Data Infrastructure Insights
Brocade Network Advisor data collector
Contributors netapp-alavoie
Data Infrastructure Insights uses the Brocade Network Advisor data collector to acquire inventory and performance data from Brocade switches.
Terminology
Data Infrastructure Insights acquires the following inventory information from the Brocade Network Advisor data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
Switch
Switch
Port
Port
Virtual Fabric, Physical Fabric
Fabric
Logical Switch
Logical Switch
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
The following are required to configure this data collector:
  • The Data Infrastructure Insights Acquisition Unit will initate connections to TCP port 443 on the BNA server. BNA server must be running version 14.2.1 or higher.
  • Brocade Network Advisor Server IP address
  • User name and password to an administrator account
  • Port requirement: HTTP/HTTPS 443
Configuration
Field Description
IP address of the Network Advisor Server
User Name
User name for the switch
User Name
Administrator user name
Password
Administrator password
Advanced configuration
Field Description
Connection Type
HTTPS (default port 443) or HTTP (default port 80)
Override Connection Port
If blank, use the default port in the Connection Type field, otherwise enter the connection port to use
Password
Password for the switch
Inventory poll interval (min)
The default is 40
Report Access Gateway
Check to include devices in Access Gateway mode
Performance Poll Interval (sec)
The default is 1800
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
Problem: Try this:
Receive a message that more than 1 node is logged into the Access Gateway port, or data collector fails to discover Access Gateway device.
Check that the NPV device is operating correctly and that all connected WWNs are expected. Do not directly acquire the NPV device. Instead, acquisition of the core fabric switch will collect the NPV device data.
Additional information may be found from the Support page or in the Data Collector Support Matrix.
