Data Infrastructure Insights
Configuring the EMC VPLEX data collector
Contributors netapp-alavoie
This data collector acquires inventory and performance data from EMC VPLEX storage systems. For configuration, the data collector requires an IP address of the VPLEX server and an administrative level domain account.
Note Data Infrastructure Insights' performance collection from VPLEX clusters requires that the performance archive service be operational, in order to populate the .CSV files and logs that Data Infrastructure Insights retrieves via SCP-based file copies. NetApp has observed that many VPLEX firmware upgrade/management station updates will leave this functionality non-operational. Customers planning such upgrades may want to proactively ask Dell/EMC if their planned upgrade will leave this functionality inoperable, and if so, how can they re-enable it to minimize gaps in performance visibility? Cloud Insight's VPLEX performance code will assess on each poll whether all the expected files exist, and if they are being properly updated; if they are missing or stale, Data Infrastructure Insights will log performance collection failures.
Terminology
Data Infrastructure Insightst acquires the following inventory information from the VPLEX data collector. For each asset type acquired, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
Cluster
Storage
Engine
Storage Node
Device, System Extent
Backend Storage Pool
Virtual Volume
Volume
Front-End Port, Back-End Port
Port
Distributed Device
Storage Synchronization
Storage View
Volume Map, Volume Mask
Storage Volume
Backend LUN
ITLs
Backend Path
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
  • An IP address of the VPLEX Management Console
  • Administrative level domain account for the VPLEX server
  • Port 443 (HTTPS). Requires outbound connectivity to TCP port 443 on the VPLEX management station.
  • For performance, read-only username and password for ssh/scp access.
  • For performance, port 22 is required.
Configuration
Field Description
IP address of VPLEX Management Console
IP address or fully-qualified domain name of the VPLEX Management Console
User Name
User name for VPLEX CLI
Password
Password used for VPLEX CLI
Performance Remote IP Address
Performance Remote IP address of the VPLEX Management Console
Performance Remote User Name
Performance Remote user name of VPLEX Management Console
Performance Remote Password
Performance Remote Password of VPLEX Management Console
Advanced configuration
Field Description
Communication Port
Port used for VPLEX CLI. The default is 443.
Inventory Poll Interval (min)
The default is 20 minutes.
Number of connection retries
The default is 3.
Performance Poll Interval (sec)
Interval between performance polls. The default is 600 seconds.
Number of Retries
The default is 2.
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
Problem: Try this:
Error: User authentication failed.
Make sure your credentials for this device are correct.
Performance
Problem: Try this:
Error: VPLEX performance for version below 5.3 is not supported.
Upgrade VPLEX to 5.3 or above
Error: No enough data collected.
• Check collection timestamp in log file and modify polling interval accordingly
• Wait for longer time
Error: Perpetual Log files not being updated.
Please contact EMC support to enable updating the perpetual log files
Error: Performance polling interval is too big.
Check collection timestamp in log file ${logfile} and modify polling interval accordingly
Error: Performance Remote IP address of VPLEX Management Console is not configured.
Edit the data source to set Performance Remote IP address of VPLEX Management Console.
Error: No performance data reported from director
• Check that the system performance monitors are running correctly
• Please contact EMC support to enable updating the system performance monitor log files
Additional information may be found from the Support page or in the Data Collector Support Matrix.
