Data Infrastructure Insights
Kubernetes Monitoring Operator Configuration Options
Contributors netapp-alavoie
The Kubernetes Monitoring Operator provides extensive customization options through the AgentConfiguration file. You can configure resource limits, collection intervals, proxy settings, tolerations, and component-specific settings to optimize monitoring for your Kubernetes environment. Use these options to customize telegraf, kube-state-metrics, logs collection, workload mapping, change management, and other monitoring components.
Sample AgentConfiguration file
Below is a sample AgentConfiguration file, with descriptions for each option.
apiVersion: monitoring.netapp.com/v1alpha1
kind: AgentConfiguration
metadata:
  namespace: "netapp-monitoring"
  labels:
    installed-by: nkmo-netapp-monitoring
spec:
  ## One can modify the following settings to configure and customize the operator.
  ## Optional settings are commented out with their default values for reference.
  ## To update them, uncomment the line, change the value, and apply the updated AgentConfiguration.
  agent:
    ## [REQUIRED FIELD]
    ## A uniquely identifiable user-friendly cluster name
    ## The cluster name must be unique across all clusters in your Data Infrastructure Insights (DII) environment.
    clusterName: "<my_cluster>"
    ## Proxy settings
    ## If applicable, specify the proxy through which the operator should communicate with DII.
    ## Refer to additional documentation here:
    ## https://docs.netapp.com/us-en/cloudinsights/task_config_telegraf_agent_k8s.html#configuring-proxy-support
    # proxy:
    #   server:
    #   port:
    #   noproxy:
    #   username:
    #   password:
    #   isTelegrafProxyEnabled:
    #   isFluentbitProxyEnabled:
    #   isCollectorsProxyEnabled:
    ## [REQUIRED FIELD]
    ## Repository from which the operator pulls the required images
    ## By default, the operator pulls from the DII repository. To use a private repository, set this field to the
    ## applicable repository name. Refer to additional documentation here:
    ## https://docs.netapp.com/us-en/cloudinsights/task_config_telegraf_agent_k8s.html#using-a-custom-or-private-docker-repository
    dockerRepo: '<my_docker_repository>'
    ## [REQUIRED FIELD]
    ## Name of the imagePullSecret required for dockerRepo
    ## When using a private repository, set this field to the applicable secret name.
    dockerImagePullSecret: 'netapp-ci-docker'
    ## Automatic expiring API key rotation settings
    ## Allow the operator to automatically rotate its expiring API key, generating a new API key and
    ## using it to replace the expiring one. The expiring API key itself must support auto rotation.
    # tokenRotationEnabled: 'true'
    ## Threshold (number of days before expiration) at which the operator should trigger rotation.
    ## The threshold must be less than the total duration of the API key.
    # tokenRotationThresholdDays: '30'
    ## Sets the minimum TLS version for the operator and all collectors
    # minimumTLSVersion: 'TLS13'
  push-button-upgrades:
    ## Allow the operator to be upgraded using the Data Infrastructure Insights (DII) UI
    # enabled: 'true'
    ## Frequency at which the operator polls and checks for upgrade requests from DII
    # polltimeSeconds: '60'
    ## Allow operator upgrade to proceed even if new images are not present
    # ignoreImageNotPresent: 'false'
    ## Allow operator upgrade to proceed even if image signature verification fails
    ## Warning: Enabling this setting is dangerous!
    # ignoreImageSignatureFailure: 'false'
    # ignoreYAMLSignatureFailure: 'false'
    ## Use dockerImagePullSecret to access the image repository and verify the existence of the new images
    # imageValidationUseSecret: 'true'
    ## Time allowed for the old operator pod to shutdown before reporting an upgrade failure to DII
    # upgradesShutdownTime: '240'
    ## Time allowed for the new operator pod to startup before reporting an upgrade failure to DII
    # upgradesStartupTime: '600'
  locally-managed-collectors:
