Data Infrastructure Insights
Workload Security API
Contributors netapp-alavoie
Integrate Workload Security with your enterprise ecosystem using a REST API protected by secure token-based authentication. Retrieve forensic activity data, manage API access tokens, and develop custom integrations with CMDBs, ticketing systems, and other applications. Interactive Swagger documentation provides complete API specifications and enables you to test endpoints directly.
Requirements for API Access:
  • An API Access Token model is used to grant access.
  • API Token management is performed by Workload Security users with the Administrator role.
API Documentation (Swagger)
The latest API information is found by logging in to Workload Security and navigating to Admin > API Access. Click the API Documentation link.
The API Documentation is Swagger-based, which provides a brief description and usage information for the API and allows you to try it out on your tenant.
Note If calling the Forensics Activity API, use the cloudsecure_forensics.activities.v2 API. If you are making multiple calls to this API, ensure that the calls occur sequentially, not in parallel. Multiple parallel calls may cause the API to time out.
API Access Tokens
Before using the Workload Security API, you must create one or more API Access Tokens. Access tokens grant read permissions. You can also set the expiration for each access token.
To create an Access Token:
  • Click Admin > API Access
  • Click +API Access Token
  • Enter Token Name
  • Specify Token Expiration
Note Your token will only be available for copying to the clipboard and saving during the creation process. Tokens can not be retrieved after they are created, so it is highly recommended to copy the token and save it in a secure location. You will be prompted to click the Copy API Access Token button before you can close the token creation screen.
You can disable, enable, and revoke tokens. Tokens that are disabled can be enabled.
Tokens grant general purpose access to APIs from a customer perspective, managing access to APIs in the scope of their own tenant.
The application receives an Access Token after a user successfully authenticates and authorizes access, then passes the Access Token as a credential when it calls the target API. The passed token informs the API that the bearer of the token has been authorized to access the API and perform specific actions based on the scope that was granted during authorization.
The HTTP header where the Access Token is passed is X-CloudInsights-ApiKey:
For example, use the following to retrieve storages assets:
curl https://<Workload Security tenant>/rest/v1/cloudsecure/activities -H 'X-CloudInsights-ApiKey: <API_Access_Token>'
Where <API_Access_Token> is the token you saved during API access key creation and <Workload Security Tenant> is the tenant URL of your Workload Security environment.
Detailed information can be found in the API Documentation link under Admin > API Access.
Script to extract data via the API
Workload Security agents include an export script to facilitate parallel calls to the v2 API by dividing the requested time range into smaller batches.
The script is located at /opt/netapp/cloudsecure/agent/export-script. A README file in the same directory provides usage instructions.
Here is an example command to invoke the script:
python3 data-export.py --tenant_url <Workload Security tenant> --access_key %ACCESS_KEY% --path_filter "<dir path>" --user_name "<user>" --from_time "01-08-2024 00:00:00" --to_time "31-08-2024 23:59:59" --iteration_interval 12 --num_workers 3
Key Parameters:
- --iteration_interval 12: Splits the requested time range into intervals of 12 hours.
- --num_workers 3: Fetches these intervals in parallel using 3 threads.
