HP Enterprise Command View data collector
The HP Enterprise Command View Advanced Edition data collector supports discovering XP and P9500 arrays via Command View Advanced Edition (CVAE) server. Data Infrastructure Insights communicates with CVAE using the standard Command View API to collect inventory and performance data.
Terminology
Data Infrastructure Insights acquires the following inventory information from the HP Enterprise Command View data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
PDEV |
Disk |
Journal Pool |
Disk Group |
Storage Array |
Storage |
Port Controller |
Storage Node |
Array Group, DP Pool |
Storage Pool |
Logical Unit, LDEV |
Volume |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Inventory requirements
You must have the following in order to collect inventory data:
IP address of the CVAE server
Read-only user name and password for the CVAE software and peer privileges
Port requirement: 2001
Performance requirements
The following requirements must be met in order to collect performance data:
HDS USP, USP V, and VSP performance
Performance Monitor must be licensed.
Monitoring switch must be enabled.
The Export Tool (Export.exe) must be copied to the Data Infrastructure Insights AU and extracted to a location. On CI Linux AUs, ensure "cisys" has read and execute permissions.
The Export Tool version must match the microcode version of the target array.
AMS performance:
The Storage Navigator Modular 2 (SNM2) CLI utility be installed on the Data Infrastructure Insights AU.
Network requirements
The Export Tools are Java based, and use RMI to speak to the array. These tools may not be firewall-friendly as they may dynamically negotiate source and destination TCP ports on each invocation. Also, different model array's Export Tools may behave differently across the network - consult HPE for your model's requirements
Configuration
| Field | Description |
Command View Server |
IP address or fully-qualified domain name of the Command View server |
User Name |
User name for the Command View server. |
Password |
Password used for the Command View server. |
Devices - VSP G1000 (R800), VSP (R700), HUS VM (HM700) and USP storages |
Device list for VSP G1000 (R800), VSP (R700), HUS VM (HM700) and USP storages. Each storage requires: |
SNM2Devices - WMS/SMS/AMS Storages |
Device list for WMS/SMS/AMS storages. Each storage requires: |
Choose Tuning Manager for Performance |
Override other performance options |
Tuning Manager Host |
IP address or fully-qualified domain name of tuning manager |
Tuning Manager Port |
Port used for Tuning Manager |
Tuning Manager Username |
User name for Tuning Manager |
Tuning Manager Password |
Password for Tuning Manager |
Note: In HDS USP, USP V, and VSP, any disk can belong to more than one array group.
Advanced configuration
Field |
Description |
Command View Server Port |
Port used for the Command View Server |
HTTPs Enabled |
Select to enable HTTPs |
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 40. |
Choose 'Exclude' or 'Include' to specify a list |
Specify whether to include or exclude the array list below when collecting data. |
Exclude or Include Devices |
Comma-separated list of device ID's or array names to include or exclude |
Query Host Manager |
Select to query host manager |
Performance Polling Interval (sec) |
Interval between performance polls. The default is 300. |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
Error: User does not have enough permission |
Use a different user account that has more privilege or increase the privilege of user account configured in the data collector |
Error: Storages list is empty. Either devices are not configured or the user does not have enough permission |
* Use DeviceManager to check if the devices are configured. |
Error: HDS storage array was not refreshed for some days |
Investigate why this array is not being refreshed in HP CommandView AE. |
Performance
Error: |
* Confirm that Export Utility is installed on the Data Infrastructure Insights Acquisition Unit |
Error: Export tool login failed for target IP |
* Confirm that username/password is correct |
Error: Export tools logged "Unable to get time range for monitoring". |
* Confirm performance monitoring is enabled on the array. |
Error: |
* Configure only supported storage arrays. |
Error: |
* Check Export utility location. |
Error: |
* Confirm that Storage Navigator Modular CLI is installed on the Data Infrastructure Insights Acquisition Unit |
Error: Configuration error: Storage Array not reported by Inventory |
Check if Storage Array in question is configured in Command View server |
Error: |
* Open Command prompt and change directory to the configured path |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
