Configuring the IBM SAN Volume Controller data collector
The IBM SAN Volume Controller (SVC) data collector collects inventory and performance data using SSH, supporting a variety of devices that run the SVC operating system.
The list of supported devices includes models such as the SVC, the v7000, the v5000, and the v3700. Refer to the Data Infrastructure Insights support matrix for supported models and firmware versions.
Terminology
Data Infrastructure Insights acquires the following inventory information from the IBM SVC data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Drive  |
Disk  |
Cluster  |
Storage  |
Node  |
Storage Node  |
Mdisk Group  |
Storage Pool  |
Vdisk  |
Volume  |
Mdisk  |
Backend LUNs and paths  |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Inventory Requirements
IP address of each SVC cluster
Port 22 available
Read-only user name and password
Performance Requirements
SVC Console, which is mandatory for any SVC cluster and required for the SVC discovery foundation package.
Credentials will require administrative access level only for copying performance files from cluster nodes to the config node.
Enable data collection by connecting to the SVC cluster by SSH and running: svctask startstats -interval 1
Note: Alternatively, enable data collection using the SVC management user interface.
Configuration
| Field | Description |
Cluster IP Addresses  |
IP addresses or fully-qualified domain names of the SVC storage  |
Inventory User Name  |
User name for the SVC CLI  |
Inventory Password  |
Password for the SVC CLI  |
Advanced configuration
Inventory Poll Interval (min)  |
Interval between inventory polls. The default is 40 minutes.  |
Performance Poll Interval (sec)  |
Interval between performance polls. The default is 300 seconds.  |
To clean up dumped stats files  |
Select this checkbox to clean up dumped stats files  |
Troubleshooting
Some things to try if you encounter problems with this data collector:
| Problem: | Try this: |
Error: "The command cannot be initiated because it was not run on the configuration node."  |
The command must be executed on the configuration node.  |
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