    ## Enable local management of optional plugins.
    ## When enabled, the operator will not request plugin configuration from DII and will instead
    ## manage the enabled plugins. This allows automated/git-based
    ## deployments to control plugin enablement without requiring UI interaction.
    # enabled: 'false'
    ## Enable Fluent Bit event collection plugin
    # fluentbit: 'true'
    ## Enable Change Observer plugin
    # change-observer: 'true'
    ## Enable Network Observer (workload map) plugin
    # net-observer: 'false'
    collectorEnvironment: 'dev'
  telegraf:
    ## Frequency at which telegraf collects data
    ## The frequency should not exceed 60s.
    # collectionInterval: '60s'
    ## Maximum number of metrics per batch
    ## Telegraf sends metrics to outputs in batches. This controls the size of those writes.
    # batchSize: '10000'
    ## Maximum number of unwritten metrics per output
    ## Telegraf caches metrics until they are successfully written by the output. This controls how many metrics
    ## can be cached. Once the buffer is filled, the oldest metrics will get dropped.
    # bufferLimit: '150000'
    ## Rounds collection interval to collectionInterval
    ## If collectionInterval is 60s, collection will occur on-the-minute
    # roundInterval: 'true'
    ## Jitter between plugins on collection
    ## Each input plugin sleeps a random amount of time within jitter before collecting. This can be used to prevent
    ## multiple input plugins from querying the same resources at the same time. The maximum collection interval would
    ## be collectionInterval + collectionJitter.
    # collectionJitter: '0s'
    ## Precision to which collected metrics are rounded
    ## When set to "0s", precision will be set by the units specified by collectionInterval.
    # precision: '0s'
    ## Frequency at which telegraf flushes and writes data
    ## Frequency should not exceed collectionInterval.
    # flushInterval: '60s'
    ## Jitter between plugins on writes
    ## Each output plugin sleeps a random amount of time within jitter before flushing. This can be used to prevent
    ## multiple output plugins from writing the same resources at the same time, and causing large spikes. The maximum
    ## flush interval would be flushInterval + flushJitter.
    # flushJitter: '0s'
    ## Timeout for HTTP output plugins
    ## Time allowed for http output plugins to successfully writing before failing.
    # outputTimeout: '5s'
    ## CPU/Mem limits and requests for netapp-ci-telegraf-ds DaemonSet (telegraf-init)
    # dsInitCpuLimit: '50m'
    # dsInitMemLimit: '20Mi'
    # dsInitCpuRequest: '10m'
    # dsInitMemRequest: '10Mi'
    ## CPU/Mem limits and requests for netapp-ci-telegraf-ds DaemonSet (telegraf-mountstats-poller)
    # dsPollerCpuLimit: '50m'
    # dsPollerMemLimit: '20Mi'
    # dsPollerCpuRequest: '10m'
    # dsPollerMemRequest: '10Mi'
    ## CPU/Mem limits and requests for netapp-ci-telegraf-ds DaemonSet (telegraf)
    # dsCpuLimit: '750m'
    # dsMemLimit: '800Mi'
    # dsCpuRequest: '100m'
    # dsMemRequest: '500Mi'
    ## CPU/Mem limits and requests for netapp-ci-telegraf-rs ReplicaSet (telegraf-rs-init)
    # rsInitCpuLimit: '50m'
    # rsInitMemLimit: '20Mi'
    # rsInitCpuRequest: '10m'
    # rsInitMemRequest: '10Mi'
    ## CPU/Mem limits and requests for netapp-ci-telegraf-rs ReplicaSet (telegraf-rs)
    # rsCpuLimit: '3'
    # rsMemLimit: '4Gi'
    # rsCpuRequest: '100m'
    # rsMemRequest: '500Mi'
    ## telegraf runs through the processor plugins a second time after the aggregators plugins, by default. Use this
    ## option to skip the second run.
    # skipProcessorsAfterAggregators: 'false'
    ## Time aggregation settings for kubernetes metrics
    ## aggregationInterval controls the period over which metrics are aggregated before being sent.
    ## aggregationGrace is the additional time to wait for late-arriving metrics before emitting aggregated values.
    # aggregationInterval: '300s'
    # aggregationGrace: '60s'
    ## Set to true to use the deprecated broad merge aggregator instead of the new
    ## basicstats-based aggregation. This is a failsafe in case the new implementation causes issues.
    # useDeprecatedMerge: false
    ## Additional tolerations for netapp-ci-telegraf-ds DaemonSet and netapp-ci-telegraf-rs ReplicaSet
    ## Inspect the netapp-ci-telegraf-rs ReplicaSet and netapp-ci-telegraf-ds DaemonSet to view the default tolerations.
    ## If additional tolerations are needed, specify them here using the following abbreviated single line format:
    ## Example: '{key: taint1, operator: Exists, effect: NoSchedule},{key: taint2, operator: Exists, effect: NoExecute}'
    # dsTolerations: ''
    # rsTolerations: ''
    ## Additional node selector terms for netapp-ci-telegraf-rs ReplicaSet
    ## Inspect the netapp-ci-telegraf-rs ReplicaSet to view the default node selectors terms. If additional node
    ## selector terms are needed, specify them here using the following abbreviated single line format:
    ## Example: '{"key": "myLabel1","operator": "In","values": ["myVal1"]},{"key": "myLabel2","operator": "In","values": ["myVal2"]}'
