Huawei OceanStor data collector
Data Infrastructure Insights uses the Huawei OceanStor (REST/HTTPS) data collector to discover inventory and performance for Huawei OceanStor and OceanStor Dorado storage.
Terminology
Data Infrastructure Insights acquires the following inventory and performance information from the Huawei OceanStor. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Storage Pool |
Storage Pool |
File System |
Internal Volume |
Controller |
Storage Node |
FC Port (Mapped) |
Volume Map |
Host FC Initiator (Mapped) |
Volume Mask |
NFS/CIFS Share |
Share |
iSCSI Link Target |
iSCSI Target Node |
iSCSI Link Initiator |
iSCSI Initiator Node |
Disk |
Disk |
LUN |
Volume |
Requirements
The following requirements are required to configure this data collector:
Device IP address
Credentials to access OceanStor device manager
Port 8088 must be available
Configuration
| Field | Description |
OceanStor Host IP Address |
IP address or fully-qualified domain name of the OceanStor Device Manager |
User Name |
Name used to log into the OceanStor Device Manager |
Password |
Password used to log into the OceanStor Device Manager |
Advanced Configuration
TCP Port |
TCP Port used to connect to OceanStor Device Manager. The default is 8088. |
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 60 minutes. |
Performance poll interval (sec). |
The default is 300 seconds. |
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
