Data Infrastructure Insights
Pure Storage FlashBlade data collector
Contributors netapp-alavoie
Data Infrastructure Insights uses the Pure Storage FlashBlade data collector to gather inventory and performance data from FlashBlade clusters that expose version 2 of their REST API.
Terminology
For each asset type acquired by Data Infrastructure Insights, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
Drive (SSD)
Disk
Array
Storage
Blade
Storage Node
File System
Internal Volume
Object storage bucket
Qtree
Initiator,Target
Volume Mask
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
  • Storage system IP address or Fully Qualified Domain Name
  • API token, ideally with an infinite lifespan. A readonly level user should suffice.
  • Port requirement: HTTPS 443
Configuration
Field Description
FlashBlade Host IP Address
IP address of the storage system
User name
User name to help Data Infrastructure Insights admins remember for which user their API token belongs to
API token
API token
Advanced configuration
Field Description
Connection type
Choose HTTP or HTTPS. Also displays the default port.
Override TCP port
If blank, use the default port in the Connection Type field, otherwise enter the connection port to use
Inventory poll interval (min)
The default is 60 minutes
Performance Poll Interval (sec)
The default is 300
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
Problem: Try this:
"Invalid login credentials" with error messages “Policy doesn't allow” or “You are not authorized”
Validate Pure user account and password via Pure http interface
Additional information may be found from the Support page or in the Data Collector Support Matrix.
