Dell EMC PowerScale data collector
Data Infrastructure Insights uses the Dell EMC PowerScale (previously Isilon) SSH data collector to acquire inventory and performance data from PowerScale scale-out NAS storage.
Terminology
Data Infrastructure Insights acquires the following inventory information from this data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Drive |
Disk |
Cluster |
Storage |
Node |
Storage Node |
File System |
Internal Volume |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
You need the following information to configure this data collector:
Administrator permissions to the PowerScale storage
IP address of the PowerScale cluster
SSH access to port 22
Configuration
| Field | Description |
IP address |
The IP address or fully-qualified domain name of the PowerScale cluster |
User Name |
User name for the PowerScale cluster |
Password |
Password used for the PowerScale cluster |
Advanced configuration
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 20. |
Performance Poll Interval (sec) |
Interval between performance polls. The default is 300. |
SSH Port |
SSH service port. The default is 22. |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
"Invalid login credentials" with error messages “Commands not enabled for role-based administration require root user access” |
* Verify that the user has permissions to run the following commands on the device: |
"Internal Error" with error messages “Command <Your command> run failed with permission: <Your current permission>. Sudo command run permission issue” |
Verify that the user has sudo permissions to run the following command on the device |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
