Dell EMC RecoverPoint data collector
The EMC RecoverPoint data collector's primary use case is to discover volume-to-volume replication relationships that the RecoverPoint storage appliance facilitates. This collector will also discover the Recoverpoint appliance itself. Please note that Dell/EMC sells a VMware backup solution for VMs--"RecoverPoint for VMs"--which is not supported by this collector
For configuration, the data collector requires the IP address of the storage processors and a read-only user name and password.
The EMC RecoverPoint data collector gathers the volume-to-volume replication relationships that RecoverPoint coordinates across other storage arrays. Data Infrastructure Insights shows a storage array for each RecoverPoint cluster, and collects inventory data for nodes and storage ports on that cluster. No storage pool or volume data is collected.
Requirements
The following information is required to configure this data collector:
IP address or fully-qualified domain name of storage processor
Read-only user name and password
REST API access via port 443
Configuration
| Field | Description |
Address of RecoverPoint |
IP address or fully-qualified domain name of RecoverPoint cluster |
User Name |
User name for the RecoverPoint cluster |
Password |
Password used for the RecoverPoint cluster |
Advanced configuration
TCP Port |
TCP Port used to connect to Recoverpoint cluster |
Inventory Poll Interval (minutes) |
Interval between inventory polls. The default is 20 minutes. |
Excluded Clusters |
Comma-separated list of cluster IDs or names to exclude when polling. |
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
