
Implemented
HTTPS
Target Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
technology which causes storage efficiency changed
RecoverPoint REST API
HTTPS
HTTPS
443
true
true
true
true
EMC Symmetrix CLI
V10.0.0.0
V10.2.0.0
V10.2.0.2
V10.3.0.0
V10.3.0.1
V9.1.0.6
V9.2.3.0
V9.2.3.1
V9.2.3.6
V9.2.4.14
V9.2.4.15
V9.2.4.3
V9.2.4.6
V9.2.4.7
V9.2.4.8
V9.2.4.9
unavailable
PowerMax_2000
PowerMax_8000
VMAX-1
VMAX100K
VMAX250F
VMAX400K
VMAX450F
VMAX950F
5876.286.194(16F40000) build 115
5876.309.196(16F40000) build 94
5977.1151.1151(17590000) build 60
5978.711.711(175A0000) build 448
5978.714.714(175A0000) build 117
5978.714.714(175A0000) build 137
5978.714.714(175A0000) build 145
5978.714.714(175A0000) build 147
5978.714.714(175A0000) build 185
5978.714.714(175A0000) build 252
5978.714.714(175A0000) build 49
5978.714.714(175A0000) build 53
5978.720.720(175A0000) build 1
5978.720.720(175A0000) build 27
5978.720.720(175A0000) build 38
5978.720.720(175A0000) build 56
5978.720.720(175A0000) build 75
foundation
Device Group
Name
Implemented
Storage Management Id
Implemented
Type
Gap
Disk
Capacity (GB)
Implemented
Used capacity
Disk Id
Implemented
Group
Implemented
Model
Implemented
Name
Implemented
Role
Implemented
Role Enum
Implemented
enum for disk role
Serial Number
Implemented
Status
Implemented
Status Enum
Implemented
Type Enum
Implemented
enum for disk type
Vendor
Implemented
Disk Group
Capacity
Implemented
DiskGroup Id
Implemented
Name
Implemented
Implemented
Redundancy
Implemented
Redundancy level
Used Capacity
Implemented
Implemented
Virtual
Implemented
Info
Api Description
Implemented
Api Name
Implemented
Api Version
Implemented
Implemented
Client Api Name
Implemented
Client Api Version
Implemented
DataSource Name
Implemented
Info
Date
Implemented
Originator ID
Implemented
Originator Key
Implemented
Network Pipe Port Wwn
WWN
Implemented
Protocol EndPoint
ID
Implemented
Name
Implemented
Storage Ip
Implemented
Storage
Display IP
Implemented
Failed Raw Capacity
Implemented
Family
Implemented
IP
Implemented
Manufacturer
Implemented
Microcode Version
Implemented
Model
Implemented
Name
Implemented
Total Raw Capacity
Implemented
Serial Number
Implemented
Spare Raw Capacity
Implemented
Virtual
Implemented
Storage Node
Name
Implemented
UUID
Implemented
Storage Pool
Auto Tiering
Implemented
Compression Enabled
Implemented
Is compression enabled on the storage pool
Compression Savings
Implemented
Gap
Data Used Capacity
Implemented
Dedupe Enabled
Implemented
Implemented
Name
Implemented
Implemented
Implemented
Raid Group
Implemented
Raw to Usable Ratio
Implemented
Redundancy
Implemented
Redundancy level
Implemented
Soft Limit (MB)
Implemented
logical volume size that is defined during volume creation or resizing operations
Storage Pool Id
Implemented
Implemented
Implemented
Total Used Capacity
Implemented
Type
Gap
Vendor Tier
Implemented
Virtual
Implemented
Implemented
Mode
Implemented
Mode Enum
Implemented
Source Storage
Implemented
Source Volume
Implemented
State
Implemented
State Enum
Implemented
Target Storage
Implemented
Target Volume
Implemented
Technology
Implemented
Volume
Implemented
Auto Tiering
Implemented
Capacity
Implemented
Disk Size
Implemented
comma seperated list of disk sizes (GB)
Disk Type
Not Available
Mainframe
Implemented
indicates if this volume is a Mainframe Volume
Meta
Implemented
Flag saying whether this volume is a meta volume with memeber or not. Meta volumes will have DiskGroup empty!
Name
Implemented
Total Raw Capacity
Implemented
Redundancy
Implemented
Redundancy level
Replica Source
Implemented
Replica Target
Implemented
Snapshot
Implemented
Storage Pool Id
Implemented
Thin Provisioned
Implemented
Type
Gap
UUID
Implemented
Used Capacity
Implemented
Virtual
Implemented
Written Capacity
Implemented
Total capacity written to this volume by a Host in MB
storage Groups
Implemented
Volume Map
LUN
Implemented
Name of the backend lun
Protocol Controller
Implemented
Storage Port
Implemented
Type
Gap
Volume Mask
Initiator
Implemented
Protocol Controller
Implemented
Storage Port
Implemented
Type
Gap
Volume Member
Auto Tiering
Implemented
Capacity
Implemented
Cylinders
Implemented
Name
Implemented
Rank
Implemented
Total Raw Capacity
Implemented
Redundancy
Implemented
Redundancy level
Storage Pool Id
Implemented
UUID
Implemented
WWN Alias
Host Aliases
Implemented
Object Type
Implemented
Source
Implemented
WWN
Implemented
performance
Disk
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Storage
Implemented
Cache Hit Ratio Total
Implemented
Implemented
Cache Utilization Total
Implemented
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
Implemented
IOPs other
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Write Pending
Implemented
total write pending
Storage Node
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
StoragePool Disk
Implemented
Raw Capacity
Implemented
Capacity Soft Limit
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Implemented
Capacity Used Ratio
Implemented
Total Data Capacity
Implemented
Data Used Capacity
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Other Used Capacity
Implemented
Implemented
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Volume
Implemented
Implemented
Implemented
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Written Capacity
Implemented
Capacity Used Ratio
Implemented
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Write Pending
Implemented
total write pending
symcli
CLI
2707
true
true
true
true
Symmetrix SMI-S
SMI-S
HTTP/HTTPS
5988/5989
true
false
false
true
EMC VNX (SSH)
VNX5200
VNX5300
VNX5400
VNX5500
VNX5600
VNX5700
VNX5800
VNX8000
05.32.000.5.216
05.32.000.5.249
05.33.021.5.266
7.1.76-4
7.1.79-8
7.1.83-2
8.1.21-266
8.1.9-184
foundation
Disk
Capacity (GB)
Implemented
SSH
Used capacity
Disk Id
Implemented
SSH
Group
Implemented
SSH
Location
Gap
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Role
Implemented
SSH
Role Enum
Implemented
SSH
enum for disk role
Serial Number
Implemented
SSH
Status
Implemented
SSH
Status Enum
Implemented
SSH
Type
Gap
SSH
Type Enum
Implemented
SSH
enum for disk type
Vendor
Implemented
SSH
File Share
Is InternalVolume
Implemented
SSH
Is Shared
Implemented
SSH
Name
Implemented
SSH
Path
Implemented
SSH
Qtree Id
Implemented
SSH
Status
Implemented
SSH
Info
Api Name
Implemented
SSH
Api Version
Implemented
SSH
Client Api Name
Implemented
SSH
Client Api Version
Implemented
SSH
DataSource Name
Implemented
SSH
Info
Date
Implemented
SSH
Originator ID
Implemented
SSH
Originator Key
Implemented
SSH
Internal Volume
Gap
SSH
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Dedupe Savings
Implemented
SSH
GuidKey 1
Implemented
SSH
GuidKey 2
Implemented
SSH
Internal Volume Id
Implemented
SSH
Last Snapshot Time
Implemented
SSH
Name
Implemented
SSH
Gap
SSH
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
Snapshot Count
Implemented
SSH
Storage Pool Id
Implemented
SSH
Thin Provisioned
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Implemented
SSH
Type
Gap
SSH
Virtual Storage
Implemented
SSH
QTree
GuidKey 1
Implemented
SSH
GuidKey 2
Implemented
SSH
Name
Implemented
SSH
Qtree Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Quota UsedCapacity
Implemented
SSH
Type
Gap
SSH
Quota
GuidKey 1
Implemented
SSH
GuidKey 2
Implemented
SSH
Implemented
SSH
Hard File Limit
Implemented
SSH
max number of files allowed for the quota target
Internal Volume Id
Implemented
SSH
Qtree Id
Implemented
SSH
Quota Id
Implemented
SSH
Implemented
SSH
Soft File Limit
Implemented
SSH
Type
Gap
SSH
Used Capacity
Implemented
SSH
Used Files
Implemented
SSH
Share
IP Interfaces
Implemented
SSH
Name
Implemented
SSH
Protocol
Implemented
SSH
Share Initiator
Initiator
Implemented
SSH
Permission
Implemented
SSH
Storage
Cpu Count
Implemented
SSH
Display IP
Implemented
SSH
Failed Raw Capacity
Implemented
SSH
Family
Implemented
SSH
IP
Implemented
SSH
Manage URL
Implemented
SSH
Manufacturer
Implemented
SSH
Microcode Version
Implemented
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Serial Number
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Implemented
SSH
Virtual
Implemented
SSH
Storage Node
Name
Implemented
SSH
Serial Number
Implemented
SSH
UUID
Implemented
SSH
Implemented
SSH
Storage Pool
Gap
SSH
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Implemented
SSH
Name
Implemented
SSH
Gap
SSH
Implemented
SSH
Implemented
SSH
Raid Group
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
Redundancy
Implemented
SSH
Redundancy level
Gap
SSH
Implemented
SSH
Status
Implemented
SSH
Storage Pool Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Type
Gap
SSH
Virtual
Implemented
SSH
Volume
Implemented
SSH
Auto Tiering
Implemented
SSH
Capacity
Implemented
SSH
DiskGroup
Implemented
SSH
Disk Group Type
Disk Type
Not Available
SSH
Junction Path
Implemented
SSH
Meta
Implemented
SSH
Name
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Redundancy
Implemented
SSH
Redundancy level
Storage Pool Id
Implemented
SSH
Thin Provisioned
Implemented
SSH
Type
Gap
SSH
UUID
Implemented
SSH
Used Capacity
Implemented
SSH
Volume Map
LUN
Implemented
SSH
Protocol Controller
Implemented
SSH
Storage Port
Implemented
SSH
Type
Gap
SSH
Volume Mask
Initiator
Implemented
SSH
Protocol Controller
Implemented
SSH
Storage Port
Implemented
SSH
Type
Gap
SSH
Volume Member
Capacity
Implemented
SSH
Name
Implemented
SSH
Rank
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Redundancy
Implemented
SSH
Redundancy level
Storage Pool Id
Implemented
SSH
Used Capacity
Implemented
SSH
WWN Alias
Host Aliases
Implemented
SSH
IP
Implemented
SSH
Object Type
Implemented
SSH
Source
Implemented
SSH
WWN
Implemented
SSH
performance
Disk
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Read Utilization
Implemented
SSH
Utilization Total
Implemented
SSH
Utilization Write
Implemented
SSH
Storage
Implemented
SSH
Implemented
SSH
Implemented
SSH
Failed Raw Capacity
Implemented
SSH
Raw Capacity
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Implemented
SSH
IOPs other
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Latency Read
Implemented
SSH
Latency Total
Implemented
SSH
Latency Write
Implemented
SSH
Partial Blocked Ratio
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Storage Node
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Server ID
Implemented
SSH
Utilization Total
Implemented
SSH
StoragePool Disk
Implemented
SSH
Raw Capacity
Implemented
SSH
Total Capacity
Implemented
SSH
Used Capacity
Implemented
SSH
Implemented
SSH
Capacity Used Ratio
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Implemented
SSH
Other Used Capacity
Implemented
SSH
Implemented
SSH
Implemented
SSH
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Read Utilization
Implemented
SSH
Utilization Total
Implemented
SSH
Utilization Write
Implemented
SSH
Volume
Implemented
SSH
Implemented
SSH
Implemented
SSH
Raw Capacity
Implemented
SSH
Total Capacity
Implemented
SSH
Used Capacity
Implemented
SSH
Capacity Used Ratio
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Latency Read
Implemented
SSH
Latency Total
Implemented
SSH
Latency Write
Implemented
SSH
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
VNX SSH and CLI
SSH
SSH
22
true
false
true
true
EMC VNXe & Unity Unisphere (CLI)
Unity 300
Unity 350F
Unity 380F
Unity 400
Unity 450F
Unity 480
Unity 480F
Unity 550F
Unity 600
Unity 650F
Unity 680
Unity 880
Unity 880F
4.1.2.9257522
5.1.2.0.5.007
5.3.0.0.5.120
5.3.1.0.5.008
5.4.0.0.5.094
5.4.1.0.5.006
5.5.0.0.5.259
5.5.2.0.5.014
5.5.3.0.5.057
5.5.4.0.5.037
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
Disk Group
Capacity
Implemented
HTTPS
DiskGroup Id
Implemented
HTTPS
Disk Type
Not Available
HTTPS
Name
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Last Snapshot Time
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Snapshot Count
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Soft Limit (MB)
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Mode
Implemented
HTTPS
Mode Enum
Implemented
HTTPS
Source Storage
Implemented
HTTPS
Source Volume
Implemented
HTTPS
State
Implemented
HTTPS
State Enum
Implemented
HTTPS
Target Storage
Implemented
HTTPS
Target Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Internal Volume
Total Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage Node
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Capacity Soft Limit
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
VNXe & Unisphere CLI
HTTPS
HTTPS
443
true
true
true
true
EMC VPLEX
VPLEX
mn-216
6.2.0.03.00.02
6.2.1.0.0.519
6.2.1.1.0.78
6.2.2.0.1.3
9.1.0.0.0
9.2.0.0.0
foundation
Info
DataSource Name
Implemented
HTTP/S
Info
Date
Implemented
HTTP/S
Originator ID
Implemented
HTTP/S
Originator Key
Implemented
HTTP/S
Storage
Display IP
Implemented
HTTP/S
Failed Raw Capacity
Implemented
HTTP/S
Family
Implemented
HTTP/S
IP
Implemented
HTTP/S
Manage URL
Implemented
HTTP/S
Manufacturer
Implemented
HTTP/S
Microcode Version
Implemented
HTTP/S
Model
Implemented
HTTP/S
Name
Implemented
HTTP/S
Total Raw Capacity
Implemented
HTTP/S
Serial Number
Implemented
HTTP/S
Spare Raw Capacity
Implemented
HTTP/S
Virtual
Implemented
HTTP/S
Storage Node
Model
Implemented
HTTP/S
Name
Implemented
HTTP/S
Serial Number
Implemented
HTTP/S
State
Implemented
HTTP/S
UUID
Implemented
HTTP/S
Version
Implemented
HTTP/S
software version
Implemented
HTTP/S
Storage Pool
Dedupe Enabled
Implemented
HTTP/S
Name
Implemented
HTTP/S
Gap
HTTP/S
Implemented
HTTP/S
Implemented
HTTP/S
Raid Group
Implemented
HTTP/S
Raw to Usable Ratio
Implemented
HTTP/S
Redundancy
Implemented
HTTP/S
Redundancy level
Status
Implemented
HTTP/S
Storage Pool Id
Implemented
HTTP/S
Implemented
HTTP/S
Implemented
HTTP/S
Total Used Capacity
Implemented
HTTP/S
Type
Gap
HTTP/S
Virtual
Implemented
HTTP/S
Mode
Implemented
HTTP/S
Mode Enum
Implemented
HTTP/S
Source Storage
Implemented
HTTP/S
Source Volume
Implemented
HTTP/S
State
Implemented
HTTP/S
State Enum
Implemented
HTTP/S
Target Storage
Implemented
HTTP/S
Target Volume
Implemented
HTTP/S
Technology
Implemented
HTTP/S
Volume
Capacity
Implemented
HTTP/S
Name
Implemented
HTTP/S
Total Raw Capacity
Implemented
HTTP/S
Redundancy
Implemented
HTTP/S
Redundancy level
Storage Pool Id
Implemented
HTTP/S
Thin Provisioned
Implemented
HTTP/S
UUID
Implemented
HTTP/S
Virtual
Implemented
HTTP/S
Volume Map
LUN
Implemented
HTTP/S
Protocol Controller
Implemented
HTTP/S
Storage Port
Implemented
HTTP/S
Type
Gap
HTTP/S
Volume Mask
Initiator
Implemented
HTTP/S
Protocol Controller
Implemented
HTTP/S
Storage Port
Implemented
HTTP/S
Type
Gap
HTTP/S
performance
Storage
Failed Raw Capacity
Implemented
SSH
Raw Capacity
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Implemented
SSH
IOPs Total
Implemented
SSH
Key
Implemented
SSH
Latency Read
Implemented
SSH
Latency Total
Implemented
SSH
Latency Write
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Storage Node
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Latency Read
Implemented
SSH
Latency Total
Implemented
SSH
Latency Write
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Utilization Total
Implemented
SSH
StoragePool Disk
Implemented
SSH
Raw Capacity
Implemented
SSH
Total Capacity
Implemented
SSH
Used Capacity
Implemented
SSH
Implemented
SSH
Capacity Used Ratio
Implemented
SSH
Implemented
SSH
Other Used Capacity
Implemented
SSH
Volume
Raw Capacity
Implemented
SSH
Total Capacity
Implemented
SSH
IOPs Total
Implemented
SSH
Key
Implemented
SSH
Latency Read
Implemented
SSH
Latency Total
Implemented
SSH
Latency Write
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
EMC VPLEX CLI
SSH
SSH
22
true
true
true
true
EMC VPLEX API
HTTP/HTTPS
HTTP/HTTPS
80/443
true
true
true
true
EMC XtremIO (HTTP)
6.2.1
6.3.2
6.3.3
6.4.2
1 Bricks & 26TB
1 Bricks & 31TB
1 Bricks & 41TB
1 Bricks & 6TB
1 Bricks & 8TB
1X10TB
2 Bricks & 83TB
6X20TB
4.0.27-1
4.0.31-11
6.3.3-8_X2
6.4.2-13_X2
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Potential Transfer Rate
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Seek Time
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
Vendor Id
Implemented
HTTPS
Info
Api Version
Implemented
HTTPS
Implemented
HTTPS
Client Api Name
Implemented
HTTPS
Client Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Storage
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Mode
Implemented
HTTPS
Mode Enum
Implemented
HTTPS
Source Volume
Implemented
HTTPS
State
Implemented
HTTPS
State Enum
Implemented
HTTPS
Target Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
Disk Size
Implemented
HTTPS
Disk Speed
Implemented
HTTPS
comma seperated list of disk speeds (rpm)
Disk Type
Not Available
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Type
Gap
HTTPS
performance
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
EMC XtremIO REST API
HTTPS
HTTPS
443
true
true
true
true
Google Cloud Compute
API versions:
  • v1
foundation
Data Store
Capacity
Implemented
HTTPS
MOID
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Provisioned Capacity
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
subscription Id
Implemented
HTTPS
Server
DataCenter Name
Implemented
HTTPS
Host OID
Implemented
HTTPS
OID
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
Virtual Disk
Capacity
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
subscription Id
Implemented
HTTPS
VirtualMachine
Guest State
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Host OID
Implemented
HTTPS
IPs
Implemented
HTTPS
MOID
Implemented
HTTPS
Memory
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
OS
Implemented
HTTPS
Power State
Implemented
HTTPS
State Change Time
Implemented
HTTPS
Processors
Implemented
HTTPS
Implemented
HTTPS
Instance Type
Implemented
HTTPS
Launch Time
Implemented
HTTPS
public Ips
Implemented
HTTPS
subscription Id
Implemented
HTTPS
VirtualMachine Disk
OID
Implemented
HTTPS
VirtualDisk OID
Implemented
HTTPS
VirtualMachine OID
Implemented
HTTPS
Host
Host OS
Implemented
HTTPS
IPs
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Info
Api Description
Implemented
HTTPS
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
performance
Virtual Disk
Total Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
vm
Total Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total CPU Utilization
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
diskIops.total
Implemented
HTTPS
Disk IOPs write
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Disk Throughput Read
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
total disk throughput read
Disk Throughput Write
Implemented
HTTPS
IP Throughput Read
Implemented
HTTPS
Throughput total
Implemented
HTTPS
IP throughput total
ipThroughput.write
Implemented
HTTPS
Total Memory Utilization
Implemented
HTTPS
swapRate.inRate
Implemented
HTTPS
Swap Rate
Implemented
HTTPS
Total Swap Rate
Implemented
HTTPS
Schedule wait time
Implemented
HTTPS
Waiting to be scheduled time in percent
Google Compute Platform REST API
HTTPS
443
true
true
true
true
Google Cloud Netapp Volumes
foundation
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Last Snapshot Time
Implemented
HTTPS
Name
Implemented
HTTPS
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Gap
HTTPS
Snapshot Count
Implemented
HTTPS
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Comment
Gap
HTTPS
state: free text comment describing the svm
Implemented
HTTPS
Qos Limit Raw
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Security Style
Implemented
HTTPS
Security style of the directory: unix, ntfs, or mixed
Status
Implemented
HTTPS
Type
Gap
HTTPS
Share
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Vendor Tier
Implemented
HTTPS
Vendor Specific Tier Name
Virtual
Implemented
HTTPS
Implemented
HTTPS
performance
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Object Store Space Used
Implemented
HTTPS
Server ID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
HTTPS
443
true
true
true
true
HDS HCP (HTTPS)
Models and versions supported by this data collector:
Hitachi Content Platform
10.0.1.4
10.1.0.100
9.7.2.27
Products supported by this data collector:
Product Category Feature/Attribute Status Protocol Used Additional Information
foundation
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Name
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Pool
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Soft Limit (MB)
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioning Supported
Implemented
HTTPS
Total Allocated Capacity
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
performance
Internal Volume
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
Key
Implemented
Total Objects
Implemented
Server ID
Implemented
Qtree
Key
Implemented
Server ID
Implemented
Storage
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
Implemented
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Storage Node
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
StoragePool Disk
Implemented
Raw Capacity
Implemented
Capacity Soft Limit
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Implemented
Capacity Used Ratio
Implemented
HDS HCP REST API
HTTPS
HTTPS
9090
true
true
true
true
HDS HNAS (CLI)
G600
G800
HNAS 4080
HNAS 4100
N800
14.7.7623.07
15.1.8030.05
foundation
Disk Group
Capacity
Implemented
SSH
DiskGroup Id
Implemented
SSH
unique id of the disk group
Name
Implemented
SSH
Used Capacity
Implemented
SSH
Vendor Tier
Implemented
SSH
Virtual
Implemented
SSH
File Share
Is InternalVolume
Implemented
SSH
Is Shared
Implemented
SSH
Name
Implemented
SSH
Path
Implemented
SSH
Qtree Id
Implemented
SSH
Info
DataSource Name
Implemented
SSH
Info
Date
Implemented
SSH
Originator ID
Implemented
SSH
Originator Key
Implemented
SSH
Internal Volume
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Internal Volume Id
Implemented
SSH
Name
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
Implemented
SSH
Status
Implemented
SSH
Storage Pool Id
Implemented
SSH
Thin Provisioned
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Implemented
SSH
Type
Gap
SSH
Virtual Storage
Implemented
SSH
QTree
Name
Implemented
SSH
Qtree Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Quota UsedCapacity
Implemented
SSH
Type
Gap
SSH
Quota
Implemented
SSH
Hard File Limit
Implemented
SSH
Internal Volume Id
Implemented
SSH
Qtree Id
Implemented
SSH
Quota Id
Implemented
