Configuring the IBM XIV/A9000 data collector
IBM XIV and A9000 (CLI) data collector uses the XIV command-line interface to collect inventory data while performance collection is accomplished by making SMI-S calls to the XIV/A9000 array, which runs a SMI-S provider on port 7778.
Terminology
| Vendor/Model Term | Data Infrastructure Insights Term |
Disk |
Disk |
Storage System |
Storage |
Storage Pool |
Storage Pool |
Volume |
Volume |
Requirements
The following requirements must be met to configure and use this data collector:
Port requirement: TCP port 7778
Read-only user name and password
The XIV CLI must be installed on the AU
Performance requirements
The following are requirements for performance collection:
SMI-S Agent 1.4 or higher
SMI-S compatible CIMService running on array. Most XIV arrays have a CIMServer installed by default.
User login must be provided for the CIMServer. The login must have full read access to the array configuration and properties.
SMI-S namespace. Default is root/ibm. This is configurable in the CIMServer.
Port Requirements: 5988 for HTTP, 5989 for HTTPS.
Refer to the following link on how to create an account for SMI-S performance collection: https://www.ibm.com/docs/en/products?topic=/com.ibm.tpc_V41.doc/fqz0_t_adding_cim_agent.html
Configuration
| Field | Description |
XIV IP address |
IP address or fully-qualified domain name of the XIV storage |
User Name |
User name for the XIV storage |
Password |
Password for the XIV storage |
Full Path to XIV CLI Directory |
Full path to the folder containing the XIV CLI |
SMI-S Host IP Address |
IP address of the SMI-S host |
Advanced configuration
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 40 minutes. |
SMI-S Protocol |
Protocol used to connect to the SMI-S provider. Also displays the default port. |
Override SMI-S Port |
If blank, use the default port in the Connection Type field, otherwise enter the connection port to use |
Username |
User name for the SMI-S Provider Host |
Password |
Password for the SMI-S Provider Host |
Performance Poll Interval (sec) |
Interval between performance polls. The default is 300 seconds. |
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