    ## These additional node selector terms will be AND'd with the default ones via matchExpressions.
    # rsNodeSelectorTerms: ''
    ## telegraf uses lockable memory to protect secrets in memory. If telegraf issues warnings about insufficient
    ## lockable memory, try increasing the limit of lockable memory on the applicable nodes. If increasing this limit
    ## is not an option for the given environment, set unprotected to true so telegraf does not attempt to use
    ## lockable memory.
    # unprotected: 'false'
    ## Run the netapp-ci-telegraf-ds DaemonSet's telegraf-mountstats-poller container in privileged mode
    ## The telegraf-mountstats-poller container needs read-only access to system files such as those in /proc/ (i.e. to
    ## monitor NFS IO metrics, etc.). Some environments impose restricts that prevent the container from reading these
    ## system files. Unless those restrictions are lifted, users may need to run this container in privileged mode.
    # runPrivileged: 'false'
    ## Run the netapp-ci-telegraf-ds DaemonSet's telegraf container in privileged mode
    ## The telegraf container needs read-only access to system files such as those in /dev/ (i.e. for the telegraf
    ## diskio input plugin to retrieve disk metrics). Some environments impose restricts that prevent the container from
    ## accessing these system files. Unless those restrictions are lifted, users may need to run this container in
    ## privileged mode.
    # runDsPrivileged: 'false'
    ## Allow the netapp-ci-telegraf-ds DaemonSet's telegraf, telegraf-init, and telegraf-mountstats-poller containers
    ## to run with escalation privilege. This is needed to access/read root-protected files (node UUID,
    ## /proc/1/mountstats, etc.). Allowing escalation privilege should negate the need to run these containers in
    ## privileged mode.
    # allowDsPrivilegeEscalation: 'false'
    ## Allow the netapp-ci-telegraf-rs DaemonSet's telegraf-rs and telegraf-rs-init containers
    ## etcd credentials when applicable, etc.). Allowing escalation privilege should negate the need to run these
    ## containers in privileged mode.
    # allowRsPrivilegeEscalation: 'false'
    ## Enable collection of block IO metrics (kubernetes.pod_to_storage)
    # dsBlockIOEnabled: 'true'
    ## Enable collection of NFS IO metrics (kubernetes.pod_to_storage)
    # dsNfsIOEnabled: 'true'
    ## Enable collection of system-specific objects/metrics for managed k8s clusters
    ## This consists of k8s objects within the kube-system and cattle-system namespaces for managed k8s clusters
    ## (i.e. EKS, AKS, GKE, managed Rancher, etc.).
    # managedK8sSystemMetricCollectionEnabled: 'false'
    ## Enable collection of pod ephemeral storage metrics (kubernetes.pod_volume)
    # podVolumeMetricCollectionEnabled: 'false'
    ## Comma-separated list of volume names for which to collect kubernetes.pod_volume metrics
    ## If list is empty, metrics will be collected for all volumes.  If list is set, metrics will be collected
    ## for the specified volume names only (i.e. "myVol1,myVol2"); all others will be ignored/dropped.
    # podVolumeIncludeList: ''
    ## Collect kubernetes.pod_volume metrics for volumes with used_bytes greater than that specified
    ## If kubernetes.pod_volume.used_bytes is less than that specified, metrics for that pod volume
    ## will be ignored/dropped.
    # podVolumeMinUsedBytes: '1048576'
    ## Declare Rancher cluster is managed
    ## Rancher can be deployed in managed or on-premise environments. The operator contains logic to try to determine