SSH
Implemented
SSH
Soft File Limit
Implemented
SSH
Type
Gap
SSH
Used Capacity
Implemented
SSH
Used Files
Implemented
SSH
Share
IP Interfaces
Implemented
SSH
Name
Implemented
SSH
Protocol
Implemented
SSH
Share Initiator
Initiator
Implemented
SSH
Permission
Implemented
SSH
Storage
Cpu Count
Implemented
SSH
Display IP
Implemented
SSH
Failed Raw Capacity
Implemented
SSH
Family
Implemented
SSH
IP
Implemented
SSH
Manufacturer
Implemented
SSH
Microcode Version
Implemented
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Serial Number
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Raw capacity of spare disks (sum of all disks that are spare)
Implemented
SSH
Virtual
Implemented
SSH
Storage Node
Memory Size
Gap
SSH
device memory in MB
Name
Implemented
SSH
Processors Count
Implemented
SSH
device CPU
Serial Number
Implemented
SSH
State
Implemented
SSH
UUID
Implemented
SSH
Version
Implemented
SSH
software version
Storage Pool
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Implemented
SSH
Name
Implemented
SSH
Raid Group
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
Snapshot Used Capacity
Implemented
SSH
Storage Pool Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Type
Gap
SSH
Virtual
Implemented
SSH
HDS HNAS CLI
SSH
SSH
22
true
true
true
true
HiCommand Device Manager
7.6.1
8.7.1
DF850MH
XP24000
XP8
0983/A-H
0984/B-H
0986/A-H
DKC:60-08-22
DKC:90-09-28
SVP:60-08-21/00
SVP:90-09-28/00
foundation
Disk
Capacity (GB)
Implemented
HDS XML API
Used capacity
Disk Id
Implemented
HDS XML API
Location
Gap
HDS XML API
Model
Implemented
HDS XML API
Name
Implemented
HDS XML API
Role
Implemented
HDS XML API
Role Enum
Implemented
HDS XML API
enum for disk role
Serial Number
Implemented
HDS XML API
Speed
Implemented
HDS XML API
Speed of disk (RPM)
Type
Gap
HDS XML API
Type Enum
Implemented
HDS XML API
enum for disk type
Vendor
Implemented
HDS XML API
Vendor Id
Implemented
HDS XML API
Info
Api Name
Implemented
HDS XML API
Api Version
Implemented
HDS XML API
DataSource Name
Implemented
HDS XML API
Info
Date
Implemented
HDS XML API
Originator ID
Implemented
HDS XML API
Originator Key
Implemented
HDS XML API
Storage
Display IP
Implemented
HDS XML API
Failed Raw Capacity
Implemented
HDS XML API
Family
Implemented
HDS XML API
IP
Implemented
HDS XML API
Manage URL
Implemented
HDS XML API
Manufacturer
Implemented
HDS XML API
Microcode Version
Implemented
HDS XML API
Model
Implemented
HDS XML API
Name
Implemented
HDS XML API
Total Raw Capacity
Implemented
HDS XML API
Serial Number
Implemented
HDS XML API
Spare Raw Capacity
Implemented
HDS XML API
Virtual
Implemented
HDS XML API
Storage Node
Name
Implemented
HDS XML API
UUID
Implemented
HDS XML API
Storage Pool
Compression Enabled
Implemented
HDS XML API
Compression Savings
Implemented
HDS XML API
Dedupe Enabled
Implemented
HDS XML API
Is dedupe enabled on the storage pool
Implemented
HDS XML API
Name
Implemented
HDS XML API
Implemented
HDS XML API
Raid Group
Implemented
HDS XML API
Raw to Usable Ratio
Implemented
HDS XML API
ratio to convert from usable capacity to raw capacity
Redundancy
Implemented
HDS XML API
Redundancy level
Soft Limit (MB)
Implemented
HDS XML API
Status
Implemented
HDS XML API
Storage Pool Id
Implemented
HDS XML API
Implemented
HDS XML API
Whether this internal volume supports thin provisioning for the volume layer on top of it
Implemented
HDS XML API
Total Used Capacity
Implemented
HDS XML API
Total capacity in MB
Type
Gap
HDS XML API
Virtual
Implemented
HDS XML API
Mode
Implemented
HDS XML API
Mode Enum
Implemented
HDS XML API
Source Volume
Implemented
HDS XML API
State
Implemented
HDS XML API
State Enum
Implemented
HDS XML API
Target Volume
Implemented
HDS XML API
Technology
Implemented
HDS XML API
Volume
Auto Tiering
Implemented
HDS XML API
Capacity
Implemented
HDS XML API
Junction Path
Implemented
HDS XML API
Mainframe
Implemented
HDS XML API
Meta
Implemented
HDS XML API
Name
Implemented
HDS XML API
Total Raw Capacity
Implemented
HDS XML API
Redundancy
Implemented
HDS XML API
Redundancy level
Replica Source
Implemented
HDS XML API
Replica Target
Implemented
HDS XML API
Storage Pool Id
Implemented
HDS XML API
Thin Provisioned
Implemented
HDS XML API
Type
Gap
HDS XML API
Used Capacity
Implemented
HDS XML API
Volume Map
LUN
Implemented
HDS XML API
Masking Required
Implemented
HDS XML API
Protocol Controller
Implemented
HDS XML API
Storage Port
Implemented
HDS XML API
Volume Mask
Initiator
Implemented
HDS XML API
Protocol Controller
Implemented
HDS XML API
Storage Port
Implemented
HDS XML API
Volume Member
Capacity
Implemented
HDS XML API
Cylinders
Implemented
HDS XML API
Name
Implemented
HDS XML API
Rank
Implemented
HDS XML API
Total Raw Capacity
Implemented
HDS XML API
Storage Pool Id
Implemented
HDS XML API
Used Capacity
Implemented
HDS XML API
WWN Alias
Host Aliases
Implemented
HDS XML API
Object Type
Implemented
HDS XML API
Source
Implemented
HDS XML API
WWN
Implemented
HDS XML API
performance
Disk
IOPs Read
Implemented
Export/CLI
Number of read IOPs on the disk
IOPs Total
Implemented
Export/CLI
IOPs Write
Implemented
Export/CLI
Key
Implemented
Export/CLI
Server ID
Implemented
Export/CLI
Throughput Read
Implemented
Export/CLI
Throughput Total
Implemented
Export/CLI
Average disk total rate (read and write across all disks) in MB/s
Throughput Write
Implemented
Export/CLI
Utilization Total
Implemented
Export/CLI
Storage
Cache Hit Ratio Read
Implemented
Export/CLI
Implemented
Export/CLI
Cache Hit Ratio Write
Implemented
Export/CLI
Failed Raw Capacity
Implemented
Export/CLI
Raw Capacity
Implemented
Export/CLI
Spare Raw Capacity
Implemented
Export/CLI
Implemented
Export/CLI
IOPs other
Implemented
Export/CLI
IOPs Read
Implemented
Export/CLI
IOPs Total
Implemented
Export/CLI
IOPs Write
Implemented
Export/CLI
Key
Implemented
Export/CLI
Latency Read
Implemented
Export/CLI
Latency Total
Implemented
Export/CLI
Latency Write
Implemented
Export/CLI
Server ID
Implemented
Export/CLI
Throughput Read
Implemented
Export/CLI
Throughput Total
Implemented
Export/CLI
Throughput Write
Implemented
Export/CLI
Storage Node
IOPs Total
Implemented
Export/CLI
Key
Implemented
Export/CLI
Latency Total
Implemented
Export/CLI
Server ID
Implemented
Export/CLI
Throughput Total
Implemented
Export/CLI
StoragePool Disk
Implemented
Export/CLI
Raw Capacity
Implemented
Export/CLI
Total Capacity
Implemented
Export/CLI
Used Capacity
Implemented
Export/CLI
Implemented
Export/CLI
Reported as a time series
Capacity Used Ratio
Implemented
Export/CLI
IOPs Read
Implemented
Export/CLI
IOPs Total
Implemented
Export/CLI
IOPs Write
Implemented
Export/CLI
Throughput Read
Implemented
Export/CLI
Throughput Total
Implemented
Export/CLI
Throughput Write
Implemented
Export/CLI
Utilization Total
Implemented
Export/CLI
Volume
Implemented
Export/CLI
Implemented
Export/CLI
Implemented
Export/CLI
Raw Capacity
Implemented
Export/CLI
Total Capacity
Implemented
Export/CLI
Used Capacity
Implemented
Export/CLI
Capacity Used Ratio
Implemented
Export/CLI
IOPs Read
Implemented
Export/CLI
IOPs Total
Implemented
Export/CLI
IOPs Write
Implemented
Export/CLI
Key
Implemented
Export/CLI
Latency Read
Implemented
Export/CLI
Latency Total
Implemented
Export/CLI
Latency Write
Implemented
Export/CLI
Server ID
Implemented
Export/CLI
Throughput Read
Implemented
Export/CLI
Throughput Total
Implemented
Export/CLI
Throughput Write
Implemented
Export/CLI
Management APIs used by this data collector:
API Protocol Used Transport layer protocol used Incoming ports used Outgoing ports used Supports authentication Requires only 'Read-only' credentials Supports Encryption Firewall friendly (static ports)
Export utility (USPV) / SNM CLI (AMS)
Export/CLI
false
false
false
false
HiCommand Device Manager XML API
HDS XML API
HTTP/HTTPS
2001
true
true
true
true
Hitachi Ops Center
Models
VSP 5100
VSP 5500
VSP 5600
VSP 5600H
VSP E1090
VSP E1090H
VSP E590
VSP E790
VSP F1500
VSP F370
VSP F900
VSP G1000
VSP G350
VSP G800
VSP One B26
VSP One B28
VSP One B85
XP8
Firmware versions:
  • 80-06-86-00/00:01-76-03/03
  • 80-06-96-00/00:01-76-03/03
  • 80-06-96-00/00:01-88-03/03
  • 83-05-51-60/00:01-76-03/03
  • 83-05-51-60/00:01-88-03/03
  • 88-08-13-60/01:01-76-03/03
  • 88-08-13-60/01:01-88-03/03
  • 88-08-19-60/00:01-76-03/03
  • 88-08-19-60/00:01-88-03/03
  • 88-08-20-60/00:01-76-03/03
  • 88-08-21-60/00:01-76-03/03
  • 88-08-21-60/00:01-88-03/03
  • 90-09-24-00/01:01-76-03/03
  • 90-09-24:01.72.00
  • 90-09-26-00/00:01-76-03/03
  • 90-09-28-00/00:01-65-03/05
  • 90-09-28-00/00:01-76-03/03
  • 90-09-28:01.72.00
  • 90-09-30-00/00:01-71-03/02
  • 90-09-30-00/00:01-76-03/03
  • 90-09-30-00/00:01-87-03/03
  • 90-09-30-00/00:01-88-03/03
  • 90-09-31-00/00:01-76-03/03
  • 90-09-31-00/20:01-76-03/03
  • 90-09-31-00/20:01-88-03/03
  • 90-09-32-00/00:01-76-03/03
  • 90-09-32-00/00:01-87-03/03
  • 93-07-29-40/00:01-76-03/03
  • 93-07-29-80/00:01-76-03/03
  • 93-07-29-80/00:01-87-03/03
  • 93-07-30-40/20:01-76-03/03
  • 93-07-30-40/20:01-88-03/03
  • 93-07-30-80/20:01-76-03/03
  • 93-07-30-80/20:01-88-03/03
  • 93-07-31-80/00:01-87-03/03
  • A0-05-43-00/00:01-88-03/03
  • A3-04-22-40/00:01-76-03/03
  • A3-04-22-40/00:01-88-03/03
  • A3-04-23-40/01:01-88-03/03
  • A3-05-22-40/00:01-88-03/03
  • null:null
foundation
Disk
Capacity (GB)
Implemented
Disk Id
Implemented
Group
Implemented
Location
Gap
Model
Implemented
Name
Implemented
Implemented
Role
Implemented
Role Enum
Implemented
Seek Time
Implemented
Serial Number
Implemented
Speed
Implemented
Status Enum
Implemented
Type Enum
Implemented
Vendor
Implemented
Disk Group
Capacity
Implemented
DiskGroup Id
Implemented
Disk Type
Not Available
Name
Implemented
Physical Disk Capacity (MB)
Implemented
Redundancy
Implemented
Status
Implemented
Used Capacity
Implemented
Vendor DiskGroup Type
Implemented
Virtual
Implemented
IP
Implemented
Listening Port
Implemented
Nic
Implemented
OID
Implemented
OID
Implemented
Portal Group Name
Implemented
Portal Group Tag
Implemented
ISCSI Node
Node Name
Implemented
OID
Implemented
Type
Gap
ISCSI Node Map
OID
Implemented
Portal Group OID
Implemented
ISCSI Session
Initiator Ips
Implemented
Initiator OID
Implemented
Max Connections
Implemented
Implemented
OID
Implemented
Portal Group OID
Implemented
Security
Implemented
Info
DataSource Name
Implemented
Date
Implemented
Originator ID
Implemented
Originator Key
Implemented
Storage
Display IP
Implemented
Failed Raw Capacity
Implemented
Family
Implemented
IP
Implemented
Manage URL
Implemented
Manufacturer
Implemented
Microcode Version
Implemented
Model
Implemented
Name
Implemented
Total Raw Capacity
Implemented
Serial Number
Implemented
Spare Raw Capacity
Implemented
SupportActive Active
Implemented
Virtual
Implemented
Storage Node
Name
Implemented
UUID
Implemented
Storage Pool
Compression Enabled
Implemented
Compression Savings
Implemented
Dedupe Enabled
Implemented
Include In Dwh Capacity
Implemented
Name
Implemented
Implemented
Raid Group
Implemented
Raw to Usable Ratio
Implemented
Redundancy
Implemented
Soft Limit (MB)
Implemented
Status
Implemented
Storage Pool Id
Implemented
Implemented
Implemented
Total Used Capacity
Implemented
Type
Gap
Virtual
Implemented
Encrypted
Implemented
Mode
Implemented
Mode Enum
Implemented
Source Storage
Implemented
Source Volume
Implemented
State
Implemented
State Enum
Implemented
Target Storage
Implemented
Target Volume
Implemented
Technology
Implemented
Volume
Capacity
Implemented
Junction Path
Implemented
Name
Implemented
Protection Type
Implemented
Total Raw Capacity
Implemented
Storage Pool Id
Implemented
Thin Provisioned
Implemented
Type
Gap
Used Capacity
Implemented
Compression Enabled
Implemented
Volume Map
LUN
Implemented
Masking Required
Implemented
Protocol Controller
Implemented
Storage Port
Implemented
Type
Gap
Volume Mask
Initiator
Implemented
Protocol Controller
Implemented
Storage Port
Implemented
Type
Gap
performance
Disk
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Storage
Implemented
Implemented
Implemented
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
StoragePools Capacity
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Storage Node
IOPs Total
Implemented
Key
Implemented
Server ID
Implemented
Throughput Total
Implemented
StoragePool Disk
Capacity Provisioned
Implemented
Raw Capacity
Implemented
Capacity Soft Limit
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Over Commit Capacity Ratio
Implemented
Capacity Used Ratio
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
Volume
Implemented
Implemented
Implemented
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Hitachi Ops Center REST API
HTTPS
HTTPS
443
true
true
true
true
HP Enterprise 3PAR / Alletra 9000 / Primera StoreServ Storage
Models
HPE Alletra 9080
HPE Alletra Storage MP
HPE Alletra Storage MP B10140
HPE_3PAR 20450
HPE_3PAR 20800_R2
HPE_3PAR 7440c
HPE_3PAR 7450c
HPE_3PAR 8200
HPE_3PAR 8400
HPE_3PAR 8440
HPE_3PAR 8450
HPE_3PAR 9450
HPE_3PAR A630
HPE_3PAR A650
HPE_3PAR A670
HPE_3PAR C650
HP_3PAR 7200
HP_3PAR 7200c
HP_3PAR 7400
HP_3PAR 7400c
HP_3PAR 8200
InServ T400
InServ V400
Firmware versions:
  • 10.4.20 Release Type: Standard Support Release
  • 10.5.50 Release Type: Standard Support Release
  • 10.5.55 Release Type: Standard Support Release
  • 10.5.60 Release Type: Standard Support Release
  • 10.5.64 Release Type: Limited Availability Release
  • 10.6.0 Release Type: Standard Support Release
  • 3.1.2 (MU3) P16
  • 3.1.3 (MU1) P07
  • 3.2.1 (MU3) P17
  • 3.2.2 (MU4) P51
  • 3.2.2 (MU4) P56
  • 3.2.2 (MU6)
  • 3.2.2 (MU6) P99
  • 3.3.1 (MU2) P32
  • 3.3.1 (MU5) P126
  • 3.3.1 (MU5) P132
  • 3.3.2 (MU1) P08
  • 3.3.2 (MU1) P10
  • 4.4.1 Release Type: Standard Support Release
  • 4.5.15 Release Type: Extended Support Release
  • 4.5.3 Release Type: Extended Support Release
  • 4.5.8 Release Type: Extended Support Release
  • 4.6.1 Release Type: Extended Support Release
  • 4.6.20 Release Type: Extended Support Release
  • 4.6.21 Release Type: Limited Availability Release
  • 9.6.20 Release Type: Extended Support Release
  • P09
  • P10
  • P102
  • P106
  • P107
  • P111
  • P113
  • P115
  • P118
  • P119
  • P120
  • P122
  • P125
  • P126
  • P127
  • P128
  • P129
  • P131
  • P132
  • P133
  • P135
  • P136
  • P137
  • P138
  • P139
  • P140
  • P141
  • P142
  • P145
  • P146
  • P148
  • P149
  • P15
  • P150
  • P151
  • P153
  • P154
  • P155
  • P156
  • P157
  • P160
  • P161
  • P162
  • P164
  • P165
  • P166
  • P167
  • P168
  • P170
  • P172
  • P173
  • P175
  • P177
  • P18
  • P180
  • P185
  • P19
  • P20
  • P23
  • P25
  • P27
  • P28
  • P29
  • P30
  • P34
  • P38
  • P40
  • P45
  • P48
  • P49
  • P50
  • P51
  • P52
  • P56
  • P58
  • P59
  • P72
  • P74
  • P76
  • P84
  • P85
  • P90
  • P91
  • P92
  • P93
  • P94
  • P96
  • P98
foundation
Device Group
Name
Implemented
SSH
Implemented
SSH
Type
Gap
SSH
Disk
Capacity (GB)
Implemented
SSH
Used capacity
Disk Id
Implemented
SSH
Uniquely identifies this disk in the array
Location
Gap
SSH
Where this disk is physically located in the array
Model
Implemented
SSH
Name
Implemented
SSH
Role
Implemented
SSH
Role Enum
Implemented
SSH
enum for disk role
Serial Number
Implemented
SSH
Status
Implemented
SSH
Status Enum
Implemented
SSH
enum for disk status
Type
Gap
SSH
Type Enum
Implemented
SSH
enum for disk type
Vendor
Implemented
SSH
Vendor Id
Implemented
SSH
IP
Implemented
SSH
Listening Port
Implemented
SSH
Nic
Implemented
SSH
OID
Implemented
SSH
OID
Implemented
SSH
Portal Group Name
Implemented
SSH
Portal Group Tag
Implemented
SSH
ISCSI Node
Node Name
Implemented
SSH
OID
Implemented
SSH
Type
Gap
SSH
Info
Api Name
Implemented
SSH
Api Version
Implemented
SSH
DataSource Name
Implemented
SSH
Info
Date
Implemented
SSH
Originator ID
Implemented
SSH
Storage
Display IP
Implemented
SSH
Failed Raw Capacity
Implemented
SSH
Raw capacity of failed disks (sum of all disks that are failed)
Family
Implemented
SSH
The storage Family could be Clariion, Symmetrix, et al
IP
Implemented
SSH
Manage URL
Implemented
SSH
Manufacturer
Implemented
SSH
Microcode Version
Implemented
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Total raw capacity (sum of all disks on the array)
Serial Number
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Virtual
Implemented
SSH
Is this a storage virtualization device?
Storage Node
Memory Size
Gap
SSH
device memory in MB
Model
Implemented
SSH
Name
Implemented
SSH
Processors Count
Implemented
SSH
device CPU
State
Implemented
SSH
free text describing the device state
UUID
Implemented
SSH
Up Time
Implemented
SSH
time in milliseconds
Version
Implemented
SSH
software version
Storage Pool
Auto Tiering
Implemented
SSH
indicates if this storagepool is participating in auto tiering with other pools
Compression Enabled
Implemented
SSH
Compression Savings
Implemented
SSH
Data Allocated Capacity
Gap
SSH
capacity allocated for data
Data Used Capacity
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Dedupe Savings
Implemented
SSH
ratio of dedupe savings in percentage
Implemented
SSH
A way from ACQ to control which storage pools are interesting in DWH Capacity
Name
Implemented
SSH
Other Allocated Capacity
Gap
SSH
Capacity allocated for other (not data and not snapshot)
Other UsedCapacity (MB)
Implemented
SSH
Any capacity other than data and snapshot
Implemented
SSH
used as raw capacity for storage pool
Raid Group
Implemented
SSH
indicates whether this storagePool is a raid group
Raw to Usable Ratio
Implemented
SSH
Redundancy
Implemented
SSH
Redundancy level
Snapshot Allocated Capacity
Gap
SSH
Allocated capacity of snapshots in MB
Implemented
SSH
Storage Pool Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Type
Gap
SSH
Vendor Tier
Implemented
SSH
Virtual
Implemented
SSH
Mode
Implemented
SSH
Mode Enum
Implemented
SSH
Source Storage
Implemented
SSH
Source Volume
Implemented
SSH
State
Implemented
SSH
State Enum
Implemented
SSH
Target Storage
Implemented
SSH
Target Volume
Implemented
SSH
Technology
Implemented
SSH
Volume
AutoTier Policy Identifier
Implemented
SSH
Dynamic Tier Policy identifier
Auto Tiering
Implemented
SSH
Capacity
Implemented
SSH
Snapshot Used capacity in MB
Name
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Redundancy
Implemented
SSH
Redundancy level
Storage Pool Id
Implemented
SSH
Thin Provisioned
Implemented
SSH
Type
Gap
SSH
UUID
Implemented
SSH
Used Capacity
Implemented
SSH
Virtual
Implemented
SSH
Written Capacity
Implemented
SSH
Volume Map
LUN
Implemented
SSH
Protocol Controller
Implemented
SSH
Storage Port
Implemented
SSH
Volume Mask
Initiator
Implemented
SSH
Protocol Controller
Implemented
SSH
Storage Port
Implemented
SSH
Volume Ref
Name
Implemented
SSH
Storage Ip
Implemented
SSH
WWN Alias
Host Aliases
Implemented
SSH
Object Type
Implemented
SSH
Source
Implemented
SSH
WWN
Implemented
SSH
performance
Disk
IOPs Read
Implemented
SMI-S
IOPs Total
Implemented
SMI-S
IOPs Write
Implemented
SMI-S
Key
Implemented
SMI-S
Server ID
Implemented
SMI-S
Throughput Read
Implemented
SMI-S
Throughput Total
Implemented
SMI-S
Throughput Write
Implemented
SMI-S
Storage
Implemented
SMI-S
Implemented
SMI-S
Implemented
SMI-S
Failed Raw Capacity
Implemented
SMI-S
Raw Capacity
Implemented
SMI-S
Spare Raw Capacity
Implemented
SMI-S
Implemented
SMI-S
IOPs other
Implemented
SMI-S
IOPs Read
Implemented
SMI-S
IOPs Total
Implemented
SMI-S
IOPs Write
Implemented
SMI-S
Key
Implemented
SMI-S
Latency Read
Implemented
SMI-S
Latency Total
Implemented
SMI-S
Latency Write
Implemented
SMI-S
Implemented
SMI-S
Server ID
Implemented
SMI-S
Throughput Read
Implemented
SMI-S
Throughput Total
Implemented
SMI-S
Throughput Write
Implemented
SMI-S
Write Pending
Implemented
SMI-S
total write pending
Storage Node
Implemented
SMI-S
IOPs Read
Implemented
SMI-S
IOPs Total
Implemented
SMI-S
IOPs Write
Implemented
SMI-S
Key
Implemented
SMI-S
Latency Read
Implemented
SMI-S
Latency Total
Implemented
SMI-S
Latency Write
Implemented
SMI-S
Server ID
Implemented
SMI-S
Throughput Read
Implemented
SMI-S
Throughput Total
Implemented
SMI-S
Throughput Write
Implemented
SMI-S
Utilization Total
Implemented
SMI-S
StoragePool Disk
Implemented
SMI-S
Raw Capacity
Implemented
SMI-S
Total Capacity
Implemented
SMI-S
Used Capacity
Implemented
SMI-S
Implemented
SMI-S
Capacity Used Ratio
Implemented
SMI-S
Total Data Capacity
Implemented
SMI-S
Data Used Capacity
Implemented
SMI-S
IOPs Read
Implemented
SMI-S
IOPs Total
Implemented
SMI-S
IOPs Write
Implemented
SMI-S
Other Total Capacity
Implemented
SMI-S
Other Used Capacity
Implemented
SMI-S
Snapshot Reserved Capacity
Implemented
SMI-S
Implemented
SMI-S
Snapshot Used Capacity Ratio
Implemented
SMI-S
Throughput Read
Implemented
SMI-S
Throughput Total
Implemented
SMI-S
Throughput Write
Implemented
SMI-S
Volume
Implemented
SMI-S
Implemented
SMI-S
Implemented
SMI-S
Raw Capacity
Implemented
SMI-S
Total Capacity
Implemented
SMI-S
Used Capacity
Implemented
SMI-S
Written Capacity
Implemented
SMI-S
Capacity Used Ratio
Implemented
SMI-S
CapacityRatio Written
Implemented
SMI-S
Total Compression Savings
Implemented
SMI-S
IOPs Read
Implemented
SMI-S
IOPs Total
Implemented
SMI-S
IOPs Write
Implemented
SMI-S
Key
Implemented
SMI-S
Latency Read
Implemented
SMI-S
Latency Total
Implemented
SMI-S
Latency Write
Implemented
SMI-S
Implemented
SMI-S
Server ID
Implemented
SMI-S
Throughput Read
Implemented
SMI-S
Throughput Total
Implemented
SMI-S
Throughput Write
Implemented
SMI-S
Write Pending
Implemented
SMI-S
total write pending
3Par SMI-S
SMI-S
HTTP/HTTPS
5988/5989
true
true
true
true
3Par CLI
SSH
SSH
22
true
false
true
true
HPE Nimble / Alletra 6000 Storage
API versions Models Firmware versions
v1
5030
6030
AF40
AF60
AF80
CS300
CS3000
HF40
5.0.8.0-677726-opt
5.2.1.1100-1027043-opt
6.1.2.502-1057650-opt
6.1.2.700-1069734-opt
6.1.2.800-1084673-opt
6.1.3.300-1084694-opt
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Seek Time
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
ISCSI Network Portal
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
ISCSI Network Portal Group
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Number Of Connections
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Specified if the storage supports active-active configurations
Virtual
Implemented
HTTPS
Storage Node
Name
