Data Infrastructure Insights
NetApp StorageGRID data collector
Contributors netapp-alavoie pixelchrome
The NetApp StorageGRID data collector supports inventory and performance collection from StorageGRID configurations.
Note
To provide consistent metering against DII entitlements across all StorageGRID systems regardless of underlying hardware topology and configuration, Data Infrastructure Insights uses the total available capacity (storagegrid_storage_utilization_total_space_bytes), instead of RAW capacity based on physical disk layout.
For customers using the Capacity-based licensing model, StorageGRID is metered as “Object” storage.
For customers using the legacy (MU) licensing model, StorageGRID is metered as secondary storage, at a rate of 40TiB to 1 MU.
Terminology
Data Infrastructure Insights acquires the following inventory information from the NetApp StorageGRID collector. For each asset type acquired, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
StorageGRID
Storage
Node
Node
Tenant
Storage Pool
Bucket
Internal Volume
Requirements
The following are requirements for configuring this data source:
  • StorageGRID Host IP Address
  • A username and password for a user that has had the Metric Query and Tenant Access roles assigned
  • Port 443 (or 8443 if configured)
Configuration
Field Description
Management IP address of the StorageGRID (Grid Manager)
User Name
Name used to log into the StorageGRID (Grid Manager)
Password
Password used to log into the StorageGRID (Grid Manager)
Advanced configuration
Field Description
Inventory Poll Interval (min)
Default is 60 minutes
performance Poll Interval (sec)
Default is 900 seconds
Single Sign-On (SSO)
The StorageGRID firmware versions have corresponding API versions; 3.0 API and newer versions support single sign-on (SSO) login.
Firmware version
API version
Support single sign on (SSO)
11.1
2
No
11.2
3.0
Yes
11.5
3.3
Yes
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
