Node Data Collection
Data Infrastructure Insights gathers metrics from the node on which you install an agent.
Installation
From Observability > Collectors, choose an operating system/platform. Note that installing any integration data collector (Kubernetes, Docker, Apache, etc.) will also configure node data collection.
Follow the instructions to configure the agent. The instructions vary depending on the type of Operating System or Platform you are using to collect data.
Objects and Counters
The following objects and their counters are collected as Node metrics:
| Object: | Identifiers: | Attributes: | Datapoints: |
Node Filesystem |
Node UUID |
Node IP |
Free |
Node Disk |
Node UUID |
Node IP |
IO Time Total |
Node CPU |
Node UUID |
Node IP |
System CPU Usage |
Node |
Node UUID |
Node IP |
Kernel Boot Time |
Node Network |
Network Interface |
Node Name |
Bytes Received |
Setup
Setup and Troubleshooting information can be found on the Configuring an Agent page.
