HP Enterprise Alletra 9000 / Primera Storage data collector
Data Infrastructure Insights uses the HP Enterprise Alletra 9000 / HP Enterprise Primera (previously 3PAR) data collector to discover inventory and performance.
Terminology
Data Infrastructure Insights acquires the following inventory information from this data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Field | Description |
Physical Disk |
Disk |
Storage System |
Storage |
Controller Node |
Storage Node |
Common Provisioning Group |
Storage Pool |
Virtual Volume |
Volume |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
The following are required to configure this data collector:
IP address or FQDN of the InServ cluster
For inventory, read-only user name and password to the StoreServ Server
For performance, read-write user name and password to the StoreServ Server
Port requirements: 22 (inventory collection), 5988 or 5989 (performance collection) [Note: Performance is supported for StoreServ OS 3.x+]
For performance collection confirm that SMI-S is enabled by logging into the array via SSH.
Configuration
Storage IP address |
Storage IP address or fully-qualified domain name of the StoreServ cluster |
User Name |
User name for the StoreServ Server |
Password |
Password used for the StoreServ Server |
SMI-S User Name |
User name for the SMI-S Provider Host |
SMI-S Password |
Password used for the SMI-S Provider Host |
Advanced configuration
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 40 minutes. |
SMI-S Connectivity |
Protocol used to connect to the SMI-S provider |
Override SMI-S Default Port |
If blank, use the default port from SMI-S Connectivity, otherwise enter the connection port to use |
Performance Poll Interval (sec) |
Interval between performance polls. The default is 300 seconds. |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
"showsys" command doesn't return any result. |
Run "showsys" and "showversion -a" from the command line and check if the version is supported by the array. |
Performance
Failed to connect or login. Provider initialization failed. |
An all-numeric array name can cause problems with SMI-S server. Try changing the array name. |
SMI-S user configured does not have any domain |
Grant appropriate domain privileges to the configured SMI-S user |
Data Infrastructure Insights states that it cannot connect/login to SMI-S service. |
Confirm there is no firewall between the CI AU and the array that would block the CI AU from making TCP connections to 5988 or 5989. |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
