Infinidat InfiniBox data collector
The Infinidat InfiniBox (HTTP) data collector is used to collect inventory information from the Infinidat InfiniBox storage system.
Terminology
Data Infrastructure Insights acquires the following inventory information from the Infinidat InfiniBox data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Storage Pool |
Storage Pool |
Node |
Controller |
Filesystem |
Internal Volume |
Filesystem |
File Share |
Filesystem Exports |
Share |
Requirements
The following are requirements when configuring this data collector.
IP address or FQDN of InfiniBox management Node
Admin userid and password
Port 443 via REST API
Configuration
| Field | Description |
InfiniBox Host |
IP address or fully-qualified domain name of the InfiniBox Management Node |
User Name |
User name for InfiniBox Management Node |
Password |
Password for the InfiniBox Management Node |
Advanced configuration
TCP Port |
TCP Port used to connect to InfiniBox Server. The default is 443. |
Inventory Poll Interval |
Interval between inventory polls. The default is 60 minutes. |
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