Implemented
HTTPS
Partner Node UUID
Implemented
HTTPS
HA pair's UUID
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Parent Serial Number
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
ratio of compression savings in percentage
Gap
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Reserved Capacity
Implemented
HTTPS
Reserved Capacity in MB
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Storage Synchronization
Mode
Implemented
HTTPS
Mode Enum
Implemented
HTTPS
Source Storage
Implemented
HTTPS
Source Volume
Implemented
HTTPS
State
Implemented
HTTPS
State Enum
Implemented
HTTPS
Target Storage
Implemented
HTTPS
Target Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
technology which causes storage efficiency changed
Volume
Capacity
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Compression Enabled
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Masking Required
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
WWN Alias
Host Aliases
Implemented
HTTPS
Object Type
Implemented
HTTPS
Source
Implemented
HTTPS
WWN
Implemented
HTTPS
performance
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Reserved Capacity
Implemented
HTTPS
Fractional reserved (included in data allocated capacity)
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Compression Savings Space
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
HP Nimble REST API
HTTPS
HTTPS
5392
true
false
true
true
Huawei OceanStor (REST/HTTPS)
5310 V5
5500 V3
5500 V5
5800 V3
6800 V3
6800 V5
Dorado 18000 V6 NVMe
Dorado 5000 V3
Dorado 6000 V3
Dorado 6000 V6 NVMe
V300R001C01
V300R001C21
V300R002C10
V300R006C50
V500R007C10
V500R007C61
V500R007C71 Kunpeng
V600R005C26
V600R005C27
V600R005C50
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume
Is Shared
Implemented
HTTPS
whether this fileShare has any shares associated with it
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Path of the fileShare
Qtree Id
Implemented
HTTPS
unique id of the qtree
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota HardCapacity Limit (MB)
Implemented
HTTPS
Maximum amount of disk space, allowed for the quota target
Quota SoftCapacity Limit (MB)
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Space in MB currently used
Status
Implemented
HTTPS
Type
Gap
HTTPS
Quota
Hard Capacity Limit (MB)
Implemented
HTTPS
max amount of disk space, allowed for the quota target (Hard limit)
Hard File Limit
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
unique id of the quota
Soft Capacity Limit (MB)
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Max number of files allowed for the quota target
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
Number of files currently used
User/Group Target
Implemented
HTTPS
user/group target this quota refers to
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
comma separated list of IP addresses on which this share is exposed
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
enum for share protocol
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Permissions for this particular share
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Name
Implemented
HTTPS
UUID
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Storage Pool
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Name of the backend lun
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Internal Volume
Total Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Implemented
HTTPS
Cache Hit Ratio Total
Implemented
HTTPS
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Huawei OceanStor REST API
HTTPS
HTTPS
8088
true
true
true
true
Huawei OceanStor Performance REST API
HTTPS
HTTPS
8088
true
false
true
true
IBM Cleversafe
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Comment
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
UUID
Implemented
HTTPS
Version
Implemented
HTTPS
software version
ManagementIp Addresses
Implemented
HTTPS
Storage Pool
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
IBM Cleversafe REST API
HTTPS
HTTPS
443
true
true
true
true
IBM DS 8K (DSCLI)
2107-951
2107-961
2107-994
2107-996
2107-A05
7.10.11.87
7.6.31.4250
7.7.51.1400
7.9.33.132
7.9.44.37
7.9.44.59
foundation
Disk
Capacity (GB)
Implemented
DSNI
Used capacity
Disk Id
Implemented
DSNI
Group
Implemented
DSNI
Location
Gap
DSNI
Model
Implemented
DSNI
Name
Implemented
Manual Entry
Role
Implemented
DSNI
Role Enum
Implemented
DSNI
enum for disk role
Speed
Implemented
DSNI
Speed of disk (RPM)
Status
Implemented
DSNI
Type
Gap
DSNI
Type Enum
Implemented
DSNI
enum for disk type
Vendor
Implemented
DSNI
Vendor Id
Implemented
DSNI
Info
DataSource Name
Implemented
DSNI
Info
Date
Implemented
DSNI
Originator ID
Implemented
DSNI
Originator Key
Implemented
DSNI
Storage
Display IP
Implemented
DSNI
Failed Raw Capacity
Implemented
DSNI
Family
Implemented
DSNI
IP
Implemented
DSNI
Manage URL
Implemented
DSNI
Manufacturer
Implemented
DSNI
Microcode Version
Implemented
DSNI
Model
Implemented
DSNI
Name
Implemented
Manual Entry
Total Raw Capacity
Implemented
DSNI
Serial Number
Implemented
DSNI
Spare Raw Capacity
Implemented
DSNI
Virtual
Implemented
DSNI
Storage Pool
Gap
DSNI
Data Used Capacity
Implemented
DSNI
Dedupe Enabled
Implemented
DSNI
Implemented
DSNI
Name
Implemented
Manual Entry
Implemented
DSNI
Raid Group
Implemented
DSNI
Raw to Usable Ratio
Implemented
DSNI
Redundancy
Implemented
DSNI
Redundancy level
Status
Implemented
DSNI
Storage Pool Id
Implemented
DSNI
Implemented
DSNI
Implemented
DSNI
Total Used Capacity
Implemented
DSNI
Type
Gap
DSNI
Virtual
Implemented
DSNI
Volume
Capacity
Implemented
DSNI
Disk Type
Not Available
DSNI
Junction Path
Implemented
DSNI
Name
Implemented
Manual Entry
Total Raw Capacity
Implemented
DSNI
Storage Pool Id
Implemented
DSNI
Thin Provisioned
Implemented
DSNI
Type
Gap
DSNI
Used Capacity
Implemented
DSNI
Volume Map
LUN
Implemented
DSNI
Protocol Controller
Implemented
DSNI
Storage Port
Implemented
DSNI
Volume Mask
Initiator
Implemented
DSNI
Protocol Controller
Implemented
DSNI
Storage Port
Implemented
DSNI
WWN Alias
Host Aliases
Implemented
DSNI
Host OS
Implemented
DSNI
Object Type
Implemented
DSNI
Source
Implemented
DSNI
WWN
Implemented
DSNI
performance
Disk
IOPs Read
Implemented
DSNI
IOPs Total
Implemented
DSNI
IOPs Write
Implemented
DSNI
Key
Implemented
DSNI
Server ID
Implemented
DSNI
Throughput Read
Implemented
DSNI
Throughput Total
Implemented
DSNI
Throughput Write
Implemented
DSNI
Read Utilization
Implemented
DSNI
Utilization Total
Implemented
DSNI
Utilization Write
Implemented
DSNI
Storage
Implemented
DSNI
Implemented
DSNI
Implemented
DSNI
Failed Raw Capacity
Implemented
DSNI
Raw Capacity
Implemented
DSNI
Spare Raw Capacity
Implemented
DSNI
Implemented
DSNI
IOPs other
Implemented
DSNI
IOPs Read
Implemented
DSNI
IOPs Total
Implemented
DSNI
IOPs Write
Implemented
DSNI
Key
Implemented
DSNI
Latency Read
Implemented
DSNI
Latency Total
Implemented
DSNI
Latency Write
Implemented
DSNI
Server ID
Implemented
DSNI
Throughput Read
Implemented
DSNI
Throughput Total
Implemented
DSNI
Throughput Write
Implemented
DSNI
StoragePool Disk
Implemented
DSNI
Raw Capacity
Implemented
DSNI
Total Capacity
Implemented
DSNI
Used Capacity
Implemented
DSNI
Implemented
DSNI
Capacity Used Ratio
Implemented
DSNI
Total Data Capacity
Implemented
DSNI
Data Used Capacity
Implemented
DSNI
IOPs Read
Implemented
DSNI
IOPs Total
Implemented
DSNI
IOPs Write
Implemented
DSNI
Throughput Read
Implemented
DSNI
Throughput Total
Implemented
DSNI
Throughput Write
Implemented
DSNI
Read Utilization
Implemented
DSNI
Utilization Total
Implemented
DSNI
Utilization Write
Implemented
DSNI
Volume
Implemented
DSNI
Implemented
DSNI
Implemented
DSNI
Raw Capacity
Implemented
DSNI
Total Capacity
Implemented
DSNI
Used Capacity
Implemented
DSNI
Capacity Used Ratio
Implemented
DSNI
IOPs Read
Implemented
DSNI
IOPs Total
Implemented
DSNI
IOPs Write
Implemented
DSNI
Key
Implemented
DSNI
Latency Read
Implemented
DSNI
Latency Total
Implemented
DSNI
Latency Write
Implemented
DSNI
Server ID
Implemented
DSNI
Throughput Read
Implemented
DSNI
Throughput Total
Implemented
DSNI
Throughput Write
Implemented
DSNI
Data source wizard configuration
Manual Entry
true
true
true
true
IBM DS CLI
DSNI
DSNI
true
true
true
true
IBM PowerVM (SSH)
foundation
Data Store
Capacity
Implemented
SSH
MOID
Implemented
SSH
Name
Implemented
SSH
OID
Implemented
SSH
Used Capacity
Implemented
SSH
Virtual Center Ip
Implemented
SSH
LUN
Disk Name
Implemented
SSH
DataStore OID
Implemented
SSH
Host OID
Implemented
SSH
Number
Implemented
SSH
OID
Implemented
SSH
Path
Active
Implemented
SSH
Lun OID
Implemented
SSH
Host Port WWPN
Implemented
SSH
OID
Implemented
SSH
Storage Port WWPN
Implemented
SSH
Type
Gap
SSH
Server
Host OID
Implemented
SSH
MOID
Implemented
SSH
OID
Implemented
SSH
Virtual Center Ip
Implemented
SSH
Virtual Disk
Capacity
Implemented
SSH
DataStore OID
Implemented
SSH
Lun OID
Implemented
SSH
Name
Implemented
SSH
OID
Implemented
SSH
Type
Gap
SSH
VirtualMachine
Dns Name
Implemented
SSH
Guest State
Implemented
SSH
Host OID
Implemented
SSH
IPs
Implemented
SSH
MOID
Implemented
SSH
Memory
Implemented
SSH
Name
Implemented
SSH
OID
Implemented
SSH
OS
Implemented
SSH
Power State
Implemented
SSH
State Change Time
Implemented
SSH
Processors
Implemented
SSH
VirtualMachine Disk
OID
Implemented
SSH
VirtualDisk OID
Implemented
SSH
VirtualMachine OID
Implemented
SSH
Host
Host Cpu Count
Implemented
SSH
Host Installed Memory
Implemented
SSH
Host Model
Implemented
SSH
NIC count
Implemented
SSH
IPs
Implemented
SSH
Manufacturer
Implemented
SSH
Name
Implemented
SSH
OID
Implemented
SSH
Platform Type
Implemented
SSH
Info
DataSource Name
Implemented
SSH
Info
Date
Implemented
SSH
Originator ID
Implemented
SSH
IBM Hardware Management Console SSH access
SSH
SSH
22
true
false
true
true
IBM SVC (CLI)
Models
2072-2N4
2072-324
2076-12F
2076-24F
2076-24G
2076-524
2076-624
2076-824
2076-AF6
2076-AFF
2078-12C
2078-12E
2078-12F
2078-224
2078-24C
2078-24E
2078-24F
2078-324
2078-AF3
4657-924
4657-92G
4662-12G
4662-6H2
4662-7H2
4666-AH8
4666-UH8
4680-24H
4680-3P2
4680-3P4
4680-92H
4983-AH8
5075-A30
5078-A40
5127-A20
9843-AE3
9848-AF8
9848-AG8
9848-UG8
SVC
Firmware versions:
  • 1.6.1.5
  • 7.7.1.8
  • 7.8.1.10
  • 7.8.1.11
  • 7.8.1.12
  • 7.8.1.5
  • 8.2.1.8
  • 8.3.1.5
  • 8.4.0.11
  • 8.4.0.15
  • 8.4.0.9
  • 8.5.0.11
  • 8.5.0.12
  • 8.5.0.13
  • 8.5.0.17
  • 8.5.0.18
  • 8.5.0.5
  • 8.5.0.7
  • 8.5.0.9
  • 8.6.0.10
  • 8.6.0.11
  • 8.6.0.2
  • 8.6.0.3
  • 8.6.0.4
  • 8.6.0.5
  • 8.6.0.6
  • 8.6.0.9
  • 8.7.0.0
  • 8.7.0.10
  • 8.7.0.11
  • 8.7.0.13
  • 8.7.0.14
  • 8.7.0.5
  • 8.7.0.6
  • 8.7.0.7
  • 8.7.0.8
  • 8.7.0.9
  • 9.1.0.4
  • 9.1.0.5
  • 9.1.0.6
  • 9.1.0.7
  • 9.1.0.8
  • 9.1.2.1
  • 9.1.3.0
  • 9.1.3.1
  • 9.1.3.2
foundation
Disk
Capacity (GB)
Implemented
SSH
Used capacity
Disk Id
Implemented
SSH
Group
Implemented
SSH
Location
Gap
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Role
Implemented
SSH
Role Enum
Implemented
SSH
enum for disk role
Serial Number
Implemented
SSH
Speed
Implemented
SSH
Speed of disk (RPM)
Status
Implemented
SSH
Type
Gap
SSH
Type Enum
Implemented
SSH
enum for disk type
Vendor
Implemented
SSH
Vendor Id
Implemented
SSH
Info
DataSource Name
Implemented
SSH
Info
Date
Implemented
SSH
Originator ID
Implemented
SSH
Storage
Display IP
Implemented
SSH
Failed Raw Capacity
Implemented
SSH
Family
Implemented
SSH
IP
Implemented
SSH
Manage URL
Implemented
SSH
Manufacturer
Implemented
SSH
Microcode Version
Implemented
SSH
Model
Implemented
SSH
Name
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Serial Number
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Virtual
Implemented
SSH
Storage Node
Model
Implemented
SSH
Name
Implemented
SSH
Partner Node UUID
Implemented
SSH
HA pair's UUID
Serial Number
Implemented
SSH
State
Implemented
SSH
UUID
Implemented
SSH
Implemented
SSH
Storage Pool
Compression Enabled
Implemented
SSH
Is compression enabled on the storage pool
Compression Savings
Implemented
SSH
Dedupe Enabled
Implemented
SSH
Implemented
SSH
Name
Implemented
SSH
Implemented
SSH
Raid Group
Implemented
SSH
Raw to Usable Ratio
Implemented
SSH
Redundancy
Implemented
SSH
Redundancy level
Status
Implemented
SSH
Storage Pool Id
Implemented
SSH
Implemented
SSH
Implemented
SSH
Total Used Capacity
Implemented
SSH
Type
Gap
SSH
Uses FlashPools
Implemented
SSH
indicate if this storagepool uses Flash Pools(NetApp specific)
Virtual
Implemented
SSH
Encrypted
Implemented
SSH
Mode
Implemented
SSH
Mode Enum
Implemented
SSH
Source Storage
Implemented
SSH
Source Volume
Implemented
SSH
State
Implemented
SSH
State Enum
Implemented
SSH
Target Storage
Implemented
SSH
Target Volume
Implemented
SSH
Technology
Implemented
SSH
Volume
Implemented
SSH
Auto Tiering
Implemented
SSH
Capacity
Implemented
SSH
DiskGroup
Implemented
SSH
Disk Group Type
Head
Implemented
SSH
Specify the head (in netapp) for this volume
Junction Path
Implemented
SSH
Name
Implemented
SSH
Protection Type
Implemented
SSH
Total Raw Capacity
Implemented
SSH
Storage Pool Id
Implemented
SSH
Thin Provisioned
Implemented
SSH
Type
Gap
SSH
UUID
Implemented
SSH
Used Capacity
Implemented
SSH
Virtual
Implemented
SSH
Written Capacity
Implemented
SSH
Total capacity written to this volume by a Host in MB
Compression Enabled
Implemented
SSH
Encrypted
Implemented
SSH
Volume Map
LUN
Implemented
SSH
Protocol Controller
Implemented
SSH
Storage Port
Implemented
SSH
Volume Mask
Initiator
Implemented
SSH
Protocol Controller
Implemented
SSH
Storage Port
Implemented
SSH
Type
Gap
SSH
WWN Alias
Host Aliases
Implemented
SSH
Object Type
Implemented
SSH
Source
Implemented
SSH
WWN
Implemented
SSH
performance
Disk
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Read Utilization
Implemented
SSH
Utilization Total
Implemented
SSH
Utilization Write
Implemented
SSH
Storage
Implemented
SSH
Implemented
SSH
Implemented
SSH
Failed Raw Capacity
Implemented
SSH
Raw Capacity
Implemented
SSH
Spare Raw Capacity
Implemented
SSH
Implemented
SSH
IOPs other
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Latency Read
Implemented
SSH
Latency Total
Implemented
SSH
Latency Write
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Storage Node
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Latency Read
Implemented
SSH
Latency Total
Implemented
SSH
Latency Write
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Utilization Total
Implemented
SSH
StoragePool Disk
Implemented
SSH
Raw Capacity
Implemented
SSH
Total Capacity
Implemented
SSH
Used Capacity
Implemented
SSH
Implemented
SSH
Capacity Used Ratio
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
Read Utilization
Implemented
SSH
Utilization Total
Implemented
SSH
Utilization Write
Implemented
SSH
Volume
Implemented
SSH
Implemented
SSH
Implemented
SSH
Raw Capacity
Implemented
SSH
Total Capacity
Implemented
SSH
Used Capacity
Implemented
SSH
Written Capacity
Implemented
SSH
Capacity Used Ratio
Implemented
SSH
Implemented
SSH
IOPs Read
Implemented
SSH
IOPs Total
Implemented
SSH
IOPs Write
Implemented
SSH
Key
Implemented
SSH
Latency Read
Implemented
SSH
Latency Total
Implemented
SSH
Latency Write
Implemented
SSH
Server ID
Implemented
SSH
Throughput Read
Implemented
SSH
Throughput Total
Implemented
SSH
Throughput Write
Implemented
SSH
IBM SVC CLI
SSH
SSH
22
true
false
true
true
IBM XIV & A9000 (XIVCLI)
A14
10.2.4.e
foundation
Disk
Capacity (GB)
Implemented
XIV CLI
Used capacity
Disk Id
Implemented
XIV CLI
Model
Implemented
XIV CLI
Name
Implemented
XIV CLI
Role
Implemented
XIV CLI
Role Enum
Implemented
XIV CLI
enum for disk role
Serial Number
Implemented
XIV CLI
Speed
Implemented
XIV CLI
Speed of disk (RPM)
Status
Implemented
XIV CLI
Type
Gap
XIV CLI
Type Enum
Implemented
XIV CLI
enum for disk type
Vendor
Implemented
XIV CLI
Info
Client Api Name
Implemented
XIV CLI
Client Api Version
Implemented
XIV CLI
DataSource Name
Implemented
XIV CLI
Info
Date
Implemented
XIV CLI
Originator ID
Implemented
XIV CLI
Originator Key
Implemented
XIV CLI
Storage
Display IP
Implemented
XIV CLI
Failed Raw Capacity
Implemented
XIV CLI
Family
Implemented
XIV CLI
IP
Implemented
XIV CLI
Manufacturer
Implemented
XIV CLI
Microcode Version
Implemented
XIV CLI
Model
Implemented
XIV CLI
Name
Implemented
XIV CLI
Total Raw Capacity
Implemented
XIV CLI
Serial Number
Implemented
XIV CLI
Spare Raw Capacity
Implemented
XIV CLI
Virtual
Implemented
XIV CLI
Storage Pool
Gap
XIV CLI
Data Used Capacity
Implemented
XIV CLI
Implemented
XIV CLI
Name
Implemented
XIV CLI
Implemented
XIV CLI
Implemented
XIV CLI
Raid Group
Implemented
XIV CLI
Raw to Usable Ratio
Implemented
XIV CLI
Redundancy
Implemented
XIV CLI
Redundancy level
Gap
XIV CLI
Implemented
XIV CLI
Soft Limit (MB)
Implemented
XIV CLI
logical volume size that is defined during volume creation or resizing operations
Storage Pool Id
Implemented
XIV CLI
Implemented
XIV CLI
Implemented
XIV CLI
Total Used Capacity
Implemented
XIV CLI
Type
Gap
XIV CLI
Virtual
Implemented
XIV CLI
Volume
Capacity
Implemented
XIV CLI
DiskGroup
Implemented
XIV CLI
Disk Group Type
Disk Type
Not Available
XIV CLI
Name
Implemented
XIV CLI
Total Raw Capacity
Implemented
XIV CLI
Redundancy
Implemented
XIV CLI
Redundancy level
Storage Pool Id
Implemented
XIV CLI
Thin Provisioned
Implemented
XIV CLI
Type
Gap
XIV CLI
Used Capacity
Implemented
XIV CLI
Compression Enabled
Implemented
XIV CLI
Volume Map
LUN
Implemented
XIV CLI
Protocol Controller
Implemented
XIV CLI
Volume Mask
Initiator
Implemented
XIV CLI
Protocol Controller
Implemented
XIV CLI
WWN Alias
Host Aliases
Implemented
XIV CLI
Host OS
Implemented
XIV CLI
Object Type
Implemented
XIV CLI
Source
Implemented
XIV CLI
WWN
Implemented
XIV CLI
IBM DS CLI
DSNI
DSNI
true
true
true
true
IBM XIV CLI
XIV CLI
TCP
7778
true
false
true
false
Infinidat Infinibox (HTTP)
F24STX
F4416T
F6306
8.1.10.250
8.4.6.30
8.5.3.30
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Vendor
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Gap
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Share
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Model
Implemented
HTTPS
Name
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Pool
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Reserved Capacity
Implemented
HTTPS
Soft Limit (MB)
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Mode
Implemented
HTTPS
Mode Enum
Implemented
HTTPS
Source Storage
Implemented
HTTPS
Source Volume
Implemented
HTTPS
State
Implemented
HTTPS
State Enum
Implemented
HTTPS
Target Storage
Implemented
HTTPS
Target Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Replica Source
Implemented
HTTPS
Replica Target
Implemented
HTTPS
Snapshot
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
WWN Alias
Host Aliases
Implemented
HTTPS
Object Type
Implemented
HTTPS
Source
Implemented
HTTPS
WWN
Implemented
HTTPS
Infinidat REST API
HTTPS
HTTPS
443
true
true
true
true
Microsoft Azure Compute
API versions:
  • 2018-06-01
foundation
Data Store
Capacity
Implemented
HTTPS
MOID
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Provisioned Capacity
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
subscription Id
Implemented
HTTPS
Server
Cluster
Implemented
HTTPS
Cluster name
DataCenter Name
Implemented
HTTPS
Host OID
Implemented
HTTPS
MOID
Implemented
HTTPS
OID
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
Virtual Disk
Capacity
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Lun OID
Implemented
HTTPS
Is Chargeable
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
subscription Id
Implemented
HTTPS
VirtualMachine
Guest State
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Host OID
Implemented
HTTPS
IPs
Implemented
HTTPS
MOID
Implemented
HTTPS
Memory
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
OS
Implemented
HTTPS
Power State
Implemented
HTTPS
State Change Time
Implemented
HTTPS
Processors
Implemented
HTTPS
Implemented
HTTPS
Instance Type
Implemented
HTTPS
Launch Time
Implemented
HTTPS
public Ips
Implemented
HTTPS
Security Groups
Implemented
HTTPS
subscription Id
Implemented
HTTPS
VirtualMachine Disk
OID
Implemented
HTTPS
VirtualDisk OID
Implemented
HTTPS
VirtualMachine OID
Implemented
HTTPS
Host
Host OS
Implemented
HTTPS
IPs
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Info
Api Description
Implemented
HTTPS
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
performance
Virtual Disk
Total Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
vm
Total Capacity
Implemented
HTTPS
Total CPU Utilization
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
diskIops.total
Implemented
HTTPS
Disk IOPs write
Implemented
HTTPS
Disk Throughput Read
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
total disk throughput read
Disk Throughput Write
Implemented
HTTPS
IP Throughput Read
Implemented
HTTPS
Throughput total
Implemented
HTTPS
IP throughput total
ipThroughput.write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Microsoft Azure Compute REST API
HTTPS
HTTPS
443
true
true
true
true
Microsoft Azure NetApp Files
Models and versions supported by this data collector:
API versions Models
2025-09-01
Azure NetApp Files
Products supported by this data collector:
Product Category Feature/Attribute Status Protocol Used Additional Information
foundation
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Info
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Last Snapshot Time
Implemented
HTTPS
time of last snapshot
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Snapshot Count
Implemented
HTTPS
Number of snapshots on the internal volumes
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Thin Provisioning Supported
Implemented
HTTPS
Total Allocated Capacity
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Total Used Capacity (MB)
Implemented
HTTPS
place holder for the used capacity as read from the device
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Comment
Gap
HTTPS
state: free text comment describing the svm
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Source Internal Volume
Implemented
HTTPS
Target Internal Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Implemented
HTTPS
Security Style
Implemented
HTTPS
Security style of the directory: unix, ntfs, or mixed
Status
Implemented
HTTPS
Type
Gap
HTTPS
Quota
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Share
