Dell EMC PowerStore data collector
The EMC PowerStore data collector gathers inventory information from EMC PowerStore storage. For configuration, the data collector requires the IP address of the storage processors and a read-only user name and password.
The EMC PowerStore data collector gathers the volume-to-volume replication relationships that PowerStore coordinates across other storage arrays. Data Infrastructure Insights shows a storage array for each PowerStore cluster, and collects inventory data for nodes and storage ports on that cluster. No storage pool or volume data is collected.
Terminology
Data Infrastructure Insights acquires the following inventory information from this data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
host |
host |
host_volume_mapping |
hardware (it has Drives under "extra_details" object): Drives |
Disk |
Appliance |
StoragePool |
Cluster |
Storage Array |
Node |
StorageNode |
fc_port |
Port |
volume |
Volume |
InternalVolume |
file_system |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
The following information is required to configure this data collector:
IP address or fully-qualified domain name of storage processor
Read-only user name and password
Configuration
| Field | Description |
PowerStore gateway(s) |
IP addresses or fully-qualified domain names of PowerStore storage |
User Name |
User name for PowerStore |
Password |
Password used for PowerStore |
Advanced configuration
HTTPS Port |
Default is 443 |
Inventory Poll Interval (minutes) |
Interval between inventory polls. The default is 60 minutes. |
Cloud Insight's PowerStore performance collection makes use of PowerStore's 5-minute granularity source data. As such, Data Infrastructure Insights polls for that data every five minutes, and this is not configurable.
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