    ## which type of environment Rancher is running in (i.e. to factor into managedK8sSystemMetricCollectionEnabled).
    ## If the operator logic misidentifies whether Rancher is running in a managed environment or not, use this option
    ## to declare Rancher is managed.
    # isManagedRancher: 'false'
    ## Locations for the etcd certificate and key files
    ## The operator looks at well-known locations for the etcd certificate and key files. If this cannot find these
    ## files, the applicable telegraf input plugin will fail. Use this option to specify the complete filepath to these
    ## files on the nodes.
    # rsHostEtcdCrt: ''
    # rsHostEtcdKey: ''
    ## Allow operator/telegraf communications with k8s without TLS verification
    ## In some environments, TLS verification will not succeed (i.e. certificates lack IP SANs). To skip the
    ## verification, use this option.
    # insecureK8sSkipVerify: 'false'
    ## telegraf-ds security context, selinux options type
    ## If SELinux is enabled, it may be configured to prevent containers from accessing system-owned directories or
    ## files (i.e. /proc/1/mountstats, etc.).  When this happens, telegraf-ds may fail to function properly, erroring
    ## on permission denials.  Users may need to circumvent the SELinux restriction by setting the context as needed.
    ## For example, dsSeLinuxOptionsType: 'spc_t'
    # dsSeLinuxOptionsType: ''
    ## Host path for kubelet pod directories on the node
    ## The telegraf-mountstats-poller container mounts this path to collect nfs metrics.
    ## Override when kubelet stores pods in a non-default location.
    # dsHostNodePodDir: '/var/lib/kubelet/pods'
    ## telegraf-rs security context, selinux options type
    ## files (i.e. /sys/class/dmi/id/product_uuid, etc.).  When this happens, telegraf-rs may fail to function
    ## properly, erroring on permission denials.  Users may need to circumvent the SELinux restriction by setting the
    ## context as needed.
    ## For example, rsSeLinuxOptionsType: 'spc_t'
    # rsSeLinuxOptionsType: ''
    ## Enable collection of etcd metrics
    ## Collection of etcd metrics requires access to etcd credential files.  The well-known locations for these files
    ## are typically root-protected. Therefore, when enableEtcdCollection is set to true, users will typically
    ## also need to set allowRsPrivilegeEscalation to true as well.  Users opposed to allowing privilege escalation
    ## may instead place the etcd credential files in a non-root-accessible location and specify that location through
    ## the rsHostEtcdCrt and rsHostEtcdKey options.
    # enableEtcdCollection: 'false'
  kube-state-metrics:
    ## CPU/Mem limits and requests for netapp-ci-kube-state-metrics StatefulSet
    # cpuLimit: '500m'
    # memLimit: '1Gi'
    # cpuRequest: '100m'
    # memRequest: '500Mi'
    ## Comma-separated list of k8s resources for which to collect metrics
    ## Refer to the kube-state-metrics --resources CLI option
    # resources: 'cronjobs,daemonsets,deployments,horizontalpodautoscalers,namespaces,nodes,persistentvolumeclaims,persistentvolumes,pods,replicasets,resourcequotas,services,statefulsets'
    ## Comma-separated list of k8s metrics to collect
    ## Refer to the kube-state-metrics --metric-allowlist CLI option