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Pool
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Comment
Gap
HTTPS
performance
Internal Volume
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
Total Data Capacity
Implemented
Data Used Capacity
Implemented
IOPs other
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Implemented
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Qtree
Quota Hard Limit
Implemented
Capacity quota hard limit
Total File Count
Implemented
Key
Implemented
Server ID
Implemented
Storage
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
Implemented
Key
Implemented
Server ID
Implemented
StoragePool Disk
Implemented
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Implemented
Capacity Used Ratio
Implemented
Total Data Capacity
Implemented
Data Used Capacity
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Azure Netapp Files REST API
HTTPS
HTTPS
443
true
true
true
true
Microsoft Hyper-V
foundation
Data Store
Capacity
Implemented
WMI
MOID
Implemented
WMI
Name
Implemented
WMI
OID
Implemented
WMI
Implemented
WMI
Used Capacity
Implemented
WMI
Virtual Center Ip
Implemented
WMI
NasShare DataStore
DataStore OID
Implemented
WMI
Nas Share OID
Implemented
WMI
OID
Implemented
WMI
NasShare Host
Nas Share OID
Implemented
WMI
Host OID
Implemented
WMI
OID
Implemented
WMI
Read Only
Implemented
WMI
LUN
Disk Name
Implemented
WMI
DataStore OID
Implemented
WMI
Host OID
Implemented
WMI
Number
Implemented
WMI
OID
Implemented
WMI
TID
Implemented
WMI
NAS Share
Capacity
Implemented
WMI
Allocated capacity in MB
Filer Ip
Implemented
WMI
Filer Name
Implemented
WMI
OID
Implemented
WMI
Share Path
Implemented
WMI
For a HvNasShare to be matched to a Share
Type
Gap
WMI
Path
Active
Implemented
WMI
Lun OID
Implemented
WMI
Host Port WWPN
Implemented
WMI
OID
Implemented
WMI
Storage Port WWPN
Implemented
WMI
Type
Gap
WMI
Server
Cluster
Implemented
WMI
Cluster name
DataCenter Name
Implemented
WMI
Host OID
Implemented
WMI
MOID
Implemented
WMI
OID
Implemented
WMI
Virtual Center Ip
Implemented
WMI
Virtual Disk
Capacity
Implemented
WMI
DataStore OID
Implemented
WMI
Name
Implemented
WMI
OID
Implemented
WMI
Type
Gap
WMI
Used Capacity
Implemented
WMI
used capacity for reporting (MB)
Used Capacity
Implemented
WMI
VirtualMachine
Dns Name
Implemented
WMI
Guest State
Implemented
WMI
DataStore OID
Implemented
WMI
Host OID
Implemented
WMI
IPs
Implemented
WMI
MOID
Implemented
WMI
Memory
Implemented
WMI
Name
Implemented
WMI
OID
Implemented
WMI
OS
Implemented
WMI
Power State
Implemented
WMI
State Change Time
Implemented
WMI
Processors
Implemented
WMI
Implemented
WMI
Used Capacity
Implemented
WMI
VirtualMachine Disk
OID
Implemented
WMI
VirtualDisk OID
Implemented
WMI
VirtualMachine OID
Implemented
WMI
Host
Host Cpu Count
Implemented
WMI
Host Cpu Speed
Implemented
WMI
Host Domain
Implemented
WMI
Implemented
WMI
Host Model
Implemented
WMI
NIC count
Implemented
WMI
NIC speed
Implemented
WMI
IPs
Implemented
WMI
Manufacturer
Implemented
WMI
Name
Implemented
WMI
OID
Implemented
WMI
Platform Type
Implemented
WMI
ISCSI Node
Host Aliases
Implemented
WMI
Node Name
Implemented
WMI
OID
Implemented
WMI
Type
Gap
WMI
Info
DataSource Name
Implemented
WMI
Info
Date
Implemented
WMI
Originator ID
Implemented
WMI
performance
Host
Implemented
WS-Management
IOPs Read
Implemented
WS-Management
diskIops.total
Implemented
WS-Management
Disk IOPs write
Implemented
WS-Management
Latency Read
Implemented
WS-Management
Latency Total
Implemented
WS-Management
Latency Write
Implemented
WS-Management
Implemented
WS-Management
Throughput Read
Implemented
WS-Management
Implemented
WS-Management
IP Throughput Read
Implemented
WS-Management
Throughput total
Implemented
WS-Management
IP throughput total
ipThroughput.write
Implemented
WS-Management
Key
Implemented
WS-Management
Total Memory Utilization
Implemented
WS-Management
Server ID
Implemented
WS-Management
Virtual Disk
Total Capacity
Implemented
WS-Management
Used Capacity
Implemented
WS-Management
Capacity Used Ratio
Implemented
WS-Management
IOPs Read
Implemented
WS-Management
IOPs Total
Implemented
WS-Management
IOPs Write
Implemented
WS-Management
Key
Implemented
WS-Management
Latency Total
Implemented
WS-Management
Server ID
Implemented
WS-Management
Throughput Read
Implemented
WS-Management
Throughput Total
Implemented
WS-Management
Throughput Write
Implemented
WS-Management
vm
Total Capacity
Implemented
WS-Management
Used Capacity
Implemented
WS-Management
Capacity Used Ratio
Implemented
WS-Management
Implemented
WS-Management
IOPs Read
Implemented
WS-Management
diskIops.total
Implemented
WS-Management
Disk IOPs write
Implemented
WS-Management
Latency Total
Implemented
WS-Management
Implemented
WS-Management
Throughput Read
Implemented
WS-Management
Implemented
WS-Management
IP Throughput Read
Implemented
WS-Management
Throughput total
Implemented
WS-Management
IP throughput total
ipThroughput.write
Implemented
WS-Management
Key
Implemented
WS-Management
Server ID
Implemented
WS-Management
PowerShell
WS-Management
HTTP
5985
true
false
false
true
WMI
WMI
WMI
135
true
false
true
true
NetApp 7 Mode
ONTAPI version=1.17
ONTAPI version=1.19
ONTAPI version=1.21
FAS2040
FAS2220
FAS2240-2
FAS2552
FAS3250
FAS3270
FAS8040
8.1.1 7-Mode
8.1.4P9D18 7-Mode
8.2.3P2 7-Mode
8.2.4P4 7-Mode
8.2.4P5 7-Mode
8.2.5P4 7-Mode
8.2.5P5 7-Mode
foundation
Capability
Active
Implemented
Licensed
Implemented
Type
Gap
Used
Implemented
Disk
Capacity (GB)
Implemented
Used capacity
Disk Id
Implemented
Group
Implemented
Location
Gap
Model
Implemented
Name
Implemented
Role
Implemented
Role Enum
Implemented
enum for disk role
Serial Number
Implemented
Speed
Implemented
Speed of disk (RPM)
Status
Implemented
Status Enum
Implemented
Type
Gap
Type Enum
Implemented
enum for disk type
Vendor
Implemented
File Share
Is InternalVolume
Implemented
Is Oplocks Enabled
Implemented
whether opportunistic locks are enabled on the FileShare
Is Shared
Implemented
Name
Implemented
Path
Implemented
Qtree Id
Implemented
Security Type
Implemented
Status
Implemented
IP
Implemented
Listening Port
Implemented
Nic
Implemented
OID
Implemented
OID
Implemented
Portal Group Name
Implemented
Portal Group Tag
Implemented
ISCSI Node
Host Aliases
Implemented
Node Name
Implemented
OID
Implemented
Type
Gap
ISCSI Node Map
OID
Implemented
Portal Group OID
Implemented
ISCSI Security Info
Auth Type
Implemented
Initiator Node Name
Implemented
OID
Implemented
Target Node Name
Implemented
ISCSI Session
Initiator Ips
Implemented
Initiator OID
Implemented
Initiator Session Id
Implemented
Max Connections
Implemented
Implemented
OID
Implemented
Portal Group OID
Implemented
Security
Implemented
Target Session Id
Implemented
Info
Api Name
Implemented
Api Version
Implemented
DataSource Name
Implemented
Info
Date
Implemented
Originator ID
Implemented
Originator Key
Implemented
Internal Volume
Compression Enabled
Implemented
Compression Savings
Implemented
Gap
Data Used Capacity
Implemented
Dedupe Enabled
Implemented
Is dedupe enabled on the storage pool
Dedupe Savings
Implemented
Internal Volume Id
Implemented
Last Known Access Time
Implemented
Last know access to the volume
Last Snapshot Time
Implemented
Name
Implemented
Protection Type
Implemented
Raw to Usable Ratio
Implemented
ratio to convert from usable capacity to raw capacity
Gap
Snapshot Count
Implemented
Implemented
Space Guarantee
Implemented
Space Guatantee policy (file, volume or none)
Status
Implemented
Storage Pool Id
Implemented
Thin Provisioned
Implemented
Implemented
Whether this internal volume supports thin provisioning for the volume layer on top of it
Implemented
Total Used Capacity
Implemented
Total capacity in MB
Implemented
Type
Gap
Virtual Storage
Implemented
Owning virtual storage (vfiler)
Implemented
Implemented
Technology
Implemented
QTree
Name
Implemented
Oplocks
Implemented
Indicates whether opportunistic locks are enabled on the Qtree
Qtree Id
Implemented
Implemented
Implemented
Quota UsedCapacity
Implemented
Security Style
Implemented
Status
Implemented
Type
Gap
Quota
Implemented
Hard File Limit
Implemented
max number of files allowed for the quota target
Internal Volume Id
Implemented
Qtree Id
Implemented
Quota Id
Implemented
Implemented
Soft File Limit
Implemented
Threshold (MB)
Implemented
Disk space threshold, for the quota target
Type
Gap
Used Capacity
Implemented
Used Files
Implemented
Share
Implemented
IP Interfaces
Implemented
Name
Implemented
Protocol
Implemented
Share Initiator
Initiator
Implemented
Permission
Implemented
Storage
Cpu Count
Implemented
Cpu Count of the storage
Display IP
Implemented
Failed Raw Capacity
Implemented
Family
Implemented
IP
Implemented
Manufacturer
Implemented
Memory
Implemented
Microcode Version
Implemented
Model
Implemented
Name
Implemented
Total Raw Capacity
Implemented
Serial Number
Implemented
Spare Raw Capacity
Implemented
Raw capacity of spare disks (sum of all disks that are spare)
Virtual
Implemented
Storage Node
Cache Size
Implemented
device cache size in MB
Memory Size
Gap
device memory in MB
Model
Implemented
Name
Implemented
Processors Count
Implemented
device CPU
Partner Node UUID
Implemented
HA pair's UUID
Serial Number
Implemented
UUID
Implemented
Version
Implemented
software version
Implemented
Storage Pool
Gap
Data Used Capacity
Implemented
Implemented
Name
Implemented
Implemented
Raid Group
Implemented
Raw to Usable Ratio
Implemented
Redundancy
Implemented
Redundancy level
Gap
Implemented
Status
Implemented
Storage Pool Id
Implemented
Implemented
Implemented
Total Used Capacity
Implemented
Type
Gap
Uses FlashPools
Implemented
Virtual
Implemented
Volume
Capacity
Implemented
DiskGroup
Implemented
Disk Group Type
Disk Size
Implemented
comma seperated list of disk sizes (GB)
Disk Speed
Implemented
comma seperated list of disk speeds (rpm)
Disk Type
Not Available
Junction Path
Implemented
Implemented
Name
Implemented
Protection Type
Implemented
Qtree Id
Implemented
Total Raw Capacity
Implemented
Storage Pool Id
Implemented
Thin Provisioned
Implemented
Type
Gap
Used Capacity
Implemented
Volume Map
LUN
Implemented
Protocol Controller
Implemented
Type
Gap
Volume Mask
Initiator
Implemented
Protocol Controller
Implemented
Storage Port
Implemented
Type
Gap
performance
Disk
IOPs Read
Implemented
Number of read IOPs on the disk
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Average disk total rate (read and write across all disks) in MB/s
Throughput Write
Implemented
Read Utilization
Implemented
Utilization Total
Implemented
Utilization Write
Implemented
Internal Volume
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
Implemented
Implemented
Total Data Capacity
Implemented
Data Used Capacity
Implemented
IO Density Read
Implemented
IO Density Total
Implemented
Write IO Density
Implemented
IOPs other
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Implemented
Implemented
Implemented
Reported as a time series
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Qtree
Quota Hard Limit
Implemented
Quota Soft Limit
Implemented
Capacity Quota soft Limit
Used Capacity
Implemented
Total File Count
Implemented
IOPs Total
Implemented
Key
Implemented
Server ID
Implemented
Storage
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
Implemented
IO Density Read
Implemented
IO Density Total
Implemented
Write IO Density
Implemented
IOPs other
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Storage Node
Implemented
Total Disk Read Replaced
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
StoragePool Disk
Implemented
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Implemented
Capacity Used Ratio
Implemented
Total Data Capacity
Implemented
Data Used Capacity
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Implemented
Implemented
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Read Utilization
Implemented
Utilization Total
Implemented
Utilization Write
Implemented
Volume
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
IO Density Read
Implemented
IO Density Total
Implemented
Write IO Density
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Partial Blocked Ratio
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Write Pending
Implemented
total write pending
Management APIs used by this data collector:
API Protocol Used Transport layer protocol used Incoming ports used Outgoing ports used Supports authentication Requires only 'Read-only' credentials Supports Encryption Firewall friendly (static ports)
NetApp 7 Mode ZAPI
ZAPI
ZAPI
true
true
true
true
NetApp Cloud Volumes ONTAP
Note Models, firmware, API versions, and product capabilities are pooled across variants that use this shared collector implementation.
Models:
  • AFF-A150
  • AFF-A1K
  • AFF-A20
  • AFF-A200
  • AFF-A220
  • AFF-A250
  • AFF-A30
  • AFF-A300
  • AFF-A320
  • AFF-A400
  • AFF-A50
  • AFF-A70
  • AFF-A700
  • AFF-A700s
  • AFF-A800
  • AFF-A90
  • AFF-A900
  • AFF-C190
  • AFF-C250
  • AFF-C30
  • AFF-C400
  • AFF-C60
  • AFF-C80
  • AFF-C800
  • AFF8020
  • AFF8040
  • AFF8080
  • ASA-A250
  • ASA-A400
  • ASA-A800
  • ASA-A900
  • ASA-C250
  • ASA-C800
  • CDvM200
  • DG5000
  • DG5200
  • DM5000H
  • FAS2520
  • FAS2552
  • FAS2554
  • FAS2620
  • FAS2650
  • FAS2720
  • FAS2750
  • FAS2820
  • FAS3270
  • FAS50
  • FAS500f
  • FAS70
  • FAS8020
  • FAS8040
  • FAS8060
  • FAS8080
  • FAS8200
  • FAS8300
  • FAS8700
  • FAS90
  • FAS9000
  • FAS9500
  • FASDvM300
  • SIMBOX
Firmware versions:
  • 8.2.3P5 clustered Data ONTAP
  • 8.3.2P12 clustered Data ONTAP
  • 9.0.0 clustered Data ONTAP
  • 9.1.0P19 clustered Data ONTAP
  • 9.1.0P3 clustered Data ONTAP
  • 9.10.0 clustered Data ONTAP
  • 9.10.1 clustered Data ONTAP
  • 9.10.1P10 clustered Data ONTAP
  • 9.10.1P12 clustered Data ONTAP
  • 9.10.1P13 clustered Data ONTAP
  • 9.10.1P14 clustered Data ONTAP
  • 9.10.1P17 clustered Data ONTAP
  • 9.10.1P20 clustered Data ONTAP
  • 9.10.1P4 clustered Data ONTAP
  • 9.11.1 clustered Data ONTAP
  • 9.11.1P10 clustered Data ONTAP
  • 9.11.1P11 clustered Data ONTAP
  • 9.11.1P12 clustered Data ONTAP
  • 9.11.1P13 clustered Data ONTAP
  • 9.11.1P14 clustered Data ONTAP
  • 9.11.1P15 clustered Data ONTAP
  • 9.11.1P17 clustered Data ONTAP
  • 9.11.1P18 clustered Data ONTAP
  • 9.11.1P19 clustered Data ONTAP
  • 9.11.1P20 clustered Data ONTAP
  • 9.11.1P3 clustered Data ONTAP
  • 9.11.1P5 clustered Data ONTAP
  • 9.11.1P8 clustered Data ONTAP
  • 9.12.1 clustered Data ONTAP
  • 9.12.1P1 clustered Data ONTAP
  • 9.12.1P10 clustered Data ONTAP
  • 9.12.1P11 clustered Data ONTAP
  • 9.12.1P12 clustered Data ONTAP
  • 9.12.1P14 clustered Data ONTAP
  • 9.12.1P15 clustered Data ONTAP
  • 9.12.1P16 clustered Data ONTAP
  • 9.12.1P17 clustered Data ONTAP
  • 9.12.1P18 clustered Data ONTAP
  • 9.12.1P19 clustered Data ONTAP
  • 9.12.1P2 clustered Data ONTAP
  • 9.12.1P20 clustered Data ONTAP
  • 9.12.1P3 clustered Data ONTAP
  • 9.12.1P4 clustered Data ONTAP
  • 9.12.1P5 clustered Data ONTAP
  • 9.12.1P6 clustered Data ONTAP
  • 9.12.1P7 clustered Data ONTAP
  • 9.12.1P9 clustered Data ONTAP
  • 9.13.1 clustered Data ONTAP
  • 9.13.1P1 clustered Data ONTAP
  • 9.13.1P10 clustered Data ONTAP
  • 9.13.1P11 clustered Data ONTAP
  • 9.13.1P12 clustered Data ONTAP
  • 9.13.1P13 clustered Data ONTAP
  • 9.13.1P14 clustered Data ONTAP
  • 9.13.1P16 clustered Data ONTAP
  • 9.13.1P17 clustered Data ONTAP
  • 9.13.1P18 clustered Data ONTAP
  • 9.13.1P19 clustered Data ONTAP
  • 9.13.1P2 clustered Data ONTAP
  • 9.13.1P20 clustered Data ONTAP
  • 9.13.1P21 clustered Data ONTAP
  • 9.13.1P3 clustered Data ONTAP
  • 9.13.1P4 clustered Data ONTAP
  • 9.13.1P6 clustered Data ONTAP
  • 9.13.1P7 clustered Data ONTAP
  • 9.13.1P8 clustered Data ONTAP
  • 9.13.1P9 clustered Data ONTAP
  • 9.14.0 clustered Data ONTAP
  • 9.14.0P1 clustered Data ONTAP
  • 9.14.1 clustered Data ONTAP
  • 9.14.1P1 clustered Data ONTAP
  • 9.14.1P10 clustered Data ONTAP
  • 9.14.1P11 clustered Data ONTAP
  • 9.14.1P12 clustered Data ONTAP
  • 9.14.1P13 clustered Data ONTAP
  • 9.14.1P14 clustered Data ONTAP
  • 9.14.1P15 clustered Data ONTAP
  • 9.14.1P16 clustered Data ONTAP
  • 9.14.1P17 clustered Data ONTAP
  • 9.14.1P18 clustered Data ONTAP
  • 9.14.1P2 clustered Data ONTAP
  • 9.14.1P4 clustered Data ONTAP
  • 9.14.1P5 clustered Data ONTAP
  • 9.14.1P6 clustered Data ONTAP
  • 9.14.1P7 clustered Data ONTAP
  • 9.14.1P8 clustered Data ONTAP
  • 9.14.1P9 clustered Data ONTAP
  • 9.15.0P1 clustered Data ONTAP
  • 9.15.1 clustered Data ONTAP
  • 9.15.1P10 clustered Data ONTAP
  • 9.15.1P11 clustered Data ONTAP
  • 9.15.1P12 clustered Data ONTAP
  • 9.15.1P13 clustered Data ONTAP
  • 9.15.1P14 clustered Data ONTAP
  • 9.15.1P15 clustered Data ONTAP
  • 9.15.1P16 clustered Data ONTAP
  • 9.15.1P17 clustered Data ONTAP
  • 9.15.1P19 clustered Data ONTAP
  • 9.15.1P2 clustered Data ONTAP
  • 9.15.1P20 clustered Data ONTAP
  • 9.15.1P3 clustered Data ONTAP
  • 9.15.1P4 clustered Data ONTAP
  • 9.15.1P5 clustered Data ONTAP
  • 9.15.1P6 clustered Data ONTAP
  • 9.15.1P7 clustered Data ONTAP
  • 9.15.1P8 clustered Data ONTAP
  • 9.16.1 clustered Data ONTAP
  • 9.16.1P1 clustered Data ONTAP
  • 9.16.1P10 clustered Data ONTAP
  • 9.16.1P11 clustered Data ONTAP
  • 9.16.1P12 clustered Data ONTAP
  • 9.16.1P13 clustered Data ONTAP
  • 9.16.1P14 clustered Data ONTAP
  • 9.16.1P15 clustered Data ONTAP
  • 9.16.1P16 clustered Data ONTAP
  • 9.16.1P2 clustered Data ONTAP
  • 9.16.1P3 clustered Data ONTAP
  • 9.16.1P4 clustered Data ONTAP
  • 9.16.1P5 clustered Data ONTAP
  • 9.16.1P6 clustered Data ONTAP
  • 9.16.1P7 clustered Data ONTAP
  • 9.16.1P8 clustered Data ONTAP
  • 9.16.1P9 clustered Data ONTAP
  • 9.17.1 clustered Data ONTAP
  • 9.17.1P1 clustered Data ONTAP
  • 9.17.1P10 clustered Data ONTAP
  • 9.17.1P11 clustered Data ONTAP
  • 9.17.1P12 clustered Data ONTAP
  • 9.17.1P2 clustered Data ONTAP
  • 9.17.1P3 clustered Data ONTAP
  • 9.17.1P4 clustered Data ONTAP
  • 9.17.1P5 clustered Data ONTAP
  • 9.17.1P6 clustered Data ONTAP
  • 9.17.1P6D2 clustered Data ONTAP
  • 9.17.1P7 clustered Data ONTAP
  • 9.17.1P8 clustered Data ONTAP
  • 9.17.1P9 clustered Data ONTAP
  • 9.18.1 clustered Data ONTAP
  • 9.18.1P1 clustered Data ONTAP
  • 9.18.1P2 clustered Data ONTAP
  • 9.18.1P3 clustered Data ONTAP
  • 9.18.1P4 clustered Data ONTAP
  • 9.18.1P5 clustered Data ONTAP
  • 9.18.1P6 clustered Data ONTAP
  • 9.18.1P7 clustered Data ONTAP
  • 9.18.1P8 clustered Data ONTAP
  • 9.19.1 clustered Data ONTAP
  • 9.19.1P2 clustered Data ONTAP
  • 9.19.1P3 clustered Data ONTAP
  • 9.19.1P4 clustered Data ONTAP
  • 9.19.1X43 clustered Data ONTAP
  • 9.20.1 clustered Data ONTAP
  • 9.4.0P2 clustered Data ONTAP
  • 9.5.0P18 clustered Data ONTAP
  • 9.5.0P2 clustered Data ONTAP
  • 9.5.0P7 clustered Data ONTAP
  • 9.6.0 clustered Data ONTAP
  • 9.6.0P11 clustered Data ONTAP
  • 9.7.0P12 clustered Data ONTAP
  • 9.7.0P17 clustered Data ONTAP
  • 9.7.0P19 clustered Data ONTAP
  • 9.7.0P20 clustered Data ONTAP
  • 9.7.0P21 clustered Data ONTAP
  • 9.7.0P22 clustered Data ONTAP
  • 9.7.0P23 clustered Data ONTAP
  • 9.7.0P6 clustered Data ONTAP
  • 9.8.0P10 clustered Data ONTAP
  • 9.8.0P11 clustered Data ONTAP
  • 9.8.0P12 clustered Data ONTAP
  • 9.8.0P18 clustered Data ONTAP
  • 9.8.0P19 clustered Data ONTAP
  • 9.8.0P20 clustered Data ONTAP
  • 9.8.0P21 clustered Data ONTAP
  • 9.8.0P4 clustered Data ONTAP
  • 9.8.0P8 clustered Data ONTAP
  • 9.8.0P9 clustered Data ONTAP
  • 9.9.1P15 clustered Data ONTAP
  • 9.9.1P16 clustered Data ONTAP
  • 9.9.1P20 clustered Data ONTAP
  • 9.9.1P7 clustered Data ONTAP
foundation
Capability
Active
Implemented
HTTPS
Licensed
Implemented
HTTPS
Type
Gap
HTTPS
Used
Implemented
HTTPS
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Uniquely identifies this disk in the array
Group
Implemented
HTTPS
Location
Gap
HTTPS
Where this disk is physically located in the array
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
enum for disk status
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
Disk Group
Capacity
Implemented
HTTPS
Snapshot Used capacity in MB
DiskGroup Id
Implemented
HTTPS
unique id of the disk group
Name
Implemented
HTTPS
Physical Disk Capacity (MB)
Implemented
HTTPS
used as raw capacity for storage pool
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Is this a storage virtualization device?
File Share
Is InternalVolume
Implemented
HTTPS
Is Oplocks Enabled
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Security Info
Auth Type
Implemented
HTTPS
Inbound Keyword
Implemented
HTTPS
Initiator Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Outbound Keyword
Implemented
HTTPS
Target Node Name
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Target Session Id
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Data Allocated Capacity
Gap
HTTPS
capacity allocated for data
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
ratio of dedupe savings in percentage
FlashPool Eligibility
Implemented
HTTPS
Whether the internal volume can participate in hybrid caching
GuidKey 1
Implemented
HTTPS
GuidKey1 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5.
GuidKey 2
Implemented
HTTPS
GuidKey2 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5.
Internal Volume Id
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Other Allocated Capacity
Gap
HTTPS
Capacity allocated for other (not data and not snapshot)
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Snapshot Allocated Capacity
Gap
HTTPS
Allocated capacity of snapshots in MB
Snapshot Count
Implemented
HTTPS
Snapshot Used Capacity
Implemented
HTTPS
Space Guarantee
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Clone Saved Capacity in MB
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Virtual Storage
Implemented
HTTPS
Adaptive Qos Policy
Implemented
HTTPS
Comment
Gap
HTTPS
Group Id
Implemented
HTTPS
Group Name
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
Qos Limit Raw
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Tiering Minimum Cooling Days
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Technology
Implemented
HTTPS
QTree
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
GuidKey 3
Implemented
HTTPS
GuidKey3 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5.
