Data Infrastructure Insights
Nutanix AHV data collector
Contributors netapp-alavoie
The Nutanix AHV collector acquires Nutanix Acropolis Hypervisor (AHV) inventory and virtualization performance from Nutanix Prism Central using Prism Central v4 REST APIs (Cluster Management and Virtual Machine Management namespaces). It reports data in the virtualization OData model (VirtualizationRoot and related entities: hosts, virtual machines, datastores, virtual disks, and relationships).
Terminology
Vendor/Model Term Data Infrastructure Insights Term
AHV Node (Host)
Host
Prism Central Cluster
Hypervisor (Virtual Server)
Acropolis VM
Virtual Machine
Storage Container
Data Store
ADSF Volume Group
LUN
VM Disk
Virtual Disk
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
  • Prism Central IP address or Fully Qualified Domain Name
  • Prism Central local or LDAP username and password (read-only account is sufficient)
  • Port requirement: HTTPS 9440
  • Prism Central version pc.2023.x or later (v3 API); pc.7.x or later recommended (v4 API)
  • Performance metrics require Prism Central with API v4.0.b1 or later (pc.7.3+). On older versions, inventory is collected but no performance data is reported.
Configuration
Field Description
Prism Central IP / Hostname
IP address or FQDN of the Prism Central instance
User name
Prism Central username
Password
Prism Central password
Advanced configuration
Field Description
TCP port
TCP Port used to connect to Prism Central. Default is 9440.
Inventory poll interval (min)
Interval between inventory polls. Default is 60 minutes.
Performance poll interval(sec)
Interval between performance polls. Default is 300 seconds.
HTTP timeout (sec)
HTTP request timeout. Default is 60.
HTTP retry count
Number of HTTP retries on transient failures. Default is 3.
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
