Brocade FC Switch data collector
Data Infrastructure Insights uses the Brocade FC Switch (SSH) data source to discover inventory for Brocade or rebranded switch devices running Factored Operating System (FOS) firmware 4.2 and later. Devices in both FC switch and Access Gateway modes are supported.
Terminology
Data Infrastructure Insights acquires the following inventory information from the Brocade FC Switch data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Switch |
Switch |
Port |
Port |
Virtual Fabric, Physical Fabric |
Fabric |
Zone |
Zone |
Logical Switch |
Logical Switch |
Virtual Volume |
Volume |
LSAN Zone |
IVR Zone |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
The Data Infrastructure Insights Acquisition Unit (AU) will initiate connections to TCP Port 22 on Brocade switches to collect inventory data. The AU will also initiate connections to UDP port 161 for collection of performance data.
There must be IP connectivity to all switches in the fabric. If you select the Discover all switches in the fabric check box, Data Infrastructure Insights identifies all the switches in the fabric; however, it needs IP connectivity to these additional switches to discover them.
The same account is needed globally across all switches in the fabric. You can use PuTTY (open source terminal emulator) to confirm access.
Ports 161 and 162 must be open to all switches in the fabric for SNMP performance polling.
SNMP read-only Community String
Configuration
| Field | Description |
Switch IP |
IP address or fully-qualified domain name of the EFC Server |
User Name |
User name for the switch |
Password |
Password for the switch |
SNMP |
SNMP version |
SNMP Community String |
SNMP read-only community string used to access the switch |
SNMP User Name |
SNMP user name |
SNMP Password |
SNMP password |
Advanced configuration
Fabric name |
Fabric name to be reported by the data collector. Leave blank to report the fabric name as WWN. |
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 15. |
Excluded Devices |
Comma-separated list of device IDs to exclude from polling |
Admin Domains Active |
Select if using Admin Domains |
Retrieve MPR Data |
Select to acquire routing data from your multiprotocol router. |
Enable Trapping |
Select to enable acquisition upon receiving an SNMP trap from the device. If you select enable trapping, you must also activate SNMP. |
Minimum Time Between Traps (sec) |
Minimum time between acquisition attempts triggered by traps. The default is 10. |
Discover all switches in the fabric |
Select to discover all switches in the fabric |
Choose Favoring HBA vs. Zone Aliases |
Choose whether to favor HBA or zone aliases |
Performance Poll Interval (sec) |
Interval between performance polls. The default is 300. |
SNMP Auth Protocol |
SNMP authentication protocol (SNMP v3 only) |
SNMP Privacy Password |
SNMP privacy password (SNMP v3 only) |
SNMP Retries |
Number of SNMP retry attempts |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
The inventory acquisition of the Brocade datasource fails with the error: |
The issue may be caused when the Brocade switch takes too long to return with a prompt, exceeding the default timeout of 5 seconds. |
Error: “Data Infrastructure Insights received Invalid Chassis Role” |
Check that the user configured in this data source has been granted the chassis role permission. |
Error: "Mismatched Chassis IP Address" |
DII does NOT support Network Address Translation or Port Address Translation between the Acquisition Unit and devices as a general rule. DII may be detecting that the hostname/IP address in the collector configuration does NOT match any of the addresses the device believes it has. |
Receive a message that more than 1 node is logged into the Access Gateway port |
Check that the NPV device is operating correctly and that all connected WWNs are expected. Do not directly acquire the NPV device. Instead, acquisition of the core fabric switch will collect the NPV device data. |
Error: ….Max remote sessions for login… |
FOS has different limits for the number of supported concurrent SSH sessions per user role. DII's SSH session to this device is being rejected at login for violating those limits. This can be a sign that you have duplicative collectors discovering the same asset, which should be avoided |
Performance
Performance collection fails with "Timed out during sending SNMP request". |
Depending on query variables and switch configuration, some queries may exceed the default timeout. Learn More. |
Performance collection fails with …Row duplicates found in SNMP table… |
DII has detected bad SNMP responses. You are likely running FOS 8.2.3e. Upgrade to 8.2.3e2 or higher. |
Performance collections fails with …Unknown user name… |
You have configured your DII collector with a "SNMP User Name" value which is not slotted into one of the SNMPv3 user slots. Simply creating a user on Brocade FOS does NOT necessarily enable it as a SNMPv3 user - you must place it in one of the v3 user slots. |
Performance collections fails with …Unsupported Security Level… |
You have configured your DII collector to use SNMPv3, but with encryption (aka privacy) and/or authorization settings which are not enabled on the device in question. |
Performance collection fails with …Empty Privacy Password is only allowed for Privacy Protocol NONE |
You have configured your DII collector to use SNMPv3, with an encryption aka privacy protocol (AES, etc), but you have an empty "SNMP Privacy Password" value, so DII cannot negotiate encrypted SNMPv3 data flows with this device |
Performance collection fails with …..VF:nn, error: No access… |
You have configured your DII collector to use SNMPv3 on a device with multiple Virtual Fabrics enabled, but the SNMPv3 user does NOT have rights for VF NN. DII does not support partial discovery of a physical asset - you should always grant DII access to all 128 possible VFs proactively as DII will always attempt to retrieve performance data for any extant VF on a given physical device |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
