Fujitsu Eternus data collector
The Fujitsu Eternus data collector acquires inventory data using administration-level access to the storage system.
Terminology
Data Infrastructure Insights acquires the following inventory information from the Fujitsu Eternus storage. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Disk |
Disk |
Storage |
Storage |
Thin Pool, Flexible Tier Pool, Raid Group |
Storage Pool |
Standard Volume, Snap Data Volume (SDV), Snap Data Pool Volume (SDPV), Thin Provisioning Volume (TPV), Flexible Tier Volume (FTV), Wide Striping Volume (WSV) |
Volume |
Channel adapter |
Controller |
Note: These are common terminology mappings only and might not represent every case for this data collectior.
Requirements
The following are required to configure this data collector:
An IP address of the Eternus storage, which cannot be comma delimited
SSH Administration-level user name and password
Port 22
Ensure that the page scroll is disabled (clienv-show-more-scroll disable)
Configuration
| Field | Description |
IP Address of Eternus Storage |
IP address of the Eternus storage |
User Name |
User name for Eternus storage |
Password |
Password for the Eternus storage |
Advanced configuration
Inventory Poll Interval (min) |
The default is 20 minutes. |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
"Error retrieving data" with error messages “Error Finding Prompt CLI” or “Error finding prompt at the end of shell results” |
Likely caused by: Storage system has page scrolling enabled. |
"Connecting error" with error messages “Failed to instantiate an SSH connection to storage” or “Failed to instantiate a connection to VirtualCenter” |
Likely causes: |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
