Cisco MDS Fabric Switches data collector
Data Infrastructure Insights uses the Cisco MDS Fabric Switches data collector to discover inventory for Cisco MDS Fabric Switches as well as a variety of Cisco Nexus FCoE switches on which the FC service is enabled.
Additionally, you can discover many models of Cisco devices running in NPV mode with this data collector.
Terminology
Data Infrastructure Insights acquires the following inventory information from the Cisco FC Switch data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Switch |
Switch |
Port |
Port |
VSAN |
Fabric |
Zone |
Zone |
Logical Switch |
Logical Switch |
Name Server Entry |
Name Server Entry |
Inter-VSAN Routing (IVR) Zone |
IVR Zone |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
An IP address of one switch in the fabric or individual switches
Chassis discovery, to enable fabric discovery
If using SNMP V2, read-only community string
Port 161 is used to access the device
Configuration
| Field | Description |
Cisco Switch IP |
IP address or fully-qualified domain name of the switch |
SNMP Version |
Select V1, V2, or V3. V2 or later is required for performance acquisition. |
SNMP Community String |
SNMP read-only community string used to access the switch (not applicable for SNMP v3) |
User Name |
User name for the switch (SNMP v3 only) |
Password |
Password used for the switch (SNMPv3 only) |
Advanced configuration
Inventory Poll Interval (min) |
Interval between inventory polls (default 40 minutes) |
SNMP Auth Protocol |
SNMP authentication protocol (SNMPv3 only) |
SNMP Privacy Protocol |
SNMP privacy protocol (SNMPv3 only) |
SNMP Privacy Password |
SNMP Retries |
Number of SNMP retry attempts |
SNMP Timeout (ms) |
SNMP timeout (default 5000 ms) |
Enable Trapping |
Select to enable trapping. If you enable trapping, you must also activate SNMP notifications. |
Minimum Time Between Traps (sec) |
Minimum time between acquisition attempts triggered by traps (default 10 seconds) |
Discover All Fabric Switches |
Select to discover all switches in the fabric |
Excluded Devices |
Comma-separated list of device IPs to exclude from polling |
Included Devices |
Comma-separated list of device IPs to include in polling |
Check Device Type |
Select to accept only those devices that explicitly advertise themselves as Cisco devices |
First Alias Type |
Provide a first preference for resolution of the alias. Choose from the following: |
Second Alias Type |
Provide a second preference for resolution of the alias |
Third Alias Type |
Provide a third preference for resolution of the alias |
Enable SANTap Proxy Mode Support |
Select if your Cisco switch is using SANTap in proxy mode. If you are using EMC RecoverPoint, then you are probably using SANTap. |
Performance Poll Interval (sec) |
Interval between performance polls (default 300 seconds) |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
Error: Failed to discover chassis - no switches have been discovered |
• Ping the device with the IP configured |
Error: Device is not a Cisco MDS switch |
• Make sure the data source IP configured for the device is correct |
Error: Data Infrastructure Insights is not able to obtain the switch’s WWN. |
This may not be a FC or FCoE switch, and as such may not be supported. Make sure the IP/FQDN configured in the datasource is truly a FC/FCoE switch. |
Error: Found more than one nodes logged into NPV switch port |
Disable direct acquisition of the NPV switch |
Error: Could not connect to the switch |
• Make sure the device is UP |
Performance
Error: Performance acquisition not supported by SNMP v1 |
• Edit Data Source and disable Switch Performance |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
