Defining annotations
When customizing Data Infrastructure Insights to track data for your corporate requirements, you can define specialized notes, called annotations, and assign them to your assets.
You can assign annotations to assets with information such as asset end of life, data center, building location, storage tier, or volume service level.
Using annotations to help monitor your environment includes the following high-level tasks:
Creating or editing definitions for all annotation types.
Displaying asset pages and associating each asset with one or more annotations.
For example, if an asset is being leased and the lease expires within two months, you might want to apply an end-of-life annotation to the asset. This helps prevent others from using that asset for an extended time.
Creating rules to automatically apply annotations to multiple assets of the same type.
Filter assets by their annotations.
Default annotation types
Data Infrastructure Insights provides some default annotation types. These annotations can be used to filter or group data.
You can associate assets with default annotation types such as the following:
Asset life cycle, such as birthday, sunset, or end of life
Location information about a device, such as data center, building, or floor
Classification of assets, such as by quality (tiers), by connected devices (switch level), or by service level
Status, such as hot (high utilization)
The following table lists the Data Infrastructure Insights-provided annotation types.
Annotation types  |
Description  |
Type  |
Alias  |
User-friendly name for a resource  |
Text  |
Compute Resource Group  |
Group assignment used by the Host and VM Filesystems data collector  |
List  |
Data Center  |
Physical location  |
List  |
Hot  |
Devices under heavy use on a regular basis or at the threshold of capacity  |
Boolean  |
Note  |
Comments associated with a resource  |
Test  |
Service Level  |
A set of supported service levels that you can assign to resources. Provides an ordered options list for internal volumes, qtree, and volumes. Edit service levels to set performance policies for different levels.  |
List  |
Sunset  |
Threshold set after which no new allocations can be made to that device. Useful for planned migrations and other pending network changes.  |
Date  |
Switch Level  |
Predefined options for setting up categories for switches. Typically, these designations remain for the life of the device, although you can edit them. Available only for switches.  |
List  |
Tier  |
Can be used to define different levels of service within your environment. Tiers can define the type of level, such as speed needed (for example, gold or silver). This feature is available only on internal volumes, qtrees, storage arrays, storage pools, and volumes.  |
List  |
Violation Severity  |
Rank (for example, major) of a violation (for example, missing host ports or missing redundancy), in a hierarchy of highest to lowest importance.  |
List  |
Alias, Data Center, Hot, Service Level, Sunset, Switch Level, Tier, and Violation Severity are system-level annotations, which you cannot delete or rename; you can change only their assigned values. |
Creating custom annotations
Using annotations, you can add custom business-specific data that matches your business needs to assets. While Data Infrastructure Insights provides a set of default annotations, you might find that you want to view data in other ways. The data in custom annotations supplements device data already collected, such as storage manufacturer, number volumes, and performance statistics. The data you add using annotations is not discovered by Data Infrastructure Insights.
In the Data Infrastructure Insights menu, click Manage > Annotations.
The Annotations page displays the list of annotations.
Click +Add
Enter a Name and Description of the annotation.
You can enter up to 255 characters in these fields.
Click Type and then select one of the following options that represents the type of data allowed in this annotation:
Boolean: Creates a drop-down list with the choices of yes and no. For example, the "Direct Attached" annotation is Boolean.
Date: This creates a field that holds a date. For example, if the annotation will be a date, select this.
List: Creates either of the following:
A drop-down fixed list
When others are assigning this annotation type on a device, they cannot add more values to the list.
A drop-down flexible list
If you select the Add new values on the fly option when you create this list, when others are assigning this annotation type on a device, they can add more values to the list.
Number: Creates a field where the user assigning the annotation can enter a number. For example, if the annotation type is "Floor", the user could select the Value Type of "number" and enter the floor number.
Text: Creates a field that allows free-form text. For example, you might enter "Language" as the annotation type, select "Text" as the value type, and enter a language as a value.
After you set the type and save your changes, you cannot change the type of the annotation. If you need to change the type, you have to delete the annotation and create a new one. |
If you select List as the annotation type, do the following:
Select Add new values on the fly if you want the ability to add more values to the annotation when on an asset page, which creates a flexible list.
For example, suppose you are on an asset page and the asset has the City annotation with the values Detroit, Tampa, and Boston. If you selected the Add new values on the fly option, you can add additional values to City like San Francisco and Chicago directly on the asset page instead of having to go to the Annotations page to add them. If you do not choose this option, you cannot add new annotation values when applying the annotation; this creates a fixed list.
Enter a value and description in Value and Description fields.
Click Add to add additional values.
Click the Trash icon to delete a value.
Click Save
Your annotations appear in the list on the Annotations page.
When filtering on a Boolean annotation, you may be presented with the following values on which to filter:
Any: This will return all results, including results set to "Yes", "No", or not set at all.
Yes: Returns only "Yes" results. Note that DII shows "Yes" as a check mark in most tables. Values may be set to "True", "On", etc.; DII treats all of these as "Yes".
No: Returns only "No" results. Note that DII shows "No" as an "X" in most tables. Values may be set to "False", "Off", etc.; DII treats all of these as "No".
None: Returns only results where the annotation has not been set at all. Also referred to as "Null" values.
In the UI, the annotation is available immediately for use.