    # metrics: 'kube_cronjob_created,kube_cronjob_status_active,kube_cronjob_labels,kube_daemonset_created,kube_daemonset_status_current_number_scheduled,kube_daemonset_status_desired_number_scheduled,kube_daemonset_status_number_available,kube_daemonset_status_number_misscheduled,kube_daemonset_status_number_ready,kube_daemonset_status_number_unavailable,kube_daemonset_status_observed_generation,kube_daemonset_status_updated_number_scheduled,kube_daemonset_metadata_generation,kube_daemonset_labels,kube_deployment_status_replicas,kube_deployment_status_replicas_available,kube_deployment_status_replicas_unavailable,kube_deployment_status_replicas_updated,kube_deployment_status_observed_generation,kube_deployment_spec_replicas,kube_deployment_spec_paused,kube_deployment_spec_strategy_rollingupdate_max_unavailable,kube_deployment_spec_strategy_rollingupdate_max_surge,kube_deployment_metadata_generation,kube_deployment_labels,kube_deployment_created,kube_namespace_created,kube_namespace_labels,kube_namespace_status_phase,kube_node_info,kube_node_labels,kube_node_role,kube_node_spec_unschedulable,kube_node_created,kube_persistentvolume_capacity_bytes,kube_persistentvolume_status_phase,kube_persistentvolume_labels,kube_persistentvolume_info,kube_persistentvolume_claim_ref,kube_persistentvolumeclaim_access_mode,kube_persistentvolumeclaim_info,kube_persistentvolumeclaim_labels,kube_persistentvolumeclaim_resource_requests_storage_bytes,kube_persistentvolumeclaim_status_phase,kube_pod_info,kube_pod_start_time,kube_pod_completion_time,kube_pod_owner,kube_pod_labels,kube_pod_status_phase,kube_pod_status_ready,kube_pod_status_scheduled,kube_pod_container_info,kube_pod_container_status_waiting,kube_pod_container_status_waiting_reason,kube_pod_container_status_running,kube_pod_container_state_started,kube_pod_container_status_terminated,kube_pod_container_status_terminated_reason,kube_pod_container_status_last_terminated_reason,kube_pod_container_status_ready,kube_pod_container_status_restarts_total,kube_pod_overhead_cpu_cores,kube_pod_overhead_memory_bytes,kube_pod_created,kube_pod_deletion_timestamp,kube_pod_init_container_info,kube_pod_init_container_status_waiting,kube_pod_init_container_status_waiting_reason,kube_pod_init_container_status_running,kube_pod_init_container_status_terminated,kube_pod_init_container_status_terminated_reason,kube_pod_init_container_status_last_terminated_reason,kube_pod_init_container_status_ready,kube_pod_init_container_status_restarts_total,kube_pod_status_scheduled_time,kube_pod_status_unschedulable,kube_pod_spec_volumes_persistentvolumeclaims_readonly,kube_pod_container_resource_requests_cpu_cores,kube_pod_container_resource_requests_memory_bytes,kube_pod_container_resource_requests_storage_bytes,kube_pod_container_resource_requests_ephemeral_storage_bytes,kube_pod_container_resource_limits_cpu_cores,kube_pod_container_resource_limits_memory_bytes,kube_pod_container_resource_limits_storage_bytes,kube_pod_container_resource_limits_ephemeral_storage_bytes,kube_pod_init_container_resource_limits_cpu_cores,kube_pod_init_container_resource_limits_memory_bytes,kube_pod_init_container_resource_limits_storage_bytes,kube_pod_init_container_resource_limits_ephemeral_storage_bytes,kube_pod_init_container_resource_requests_cpu_cores,kube_pod_init_container_resource_requests_memory_bytes,kube_pod_init_container_resource_requests_storage_bytes,kube_pod_init_container_resource_requests_ephemeral_storage_bytes,kube_replicaset_status_replicas,kube_replicaset_status_ready_replicas,kube_replicaset_status_observed_generation,kube_replicaset_spec_replicas,kube_replicaset_metadata_generation,kube_replicaset_labels,kube_replicaset_created,kube_replicaset_owner,kube_resourcequota,kube_resourcequota_created,kube_service_info,kube_service_labels,kube_service_created,kube_service_spec_type,kube_statefulset_status_replicas,kube_statefulset_status_replicas_current,kube_statefulset_status_replicas_ready,kube_statefulset_status_replicas_updated,kube_statefulset_status_observed_generation,kube