Hitachi HCP data collector
This data collector supports the Hitachi Content Platform (HCP) using the HCP Management API.
Hitachi Content Platform is metered at a different Raw TB to Managed Unit rate. Every 40 TB of unformatted HCP capacity is charged as 1 Managed Unit (MU). |
Terminology
Data Infrastructure Insights acquires the following inventory information from the Hitachi HCP data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
HCP Cluster |
Storage |
Tenant |
Storage Pool |
Namespace |
Internal Volume |
Node |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Inventory Requirements
You must have the following in order to collect inventory data:
IP address of the HCP server
Read-only user name and password for the HCP software and peer privileges
Configuration
| Field | Description |
HCP Host |
IP address or fully-qualified domain name of the HCP host |
HCP Port |
Default is 9090 |
HCP User ID |
User name for the HCP host. |
HCP Password |
Password used for the HCP host. |
HCP Authentication Type |
Choose HCP_LOCAL or ACTIVE_DIRECTORY |
Advanced configuration
Field |
Description |
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 60. |
Performance Poll Interval (sec) |
Interval between performance polls. The default is 900. |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
