Amazon FSx for NetApp ONTAP data collector
This data collector acquires inventory and performance data from Amazon FSx for NetApp ONTAP. This data collector will be made available incrementally throughout the Data Infrastructure Insights service regions. Contact your sales person if you do not see the Icon for this collector in your Data Infrastructure Insights Environment.
This Data Infrastructure Insights collector requires an ONTAP user with a Filesystem-Scoped role. Please review the AWS Roles and Rules documentation for available options. At this time AWS supports only one kind of user role with Filesystem Scope, which is fsxadmin. This is the appropriate role to be used for the Data Infrastructure Insights collector. The user should also have all three of these applications assigned to it: http, ontapi, ssh. |
Terminology
Data Infrastructure Insights acquires inventory and performance data from the FSx-NetApp data collector. For each asset type acquired, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Cluster  |
Storage  |
LUN  |
Volume  |
Volume  |
Internal Volume  |
FSx-NetApp Terminology
The following terms apply to objects or references that you might find on FSx-NetApp storage asset landing pages. Many of these terms apply to other data collectors as well.
Storage
Model – A comma-delimited list of the unique, discrete model names within this cluster.
Vendor – AWS
Serial number – The array serial number.
IP – generally will be the IP(s) or hostname(s) as configured in the data source.
Raw Capacity – base 2 summation of all the SSD storage assigned to the FSx filesystem.
Latency – a representation of what the host facing workloads are experiencing, across both reads and writes. Ideally, Data Infrastructure Insights is sourcing this value directly, but this is often not the case. In lieu of the array offering this up, Data Infrastructure Insights is generally performing an IOPs-weighted calculation derived from the individual internal volumes’ statistics.
Throughput – aggregated from internal volumes.
Management – this may contain a hyperlink for the management interface of the device. Created programmatically by the Data Infrastructure Insights data source as part of inventory reporting.
Storage Pool
Storage – what storage array this pool lives on. Mandatory.
Type – a descriptive value from a list of an enumerated list of possibilities. Most commonly will be “Aggregate” or “RAID Group””.
Capacity – the values here are the logical used, usable capacity and the logical total capacity, and the percentage used across these.
IOPS – the sum IOPs of all the volumes allocated on this storage pool.
Throughput – the sum throughput of all the volumes allocated on this storage pool.
Requirements
The following are requirements to configure and use this data collector:
You must have access to an account with the "fsxadmin" role, with three applications assigned to it - ssh, ontapi, http
Account details include username and password.
Port requirements: 443
Configuration
| Field | Description |
NetApp Management IP  |
IP address or fully-qualified domain name of the NetApp cluster  |
User Name  |
User name for NetApp cluster  |
Password  |
Password for NetApp cluster  |
Advanced Metrics
This data collector collects the following advanced metrics from the FSx for NetApp ONTAP storage:
fpolicy
nfsv3
nfsv3:node
nfsv4
nfsv4_1
nfsv4_1:node
nfsv4:node
policy_group
qtree
volume
workload_volume
Note that FSx CLI and API commands retrieve some capacity values that Data Infrastructure Insights ZAPI doesn't collect, so certain capacity values (such as those for storage pools) may be different in Data Infrastructure Insights than they are on the FSx itself.
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
Receive 401 HTTP response or 13003 ZAPI error code and ZAPI returns “Insufficient privileges” or “not authorized for this command”  |
Check username and password, and user privileges/permissions.  |
ZAPI returns "cluster role is not cluster_mgmt LIF"  |
AU needs to talk to cluster management IP. Check the IP and change to a different IP if necessary  |
ZAPI command fails after retry  |
AU has communication problem with the cluster. Check network, port number, and IP address. User should also try to run a command from command line from the AU machine.  |
AU failed to connect to ZAPI via HTTP  |
Check whether ZAPI port accepts plaintext. If AU tries to send plaintext to an SSL socket, the communication fails.  |
Communication fails with SSLException  |
AU is attempting to send SSL to a plaintext port on a filer. Check whether the ZAPI port accepts SSL, or use a different port.  |
Additional Connection errors:  |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