Name
Implemented
HTTPS
Oplocks
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Security Style
Implemented
HTTPS
Status
Implemented
HTTPS
Type
Gap
HTTPS
Quota
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
GuidKey 3
Implemented
HTTPS
Implemented
HTTPS
Hard File Limit
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Threshold (MB)
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
User/Group Target
Implemented
HTTPS
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Cluster
Not Available
HTTPS
Whether this storage is a cluster
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Raw capacity of failed disks (sum of all disks that are failed)
Family
Implemented
HTTPS
The storage Family could be Clariion, Symmetrix, et al
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Total raw capacity (sum of all disks on the array)
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
SupportActive Active
Implemented
HTTPS
Specified if the storage supports active-active configurations
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Partner Node UUID
Implemented
HTTPS
HA pair's UUID
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
free text describing the device state
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
time in milliseconds
Version
Implemented
HTTPS
software version
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
ratio of compression savings in percentage
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Include In Dwh Capacity
Implemented
HTTPS
A way from ACQ to control which storage pools are interesting in DWH Capacity
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
indicates whether this storagePool is a raid group
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Reserved Capacity
Implemented
HTTPS
Reserved Capacity in MB
Gap
HTTPS
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Uses FlashPools
Implemented
HTTPS
Virtual
Implemented
HTTPS
CompactionSavings Enabled
Implemented
HTTPS
Encrypted
Implemented
HTTPS
License Used Percent
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage VirtualMachine
Allocated capacity (MB)
Implemented
HTTPS
Comment
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Guid Key
Implemented
HTTPS
Globally Unique Key of the storage virtual machine
IP Space
Implemented
HTTPS
Internal Volume Limit
Implemented
HTTPS
Name
Implemented
HTTPS
Protocols
Implemented
HTTPS
csv of svm enabled protocols (fcp, iscsi, nfs, cifs…​)
State
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
VirtualMachine Internal Volume Ref
Internal Volume Id
Implemented
HTTPS
VirtualMachine StoragePool lRef
Storage Pool Id
Implemented
HTTPS
VirtualMachine Volume Ref
Volume Name
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
DiskGroup
Implemented
HTTPS
Disk Group Type
Disk Size
Implemented
HTTPS
Disk Speed
Implemented
HTTPS
Disk Type
Not Available
HTTPS
Junction Path
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
Qos Limit Raw
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Clone Saved Capacity Total
Implemented
HTTPS
Total Compression Savings
Implemented
HTTPS
Compression Savings Space
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
deduplicationSavingsPercent.total
Implemented
HTTPS
Deduplication Savings Space
Implemented
HTTPS
File System Capacity Logical Used
Implemented
HTTPS
File System Capacity Physical Available
Implemented
HTTPS
File System Capacity Physical Used
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Object Store Space Used
Implemented
HTTPS
Other Total Capacity
Implemented
HTTPS
QOS Wait
Implemented
HTTPS
Total qos wait time
Server ID
Implemented
HTTPS
Snapshot Reserved Capacity
Implemented
HTTPS
Implemented
HTTPS
Snapshot Used Capacity Ratio
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Quota Soft Limit
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
StoragePools Capacity
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
Failed Fans
Implemented
HTTPS
Failed Power Units
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Optimal Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Capacity Provisioned
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Reserved Capacity
Implemented
HTTPS
Fractional reserved (included in data allocated capacity)
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Over Commit Capacity Ratio
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
compactionSavingsPercent.total
Implemented
HTTPS
Total Compaction Space
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Object Store Space Physical Space Used
Implemented
HTTPS
Object Store Space Referenced Space
Implemented
HTTPS
Object Store Space SIS Space Saved
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
NetApp ONTAP API
HTTP/HTTPS
HTTP/HTTPS
80/443
true
true
true
true
NetApp ONTAP Data Management Software
Models:
  • AFF-A150
  • AFF-A1K
  • AFF-A20
  • AFF-A200
  • AFF-A220
  • AFF-A250
  • AFF-A30
  • AFF-A300
  • AFF-A320
  • AFF-A400
  • AFF-A50
  • AFF-A70
  • AFF-A700
  • AFF-A700s
  • AFF-A800
  • AFF-A90
  • AFF-A900
  • AFF-C190
  • AFF-C250
  • AFF-C30
  • AFF-C400
  • AFF-C60
  • AFF-C80
  • AFF-C800
  • AFF8020
  • AFF8040
  • AFF8080
  • ASA-A250
  • ASA-A400
  • ASA-A800
  • ASA-A900
  • ASA-C250
  • ASA-C800
  • CDvM200
  • DG5000
  • DG5200
  • DM5000H
  • FAS2520
  • FAS2552
  • FAS2554
  • FAS2620
  • FAS2650
  • FAS2720
  • FAS2750
  • FAS2820
  • FAS3270
  • FAS50
  • FAS500f
  • FAS70
  • FAS8020
  • FAS8040
  • FAS8060
  • FAS8080
  • FAS8200
  • FAS8300
  • FAS8700
  • FAS90
  • FAS9000
  • FAS9500
  • FASDvM300
  • SIMBOX
Firmware versions:
foundation
Capability
Active
Implemented
HTTPS
Licensed
Implemented
HTTPS
Type
Gap
HTTPS
Used
Implemented
HTTPS
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
Disk Group
Capacity
Implemented
HTTPS
DiskGroup Id
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume
Is Oplocks Enabled
Implemented
HTTPS
Is Shared
Implemented
HTTPS
whether this fileShare has any shares associated with it
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Path of the fileShare
Qtree Id
Implemented
HTTPS
unique id of the qtree
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
ISCSI Network Portal
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
ISCSI Network Portal Group
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Security Info
Auth Type
Implemented
HTTPS
Inbound Keyword
Implemented
HTTPS
Initiator Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Outbound Keyword
Implemented
HTTPS
Target Node Name
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Number Of Connections
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Target Session Id
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Gap
HTTPS
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Gap
HTTPS
Snapshot Count
Implemented
HTTPS
Implemented
HTTPS
Space Guarantee
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Virtual Storage
Implemented
HTTPS
Adaptive Qos Policy
Implemented
HTTPS
Comment
Gap
HTTPS
Group Id
Implemented
HTTPS
Group Name
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
Qos Limit Raw
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Implemented
HTTPS
Storage Synchronization
Implemented
HTTPS
Implemented
HTTPS
Technology
Implemented
HTTPS
technology which causes storage efficiency changed
QTree
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
GuidKey 3
Implemented
HTTPS
Name
Implemented
HTTPS
Oplocks
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota HardCapacity Limit (MB)
Implemented
HTTPS
Maximum amount of disk space, allowed for the quota target
Quota SoftCapacity Limit (MB)
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Space in MB currently used
Security Style
Implemented
HTTPS
Status
Implemented
HTTPS
Type
Gap
HTTPS
Quota
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
GuidKey 3
Implemented
HTTPS
Hard Capacity Limit (MB)
Implemented
HTTPS
max amount of disk space, allowed for the quota target (Hard limit)
Hard File Limit
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
unique id of the quota
Soft Capacity Limit (MB)
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Max number of files allowed for the quota target
Threshold (MB)
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
Number of files currently used
User/Group Target
Implemented
HTTPS
user/group target this quota refers to
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
comma separated list of IP addresses on which this share is exposed
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
enum for share protocol
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Permissions for this particular share
Storage
Cluster
Not Available
HTTPS
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Partner Node UUID
Implemented
HTTPS
HA pair's UUID
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
Version
Implemented
HTTPS
software version
ManagementIp Addresses
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Reserved Capacity
Implemented
HTTPS
Gap
HTTPS
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Uses FlashPools
Implemented
HTTPS
Virtual
Implemented
HTTPS
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
UUID
Implemented
HTTPS
Implemented
HTTPS
Comment
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Guid Key
Implemented
HTTPS
IP Space
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Protocols
Implemented
HTTPS
State
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Volume Name
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
DiskGroup
Implemented
HTTPS
Disk Group Type
Disk Size
Implemented
HTTPS
Disk Speed
Implemented
HTTPS
Disk Type
Not Available
HTTPS
Junction Path
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
Qos Limit Raw
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Name of the backend lun
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
QOS Wait
Implemented
HTTPS
Total qos wait time
Server ID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Quota Soft Limit
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Cache Hit Ratio Total
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
Failed Fans
Implemented
HTTPS
Failed Power Units
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Optimal Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Reserved Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
NetApp ONTAP API
HTTP/HTTPS
HTTP/HTTPS
80/443
true
true
true
true
NetApp ONTAP Select
Models:
  • AFF-A150
  • AFF-A1K
  • AFF-A20
  • AFF-A200
  • AFF-A220
  • AFF-A250
  • AFF-A30
  • AFF-A300
  • AFF-A320
  • AFF-A400
  • AFF-A50
  • AFF-A70
  • AFF-A700
  • AFF-A700s
  • AFF-A800
  • AFF-A90
  • AFF-A900
  • AFF-C190
  • AFF-C250
  • AFF-C30
  • AFF-C400
  • AFF-C60
  • AFF-C80
  • AFF-C800
  • AFF8020
  • AFF8040
  • AFF8080
  • ASA-A250
  • ASA-A400
  • ASA-A800
  • ASA-A900
  • ASA-C250
  • ASA-C800
  • CDvM200
  • DG5000
  • DG5200
  • DM5000H
  • FAS2520
  • FAS2552
  • FAS2554
  • FAS2620
  • FAS2650
  • FAS2720
  • FAS2750
  • FAS2820
  • FAS3270
  • FAS50
  • FAS500f
  • FAS70
  • FAS8020
  • FAS8040
  • FAS8060
  • FAS8080
  • FAS8200
  • FAS8300
  • FAS8700
  • FAS90
  • FAS9000
  • FAS9500
  • FASDvM300
  • SIMBOX
Firmware versions:
foundation
Capability
Active
Implemented
HTTPS
Licensed
Implemented
HTTPS
Type
Gap
HTTPS
Used
Implemented
HTTPS
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
Disk Group
Capacity
Implemented
HTTPS
DiskGroup Id
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
Is Oplocks Enabled
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Security Info
Auth Type
Implemented
HTTPS
Inbound Keyword
Implemented
HTTPS
Initiator Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Outbound Keyword
Implemented
HTTPS
Target Node Name
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Target Session Id
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Is compression enabled on the storage pool
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Gap
HTTPS
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Gap
HTTPS
Snapshot Count
Implemented
HTTPS
Implemented
HTTPS
Space Guarantee
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Virtual Storage
Implemented
HTTPS
Adaptive Qos Policy
Implemented
HTTPS
Comment
Gap
HTTPS
Group Id
Implemented
HTTPS
Group Name
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
Qos Limit Raw
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Technology
Implemented
HTTPS
QTree
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
GuidKey 3
Implemented
HTTPS
Name
Implemented
HTTPS
Oplocks
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Security Style
Implemented
HTTPS
Status
Implemented
HTTPS
Type
Gap
HTTPS
Quota
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
GuidKey 3
Implemented
HTTPS
Implemented
HTTPS
Hard File Limit
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Threshold (MB)
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
User/Group Target
Implemented
HTTPS
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Cluster
Not Available
HTTPS
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Partner Node UUID
Implemented
HTTPS
HA pair's UUID
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Reserved Capacity
Implemented
HTTPS
Gap
HTTPS
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Uses FlashPools
Implemented
HTTPS
indicate if this storagepool uses Flash Pools(NetApp specific)
Virtual
Implemented
HTTPS
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
UUID
Implemented
HTTPS
Implemented
HTTPS
Comment
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Guid Key
Implemented
HTTPS
IP Space
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Protocols
Implemented
HTTPS
State
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Volume Name
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
DiskGroup
Implemented
HTTPS
Disk Group Type
Disk Size
Implemented
HTTPS
Disk Speed
Implemented
HTTPS
Disk Type
Not Available
HTTPS
Junction Path
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
Qos Limit Raw
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
QOS Wait
Implemented
HTTPS
Total qos wait time
Server ID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Quota Soft Limit
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
Failed Fans
Implemented
HTTPS
Failed Power Units
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Optimal Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Reserved Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
NetApp ONTAP API
HTTP/HTTPS
HTTP/HTTPS
80/443
true
true
true
true
NetApp E-Series
Models and versions supported by this data collector:
Models
2700
2704
2800B
2804
2806
3000
4000
5486
5488
5600
5700
5700B
7999
Firmware versions:
  • 08.80.00.00
  • 2.10.1.0
  • 32.10.59.63
  • 58.90.55.79
  • 62.10.0.33
  • 7.84.46.0
  • 8.20.16.0
  • 8.20.27.0
  • 8.20.30.0
  • 8.25.14.0
  • 8.25.6.0
  • 8.25.9.0
  • 8.30.20.0
  • 8.40.10.1
  • 8.40.20.0
  • 8.40.40.0
  • 8.40.50.0
  • 8.40.60.1
  • 8.40.60.2
  • 8.42.20.0
  • 8.51.0.0
  • 8.52.0.0
  • 8.52.0.1
  • 8.53.0.4
  • 8.62.0.2
  • 8.63.0.2
  • 8.70.0.2
  • 8.70.0.3
  • 8.71.2.0
  • 8.71.3.0
  • 8.72.0.0
  • 8.72.1.0
  • 8.73.0.0
  • 8.74.2.0
  • 8.74.3.0
  • 8.75.0.1
  • 8.75.1.0
  • 8.80.0.0
  • 8.80.1.0
  • 8.81.0.2
  • 8.81.0.3
  • 8.81.1.0
  • 8.81.2.0
  • 8.81.3.0
  • 8.81.7.0
  • 8.90.12.0
  • 8.90.15.0
  • 8.90.16.0
  • 8.90.6.0
  • 8.90.9.0
  • 82.0.56.24
  • 82.0.57.37
  • 82.10.59.53
  • 88.81.54.43
  • 92.0.13.0
  • 92.0.16.0
  • 92.0.19.0
  • 92.10.0.0
  • 92.10.4.0
  • 98.81.9.0
  • 98.90.10.0
  • 98.90.28.0
  • 98.90.33.0
  • 98.90.57.0
  • 98.90.62.0
  • 98.90.9.0
Products supported by this data collector:
Product Category Feature/Attribute Status Protocol Used Additional Information
foundation
Disk
Capacity (GB)
Implemented
RMI
Used capacity
Disk Id
Implemented
RMI
Group
Implemented
RMI
Location
Gap
RMI
Model
Implemented
RMI
Name
Implemented
RMI
Role
Implemented
RMI
Role Enum
Implemented
RMI
enum for disk role
Serial Number
Implemented
RMI
Speed
Implemented
RMI
Speed of disk (RPM)
Status
Implemented
RMI
Status Enum
Implemented
RMI
Type
Gap
RMI
Type Enum
Implemented
RMI
enum for disk type
Vendor
Implemented
RMI
Vendor Id
Implemented
RMI
IP
Implemented
RMI
Listening Port
Implemented
RMI
Nic
Implemented
RMI
OID
Implemented
RMI
OID
Implemented
RMI
Portal Group Name
Implemented
RMI
Portal Group Tag
Implemented
RMI
ISCSI Node
Host Aliases
Implemented
RMI
Node Name
Implemented
RMI
OID
Implemented
RMI
Type
Gap
RMI
ISCSI Session
Initiator Ips
Implemented
RMI
Initiator OID
Implemented
RMI
Max Connections
Implemented
RMI
Implemented
RMI
OID
Implemented
RMI
Portal Group OID
Implemented
RMI
Security
Implemented
RMI
Target Session Id
Implemented
RMI
Info
DataSource Name
Implemented
RMI
Info
Date
Implemented
RMI
Originator ID
Implemented
RMI
Storage
Display IP
Implemented
RMI
Failed Raw Capacity
Implemented
RMI
Family
Implemented
RMI
IP
Implemented
RMI
Manufacturer
Implemented
RMI
Microcode Version
Implemented
RMI
Model
Implemented
RMI
Name
Implemented
RMI
Total Raw Capacity
Implemented
RMI
Serial Number
Implemented
RMI
Spare Raw Capacity
Implemented
RMI
Virtual
Implemented
RMI
Storage Node
Cache Size
Implemented
RMI
Memory Size
Gap
RMI
device memory in MB
Model
Implemented
RMI
Name
Implemented
RMI
Serial Number
Implemented
RMI
State
Implemented
RMI
UUID
Implemented
RMI
Up Time
Implemented
RMI
Storage Pool
Gap
RMI
Data Used Capacity
Implemented
RMI
Dedupe Enabled
Implemented
RMI
Implemented
RMI
Name
Implemented
RMI
Gap
RMI
Other UsedCapacity (MB)
Implemented
RMI
Any capacity other than data and snapshot
Implemented
RMI
Raid Group
Implemented
RMI
Raw to Usable Ratio
Implemented
RMI
Redundancy
Implemented
RMI
Redundancy level
Status
Implemented
RMI
Storage Pool Id
Implemented
RMI
Thin Provisioning Supported
Implemented
RMI
Total Allocated Capacity
Implemented
RMI
Total Used Capacity
Implemented
RMI
Type
Gap
RMI
Virtual
Implemented
RMI
Volume
Capacity
Implemented
RMI
Disk Type
Not Available
RMI
Name
Implemented
RMI
Total Raw Capacity
Implemented
RMI
Redundancy
Implemented
RMI
Redundancy level
Storage Pool Id
Implemented
RMI
Thin Provisioned
Implemented
RMI
Type
Gap
RMI
UUID
Implemented
RMI
Used Capacity
Implemented
RMI
Virtual
Implemented
RMI
Written Capacity
Implemented
RMI
Total capacity written to this volume by a Host in MB
Volume Map
LUN
Implemented
RMI
Storage Port
Implemented
RMI
Type
Gap
RMI
Volume Mask
Initiator
Implemented
RMI
Storage Port
Implemented
RMI
Type
Gap
RMI
performance
Disk
IOPs Read
Implemented
RMI
IOPs Total
Implemented
RMI
IOPs Write
Implemented
RMI
Key
Implemented
RMI
Server ID
Implemented
RMI
Throughput Read
Implemented
RMI
Throughput Total
Implemented
RMI
Throughput Write
Implemented
RMI
Read Utilization
Implemented
RMI
Utilization Total
Implemented
RMI
Utilization Write
Implemented
RMI
Storage
Cache Hit Ratio Read
Implemented
RMI
Implemented
RMI
Cache Hit Ratio Write
Implemented
RMI
Failed Raw Capacity
Implemented
RMI
Raw Capacity
Implemented
RMI
Spare Raw Capacity
Implemented
RMI
Implemented
RMI
IOPs other
Implemented
RMI
IOPs Read
Implemented
RMI
IOPs Total
Implemented
RMI
IOPs Write
Implemented
RMI
Key
Implemented
RMI
Latency Read
Implemented
RMI
Latency Total
Implemented
RMI
Latency Write
Implemented
RMI
Server ID
Implemented
RMI
Throughput Read
Implemented
RMI
Throughput Total
Implemented
RMI
Throughput Write
Implemented
RMI
Storage Node
Implemented
RMI
IOPs Read
Implemented
RMI
IOPs Total
Implemented
RMI
IOPs Write
Implemented
RMI
Key
Implemented
RMI
Latency Read
Implemented
RMI
Latency Total
Implemented
RMI
Latency Write
Implemented
RMI
Server ID
Implemented
RMI
Throughput Read
Implemented
RMI
Throughput Total
Implemented
RMI
Throughput Write
Implemented
RMI
StoragePool Disk
Implemented
RMI
Raw Capacity
Implemented
RMI
Total Capacity
Implemented
RMI
Used Capacity
Implemented
RMI
Implemented
RMI
Capacity Used Ratio
Implemented
RMI
Total Data Capacity
Implemented
RMI
Data Used Capacity
Implemented
RMI
IOPs Read
Implemented
RMI
IOPs Total
Implemented
RMI
IOPs Write
Implemented
RMI
Implemented
RMI
Other Used Capacity
Implemented
RMI
Throughput Read
Implemented
RMI
Throughput Total
Implemented
RMI
Throughput Write
Implemented
RMI
Read Utilization
Implemented
RMI
Utilization Total
Implemented
RMI
Utilization Write
Implemented
RMI
Volume
Implemented
RMI
Implemented
RMI
Implemented
RMI
Raw Capacity
Implemented
RMI
Total Capacity
Implemented
RMI
Used Capacity
Implemented
RMI
Written Capacity
Implemented
RMI
Capacity Used Ratio
Implemented
RMI
CapacityRatio Written
Implemented
RMI
IOPs Read
Implemented
RMI
IOPs Total
Implemented
RMI
IOPs Write
Implemented
RMI
Key
Implemented
RMI
Latency Read
Implemented
RMI
Latency Total
Implemented
RMI
Latency Write
Implemented
RMI
Server ID
Implemented
RMI
Throughput Read
Implemented
RMI
Throughput Total
Implemented
RMI
Throughput Write
Implemented
RMI
SANtricity API
RMI
TCP
true
true
false
false
NetApp E-Series REST
Models Firmware versions
2800B
2806
3000
4000
5700
EF570
02.10.01.00
08.53.00.04
08.53.00.09
08.62.00.02
08.70.00.03
08.71.02.00
08.72.00.00
08.72.01.00
08.73.00.00
08.74.02.00
08.74.03.00
08.75.00.01
08.75.01.00
08.80.00.00
08.81.00.02
08.81.00.03
08.81.01.00
08.81.02.00
08.81.03.00
08.81.07.00
08.90.04.00
08.90.06.00
08.90.09.00
08.90.12.00
08.90.15.00
08.90.16.00
58.90.55.79
82.00.56.24
82.00.57.37
82.10.59.53
88.81.54.43
92.00.13.00
92.00.19.00
92.10.00.00
92.10.04.00
98.81.09.00
98.90.09.00
98.90.33.00
98.90.57.00
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
Vendor Id
Implemented
HTTPS
Encrypted
Implemented
HTTPS
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Target Session Id
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Raw capacity of spare disks (sum of all disks that are spare)
Virtual
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
device cache size in MB
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
Storage Pool
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Is dedupe enabled on the storage pool
Implemented
HTTPS
Name
Implemented
HTTPS
Gap
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
ratio to convert from usable capacity to raw capacity
Redundancy
Implemented
HTTPS
Redundancy level
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Whether this internal volume supports thin provisioning for the volume layer on top of it
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Total capacity in MB
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
Disk Type
Not Available
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
Number of read IOPs on the disk
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Average disk total rate (read and write across all disks) in MB/s
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Storage
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Reported as a time series
Capacity Used Ratio
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Implemented
HTTPS
Other Used Capacity
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Volume
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Management APIs used by this data collector:
API Protocol Used Transport layer protocol used Incoming ports used Outgoing ports used Supports authentication Requires only 'Read-only' credentials Supports Encryption Firewall friendly (static ports)
NetApp E-Series REST API
HTTPS
HTTPS
443
true
true
true
true
NetApp Cloud Volumes ONTAP REST
Note Models, firmware, API versions, and product capabilities are pooled across variants that use this shared collector implementation.
