Pure Storage FlashArray data collector
Data Infrastructure Insights uses the Pure Storage FlashArray data collector to gather inventory and performance data.
Terminology
For each asset type acquired by Data Infrastructure Insights, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Drive (SSD) |
Disk |
Array |
Storage |
Controller |
Storage Node |
Volume |
Volume |
LUN Map |
Volume Map |
Initiator,Target |
Volume Mask |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
Storage system IP address
User name and password for the Administrator account of the Pure storage system.
Port requirement: HTTP/HTTPS 80/443
Configuration
| Field | Description |
FlashArray Host IP Address |
IP address of the storage system |
User name |
User name with admin privileges |
Password for the admin privileged account |
Password |
Advanced configuration
Connection type |
Choose HTTP or HTTPS. Also displays the default port. |
Override TCP port |
If blank, use the default port in the Connection Type field, otherwise enter the connection port to use |
Inventory poll interval (min) |
The default is 60 minutes |
Performance Poll Interval (sec) |
The default is 300 |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
"Invalid login credentials" with error messages “Policy doesn't allow” or “You are not authorized” |
Validate Pure user account and password via Pure http interface |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
