Dell EMC VNX Block Storage (NaviCLI) data collector
Data Infrastructure Insights uses the Dell EMC VNX Block Storage (NaviSec) data collector (formerly CLARiiON) to acquire inventory and performance data.
Terminology
Data Infrastructure Insights acquires the following inventory information from the EMC VNX Block Storage data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Disk |
Disk |
Storage |
Storage |
Storage Processor |
Storage Node |
This Pool, RAID Group |
Storage Pool |
LUN |
Volume |
Note: These are common terminology mappings only and might not represent every case for this data source.
Requirements
The following requirements must be met in order to collect data:
An IP address of each VNX block storage processor
Read-only Navisphere username and password to the VNX block storage arrays
NaviSecCli must be installed on the Data Infrastructure Insights AU
Access validation: Run NaviSecCLI from the Data Infrastructure Insights AU to each array using the username and password.
Port requirements: 80, 443
NaviSecCLI version should correspond with the newest FLARE code on your array
For performance, statistics logging must be enabled.
NaviSphere command line interface syntax
naviseccli.exe -h <IP address> -user <user> -password <password> -scope
<scope,use 0 for global scope> -port <use 443 by default> command
Configuration
| Field | Description |
VNX Block Storage IP Address |
IP address or fully-qualified domain name of the VNX block storage |
User Name |
Name used to log into the VNX block storage device. |
Password |
Password used to log into the VNX block storage device. |
CLI Path to naviseccli.exe |
Full path to the folder containing the naviseccli.exe executable |
Advanced Configuration
Inventory Poll Interval (min) |
Interval between inventory polls. Default is 40 minutes. |
Scope |
The secure client scope. The default is Global. |
Performance Poll Interval (sec) |
Interval between performance polls. The default is 300 seconds. |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
Error:
Error: 4.29 emc235848 emc241018 getall Failed to parse host alias info |
This is likely caused by a FLARE 29 corruption issue of the host initiator database on the array itself. See EMC knowledge base articles: emc235848, emc241018. You can also check https://now.netapp.com/Knowledgebase/solutionarea.asp?id=kb58128 |
Error: Unable to retrieve Meta LUNs. Error Executing java -jar navicli.jar |
Error: Storage Pools not reporting disks on Service Processor at configured IP address |
Configure the data collector with both Service Processor IPs, separated by a comma |
Error: Revision mismatch error |
Error: Unsupported Configuration - No Fibre Channel Ports |
The device is not configured with any Fibre Channel ports. Currently, only FC configurations are supported. Verify this version/firmware is supported. |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