Models:
  • AFF-A150
  • AFF-A1K
  • AFF-A20
  • AFF-A220
  • AFF-A250
  • AFF-A30
  • AFF-A300
  • AFF-A400
  • AFF-A50
  • AFF-A70
  • AFF-A700
  • AFF-A800
  • AFF-A90
  • AFF-A900
  • AFF-C190
  • AFF-C250
  • AFF-C30
  • AFF-C400
  • AFF-C60
  • AFF-C80
  • AFF-C800
  • ASA-A250
  • ASA-A800
  • ASA-A900
  • ASA-C250
  • ASA-C800
  • CDvM200
  • FAS2720
  • FAS2750
  • FAS2820
  • FAS50
  • FAS500f
  • FAS70
  • FAS8200
  • FAS8300
  • FAS8700
  • FAS90
  • FAS9000
  • FAS9500
  • FASDvM300
  • SIMBOX
Firmware versions:
  • NetApp Release 9.14.1P10: Thu Nov 28 12:32:16 UTC 2024
  • NetApp Release 9.14.1P12: Tue Mar 25 23:16:26 UTC 2025
  • NetApp Release 9.14.1P14: Sun Aug 24 04:57:05 UTC 2025
  • NetApp Release 9.14.1P18HF1: Sat Oct 24 09:42:51 UTC 2026
  • NetApp Release 9.14.1P1: Thu Feb 15 00:45:21 UTC 2024
  • NetApp Release 9.14.1P6: Tue Jun 18 16:11:44 UTC 2024
  • NetApp Release 9.15.1: Thu Jul 04 07:17:54 UTC 2024
  • NetApp Release 9.15.1P10: Thu Apr 17 14:04:43 UTC 2025
  • NetApp Release 9.15.1P11: Wed May 21 22:53:05 UTC 2025
  • NetApp Release 9.15.1P12: Fri Jun 20 16:04:19 UTC 2025
  • NetApp Release 9.15.1P13: Tue Jul 15 14:07:45 UTC 2025
  • NetApp Release 9.15.1P14: Tue Aug 05 15:53:54 UTC 2025
  • NetApp Release 9.15.1P15: Sun Oct 05 06:25:31 UTC 2025
  • NetApp Release 9.15.1P16: Sat Nov 29 23:46:11 UTC 2025
  • NetApp Release 9.15.1P17: Tue Feb 10 12:35:50 UTC 2026
  • NetApp Release 9.15.1P19: Sat May 09 17:13:04 UTC 2026
  • NetApp Release 9.15.1P20: Thu Aug 20 10:17:54 UTC 2026
  • NetApp Release 9.15.1P20HF1: Fri Oct 23 21:22:11 UTC 2026
  • NetApp Release 9.15.1P3: Wed Sep 25 22:33:44 UTC 2024
  • NetApp Release 9.15.1P6: Wed Dec 04 01:42:39 UTC 2024
  • NetApp Release 9.15.1P7: Sat Jan 18 21:34:02 UTC 2025
  • NetApp Release 9.15.1P8: Fri Mar 07 22:41:00 UTC 2025
  • NetApp Release 9.16.1: Sat Jan 18 19:31:15 UTC 2025
  • NetApp Release 9.16.1P10: Thu Nov 27 17:12:10 UTC 2025
  • NetApp Release 9.16.1P11: Thu Jan 15 11:21:38 UTC 2026
  • NetApp Release 9.16.1P12: Wed Mar 11 12:37:44 UTC 2026
  • NetApp Release 9.16.1P12D1: Fri May 15 20:58:40 UTC 2026
  • NetApp Release 9.16.1P13: Fri May 08 03:41:42 UTC 2026
  • NetApp Release 9.16.1P14: Thu Jul 09 16:46:59 UTC 2026
  • NetApp Release 9.16.1P15: Fri Aug 14 04:40:34 UTC 2026
  • NetApp Release 9.16.1P16: Wed Sep 30 17:34:28 UTC 2026
  • NetApp Release 9.16.1P16HF1: Fri Oct 23 13:26:11 UTC 2026
  • NetApp Release 9.16.1P16HF2: Sun Nov 01 17:22:33 UTC 2026
  • NetApp Release 9.16.1P1: Fri Feb 14 03:53:50 UTC 2025
  • NetApp Release 9.16.1P2: Wed Mar 19 10:28:11 UTC 2025
  • NetApp Release 9.16.1P3: Thu Apr 24 02:50:10 UTC 2025
  • NetApp Release 9.16.1P5: Sat Jun 21 02:06:33 UTC 2025
  • NetApp Release 9.16.1P6: Wed Jul 16 03:10:07 UTC 2025
  • NetApp Release 9.16.1P7: Thu Aug 21 10:29:10 UTC 2025
  • NetApp Release 9.16.1P8: Sat Oct 04 03:23:15 UTC 2025
  • NetApp Release 9.16.1P9: Fri Nov 07 08:49:09 UTC 2025
  • NetApp Release 9.17.1: Fri Sep 05 00:50:54 UTC 2025
  • NetApp Release 9.17.1P10: Tue Jul 21 21:51:01 UTC 2026
  • NetApp Release 9.17.1P11: Thu Aug 20 00:43:57 UTC 2026
  • NetApp Release 9.17.1P11D2: Mon Sep 14 21:18:54 UTC 2026
  • NetApp Release 9.17.1P11HF1: Fri Oct 23 16:18:54 UTC 2026
  • NetApp Release 9.17.1P12: Fri Oct 30 17:25:01 UTC 2026
  • NetApp Release 9.17.1P1: Sat Oct 04 06:37:53 UTC 2025
  • NetApp Release 9.17.1P2: Fri Nov 07 09:39:01 UTC 2025
  • NetApp Release 9.17.1P3: Sun Dec 07 04:46:28 UTC 2025
  • NetApp Release 9.17.1P4: Thu Jan 15 22:33:51 UTC 2026
  • NetApp Release 9.17.1P5: Wed Feb 18 10:54:36 UTC 2026
  • NetApp Release 9.17.1P6: Wed Mar 25 15:38:10 UTC 2026
  • NetApp Release 9.17.1P7: Mon Apr 20 13:57:24 UTC 2026
  • NetApp Release 9.17.1P8: Sun May 17 22:59:03 UTC 2026
  • NetApp Release 9.17.1P9: Wed Jun 24 13:09:36 UTC 2026
  • NetApp Release 9.17.1RC1: Fri Jul 18 12:39:11 UTC 2025
  • NetApp Release 9.18.1: Thu Jan 29 07:43:55 UTC 2026
  • NetApp Release 9.18.1P1: Thu Mar 05 07:06:39 UTC 2026
  • NetApp Release 9.18.1P2: Sun Mar 29 12:49:32 UTC 2026
  • NetApp Release 9.18.1P3: Thu May 07 19:01:14 UTC 2026
  • NetApp Release 9.18.1P4: Thu Jun 04 11:38:00 UTC 2026
  • NetApp Release 9.18.1P5: Thu Jul 09 23:05:16 UTC 2026
  • NetApp Release 9.18.1P6: Fri Aug 07 23:43:59 UTC 2026
  • NetApp Release 9.18.1P7: Thu Sep 03 20:55:20 UTC 2026
  • NetApp Release 9.18.1P8: Sat Oct 10 06:34:15 UTC 2026
  • NetApp Release 9.18.1P8HF1: Fri Oct 23 20:43:35 UTC 2026
  • NetApp Release 9.19.1: Sat Jul 18 20:33:10 UTC 2026
  • NetApp Release 9.19.1P2: Wed Aug 19 19:38:56 UTC 2026
  • NetApp Release 9.19.1P3: Thu Sep 24 08:36:11 UTC 2026
  • NetApp Release 9.19.1P3HF1: Fri Oct 23 18:44:28 UTC 2026
  • NetApp Release 9.19.1P4: Sat Oct 24 10:13:48 UTC 2026
  • NetApp Release 9.19.1RC1: Sat May 02 12:38:22 UTC 2026
  • NetApp Release 9.19.1RC1D2: Sat May 30 08:35:20 UTC 2026
  • NetApp Release 9.19.1X43: Sat Jul 18 20:33:10 UTC 2026
  • NetApp Release 9.20.1RC1X11: Mon Sep 28 13:47:02 UTC 2026
  • NetApp Release 9.20.1RC1X15: Thu Oct 29 14:51:09 UTC 2026
  • NetApp Release 9.20.1RC1X9: Wed Sep 16 13:58:14 UTC 2026
  • NetApp Release Cloudstream__9.16.1: Sat Jan 18 14:32:15 UTC 2025
  • NetApp Release Cloudstream__9.16.1: Sun Oct 19 07:41:54 UTC 2025
  • NetApp Release Cloudstream__9.16.1: Wed Apr 23 22:03:30 UTC 2025
  • NetApp Release Skilletdonut__9.19.1: Sat Jul 18 13:42:28 UTC 2026
  • NetApp Release Skilletdonut__9.19.1: Thu Apr 30 07:48:20 UTC 2026
  • NetApp Release Tropicallightning__9.18.1: Fri Aug 07 20:52:40 UTC 2026
  • NetApp Release Wookeyjack__9.21.1: Mon Sep 21 06:55:54 UTC 2026
foundation
Capability
Active
Implemented
HTTPS
Licensed
Implemented
HTTPS
Type
Gap
HTTPS
Used
Implemented
HTTPS
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Security Info
Auth Type
Implemented
HTTPS
Inbound Keyword
Implemented
HTTPS
Initiator Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Outbound Keyword
Implemented
HTTPS
Target Node Name
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Initiator Session Id
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Target Session Id
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Gap
HTTPS
Snapshot Count
Implemented
HTTPS
Number of snapshots on the internal volumes
Implemented
HTTPS
Space Guarantee
Implemented
HTTPS
Space Guatantee policy (file, volume or none)
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Total Used Capacity (MB)
Implemented
HTTPS
place holder for the used capacity as read from the device
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Virtual Storage
Implemented
HTTPS
Owning virtual storage (vfiler)
Adaptive Qos Policy
Implemented
HTTPS
Comment
Gap
HTTPS
state: free text comment describing the svm
Group Id
Implemented
HTTPS
Group Name
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Implemented
HTTPS
Source Internal Volume
Implemented
HTTPS
Target Internal Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Security Style
Implemented
HTTPS
Security style of the directory: unix, ntfs, or mixed
Status
Implemented
HTTPS
Type
Gap
HTTPS
QoS - Policy
Implemented
HTTPS
Quota
Implemented
HTTPS
Hard File Limit
Implemented
HTTPS
max number of files allowed for the quota target
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Threshold (MB)
Implemented
HTTPS
Disk space threshold, for the quota target
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
User/Group Target
Implemented
HTTPS
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Cluster
Not Available
HTTPS
Cpu Count
Implemented
HTTPS
Cpu Count of the storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
Is this a storage virtualization device?
UUID
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Partner Node UUID
Implemented
HTTPS
HA pair's UUID
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Data Allocated Capacity
Gap
HTTPS
capacity allocated for data
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
ratio of dedupe savings in percentage
Implemented
HTTPS
Name
Implemented
HTTPS
Physical Disk Capacity (MB)
Implemented
HTTPS
used as raw capacity for storage pool
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Snapshot Allocated Capacity
Gap
HTTPS
Allocated capacity of snapshots in MB
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Uses FlashPools
Implemented
HTTPS
Virtual
Implemented
HTTPS
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
UUID
Implemented
HTTPS
Implemented
HTTPS
Comment
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Guid Key
Implemented
HTTPS
IP Space
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Protocols
Implemented
HTTPS
State
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Volume Name
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
Snapshot Used capacity in MB
DiskGroup
Implemented
HTTPS
Disk Group Type
Disk Size
Implemented
HTTPS
comma seperated list of disk sizes (GB)
Disk Speed
Implemented
HTTPS
comma seperated list of disk speeds (rpm)
Disk Type
Not Available
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Total raw capacity (sum of all disks on the array)
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Internal Volume
Implemented
HTTPS
Cache Utilization Total
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
QOS Wait
Implemented
HTTPS
Total qos wait time
Server ID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Capacity quota hard limit
Quota Soft Limit
Implemented
HTTPS
Capacity Quota soft Limit
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Quota Capacity
Implemented
HTTPS
Physical used quota capacity
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Implemented
HTTPS
Total Disk Read Replaced
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
Failed Fans
Implemented
HTTPS
Failed Power Units
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Optimal Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Compression Savings
Implemented
HTTPS
Compression Savings Space
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
deduplicationSavingsPercent.total
Implemented
HTTPS
Deduplication Savings Space
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Object Store Space Used
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Partial Blocked Ratio
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
NetApp ONTAP REST API
HTTPS
HTTPS
443
true
true
true
true
NetApp ONTAP REST Data Management Software
Models:
  • AFF-A150
  • AFF-A1K
  • AFF-A20
  • AFF-A220
  • AFF-A250
  • AFF-A30
  • AFF-A300
  • AFF-A400
  • AFF-A50
  • AFF-A70
  • AFF-A700
  • AFF-A800
  • AFF-A90
  • AFF-A900
  • AFF-C190
  • AFF-C250
  • AFF-C30
  • AFF-C400
  • AFF-C60
  • AFF-C80
  • AFF-C800
  • ASA-A250
  • ASA-A800
  • ASA-A900
  • ASA-C250
  • ASA-C800
  • CDvM200
  • FAS2720
  • FAS2750
  • FAS2820
  • FAS50
  • FAS500f
  • FAS70
  • FAS8200
  • FAS8300
  • FAS8700
  • FAS90
  • FAS9000
  • FAS9500
  • FASDvM300
  • SIMBOX
Firmware versions:
foundation
Capability
Active
Implemented
HTTPS
Licensed
Implemented
HTTPS
Type
Gap
HTTPS
Used
Implemented
HTTPS
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Uniquely identifies this disk in the array
Group
Implemented
HTTPS
Location
Gap
HTTPS
Where this disk is physically located in the array
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
enum for disk status
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Security Info
Auth Type
Implemented
HTTPS
Inbound Keyword
Implemented
HTTPS
Initiator Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Outbound Keyword
Implemented
HTTPS
Target Node Name
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Target Session Id
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
ratio of compression savings in percentage
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
FlashPool Eligibility
Implemented
HTTPS
Whether the internal volume can participate in hybrid caching
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Gap
HTTPS
Snapshot Count
Implemented
HTTPS
Snapshot Used Capacity
Implemented
HTTPS
Space Guarantee
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Clone Saved Capacity in MB
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Virtual Storage
Implemented
HTTPS
Adaptive Qos Policy
Implemented
HTTPS
Comment
Gap
HTTPS
Group Id
Implemented
HTTPS
Group Name
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Tiering Minimum Cooling Days
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Technology
Implemented
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Security Style
Implemented
HTTPS
Status
Implemented
HTTPS
Type
Gap
HTTPS
QoS - Policy
Implemented
HTTPS
Quota
Implemented
HTTPS
Hard File Limit
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Threshold (MB)
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
User/Group Target
Implemented
HTTPS
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Cluster
Not Available
HTTPS
Whether this storage is a cluster
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Raw capacity of failed disks (sum of all disks that are failed)
Family
Implemented
HTTPS
The storage Family could be Clariion, Symmetrix, et al
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
SupportActive Active
Implemented
HTTPS
Specified if the storage supports active-active configurations
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Partner Node UUID
Implemented
HTTPS
HA pair's UUID
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
free text describing the device state
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
time in milliseconds
Version
Implemented
HTTPS
software version
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Include In Dwh Capacity
Implemented
HTTPS
A way from ACQ to control which storage pools are interesting in DWH Capacity
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
indicates whether this storagePool is a raid group
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Gap
HTTPS
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Uses FlashPools
Implemented
HTTPS
Virtual
Implemented
HTTPS
CompactionSavings Enabled
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage VirtualMachine
Allocated capacity (MB)
Implemented
HTTPS
Comment
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Guid Key
Implemented
HTTPS
Globally Unique Key of the storage virtual machine
IP Space
Implemented
HTTPS
Internal Volume Limit
Implemented
HTTPS
Name
Implemented
HTTPS
Protocols
Implemented
HTTPS
csv of svm enabled protocols (fcp, iscsi, nfs, cifs…​)
State
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
VirtualMachine Internal Volume Ref
Internal Volume Id
Implemented
HTTPS
VirtualMachine StoragePool lRef
Storage Pool Id
Implemented
HTTPS
VirtualMachine Volume Ref
Volume Name
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
DiskGroup
Implemented
HTTPS
Disk Group Type
Disk Size
Implemented
HTTPS
Disk Speed
Implemented
HTTPS
Disk Type
Not Available
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
unique id of the qtree
Total Raw Capacity
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Internal Volume
Implemented
HTTPS
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Clone Saved Capacity Total
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
File System Capacity Logical Used
Implemented
HTTPS
File System Capacity Physical Available
Implemented
HTTPS
File System Capacity Physical Used
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
QOS Wait
Implemented
HTTPS
Total qos wait time
Server ID
Implemented
HTTPS
Snapshot Reserved Capacity
Implemented
HTTPS
Implemented
HTTPS
Snapshot Used Capacity Ratio
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Quota Soft Limit
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Quota Capacity
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
StoragePools Capacity
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
Failed Fans
Implemented
HTTPS
Failed Power Units
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Optimal Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Capacity Provisioned
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Over Commit Capacity Ratio
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
compactionSavingsPercent.total
Implemented
HTTPS
Total Compaction Space
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
HTTPS
HTTPS
443
true
true
true
true
NetApp ONTAP REST Select
Models:
  • AFF-A150
  • AFF-A1K
  • AFF-A20
  • AFF-A220
  • AFF-A250
  • AFF-A30
  • AFF-A300
  • AFF-A400
  • AFF-A50
  • AFF-A70
  • AFF-A700
  • AFF-A800
  • AFF-A90
  • AFF-A900
  • AFF-C190
  • AFF-C250
  • AFF-C30
  • AFF-C400
  • AFF-C60
  • AFF-C80
  • AFF-C800
  • ASA-A250
  • ASA-A800
  • ASA-A900
  • ASA-C250
  • ASA-C800
  • CDvM200
  • FAS2720
  • FAS2750
  • FAS2820
  • FAS50
  • FAS500f
  • FAS70
  • FAS8200
  • FAS8300
  • FAS8700
  • FAS90
  • FAS9000
  • FAS9500
  • FASDvM300
  • SIMBOX
Firmware versions:
foundation
Capability
Active
Implemented
HTTPS
Licensed
Implemented
HTTPS
Type
Gap
HTTPS
Used
Implemented
HTTPS
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume
Is Shared
Implemented
HTTPS
whether this fileShare has any shares associated with it
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Path of the fileShare
Qtree Id
Implemented
HTTPS
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
ISCSI Network Portal
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
ISCSI Network Portal Group
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Security Info
Auth Type
Implemented
HTTPS
Inbound Keyword
Implemented
HTTPS
Initiator Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Outbound Keyword
Implemented
HTTPS
Target Node Name
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Number Of Connections
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Target Session Id
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Protection Type
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Gap
HTTPS
Snapshot Count
Implemented
HTTPS
Implemented
HTTPS
Space Guarantee
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Virtual Storage
Implemented
HTTPS
Adaptive Qos Policy
Implemented
HTTPS
Comment
Gap
HTTPS
Group Id
Implemented
HTTPS
Group Name
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
Qos Limit MBPS
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Implemented
HTTPS
Storage Synchronization
Implemented
HTTPS
Implemented
HTTPS
Technology
Implemented
HTTPS
technology which causes storage efficiency changed
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota HardCapacity Limit (MB)
Implemented
HTTPS
Maximum amount of disk space, allowed for the quota target
Quota SoftCapacity Limit (MB)
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Space in MB currently used
Security Style
Implemented
HTTPS
Status
Implemented
HTTPS
Type
Gap
HTTPS
QoS - Policy
Implemented
HTTPS
Quota
Hard Capacity Limit (MB)
Implemented
HTTPS
max amount of disk space, allowed for the quota target (Hard limit)
Hard File Limit
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
unique id of the quota
Soft Capacity Limit (MB)
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Max number of files allowed for the quota target
Threshold (MB)
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
Number of files currently used
User/Group Target
Implemented
HTTPS
user/group target this quota refers to
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
comma separated list of IP addresses on which this share is exposed
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
enum for share protocol
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Permissions for this particular share
Storage
Cluster
Not Available
HTTPS
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Partner Node UUID
Implemented
HTTPS
HA pair's UUID
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Up Time
Implemented
HTTPS
Version
Implemented
HTTPS
software version
ManagementIp Addresses
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Is compression enabled on the storage pool
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Gap
HTTPS
Implemented
HTTPS
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Uses FlashPools
Implemented
HTTPS
Virtual
Implemented
HTTPS
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
UUID
Implemented
HTTPS
Implemented
HTTPS
Comment
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Guid Key
Implemented
HTTPS
IP Space
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Protocols
Implemented
HTTPS
State
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Volume Name
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
DiskGroup
Implemented
HTTPS
Disk Group Type
Disk Size
Implemented
HTTPS
Disk Speed
Implemented
HTTPS
Disk Type
Not Available
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Name of the backend lun
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Internal Volume
Cache Hit Ratio Total
Implemented
HTTPS
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
QOS Wait
Implemented
HTTPS
Total qos wait time
Server ID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Quota Soft Limit
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Quota Capacity
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
Failed Fans
Implemented
HTTPS
Failed Power Units
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Optimal Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Failed Disks
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Read Utilization
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Utilization Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
HTTPS
HTTPS
443
true
true
true
true
NetApp SolidFire 8.1+
H410S-2
H610S-4
SF19210
SF9605
H410S-0
H410S-2
H610S-1
H610S-2
H610S-4
SF19210
SF38410
SF4805
11.7.0.76
12.3.0.958
12.3.1.103
12.3.1.165
12.3.2.3
12.5.0.897
12.7.0.380
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Group
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Potential Transfer Rate
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Seek Time
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
Encrypted
Implemented
HTTPS
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Host Aliases
Implemented
HTTPS
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Storage
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Serial Number
Implemented
HTTPS
UUID
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Dedupe Savings
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Other Allocated Capacity
Gap
HTTPS
Capacity allocated for other (not data and not snapshot)
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Status
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Mode
Implemented
HTTPS
Mode Enum
Implemented
HTTPS
Source Storage
Implemented
HTTPS
Source Volume
Implemented
HTTPS
State
Implemented
HTTPS
State Enum
Implemented
HTTPS
Target Storage
Implemented
HTTPS
Target Volume
Implemented
HTTPS
Technology
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Replica Source
Implemented
HTTPS
Replica Target
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Account Identifier
Implemented
HTTPS
Account Name
Implemented
HTTPS
Compression Enabled
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Qos Burst IOPS
Implemented
HTTPS
Qos Limit IOPS
Implemented
HTTPS
qos Min IOPS
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Masking Required
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
Storage Node
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Other Total Capacity
Implemented
HTTPS
Other Used Capacity
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
SolidFire REST API
HTTPS
HTTPS
443
true
true
true
true
NetApp StorageGRID (HTTPS)
Models and versions supported by this data collector:
API versions Models Firmware versions
3.4
3.5
4.0
4.1
4.2
4.3
Webscale
11.6.0.7
11.7.0.14
11.7.0.4
11.7.0.6
11.7.0.8
11.8.0.11
11.8.0.13
11.8.0.14
11.8.0.15
11.8.0.3
11.8.0.5
11.8.0.7
11.8.0.8
11.9.0
11.9.0.11
11.9.0.12
11.9.0.13
11.9.0.14
11.9.0.15
11.9.0.3
11.9.0.6
11.9.0.7
11.9.0.9
12.0.0
12.0.0.3
12.0.0.4
12.0.0.6
12.0.0.7
12.0.0.8
12.0.0.9
12.1.0
12.1.0.1
12.1.1
12.2.0
Products supported by this data collector:
Product Category Feature/Attribute Status Protocol Used Additional Information
foundation
Info
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Internal Volume
Dedupe Enabled
Implemented
HTTPS
GuidKey 1
Implemented
HTTPS
GuidKey1 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5.
GuidKey 2
Implemented
HTTPS
GuidKey2 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5.
