Data Infrastructure Insights Reporting Overview
Data Infrastructure Insights reporting is a business intelligence tool that enables you to view pre-defined reports or create custom reports.
The Reporting feature is available in Data Infrastructure Insights Premium Edition. Availability of the reporting feature is subject to a minimum footprint requirement. Contact your NetApp sales representative for more information. |
With Data Infrastructure Insights reporting you can perform the following tasks:
Run a pre-defined report
Create a custom report
Customize a report's format and delivery method
Schedule reports to run automatically
Email reports
Use colors to represent thresholds on data
Data Infrastructure Insights Reporting can generate custom reports for areas like chargeback, consumption analysis, and forecasting, and can help answer questions such as the following:
What inventory do I have?
Where is my inventory?
Who is using our assets?
What is the chargeback for allocated storage for a business unit?
How long until I need to acquire additional storage capacity?
Are business units aligned along the proper storage tiers?
How is storage allocation changing over a month, quarter, or year?
Accessing Data Infrastructure Insights Reporting
You can access Data Infrastructure Insights Reporting by clicking the Reports link in the menu.
You will be taken to the Reporting interface. Data Infrastructure Insights uses IBM Cognos Analytics for its reporting engine.
What is ETL?
When working with Reporting, you will hear the terms "Data Warehouse" and "ETL". ETL stands for "Extract, Transform, and Load". The ETL process retrieves data collected in Data Infrastructure Insights, and transforms the data into a format for use in Reporting. "Data Warehouse" refers to the collected data available for Reporting.
The ETL process includes these individual processes:
Extract: Takes data from Data Infrastructure Insights.
Transform: Applies business logic rules or functions to the data as it is extracted from Data Infrastructure Insights.
Load: Saves the transformed data into the data warehouse for use in Reporting.
