NetApp Generic DB Host resolver
This data collector acquires inventory
Terminology
Data Infrastructure Insights acquires inventory from this collector.
Configuration
Field | Description |
DB Server IP Address |
IP address of the DB server |
DB Server Port |
default is 3306 |
Qualified Driver Class Name |
Class name for the driver. |
JDBC Driver URL |
URL for the driver |
SQL Query |
The query used to return data from the table |
Advanced configuration
Inventory Poll Interval (Min) |
Default is 60 minutes |
Enable SSL Connection |
Select to enable connection via SSL |
Report WWN Alias |
Select to report the WWN alias |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