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Thin Provisioning Supported
Implemented
HTTPS
Total Allocated Capacity
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
Encrypted
Implemented
HTTPS
QTree
GuidKey 1
Implemented
HTTPS
GuidKey 2
Implemented
HTTPS
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Cache Size
Implemented
HTTPS
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
UUID
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Implemented
HTTPS
Node Capacity Utilization Allowed Meta Data in MB
Implemented
HTTPS
Node Capacity Utilization Total in MB
Implemented
HTTPS
Node Capacity Utilization Usable in MB
Implemented
HTTPS
Node Capacity Utilization Used in MB
Implemented
HTTPS
Node Capacity Utilization Used Meta Data in MB
Implemented
HTTPS
Site Name
Implemented
HTTPS
Storage Pool
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
performance
Internal Volume
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
Key
Implemented
Total Objects
Implemented
Server ID
Implemented
Qtree
Key
Implemented
Server ID
Implemented
Storage
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
Implemented
Key
Implemented
Server ID
Implemented
Storage Node
Key
Implemented
Implemented
Implemented
Implemented
Implemented
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
StoragePool Disk
Implemented
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Implemented
Capacity Used Ratio
Implemented
StorageGrid REST API
HTTPS
HTTPS
443
true
false
true
true
Nutanix AHV (Acropolis Hypervisor)
foundation
Data Store
Capacity
Implemented
HTTPS
MOID
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
LUN
Disk Name
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Host OID
Implemented
HTTPS
Number
Implemented
HTTPS
OID
Implemented
HTTPS
TID
Implemented
HTTPS
Volume Uuid
Implemented
HTTPS
Server
Cluster
Implemented
HTTPS
Cluster name
DataCenter Name
Implemented
HTTPS
Host OID
Implemented
HTTPS
MOID
Implemented
HTTPS
OID
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
Virtual Disk
Capacity
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Lun OID
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
VirtualMachine
DataStore OID
Implemented
HTTPS
Host OID
Implemented
HTTPS
IPs
Implemented
HTTPS
MOID
Implemented
HTTPS
Memory
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
OS
Implemented
HTTPS
Power State
Implemented
HTTPS
State Change Time
Implemented
HTTPS
Processors
Implemented
HTTPS
Provisioned Capacity
Implemented
HTTPS
Instance Type
Implemented
HTTPS
UUID
Implemented
HTTPS
VirtualMachine Disk
OID
Implemented
HTTPS
VirtualDisk OID
Implemented
HTTPS
VirtualMachine OID
Implemented
HTTPS
Host
Host Cpu Count
Implemented
HTTPS
Host Cpu Speed
Implemented
HTTPS
Host Installed Memory
Implemented
HTTPS
Host Model
Implemented
HTTPS
Host OS
Implemented
HTTPS
IPs
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
Client Api Name
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
performance
Data Store
Total Capacity
Implemented
HTTPS
Host
Total CPU Utilization
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
diskIops.total
Implemented
HTTPS
Disk IOPs write
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Disk Throughput Read
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
total disk throughput read
Disk Throughput Write
Implemented
HTTPS
IP Throughput Read
Implemented
HTTPS
Throughput total
Implemented
HTTPS
IP throughput total
ipThroughput.write
Implemented
HTTPS
Key
Implemented
HTTPS
Total Memory Utilization
Implemented
HTTPS
Server ID
Implemented
HTTPS
Virtual Disk
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
vm
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
diskIops.total
Implemented
HTTPS
Disk IOPs write
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Implemented
HTTPS
IP Throughput Read
Implemented
HTTPS
Throughput total
Implemented
HTTPS
IP throughput total
ipThroughput.write
Implemented
HTTPS
Key
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Schedule wait time
Implemented
HTTPS
Waiting to be scheduled time in percent
Nutanix Prism Central REST API
HTTPS
HTTPS
9440
true
true
true
true
Nutanix Storage (REST)
Cisco UCS C240-M7SN
NX-3060-G6
NX-8150-G8
XC750-24 CORE
XF3070
6.10.1
6.5.5.7
6.5.6.6
7.0.1.6
7.3.1.9
7.5.1.10
7.6.0.8
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
IP
Implemented
HTTPS
Listening Port
Implemented
HTTPS
Nic
Implemented
HTTPS
OID
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group Name
Implemented
HTTPS
Portal Group Tag
Implemented
HTTPS
ISCSI Node
Node Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
ISCSI Node Map
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
ISCSI Session
Initiator Ips
Implemented
HTTPS
Initiator OID
Implemented
HTTPS
Max Connections
Implemented
HTTPS
Implemented
HTTPS
OID
Implemented
HTTPS
Portal Group OID
Implemented
HTTPS
Security
Implemented
HTTPS
Info
Api Name
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Is dedupe enabled on the storage pool
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
ratio to convert from usable capacity to raw capacity
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Whether this internal volume supports thin provisioning for the volume layer on top of it
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Total capacity in MB
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Technology
Implemented
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Share
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Storage
Cluster
Not Available
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Raw capacity of spare disks (sum of all disks that are spare)
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Memory Size
Gap
HTTPS
device memory in MB
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Pool
Auto Tiering
Implemented
HTTPS
indicates if this storagepool is participating in auto tiering with other pools
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Reserved Capacity
Implemented
HTTPS
Reserved Capacity in MB
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Volume
Capacity
Implemented
HTTPS
Junction Path
Implemented
HTTPS
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Redundancy
Implemented
HTTPS
Redundancy level
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
UUID
Implemented
HTTPS
Volume Map
LUN
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
Volume Mask
Initiator
Implemented
HTTPS
Protocol Controller
Implemented
HTTPS
Storage Port
Implemented
HTTPS
Type
Gap
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
Number of read IOPs on the disk
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Average disk total rate (read and write across all disks) in MB/s
Throughput Write
Implemented
HTTPS
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Reserved Capacity
Implemented
HTTPS
Fractional reserved (included in data allocated capacity)
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Reported as a time series
Capacity Used Ratio
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Volume
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Management APIs used by this data collector:
API Protocol Used Transport layer protocol used Incoming ports used Outgoing ports used Supports authentication Requires only 'Read-only' credentials Supports Encryption Firewall friendly (static ports)
Nutanix REST API
HTTPS
HTTPS
443
true
true
true
true
Oracle Linux Virtualization Manager (REST)
foundation
Data Store
Capacity
Implemented
HTTP/S
MOID
Implemented
HTTP/S
Name
Implemented
HTTP/S
OID
Implemented
HTTP/S
Implemented
HTTP/S
Used Capacity
Implemented
HTTP/S
Virtual Center Ip
Implemented
HTTP/S
NasShare DataStore
DataStore OID
Implemented
HTTP/S
Nas Share OID
Implemented
HTTP/S
OID
Implemented
HTTP/S
NasShare Host
Nas Share OID
Implemented
HTTP/S
Host OID
Implemented
HTTP/S
OID
Implemented
HTTP/S
Read Only
Implemented
HTTP/S
LUN
DataStore OID
Implemented
HTTP/S
Host OID
Implemented
HTTP/S
Number
Implemented
HTTP/S
OID
Implemented
HTTP/S
Volume Uuid
Implemented
HTTP/S
NAS Share
Capacity
Implemented
HTTP/S
Allocated capacity in MB
Filer Ip
Implemented
HTTP/S
Filer Name
Implemented
HTTP/S
OID
Implemented
HTTP/S
Share Path
Implemented
HTTP/S
For a HvNasShare to be matched to a Share
Type
Gap
HTTP/S
Path
Active
Implemented
HTTP/S
Lun OID
Implemented
HTTP/S
Host Port WWPN
Implemented
HTTP/S
OID
Implemented
HTTP/S
Storage Port WWPN
Implemented
HTTP/S
Type
Gap
HTTP/S
Server
Cluster
Implemented
HTTP/S
Cluster name
DataCenter Name
Implemented
HTTP/S
Host OID
Implemented
HTTP/S
MOID
Implemented
HTTP/S
OID
Implemented
HTTP/S
Virtual Center Ip
Implemented
HTTP/S
Virtual Disk
Capacity
Implemented
HTTP/S
DataStore OID
Implemented
HTTP/S
Name
Implemented
HTTP/S
OID
Implemented
HTTP/S
Type
Gap
HTTP/S
Used Capacity
Implemented
HTTP/S
VirtualMachine
Dns Name
Implemented
HTTP/S
Guest State
Implemented
HTTP/S
DataStore OID
Implemented
HTTP/S
Host OID
Implemented
HTTP/S
MOID
Implemented
HTTP/S
Memory
Implemented
HTTP/S
Name
Implemented
HTTP/S
OID
Implemented
HTTP/S
OS
Implemented
HTTP/S
Power State
Implemented
HTTP/S
State Change Time
Implemented
HTTP/S
Processors
Implemented
HTTP/S
Implemented
HTTP/S
Used Capacity
Implemented
HTTP/S
Launch Time
Implemented
HTTP/S
UUID
Implemented
HTTP/S
VirtualMachine Disk
OID
Implemented
HTTP/S
VirtualDisk OID
Implemented
HTTP/S
VirtualMachine OID
Implemented
HTTP/S
Host
Host Cpu Count
Implemented
HTTP/S
Host Cpu Speed
Implemented
HTTP/S
Implemented
HTTP/S
Host Model
Implemented
HTTP/S
NIC count
Implemented
HTTP/S
NIC speed
Implemented
HTTP/S
IPs
Implemented
HTTP/S
Manufacturer
Implemented
HTTP/S
Name
Implemented
HTTP/S
OID
Implemented
HTTP/S
Platform Type
Implemented
HTTP/S
ISCSI Node
Node Name
Implemented
HTTP/S
OID
Implemented
HTTP/S
Type
Gap
HTTP/S
Info
DataSource Name
Implemented
HTTP/S
Info
Date
Implemented
HTTP/S
Originator ID
Implemented
HTTP/S
performance
Host
Implemented
HTTP/S
IOPs Read
Implemented
HTTP/S
diskIops.total
Implemented
HTTP/S
Disk IOPs write
Implemented
HTTP/S
Latency Read
Implemented
HTTP/S
Latency Total
Implemented
HTTP/S
Latency Write
Implemented
HTTP/S
Implemented
HTTP/S
Throughput Read
Implemented
HTTP/S
Implemented
HTTP/S
Key
Implemented
HTTP/S
Implemented
HTTP/S
Server ID
Implemented
HTTP/S
Virtual Disk
Total Capacity
Implemented
HTTP/S
Used Capacity
Implemented
HTTP/S
Capacity Used Ratio
Implemented
HTTP/S
IOPs Read
Implemented
HTTP/S
IOPs Total
Implemented
HTTP/S
IOPs Write
Implemented
HTTP/S
Key
Implemented
HTTP/S
Latency Read
Implemented
HTTP/S
Latency Total
Implemented
HTTP/S
Latency Write
Implemented
HTTP/S
Server ID
Implemented
HTTP/S
Throughput Read
Implemented
HTTP/S
Throughput Total
Implemented
HTTP/S
Throughput Write
Implemented
HTTP/S
vm
Total Capacity
Implemented
HTTP/S
Used Capacity
Implemented
HTTP/S
Capacity Used Ratio
Implemented
HTTP/S
IOPs Read
Implemented
HTTP/S
diskIops.total
Implemented
HTTP/S
Disk IOPs write
Implemented
HTTP/S
Latency Read
Implemented
HTTP/S
Latency Total
Implemented
HTTP/S
Latency Write
Implemented
HTTP/S
Implemented
HTTP/S
Throughput Read
Implemented
HTTP/S
Implemented
HTTP/S
Key
Implemented
HTTP/S
Implemented
HTTP/S
Server ID
Implemented
HTTP/S
oVirt REST API v4
HTTPS
HTTPS
443
true
true
true
true
Oracle ZFS (HTTPS)
Sun Storage 7000
Sun ZFS Storage 7120
Sun ZFS Storage 7330
Sun ZFS Storage 7350
Sun ZFS Storage 7370
Sun ZFS Storage 7390
Sun ZFS Storage 7420
1-1.1
1-1.2
1-1.3
1-1.34
1-1.4
1-2.68.5603.1
1-2.92.5919.1
2013.06.05.7.24
2013.06.05.7.29
2013.06.05.8.0
2013.06.05.8.44
2013.06.05.8.50
2013.06.05.8.56
2013.06.05.8.6
2013.06.05.8.65
2013.06.05.8.68
2013.06.05.8.72
2013.06.05.8.74
2013.06.05.8.76
2013.06.05.8.83
2013.06.05.8.87
2013.06.05.8.89
2013.06.05.8.90
2013.06.05.8.91
2013.06.05.8.92
2026.04.20.8.93
2026.04.20.8.94
foundation
Disk
Capacity (GB)
Implemented
HTTP/S
Used capacity
Disk Id
Implemented
HTTP/S
Location
Gap
HTTP/S
Model
Implemented
HTTP/S
Name
Implemented
HTTP/S
Role
Implemented
HTTP/S
Role Enum
Implemented
HTTP/S
enum for disk role
Serial Number
Implemented
HTTP/S
Speed
Implemented
HTTP/S
Speed of disk (RPM)
Status
Implemented
HTTP/S
Status Enum
Implemented
HTTP/S
Type
Gap
HTTP/S
Type Enum
Implemented
HTTP/S
enum for disk type
Vendor
Implemented
HTTP/S
File Share
Is InternalVolume
Implemented
HTTP/S
Is Shared
Implemented
HTTP/S
Name
Implemented
HTTP/S
Path
Implemented
HTTP/S
Qtree Id
Implemented
HTTP/S
Info
DataSource Name
Implemented
HTTP/S
Info
Date
Implemented
HTTP/S
Originator ID
Implemented
HTTP/S
Originator Key
Implemented
HTTP/S
Internal Volume
Compression Enabled
Implemented
HTTP/S
Compression Savings
Implemented
HTTP/S
Data Used Capacity
Implemented
HTTP/S
Dedupe Enabled
Implemented
HTTP/S
Dedupe Savings
Implemented
HTTP/S
Internal Volume Id
Implemented
HTTP/S
Name
Implemented
HTTP/S
Other UsedCapacity (MB)
Implemented
HTTP/S
Any capacity other than data and snapshot
Protection Type
Implemented
HTTP/S
Raw to Usable Ratio
Implemented
HTTP/S
Implemented
HTTP/S
Storage Pool Id
Implemented
HTTP/S
Thin Provisioned
Implemented
HTTP/S
Implemented
HTTP/S
Implemented
HTTP/S
Total Used Capacity
Implemented
HTTP/S
Total Used Capacity (MB)
Implemented
HTTP/S
place holder for the used capacity as read from the device
Type
Gap
HTTP/S
QTree
Name
Implemented
HTTP/S
Qtree Id
Implemented
HTTP/S
Quota UsedCapacity
Implemented
HTTP/S
Type
Gap
HTTP/S
Quota
Internal Volume Id
Implemented
HTTP/S
Qtree Id
Implemented
HTTP/S
Quota Id
Implemented
HTTP/S
Implemented
HTTP/S
Type
Gap
HTTP/S
Used Capacity
Implemented
HTTP/S
User/Group Target
Implemented
HTTP/S
Share
IP Interfaces
Implemented
HTTP/S
Name
Implemented
HTTP/S
Protocol
Implemented
HTTP/S
Share Initiator
Initiator
Implemented
HTTP/S
Permission
Implemented
HTTP/S
Storage
Display IP
Implemented
HTTP/S
Failed Raw Capacity
Implemented
HTTP/S
Family
Implemented
HTTP/S
IP
Implemented
HTTP/S
Manufacturer
Implemented
HTTP/S
Microcode Version
Implemented
HTTP/S
Model
Implemented
HTTP/S
Name
Implemented
HTTP/S
Total Raw Capacity
Implemented
HTTP/S
Serial Number
Implemented
HTTP/S
Spare Raw Capacity
Implemented
HTTP/S
Implemented
HTTP/S
Virtual
Implemented
HTTP/S
Is this a storage virtualization device?
Storage Node
Memory Size
Gap
HTTP/S
device memory in MB
Model
Implemented
HTTP/S
Name
Implemented
HTTP/S
Processors Count
Implemented
HTTP/S
device CPU
Serial Number
Implemented
HTTP/S
State
Implemented
HTTP/S
UUID
Implemented
HTTP/S
Storage Pool
Auto Tiering
Implemented
HTTP/S
Compression Enabled
Implemented
HTTP/S
Compression Savings
Implemented
HTTP/S
Data Allocated Capacity
Gap
HTTP/S
capacity allocated for data
Data Used Capacity
Implemented
HTTP/S
Dedupe Enabled
Implemented
HTTP/S
Dedupe Savings
Implemented
HTTP/S
ratio of dedupe savings in percentage
Implemented
HTTP/S
Name
Implemented
HTTP/S
Implemented
HTTP/S
Physical Disk Capacity (MB)
Implemented
HTTP/S
used as raw capacity for storage pool
Raid Group
Implemented
HTTP/S
Raw to Usable Ratio
Implemented
HTTP/S
Redundancy
Implemented
HTTP/S
Redundancy level
Implemented
HTTP/S
Status
Implemented
HTTP/S
Storage Pool Id
Implemented
HTTP/S
Implemented
HTTP/S
Implemented
HTTP/S
Total Used Capacity
Implemented
HTTP/S
Type
Gap
HTTP/S
Virtual
Implemented
HTTP/S
Encrypted
Implemented
HTTP/S
Volume
Auto Tiering
Implemented
HTTP/S
Capacity
Implemented
HTTP/S
Snapshot Used capacity in MB
Disk Size
Implemented
HTTP/S
comma seperated list of disk sizes (GB)
Disk Speed
Implemented
HTTP/S
comma seperated list of disk speeds (rpm)
Disk Type
Not Available
HTTP/S
Junction Path
Implemented
HTTP/S
Name
Implemented
HTTP/S
Total Raw Capacity
Implemented
HTTP/S
Total raw capacity (sum of all disks on the array)
Redundancy
Implemented
HTTP/S
Redundancy level
Storage Pool Id
Implemented
HTTP/S
Thin Provisioned
Implemented
HTTP/S
Type
Gap
HTTP/S
UUID
Implemented
HTTP/S
Used Capacity
Implemented
HTTP/S
Virtual
Implemented
HTTP/S
Volume Map
LUN
Implemented
HTTP/S
Masking Required
Implemented
HTTP/S
Protocol Controller
Implemented
HTTP/S
Storage Port
Implemented
HTTP/S
Type
Gap
HTTP/S
Volume Mask
Initiator
Implemented
HTTP/S
Protocol Controller
Implemented
HTTP/S
Storage Port
Implemented
HTTP/S
Type
Gap
HTTP/S
performance
Disk
IOPs Total
Implemented
Key
Implemented
Server ID
Implemented
Internal Volume
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
Implemented
Implemented
Data Used Capacity
Implemented
IOPs Total
Implemented
Key
Implemented
Other Used Capacity
Implemented
Server ID
Implemented
Implemented
Implemented
Qtree
Used Capacity
Implemented
Total File Count
Implemented
Key
Implemented
Server ID
Implemented
Storage
Implemented
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
Implemented
IOPs other
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Storage Node
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Utilization Total
Implemented
StoragePool Disk
Implemented
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Implemented
Capacity Used Ratio
Implemented
Total Data Capacity
Implemented
Data Used Capacity
Implemented
IOPs Total
Implemented
Other Used Capacity
Implemented
Implemented
Implemented
Volume
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Capacity Used Ratio
Implemented
Key
Implemented
Server ID
Implemented
Oracle ZFS REST API
HTTP/HTTPS
HTTP/HTTPS
215
true
true
true
true
Pure Storage FlashArray (HTTP)
DFSC1
DFSC2
FA-C50R4
FA-C60R3
FA-C70R4
FA-C90R4
FA-X20R2
FA-X20R3
FA-X20R4
FA-X20R5
FA-X50R3
FA-X50R4
FA-X50R5
FA-X70R3
FA-X70R4
FA-X70R5
FA-X90R2
FA-X90R3
FA-X90R4
FA-X90R5
FA-XL130
FA-XL130R5
FA-XL170
FA-XL170R5
FA-m20
FA-m20r2
6.1.14
6.10.3
6.10.4
6.10.6
6.10.7
6.11.8
6.3.10
6.3.14
6.3.17
6.3.21
6.5.10
6.5.12.post3
6.5.13
6.5.3
6.5.8
6.5.9
6.7.3
6.7.4
6.7.6
6.7.7
6.7.8
6.9.1
6.9.2
6.9.3
6.9.4
6.9.5
6.9.6
6.9.7
6.9.8
6.9.9
foundation
Disk
Capacity (GB)
Implemented
HTTP/S
Used capacity
Disk Id
Implemented
HTTP/S
Location
Gap
HTTP/S
Name
Implemented
HTTP/S
Implemented
HTTP/S
Role
Implemented
HTTP/S
Role Enum
Implemented
HTTP/S
enum for disk role
Seek Time
Implemented
HTTP/S
Serial Number
Implemented
HTTP/S
Speed
Implemented
HTTP/S
Speed of disk (RPM)
Status
Implemented
HTTP/S
Status Enum
Implemented
HTTP/S
Type
Gap
HTTP/S
Type Enum
Implemented
HTTP/S
enum for disk type
Vendor
Implemented
HTTP/S
IP
Implemented
HTTP/S
Listening Port
Implemented
HTTP/S
Nic
Implemented
HTTP/S
OID
Implemented
HTTP/S
OID
Implemented
HTTP/S
Portal Group Name
Implemented
HTTP/S
Portal Group Tag
Implemented
HTTP/S
ISCSI Node
Node Name
Implemented
HTTP/S
OID
Implemented
HTTP/S
Type
Gap
HTTP/S
ISCSI Node Map
OID
Implemented
HTTP/S
Portal Group OID
Implemented
HTTP/S
ISCSI Session
Initiator Ips
Implemented
HTTP/S
Initiator OID
Implemented
HTTP/S
Max Connections
Implemented
HTTP/S
Implemented
HTTP/S
OID
Implemented
HTTP/S
Portal Group OID
Implemented
HTTP/S
Security
Implemented
HTTP/S
Info
DataSource Name
Implemented
HTTP/S
Info
Date
Implemented
HTTP/S
Originator ID
Implemented
HTTP/S
Originator Key
Implemented
HTTP/S
Storage
Display IP
Implemented
HTTP/S
Failed Raw Capacity
Implemented
HTTP/S
Family
Implemented
HTTP/S
IP
Implemented
HTTP/S
Manage URL
Implemented
HTTP/S
Manufacturer
Implemented
HTTP/S
Microcode Version
Implemented
HTTP/S
Model
Implemented
HTTP/S
Name
Implemented
HTTP/S
Total Raw Capacity
Implemented
HTTP/S
Serial Number
Implemented
HTTP/S
Spare Raw Capacity
Implemented
HTTP/S
Implemented
HTTP/S
Virtual
Implemented
HTTP/S
Storage Node
Memory Size
Gap
HTTP/S
device memory in MB
Model
Implemented
HTTP/S
Name
Implemented
HTTP/S
Serial Number
Implemented
HTTP/S
State
Implemented
HTTP/S
UUID
Implemented
HTTP/S
Version
Implemented
HTTP/S
software version
Parent Serial Number
Implemented
HTTP/S
Storage Pool
Gap
HTTP/S
Data Used Capacity
Implemented
HTTP/S
Dedupe Enabled
Implemented
HTTP/S
Dedupe Savings
Implemented
HTTP/S
Implemented
HTTP/S
Name
Implemented
HTTP/S
Implemented
HTTP/S
Implemented
HTTP/S
Raid Group
Implemented
HTTP/S
Raw to Usable Ratio
Implemented
HTTP/S
Redundancy
Implemented
HTTP/S
Redundancy level
Implemented
HTTP/S
Storage Pool Id
Implemented
HTTP/S
Implemented
HTTP/S
Implemented
HTTP/S
Total Used Capacity
Implemented
HTTP/S
Type
Gap
HTTP/S
Virtual
Implemented
HTTP/S
Mode
Implemented
HTTP/S
Mode Enum
Implemented
HTTP/S
Source Storage
Implemented
HTTP/S
Source Volume
Implemented
HTTP/S
State
Implemented
HTTP/S
State Enum
Implemented
HTTP/S
Target Storage
Implemented
HTTP/S
Target Volume
Implemented
HTTP/S
Technology
Implemented
HTTP/S
Volume
Capacity
Implemented
HTTP/S
Disk Size
Implemented
HTTP/S
Disk Speed
Implemented
HTTP/S
Disk Type
Not Available
HTTP/S
Name
Implemented
HTTP/S
Protection Type
Implemented
HTTP/S
Total Raw Capacity
Implemented
HTTP/S
Redundancy
Implemented
HTTP/S
Redundancy level
Storage Pool Id
Implemented
HTTP/S
Thin Provisioned
Implemented
HTTP/S
Type
Gap
HTTP/S
UUID
Implemented
HTTP/S
Used Capacity
Implemented
HTTP/S
Virtual
Implemented
HTTP/S
Written Capacity
Implemented
HTTP/S
Total capacity written to this volume by a Host in MB
Compression Enabled
Implemented
HTTP/S
Volume Map
LUN
Implemented
HTTP/S
Protocol Controller
Implemented
HTTP/S
Storage Port
Implemented
HTTP/S
Type
Gap
HTTP/S
Volume Mask
Initiator
Implemented
HTTP/S
Protocol Controller
Implemented
HTTP/S
Storage Port
Implemented
HTTP/S
Type
Gap
HTTP/S
WWN Alias
Host Aliases
Implemented
HTTP/S
Object Type
Implemented
HTTP/S
Source
Implemented
HTTP/S
WWN
Implemented
HTTP/S
performance
Storage
Failed Raw Capacity
Implemented
Raw Capacity
Implemented
Spare Raw Capacity
Implemented
Implemented
IOPs other
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
StoragePool Disk
Implemented
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Implemented
Capacity Used Ratio
Implemented
Total Data Capacity
Implemented
Data Used Capacity
Implemented
Other Used Capacity
Implemented
Implemented
Implemented
Volume
Raw Capacity
Implemented
Total Capacity
Implemented
Used Capacity
Implemented
Written Capacity
Implemented
Capacity Used Ratio
Implemented
CapacityRatio Written
Implemented
Total Compression Savings
Implemented
Compression Savings Space
Implemented
IOPs Read
Implemented
IOPs Total
Implemented
IOPs Write
Implemented
Key
Implemented
Latency Read
Implemented
Latency Total
Implemented
Latency Write
Implemented
Server ID
Implemented
Throughput Read
Implemented
Throughput Total
Implemented
Throughput Write
Implemented
Pure Storage REST API
HTTP/HTTPS
HTTP/HTTPS
80/443
true
true
true
true
Pure Storage FlashBlade REST
FlashBlade
FlashBlade//S200
FlashBlade//S200R2
Purity//FB 4.3.11
Purity//FB 4.5.11
Purity//FB 4.5.14
Purity//FB 4.5.17
Purity//FB 4.6.6
Purity//FB 4.6.7
Purity//FB 4.7.10
Purity//FB 4.7.11
Purity//FB 4.7.12
Purity//FB 4.8.7
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Uniquely identifies this disk in the array
Location
Gap
HTTPS
Where this disk is physically located in the array
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Status
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
ratio of compression savings in percentage
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Share
Implemented
HTTPS
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Version
Implemented
HTTPS
software version
Implemented
HTTPS
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
performance
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Total Objects
Implemented
HTTPS
Server ID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Pure Storage FlashBlade API
HTTPS
HTTPS
443
true
true
true
true
Qumulo REST
PROTECTION_SYSTEM_TYPE_EC
Qumulo Core 7.4.0.4
Qumulo Core 7.5.4
Qumulo Core 7.8.4.3
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Location
Gap
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
enum for disk status
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
File Share
Is InternalVolume
Implemented
HTTPS
Is Shared
Implemented
HTTPS
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Gap
HTTPS
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Implemented
HTTPS
Quota UsedCapacity
Implemented
HTTPS
Type
Gap
HTTPS
Quota
Implemented
HTTPS
Hard File Limit
Implemented
HTTPS
max number of files allowed for the quota target
Internal Volume Id
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
unique id of the qtree
Quota Id
Implemented
HTTPS
Soft File Limit
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Share
IP Interfaces
Implemented
HTTPS
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Raw capacity of failed disks (sum of all disks that are failed)
Family
Implemented
HTTPS
The storage Family could be Clariion, Symmetrix, et al
IP
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Serial Number
Implemented
HTTPS
UUID
Implemented
HTTPS
Implemented
HTTPS
Storage Pool
Include In Dwh Capacity
Implemented
HTTPS
A way from ACQ to control which storage pools are interesting in DWH Capacity
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
indicates whether this storagePool is a raid group
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
performance
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Other Used Capacity
