Data Infrastructure Insights
Configuring the NetApp HCI Management server data collector
Contributors netapp-alavoie dgracenetapp
The NetApp HCI Management server data collector collects NetApp HCI Host information and requires read-only privileges on all objects within the Management server.
This data collector acquires from the NetApp HCI Management server only. To collect data from the storage system, you must also configure the NetApp SolidFire data collector.
Terminology
Data Infrastructure Insights acquires the following inventory information from this data collector. For each asset type acquired, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
Virtual disk
Disk
Host
Host
Virtual machine
Virtual machine
Data store
Data store
LUN
Volume
Fibre channel port
Port
These are common terminology mappings only and might not represent every case for this data collector.
Requirements
The following information is required to configure this data collector:
  • IP address of the NetApp HCI Management server
  • Read-only username and password for the NetApp HCI Management server
  • Read only privileges on all objects in the NetApp HCI Management server.
  • SDK access on the NetApp HCI Management server – normally already set up.
  • Port requirements: http-80 https-443
  • Validate access:
    • Log into the NetApp HCI Management server using above username and password
    • Verify SDK enabled: telnet <vc_ip> 443
Setup and connection
Field Description
Name
Unique name for the data collector
Acquisition unit
Name of acquisition unit
Configuration
Field Description
NetApp HCI Storage Cluster MVIP
Management Virtual IP Address
SolidFire Management Node (mNode)
Management Node IP Address
User name
User name used to access the NetApp HCI Management server
Password
Password used to access the NetApp HCI Management server
VCenter User Name
User name for VCenter
VCenter Password
Password for VCenter
Advanced configuration
In the advanced configuration screen, check the VM Performance box to collect performance data. Inventory collection is enabled by default.
The following fields can be configured:
Field Description
Inventory poll interval (min)
Deafult is 20
Filter VMs by
Select CLUSTER, DATACENTER, or ESX HOST
Choose 'Exclude' or 'Include' to Specify a List
Specify Whether to Include or Exclude VMs
Filter Device List
List of VMs to filter (comma separated, or semicolon separated if comma is used in the value) for for Filtering by ESX_HOST, CLUSTER, and DATACENTER Only
Performance poll interval (sec)
Default is 300
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
Problem: Try this:
Error: Include list to filter VMs cannot be empty
If Include List is selected, please list valid DataCenter, Cluster, or Host names to filter VMs
Error: Failed to instantiate a connection to VirtualCenter at IP
Possible solutions:
* Verify credentials and IP address entered.
* Try to communicate with Virtual Center using Infrastructure Client.
* Try to communicate with Virtual Center using Managed Object Browser (e.g MOB).
Error: VirtualCenter at IP has non-conform certificate that JVM requires
Possible solutions:
* Recommended: Re-generate certificate for Virtual Center by using stronger (e.g. 1024-bit) RSA key.
* Not Recommended: Modify the JVM java.security configuration to leverage the constraint jdk.certpath.disabledAlgorithms to allow 512-bit RSA key. See JDK 7 update 40 release notes at "http://www.oracle.com/technetwork/java/javase/7u40-relnotes-2004172.html"
Additional information may be found from the Support page or in the Data Collector Support Matrix.
