Configuring the VMware VSphere data collector
The data collector for VMware vSphere collects VM guest and ESXi Host performance and configuration information and requires read-only privileges on all objects within vSphere. As of August 2024, the vSphere collector additionally brings in log messages from vSphere environments, and some VMware specific metrics. Please note that Data Infrastructure Insights can only retrieve VMware logs information from vSphere 8.0.1 or higher environments. Similarly, the Vendor Specific Metrics is only supported for vSphere 7+ environments. As such, you may want to disable the logs and/or Vendor Specific Metrics checkbox on a given collector if it is pointed at an older vSphere instance.
Terminology
Data Infrastructure Insights acquires the following inventory information from the VMware vSphere data collector. For each asset type acquired, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Virtual disk |
Disk |
Host |
Host |
Virtual machine |
Virtual machine |
Data store |
Data store |
LUN |
Volume |
Fibre channel port |
Port |
These are common terminology mappings only and might not represent every case for this data collector.
Requirements
The following information is required to configure this data collector:
IP address of the Virtual Center server
Read-only username and password in Virtual Center
We require read only privileges on all objects within Virtual Center.
SDK access on the Virtual Center server – normally already setup.
Port requirements: http-80 https-443
Validate access:
Log into Virtual Center Client using above username and password
Verify SDK enabled: telnet <vc_ip> 443
Setup and connection
| Field | Description |
Name |
Unique name for the data collector |
Acquisition unit |
Name of acquisition unit |
Configuration
Virtual center IP Address |
IP address of the Virtual Center |
User name |
User name used to access the Virtual Center |
Password |
Password used to access the Virtual Center |
Advanced configuration
In the advanced configuration screen, check the VM Performance box to collect performance data. Inventory collection is enabled by default.
The following fields can be configured:
Inventory poll interval (min) |
Default is 20 |
Filter VMs |
Select CLUSTER, DATACENTER, or ESX HOST |
Choose 'Exclude' or 'Include' to Specify a List |
Create a filter list (CLUSTER, DATACENTER, and/or ESX_HOST) |
Number of retries |
Default is 3 |
Communication port |
Default is 443 |
Filter Device List… |
This list must consist of exact string matches - if you intend to filter by ESX_HOST, you must build a comma delimited list of the exact "names" of your ESX hosts as reported in both Data Infrastructure Insights and vSphere. These "names" may be either IP addresses, simple hostnames, or fully qualified domain names (FQDNs) - this is determined by how these hosts were named when they were originally added to vSphere. |
Performance poll interval (sec) |
Default is 300 |
Mapping VMware tags to Data Infrastructure Insights annotations
The VMware data collector allows you to populate Data Infrastructure Insights annotations with tags configured on VMware. The DII annotation name must be identical to the VMware category name; the tag is then applied as an annotation value of a DII annotation of the same name as the category. Data Infrastructure Insights will always populate same-named text-type annotations, and will make a "best attempt" to populate annotations of other types (number, boolean, etc). If your annotation is of a different type and the data collector fails to populate it, it may be necessary to remove the annotation and re-create it as a text type.
Note that VMware tags may be case-sensitive, while Data Infrastructure Insights tags are case-insensitive. So if you create an annotation named "OWNER" in Data Infrastructure Insights, and tags named "OWNER", "Owner", and "owner" in VMware, all of those variations of "owner" would map to Cloud Insight’s "OWNER" annotation.
Keep the following in mind:
Data Infrastructure Insights currently only auto-publishes support information for NetApp devices.
Since this support information is held in annotation form, you can query it or use it in dashboards.
If a user overwrites or empties the annotation value, the value is autofilled again when Data Infrastructure Insights updates annotations, which it does once a day.
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
Error: Include list to filter VMs cannot be empty |
If Include List is selected, please list valid DataCenter, Cluster, or Host names to filter VMs |
Error: Failed to instantiate a connection to VirtualCenter at IP |
Possible solutions: |
Error: VirtualCenter at IP has non-conform certificate that JVM requires |
I'm seeing the message: |
Logs collection is not supported on VMware versions prior to 8.0.1. Upgrade your VI Center Infrastructure to version 8.0.1 or later if you wish to use the Logs Collections feature within Data Infrastructure Insights. |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
