IBM System Storage DS8000 Series data collector
The IBM DS (CLI) data collector supports inventory and performance data acquisition for DS6xxx and DS8xxx devices.
DS3xxx, DS4xxx, and DS5xxx devices are supported by the NetApp E-Series data collector. You should refer to the Data Infrastructure Insights support matrix for supported models and firmware versions.
Terminology
Data Infrastructure Insights acquires the following inventory information from the IBM DS data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Disk Drive Module |
Disk |
Storage Image |
Storage |
Extent Pool |
Storage Node |
Fixed Block Volume |
Volume |
Host FC Initiator (Mapped) |
Volume Mask |
Note: These are common terminology mappings only and might not represent every case for this data collecor.
Requirements
You need the following to configure this data collector:
IP address of each DS array
Read-only username and password on each DS array
Third-party software installed on the Data Infrastructure Insights AU: IBM dscli
Access validation: Run dscli commands using the username and password
Port requirements: 80, 443, & 1750
Configuration
| Field | Description |
DS Storage |
IP address or fully-qualified domain name of the DS device |
User Name |
User name for the DS CLI |
Password |
Password for the DS CLI |
dscli executable path |
Full path to the dscli executable |
Advanced configuration
Inventory Poll Interval (min) |
Interval between inventory polls (min). The default is 40. |
Storage Display Name |
Name of the IBM DS storage array |
Inventory Exclude Devices |
Comma-separated list of device serial numbers to exclude from inventory collection |
Performance Poll Interval (sec) |
The default is 300. |
Performance Filter Type |
Include: Data collected only from devices on list. Exclude: No data from these devices is collected |
Performance Filter Device List |
Comma-separated list of device IDs to include or exclude from performance collection |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
Error containing: CMUC00192E, CMUC00191E or CMUC00190E |
* Verify credentials and IP address entered. |
Error: |
* From Data Infrastructure Insights Acquisition Unit Open a CMD |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
