Managing Reports
You can customize a report's output format and delivery, set report properties or schedules, and email reports.
The Reporting feature is available in Data Infrastructure Insights Premium Edition. |
Before making changes to reporting permissions or security, you must copy "My Content" reports to the "Team Content" folder to ensure Reports are saved. |
Customizing a report's output format and delivery
You can customize the format and delivery method of reports.
In the Data Infrastructure Insights Reporting Portal, Go to Menu > Content > My Content/Team Content. Mouse over the report you want to customize and open the "three dots" menu.
Click Properties > Schedule
You can set the following options:
Schedule when you want reports to run.
Choose Options for report format and delivery (Save, Print, Email) and Languages for the report.
Click Save to produce the report using the selections you made.
Copying a report to the clipboard
Use this process to copy a report to the clipboard.
Select a report to copy from (Menu > Content > My Content or Team Content)
Choose Edit report from the report's drop-down menu
In the upper-right of the screen, open the "three dots" menu next to "Properties".
Select Copy Report to Clipboard.
Opening reports from the clipboard
You can open a report specification that was previously copied to the clipboard.
About this task
Start by creating a new report or opening an existing report that you wish to replace with the copied report. The steps below are for a new report.
Select Menu > +New > Report and create a blank report.
Select Open Report from Clipboard.
Paste the copied code into the window and select OK.
Select the floppy disk icon to save the report.
Choose where to save the report (My Content, Team Content, or create a new folder).
Give the new report a meaningful name and select Save.
Editing an existing report
Be aware that editing files in their default location runs a risk of those reports being overwritten upon the next report catalog refresh. It is recommended to save the edited report under a new name or store it in a non-default location.
Troubleshooting
Here you will find suggestions for troubleshooting problems with Reporting.
Problem: |
Try this: |
When scheduling a report to be sent via email, the name of the user logged in is pre-populated to the email's “To” field. However, the name is in the form of "firstname lastname" (first name, space, last name). Since this is not a valid email address, the email will fail to send when the scheduled report is run. |
When scheduling the report to be sent via email, clear the pre-populated name and enter a valid, properly-formatted email address in the “To” field. |
My scheduled report sends out via email, but the report can not be accessed if the origination is from the “My Content” folder. |
In order to avoid this, the report or report-view must be saved to the “Team Content > Custom Reports - xxxxxx" folder, and the schedule created from that saved version. The "Custom Reports - xxxxxx" folder is visible to all users on the tenant. |
when saving a Job, the folder may show “Team Content” with the list of content from “Custom Reports - xxxxxx”, however you can not save the Job here because Cognos thinks this is the “Team Content” folder where you don't have access to write. |
The work around is to create a new folder with a unique name (i.e. “NewFolder”) and save there, or to save to “My Content” and then copy/move to “Custom Reports - xxxxxx”. |
