Data Infrastructure Insights
Proxmox Virtual Environment data collector
Contributors netapp-alavoie
The DII Proxmox Virtual Environment collector will collect inventory and performance data for PVE based virtual machines (not LXC containers) and host/hypervisors. This is an HTTPS REST API-based collector that needs to speak to the Proxmox REST API provided by the pveproxy service/daemon that listens on TCP 8006.
This data collector uses user + token authentication. You will need to create a service account on each Proxmox cluster, and assign the appropriate permissions to the user, and then generate an API token with those same rights. Please note that a given Proxmox user's token does NOT necessarily have the same rights/permissions as the user. DII will generally need global Audit/Monitor level rights - if you are creating a service account via the Proxmox UI, for PathPermision start at "/", set Propagate to "Yes", and unlock Datastore Audit, Mapping Audit, Pool Audit, SDN Audit, Sys Audit, VM Audit, VM Monitor at minimum. With the user created, you can then create an access token for it. Strongly consider creating the token with an expiration of 0 to ensure the token never expires.
Terminology
For each asset type acquired by Data Infrastructure Insights, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
Disk
Virtual Disk
Host
Host
Virtual Machine
Virtual Machine
Storage
Data Store
Note: These are common terminology mappings only and might not represent every case for this data collector.
Configuration
Field Description
Hostname or IP address
hostname IP address of the storage system
API Token ID
API token required for access
API Token Secret
Secret for the above token
Advanced configuration
Field Description
HTTPS Communication Port
Port used for HTTPS communication (default 8006)
Inventory poll interval (min)
The default is 20 minutes.
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
