Configuring the Hitachi Vantara NAS data collector
The Hitachi Vantara NAS data collector is an inventory and configuration data collector that supports discovery of HDS NAS clusters. Data Infrastructure Insights supports discovering NFS and CIFS shares, file systems (Internal Volumes), and spans (Storage Pools).
Terminology
Data Infrastructure Insights acquires the following inventory information from the HNAS data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Tier |
Disk Group |
Cluster |
Storage |
Node |
Storage Node |
Span |
Storage Pool |
System Drive |
Backend Lun |
Files System |
Internal Volume |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
Device IP address
Port 22, SSH protocol
Username and password - privilege level: Supervisor
Note: This data collector is SSH based, so the AU that hosts it must be able to initiate SSH sessions to TCP 22 on the HNAS itself, or the Systems Management Unit (SMU) that the cluster is connected to.
Configuration
| Field | Description |
HNAS Host |
IP address or fully-qualified domain name of HNAS Management Host |
User Name |
User name for HNAS CLI |
Password |
Password used for HNAS CLI |
Advanced configuration
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 30 minutes. |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
"Error connecting" with error messages “Error setting up shell channel:”or “Error opening shell channel” |
Likely caused by network connectivity issues or SSH is misconfigured. Confirm connection with alternate SSH client |
"Timeout" or “Error retrieving data" with error messages “Command: XXX has timed out." |
* Try the command with alternate SSH client |
"Error connecting " or “Invalid login credentials" with error messages “Could not communicate with the device:" |
* Check IP address |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