_statefulset_replicas,kube_statefulset_metadata_generation,kube_statefulset_created,kube_statefulset_labels,kube_statefulset_status_current_revision,kube_statefulset_status_update_revision,kube_node_status_capacity,kube_node_status_allocatable,kube_node_status_condition,kube_pod_container_resource_requests,kube_pod_container_resource_limits,kube_pod_init_container_resource_limits,kube_pod_init_container_resource_requests,kube_horizontalpodautoscaler_spec_max_replicas,kube_horizontalpodautoscaler_spec_min_replicas,kube_horizontalpodautoscaler_status_condition,kube_horizontalpodautoscaler_status_current_replicas,kube_horizontalpodautoscaler_status_desired_replicas'
    ## Comma-separated list of k8s label keys that will be used to determine which labels to export/collect
    ## Refer to the kube-state-metrics --metric-labels-allowlist CLI option
    # labels: 'cronjobs=[*],daemonsets=[*],deployments=[*],horizontalpodautoscalers=[*],namespaces=[*],nodes=[*],persistentvolumeclaims=[*],persistentvolumes=[*],pods=[*],replicasets=[*],resourcequotas=[*],services=[*],statefulsets=[*]'
    ## Additional tolerations for netapp-ci-kube-state-metrics StatefulSet
    ## Inspect the netapp-ci-kube-state-metrics StatefulSet to view the default tolerations. If additional
    ## tolerations are needed, specify them here using the following abbreviated single line format:
    # tolerations: ''
    ## Additional node selector terms for netapp-ci-kube-state-metrics StatefulSet
    ## Inspect the kube-state-metrics StatefulSet to view the default node selectors terms. If additional node selector
    ## terms are needed, specify them here using the following abbreviated single line format:
    # nodeSelectorTerms: ''
    ## Number of kube-state-metrics shards
    ## For large clusters, kube-state-metrics may be overwhelmed with collecting and exporting the amount of metrics
    ## generated. This can lead to collection timeouts for the netapp-ci-telegraf-rs pod. If this is observed, use this
    ## option to increase the number of kube-state-metrics shards to redistribute the workload.
    # shards: '2'
  logs:
    ## Allow the netapp-ci-fluent-bit-ds DaemonSet's fluent-bit container to run with escalation privilege.
    # fluent-bit-allowPrivilegeEscalation: 'false'
    ## Read content from the head of the file, not the tail
    # readFromHead: "true"
    ## Network protocol for DNS (i.e. UDP, TCP, etc.)
    # dnsMode: "UDP"
    ## DNS resolver (i.e. LEGACY, ASYNC, etc.)
    # fluentBitDNSResolver: "LEGACY"
    ## Additional tolerations for netapp-ci-fluent-bit-rs ReplicaSet
    ## Inspect the netapp-ci-fluent-bit-rs ReplicaSet to view the default tolerations. If additional tolerations are
    ## needed, specify them here using the following abbreviated single line format:
    # fluent-bit-tolerations: ''
    ## CPU/Mem limits and requests for netapp-ci-fluent-bit-rs ReplicaSet (fluent-bit-init)
    # fluent-bit-init-cpuLimit: '50m'
    # fluent-bit-init-memLimit: '20Mi'
    # fluent-bit-init-cpuRequest: '10m'
    # fluent-bit-init-memRequest: '10Mi'
    ## CPU/Mem limits and requests for netapp-ci-fluent-bit-rs ReplicaSet (logrotate)
    # fluent-bit-rotate-cpuLimit: '50m'
    # fluent-bit-rotate-memLimit: '20Mi'
    # fluent-bit-rotate-cpuRequest: '10m'
    # fluent-bit-rotate-memRequest: '10Mi'
    ## CPU/Mem limits and requests for netapp-ci-fluent-bit-rs ReplicaSet (fluent-bit)
    # fluent-bit-cpuLimit: '500m'
    # fluent-bit-memLimit: '1Gi'
    # fluent-bit-cpuRequest: '50m'
    # fluent-bit-memRequest: '100Mi'
    ## TTL for deduping of k8s events
    # fluent-bit-k8s-event-ttl-seconds: '3600'
  workload-map:
