Data Infrastructure Insights
Red Hat OpenShift Virtualization data collector
Contributors netapp-alavoie
The DII Promox Virtual Environment collector will collect inventory data. This is an HTTPS REST API-based collector.
Terminology
For each asset type acquired by Data Infrastructure Insights, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
Disk
Virtual Disk
Host
Host
Virtual Machine
Virtual Machine
Storage Domain
Data Store
Logical Unit
LUN
Note: These are common terminology mappings only and might not represent every case for this data collector.
Configuration
Field Description
Hostname or IP address
hostname IP address of the storage system
API Token ID
API token required for access
API Token Secret
Secret for the above token
Advanced configuration
Field Description
HTTPS Communication Port
Port used for HTTPS communication (default 8006)
Inventory poll interval (min)
The default is 20 minutes.
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