Implemented
HTTPS
Server ID
Implemented
HTTPS
Snapshot Used Capacity
Implemented
HTTPS
Snapshot Used Capacity Ratio
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
Quota Hard Limit
Implemented
HTTPS
Capacity quota hard limit
Used Capacity
Implemented
HTTPS
Total File Count
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
StoragePools Capacity
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qumulo REST API
HTTPS
HTTPS
8000
true
true
true
true
Red Hat OpenShift Virtualization
API versions:
  • v1
foundation
Data Store
Capacity
Implemented
HTTPS
MOID
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
subscription Id
Implemented
HTTPS
Type
Implemented
HTTPS
NasShare DataStore
DataStore OID
Implemented
HTTPS
Nas Share OID
Implemented
HTTPS
OID
Implemented
HTTPS
NasShare Host
Nas Share OID
Implemented
HTTPS
Host OID
Implemented
HTTPS
OID
Implemented
HTTPS
Read Only
Implemented
HTTPS
LUN
Disk Name
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Host OID
Implemented
HTTPS
Number
Implemented
HTTPS
OID
Implemented
HTTPS
Volume Uuid
Implemented
HTTPS
NAS Share
Capacity
Implemented
HTTPS
Filer Ip
Implemented
HTTPS
Filer Name
Implemented
HTTPS
OID
Implemented
HTTPS
Share Path
Implemented
HTTPS
Type
Gap
HTTPS
Path
Active
Implemented
HTTPS
Lun OID
Implemented
HTTPS
OID
Implemented
HTTPS
Storage Port WWPN
Implemented
HTTPS
Type
Gap
HTTPS
Server
Cluster
Implemented
HTTPS
Cluster name
DataCenter Name
Implemented
HTTPS
Host OID
Implemented
HTTPS
MOID
Implemented
HTTPS
OID
Implemented
HTTPS
Virtual Center Ip
Implemented
HTTPS
Virtual Disk
Capacity
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Lun OID
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
used capacity for reporting (MB)
Used Capacity
Implemented
HTTPS
VirtualMachine
Dns Name
Implemented
HTTPS
Guest State
Implemented
HTTPS
DataStore OID
Implemented
HTTPS
Host OID
Implemented
HTTPS
IPs
Implemented
HTTPS
MOID
Implemented
HTTPS
Memory
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
OS
Implemented
HTTPS
Power State
Implemented
HTTPS
State Change Time
Implemented
HTTPS
Processors
Implemented
HTTPS
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Instance Type
Implemented
HTTPS
Launch Time
Implemented
HTTPS
public Ips
Implemented
HTTPS
UUID
Implemented
HTTPS
VirtualMachine Disk
OID
Implemented
HTTPS
VirtualDisk OID
Implemented
HTTPS
VirtualMachine OID
Implemented
HTTPS
Host
Host Cpu Count
Implemented
HTTPS
Host Domain
Implemented
HTTPS
Implemented
HTTPS
Host OS
Implemented
HTTPS
IPs
Implemented
HTTPS
Name
Implemented
HTTPS
OID
Implemented
HTTPS
Platform Type
Implemented
HTTPS
Info
Api Description
Implemented
HTTPS
Api Name
Implemented
HTTPS
Api Version
Implemented
HTTPS
Client Api Name
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
performance
Data Store
Capacity Provisioned
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Over Commit Capacity Ratio
Implemented
HTTPS
Host
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
diskIops.total
Implemented
HTTPS
Disk IOPs write
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Implemented
HTTPS
IP Throughput Read
Implemented
HTTPS
Throughput total
Implemented
HTTPS
IP throughput total
ipThroughput.write
Implemented
HTTPS
Implemented
HTTPS
Virtual Disk
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
vm
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
diskIops.total
Implemented
HTTPS
Disk IOPs write
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Implemented
HTTPS
IP Throughput Read
Implemented
HTTPS
Throughput total
Implemented
HTTPS
IP throughput total
ipThroughput.write
Implemented
HTTPS
Key
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
swapRate.inRate
Implemented
HTTPS
Swap Rate
Implemented
HTTPS
Total Swap Rate
Implemented
HTTPS
OpenShift/KubeVirt Kubernetes API
HTTPS
HTTPS
6443
true
true
true
true
Thanos Querier (Prometheus)
HTTPS
HTTPS
443
true
true
true
true
Rubrik Storage
Firmware versions:
  • 6.0.3-p16-13857
  • 9.4.3-p1-31252
  • 9.4.3-p4-31485
  • 9.5.1-p2-36376
  • 9.5.1-p2-36376_HP72dc853
  • 9.5.2-36527
  • 9.5.3-p3-36812
  • 9.6.0-p1-33410
  • 9.6.0-p2-33501
  • 9.6.1-p1-33607
  • 9.6.1-p2-33730
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Location
Gap
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Encrypted
Implemented
HTTPS
Info
Api Description
Implemented
HTTPS
Api Name
Implemented
HTTPS
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Originator Key
Implemented
HTTPS
Storage
Cluster
Not Available
HTTPS
Whether this storage is a cluster
Cpu Count
Implemented
HTTPS
Cpu Count of the storage
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Memory
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
Storage Node
Memory Size
Gap
HTTPS
device memory in MB
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
State
Implemented
HTTPS
free text describing the device state
UUID
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Site Name
Implemented
HTTPS
Storage Pool
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Effective Used Capacity Percent
Implemented
HTTPS
performance
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Raw Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Other Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Rubrik Storage REST API
HTTPS
HTTPS
443
true
true
true
true
VAST DataStore
VAST Data
Build version: release-5.3.3-hf5-2058254
Build version: release-5.3.3-hf7-2198162
Build version: release-5.3.3-sp3-2009124
Build version: release-5.4.3-sp4-hf21-2650650
Build version: release-5.4.6-hf6-2650431
Build version: release-5.4.6-sp1-2679416
System version: 5.3.3.0.10090135699003918747
System version: 5.3.3.1.3876442573258902143
System version: 5.4.3.1.7633800423310192645
System version: 5.4.6.0.15923970655878004698
System version: 5.4.6.0.17320657730101426841
foundation
Disk
Capacity (GB)
Implemented
HTTPS
Used capacity
Disk Id
Implemented
HTTPS
Location
Gap
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Role
Implemented
HTTPS
Role Enum
Implemented
HTTPS
enum for disk role
Serial Number
Implemented
HTTPS
Speed
Implemented
HTTPS
Speed of disk (RPM)
Status
Implemented
HTTPS
Status Enum
Implemented
HTTPS
Type
Gap
HTTPS
Type Enum
Implemented
HTTPS
enum for disk type
Vendor
Implemented
HTTPS
File Share
Is InternalVolume
Implemented
HTTPS
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume
Is Oplocks Enabled
Implemented
HTTPS
whether opportunistic locks are enabled on the FileShare
Is Shared
Implemented
HTTPS
whether this fileShare has any shares associated with it
Name
Implemented
HTTPS
Path
Implemented
HTTPS
Path of the fileShare
Qtree Id
Implemented
HTTPS
Security Type
Implemented
HTTPS
Status
Implemented
HTTPS
Info
DataSource Name
Implemented
HTTPS
Info
Date
Implemented
HTTPS
Originator ID
Implemented
HTTPS
Internal Volume
Compression Enabled
Implemented
HTTPS
Is compression enabled on the storage pool
Compression Savings
Implemented
HTTPS
Dedupe Enabled
Implemented
HTTPS
Internal Volume Id
Implemented
HTTPS
Name
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Thin Provisioned
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Virtual Storage
Implemented
HTTPS
Owning virtual storage (vfiler)
Implemented
HTTPS
QoS - Policy
Implemented
HTTPS
QTree
Name
Implemented
HTTPS
Qtree Id
Implemented
HTTPS
Type
Gap
HTTPS
Quota
Hard Capacity Limit (MB)
Implemented
HTTPS
max amount of disk space, allowed for the quota target (Hard limit)
Internal Volume Id
Implemented
HTTPS
Quota Id
Implemented
HTTPS
unique id of the quota
Type
Gap
HTTPS
Used Capacity
Implemented
HTTPS
Used Files
Implemented
HTTPS
Number of files currently used
Share
IP Interfaces
Implemented
HTTPS
comma separated list of IP addresses on which this share is exposed
Name
Implemented
HTTPS
Protocol
Implemented
HTTPS
enum for share protocol
Share Initiator
Initiator
Implemented
HTTPS
Permission
Implemented
HTTPS
Permissions for this particular share
Storage
Cpu Count
Implemented
HTTPS
Display IP
Implemented
HTTPS
Failed Raw Capacity
Implemented
HTTPS
Family
Implemented
HTTPS
IP
Implemented
HTTPS
Manage URL
Implemented
HTTPS
Manufacturer
Implemented
HTTPS
Microcode Version
Implemented
HTTPS
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Total Raw Capacity
Implemented
HTTPS
Serial Number
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Virtual
Implemented
HTTPS
UUID
Implemented
HTTPS
Storage Node
Model
Implemented
HTTPS
Name
Implemented
HTTPS
Processors Count
Implemented
HTTPS
device CPU
Serial Number
Implemented
HTTPS
State
Implemented
HTTPS
UUID
Implemented
HTTPS
Version
Implemented
HTTPS
software version
ManagementIp Addresses
Implemented
HTTPS
Implemented
HTTPS
Site Name
Implemented
HTTPS
Storage Pool
Compression Enabled
Implemented
HTTPS
Compression Savings
Implemented
HTTPS
Gap
HTTPS
Data Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Name
Implemented
HTTPS
Implemented
HTTPS
Raid Group
Implemented
HTTPS
Raw to Usable Ratio
Implemented
HTTPS
Reserved Capacity
Implemented
HTTPS
Snapshot Allocated Capacity
Gap
HTTPS
Allocated capacity of snapshots in MB
Implemented
HTTPS
Storage Pool Id
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Total Used Capacity
Implemented
HTTPS
Type
Gap
HTTPS
Virtual
Implemented
HTTPS
Encrypted
Implemented
HTTPS
Storage VirtualMachine
Allocated capacity (MB)
Implemented
HTTPS
Comment
Implemented
HTTPS
Guid Key
Implemented
HTTPS
Globally Unique Key of the storage virtual machine
Name
Implemented
HTTPS
Type
Gap
HTTPS
UUID
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
VirtualMachine Internal Volume Ref
Internal Volume Id
Implemented
HTTPS
performance
Disk
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Internal Volume
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Qtree
IOPs Total
Implemented
HTTPS
Key
Implemented
HTTPS
Server ID
Implemented
HTTPS
Storage
Failed Raw Capacity
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Spare Raw Capacity
Implemented
HTTPS
Implemented
HTTPS
IO Density Read
Implemented
HTTPS
IO Density Total
Implemented
HTTPS
Write IO Density
Implemented
HTTPS
IOPs other
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Storage Node
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Utilization Total
Implemented
HTTPS
StoragePool Disk
Implemented
HTTPS
Raw Capacity
Implemented
HTTPS
Reserved Capacity
Implemented
HTTPS
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
Implemented
HTTPS
Capacity Used Ratio
Implemented
HTTPS
Total Data Capacity
Implemented
HTTPS
Data Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Snapshot Reserved Capacity
Implemented
HTTPS
Implemented
HTTPS
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
Virtual Machine
Total Capacity
Implemented
HTTPS
Used Capacity
Implemented
HTTPS
IOPs Read
Implemented
HTTPS
IOPs Total
Implemented
HTTPS
IOPs Write
Implemented
HTTPS
Key
Implemented
HTTPS
Latency Read
Implemented
HTTPS
Latency Total
Implemented
HTTPS
Latency Write
Implemented
HTTPS
Server ID
Implemented
HTTPS
Throughput Read
Implemented
HTTPS
Throughput Total
Implemented
HTTPS
Throughput Write
Implemented
HTTPS
VAST DataStore API
HTTPS
HTTPS
443
true
true
true
true
VMware Cloud on AWS
API versions:
  • VMware vCenter Server 8.0.3 build-24322831
foundation
Data Store
Capacity
Implemented
Web Services
MOID
Implemented
Web Services
Name
Implemented
Web Services
OID
Implemented
Web Services
Implemented
Web Services
Used Capacity
Implemented
Web Services
Virtual Center Ip
Implemented
Web Services
Type
Implemented
Web Services
NasShare DataStore
DataStore OID
Implemented
Web Services
Nas Share OID
Implemented
Web Services
OID
Implemented
Web Services
NasShare Host
Nas Share OID
Implemented
Web Services
Host OID
Implemented
Web Services
OID
Implemented
Web Services
Read Only
Implemented
Web Services
NAS Share
Capacity
Implemented
Web Services
Filer Ip
Implemented
Web Services
Filer Name
Implemented
Web Services
OID
Implemented
Web Services
Share Path
Implemented
Web Services
Type
Gap
Web Services
Server
Cluster
Implemented
Web Services
Cluster name
DataCenter Name
Implemented
Web Services
Host OID
Implemented
Web Services
MOID
Implemented
Web Services
OID
Implemented
Web Services
Virtual Center Ip
Implemented
Web Services
Virtual Disk
Capacity
Implemented
Web Services
DataStore OID
Implemented
Web Services
Name
Implemented
Web Services
OID
Implemented
Web Services
Type
Gap
Web Services
Used Capacity
Implemented
Web Services
VirtualMachine
Dns Name
Implemented
Web Services
Guest State
Implemented
Web Services
DataStore OID
Implemented
Web Services
Host OID
Implemented
Web Services
IPs
Implemented
Web Services
MOID
Implemented
Web Services
Memory
Implemented
Web Services
Name
Implemented
Web Services
OID
Implemented
Web Services
OS
Implemented
Web Services
Power State
Implemented
Web Services
State Change Time
Implemented
Web Services
Processors
Implemented
Web Services
Implemented
Web Services
Used Capacity
Implemented
Web Services
Launch Time
Implemented
Web Services
UUID
Implemented
Web Services
VirtualMachine Disk
OID
Implemented
Web Services
VirtualDisk OID
Implemented
Web Services
VirtualMachine OID
Implemented
Web Services
Host
Host Cpu Count
Implemented
Web Services
Host Cpu Speed
Implemented
Web Services
Host Domain
Implemented
Web Services
Implemented
Web Services
Host Model
Implemented
Web Services
NIC count
Implemented
Web Services
NIC speed
Implemented
Web Services
IPs
Implemented
Web Services
Manufacturer
Implemented
Web Services
Name
Implemented
Web Services
OID
Implemented
Web Services
Platform Type
Implemented
Web Services
Info
Api Description
Implemented
Web Services
Api Name
Implemented
Web Services
Api Version
Implemented
Web Services
Client Api Name
Implemented
Web Services
Client Api Version
Implemented
Web Services
DataSource Name
Implemented
Web Services
Info
Date
Implemented
Web Services
Originator ID
Implemented
Web Services
performance
Host
Implemented
Web Services
IOPs Read
Implemented
Web Services
diskIops.total
Implemented
Web Services
Disk IOPs write
Implemented
Web Services
Latency Read
Implemented
Web Services
Latency Total
Implemented
Web Services
Latency Write
Implemented
Web Services
Implemented
Web Services
Throughput Read
Implemented
Web Services
Implemented
Web Services
IP Throughput Read
Implemented
Web Services
Throughput total
Implemented
Web Services
IP throughput total
ipThroughput.write
Implemented
Web Services
Key
Implemented
Web Services
Implemented
Web Services
Server ID
Implemented
Web Services
swapRate.inRate
Implemented
Web Services
Swap Rate
Implemented
Web Services
Total Swap Rate
Implemented
Web Services
Virtual Disk
Total Capacity
Implemented
Web Services
Used Capacity
Implemented
Web Services
Capacity Used Ratio
Implemented
Web Services
IOPs Read
Implemented
Web Services
IOPs Total
Implemented
Web Services
IOPs Write
Implemented
Web Services
Key
Implemented
Web Services
Latency Read
Implemented
Web Services
Latency Total
Implemented
Web Services
Latency Write
Implemented
Web Services
Server ID
Implemented
Web Services
Throughput Read
Implemented
Web Services
Throughput Total
Implemented
Web Services
Throughput Write
Implemented
Web Services
vm
Total Capacity
Implemented
Web Services
Used Capacity
Implemented
Web Services
Capacity Used Ratio
Implemented
Web Services
cpuCoSchedulingDelayTimePercent.total
Implemented
Web Services
cpuDemandToEntitlementPercent.total
Implemented
Web Services
Idle CPU Time
Implemented
Web Services
idle time in percent
CPU Wait Time
Implemented
Web Services
total cpu wait time in percent
Implemented
Web Services
IOPs Read
Implemented
Web Services
diskIops.total
Implemented
Web Services
Disk IOPs write
Implemented
Web Services
Latency Read
Implemented
Web Services
Latency Total
Implemented
Web Services
Latency Write
Implemented
Web Services
Implemented
Web Services
Throughput Read
Implemented
Web Services
Implemented
Web Services
IP Throughput Read
Implemented
Web Services
Throughput total
Implemented
Web Services
IP throughput total
ipThroughput.write
Implemented
Web Services
Key
Implemented
Web Services
Implemented
Web Services
Server ID
Implemented
Web Services
swapRate.inRate
Implemented
Web Services
Swap Rate
Implemented
Web Services
Total Swap Rate
Implemented
Web Services
Schedule wait time
Implemented
Web Services
VMware REST API
Web Services
HTTP/HTTPS
80/443
true
true
true
true
VMware vSphere (Web Services)
API versions:
  • VMware ESXi 6.5.0 build-14990892
  • VMware ESXi 7.0.3 build-20036589
  • VMware vCenter Server 5.5.0 build-9911218
  • VMware vCenter Server 6.5.0 build-10964411
  • VMware vCenter Server 6.5.0 build-14020092
  • VMware vCenter Server 6.5.0 build-17994927
  • VMware vCenter Server 6.5.0 build-22499743
  • VMware vCenter Server 6.7.0 build-10244857
  • VMware vCenter Server 6.7.0 build-15129973
  • VMware vCenter Server 6.7.0 build-17137327
  • VMware vCenter Server 6.7.0 build-19299595
  • VMware vCenter Server 6.7.0 build-19832280
  • VMware vCenter Server 6.7.0 build-22509751
  • VMware vCenter Server 7.0.2 build-17958471
  • VMware vCenter Server 7.0.3 build-18700403
  • VMware vCenter Server 7.0.3 build-19234570
  • VMware vCenter Server 7.0.3 build-19480866
  • VMware vCenter Server 7.0.3 build-19717403
  • VMware vCenter Server 7.0.3 build-20990077
  • VMware vCenter Server 7.0.3 build-21477706
  • VMware vCenter Server 7.0.3 build-21784236
  • VMware vCenter Server 7.0.3 build-21958406
  • VMware vCenter Server 7.0.3 build-22357613
  • VMware vCenter Server 7.0.3 build-22837322
  • VMware vCenter Server 7.0.3 build-23788036
  • VMware vCenter Server 7.0.3 build-24026615
  • VMware vCenter Server 7.0.3 build-24201990
  • VMware vCenter Server 7.0.3 build-24322018
  • VMware vCenter Server 7.0.3 build-24614210
  • VMware vCenter Server 7.0.3 build-24730281
  • VMware vCenter Server 7.0.3 build-24927011
  • VMware vCenter Server 7.0.3 build-25606036
  • VMware vCenter Server 8.0.0 build-20519528
  • VMware vCenter Server 8.0.1 build-21560480
  • VMware vCenter Server 8.0.2 build-22617221
  • VMware vCenter Server 8.0.2 build-23504390
  • VMware vCenter Server 8.0.2 build-24321653
  • VMware vCenter Server 8.0.2 build-25624321
  • VMware vCenter Server 8.0.3 build-24022515
  • VMware vCenter Server 8.0.3 build-24091160
  • VMware vCenter Server 8.0.3 build-24305161
  • VMware vCenter Server 8.0.3 build-24674346
  • VMware vCenter Server 8.0.3 build-24853646
  • VMware vCenter Server 8.0.3 build-25092719
  • VMware vCenter Server 8.0.3 build-25197330
  • VMware vCenter Server 8.0.3 build-25413364
  • VMware vCenter Server 8.0.3 build-25600417
  • VMware vCenter Server 9.0.1 build-24957454
  • VMware vCenter Server 9.0.2 build-25148086
  • VMware vCenter Server 9.0.2 build-25629525
  • VMware vCenter Server 9.1.0.0.25370922
  • VMware vCenter Server 9.1.0.0100.25417926
  • VMware vCenter Server 9.1.0.0200.25573614
  • VMware vCenter Server 9.1.0.0300.25629530
  • VMware vCenter Server 9.1.1.0.25712839
  • VMware vCenter Server 9.1.1.0100.25784172
Products supported by this data collector:
Product Category Feature/Attribute Status Protocol Used Additional Information
foundation
Data Store
Capacity
Implemented
Web Services
MOID
Implemented
Web Services
Name
Implemented
Web Services
OID
Implemented
Web Services
Implemented
Web Services
Used Capacity
Implemented
Web Services
Virtual Center Ip
Implemented
Web Services
Type
Implemented
Web Services
NasShare DataStore
DataStore OID
Implemented
Web Services
Nas Share OID
Implemented
Web Services
OID
Implemented
Web Services
NasShare Host
Nas Share OID
Implemented
Web Services
Host OID
Implemented
Web Services
OID
Implemented
Web Services
Read Only
Implemented
Web Services
LUN
Disk Name
Implemented
Web Services
DataStore OID
Implemented
Web Services
Host OID
Implemented
Web Services
Number
Implemented
Web Services
OID
Implemented
Web Services
Policy
Implemented
Web Services
TID
Implemented
Web Services
Volume Uuid
Implemented
Web Services
NAS Share
Capacity
Implemented
Web Services
Filer Ip
Implemented
Web Services
Filer Name
Implemented
Web Services
OID
Implemented
Web Services
Share Path
Implemented
Web Services
Type
Gap
Web Services
Path
Active
Implemented
Web Services
Lun OID
Implemented
Web Services
Host Port WWPN
Implemented
Web Services
OID
Implemented
Web Services
Storage Port WWPN
Implemented
Web Services
Type
Gap
Web Services
Server
Cluster
Implemented
Web Services
Cluster name
DataCenter Name
Implemented
Web Services
Host OID
Implemented
Web Services
MOID
Implemented
Web Services
OID
Implemented
Web Services
Virtual Center Ip
Implemented
Web Services
Virtual Disk
Capacity
Implemented
Web Services
DataStore OID
Implemented
Web Services
Lun OID
Implemented
Web Services
Name
Implemented
Web Services
OID
Implemented
Web Services
Type
Gap
Web Services
Used Capacity
Implemented
Web Services
Used Capacity
Implemented
Web Services
VirtualMachine
Dns Name
Implemented
Web Services
Guest State
Implemented
Web Services
DataStore OID
Implemented
Web Services
Host OID
Implemented
Web Services
IPs
Implemented
Web Services
MOID
Implemented
Web Services
Memory
Implemented
Web Services
Name
Implemented
Web Services
OID
Implemented
Web Services
OS
Implemented
Web Services
Power State
Implemented
Web Services
State Change Time
Implemented
Web Services
Processors
Implemented
Web Services
Implemented
Web Services
Used Capacity
Implemented
Web Services
Launch Time
Implemented
Web Services
UUID
Implemented
Web Services
VirtualMachine Disk
OID
Implemented
Web Services
VirtualDisk OID
Implemented
Web Services
VirtualMachine OID
Implemented
Web Services
Host
Host Cpu Count
Implemented
Web Services
Host Cpu Speed
Implemented
Web Services
Host Domain
Implemented
Web Services
Implemented
Web Services
Host Model
Implemented
Web Services
NIC count
Implemented
Web Services
NIC speed
Implemented
Web Services
IPs
Implemented
Web Services
Manufacturer
Implemented
Web Services
Name
Implemented
Web Services
OID
Implemented
Web Services
Platform Type
Implemented
Web Services
ISCSI Node
Host Aliases
Implemented
Web Services
Node Name
Implemented
Web Services
OID
Implemented
Web Services
Type
Gap
Web Services
Info
Api Description
Implemented
Web Services
Api Name
Implemented
Web Services
Api Version
Implemented
Web Services
Client Api Name
Implemented
Web Services
Client Api Version
Implemented
Web Services
DataSource Name
Implemented
Web Services
Info
Date
Implemented
Web Services
Originator ID
Implemented
Web Services
performance
Host
Implemented
Web Services
IOPs Read
Implemented
Web Services
diskIops.total
Implemented
Web Services
Disk IOPs write
Implemented
Web Services
Latency Read
Implemented
Web Services
Latency Total
Implemented
Web Services
Latency Write
Implemented
Web Services
Implemented
Web Services
Throughput Read
Implemented
Web Services
Implemented
Web Services
IP Throughput Read
Implemented
Web Services
Throughput total
Implemented
Web Services
IP throughput total
ipThroughput.write
Implemented
Web Services
Key
Implemented
Web Services
Implemented
Web Services
Server ID
Implemented
Web Services
swapRate.inRate
Implemented
Web Services
Swap Rate
Implemented
Web Services
Total Swap Rate
Implemented
Web Services
Virtual Disk
Total Capacity
Implemented
Web Services
Used Capacity
Implemented
Web Services
Capacity Used Ratio
Implemented
Web Services
IOPs Read
Implemented
Web Services
IOPs Total
Implemented
Web Services
IOPs Write
Implemented
Web Services
Key
Implemented
Web Services
Latency Read
Implemented
Web Services
Latency Total
Implemented
Web Services
Latency Write
Implemented
Web Services
Server ID
Implemented
Web Services
Throughput Read
Implemented
Web Services
Throughput Total
Implemented
Web Services
Throughput Write
Implemented
Web Services
vm
Total Capacity
Implemented
Web Services
Used Capacity
Implemented
Web Services
Capacity Used Ratio
Implemented
Web Services
Implemented
Web Services
Implemented
Web Services
Idle CPU Time
Implemented
Web Services
CPU Wait Time
Implemented
Web Services
Total CPU Utilization
Implemented
Web Services
IOPs Read
Implemented
Web Services
diskIops.total
Implemented
Web Services
Disk IOPs write
Implemented
Web Services
Latency Read
Implemented
Web Services
Latency Total
Implemented
Web Services
Latency Write
Implemented
Web Services
Disk Throughput Read
Implemented
Web Services
Throughput Read
Implemented
Web Services
total disk throughput read
Disk Throughput Write
Implemented
Web Services
IP Throughput Read
Implemented
Web Services
Throughput total
Implemented
Web Services
IP throughput total
ipThroughput.write
Implemented
Web Services
Key
Implemented
Web Services
Total Memory Utilization
Implemented
Web Services
Server ID
Implemented
Web Services
swapRate.inRate
Implemented
Web Services
Swap Rate
Implemented
Web Services
Total Swap Rate
Implemented
Web Services
Schedule wait time
Implemented
Web Services
Waiting to be scheduled time in percent
VMware REST API
Web Services
HTTP/HTTPS
80/443
true
true
true
true