    ## Run workload-map container with escalation privilege to coordinate memlocks
    ## Allow the netapp-ci-net-observer-l4-ds DaemonSet's net-observer container to run with escalation privilege.
    ## This is needed to coordinate memlocks.
    # allowPrivilegeEscalation: 'true'
    ## CPU/Mem limits and requests for netapp-ci-net-observer-l4-ds DaemonSet
    # cpuLimit: '500m'
    # memLimit: '500Mi'
    ## Metric aggregation interval (in seconds)
    ## Set metricAggregationInterval between 30 and 120
    # metricAggregationInterval: '60'
    ## Interval for bpf polling
    ## Set bpfPollInterval between 3 and 15
    # bpfPollInterval: '8'
    ## Enable reverse DNS lookups on observed IPs
    # enableDNSLookup: 'true'
    ## Additional tolerations for netapp-ci-net-observer-l4-ds DaemonSet
    ## Inspect the netapp-ci-net-observer-l4-ds DaemonSet to view the default tolerations. If additional tolerations
    ## are needed, specify them here using the following abbreviated single line format:
    # l4-tolerations: ''
    ## Run the netapp-ci-net-observer-l4-ds DaemonSet's net-observer container in privileged mode
    ## Some environments impose restricts that prevent the net-observer container from running.
    ## Unless those restrictions are lifted, users may need to run this container in privileged mode.
    ## net-observer-l4-ds security context, selinux options type
    ## files (i.e. /sys/kernel, etc.).  When this happens, net-observer-l4-ds may fail to function
    ## For example, seLinuxOptionsType: 'spc_t'
    # seLinuxOptionsType: ''
  change-management:
    ## CPU/Mem limits and requests for netapp-ci-change-observer-watch-rs ReplicaSet
    # cpuLimit: '1'
    # memLimit: '1Gi'
    # cpuRequest: '500m'
    ## Interval (in seconds) after which a non-successful deployment of a workload will be marked as failed
    # workloadFailureDeclarationIntervalSeconds: '30'
    ## Frequency (in seconds) at which workload deployments are combined and sent
    # workloadDeployAggrIntervalSeconds: '300'
    ## Frequency (in seconds) at which non-workload deployments are combined and sent
    # nonWorkloadDeployAggrIntervalSeconds: '15'
    ## Set of regular expressions used in env names and data maps whose value will be redacted
    # termsToRedact: '"pwd", "password", "token", "apikey", "api-key", "api_key", "jwt", "accesskey", "access_key", "access-key", "ca-file", "key-file", "cert", "cafile", "keyfile", "tls", "crt", "salt", ".dockerconfigjson", "auth", "secret"'
    ## Additional node selector terms for netapp-ci-change-observer-watch-rs ReplicaSet
    ## Inspect the netapp-ci-change-observer-watch-rs ReplicaSet to view the default node selectors terms. If additional
    ## node selector terms are needed, specify them here using the following abbreviated single line format:
    ## Comma-separated list of additional kinds to watch
    ## Each kind should be prefixed by its API group. This list in addition to the default set of kinds watched by the
    ## collector.
    ## Note: Kubernetes secrets are not watched by default. To enable secret change tracking, add "secrets" here
    ## and grant secrets RBAC permissions via additional-permissions.yaml.
    ## Example: '"authorization.k8s.io.subjectaccessreviews"'
    # additionalKindsToWatch: ''
    ## Comma-separated list of additional field paths whose diff is ignored as part of change analytics
    ## This list in addition to the default set of field paths ignored by the collector.
    ## Example: '"metadata.specTime", "data.status"'
    # additionalFieldsDiffToIgnore: ''
    ## Comma-separated list of kinds to ignore from watching from the default set of kinds watched by the collector
    ## Example: '"networking.k8s.io.networkpolicies,batch.jobs", "authorization.k8s.io.subjectaccessreviews"'
    # kindsToIgnoreFromWatch: ''
    ## Frequency with which log records are sent to DII from the collector
    # logRecordAggrIntervalSeconds: '20'
    ## Additional tolerations for netapp-ci-change-observer-watch-rs ReplicaSet
    ## Inspect the netapp-ci-change-observer-watch-rs ReplicaSet to view the default tolerations. If additional
    # watch-tolerations: ''
