Data Infrastructure Insights
Qumulo REST data collector
Contributors netapp-alavoie
Data Infrastructure Insights uses this collector to acquire inventory and performance data from Qumulo storage.
Terminology
Data Infrastructure Insights acquires the following inventory information from this data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
Drive
Disk
Cluster
Storage
Node
Storage Node
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
You need the following information to configure this data collector:
  • A user account and password with at least read permission.
  • IP address / Fully Qualified Domain Name of the Qumulo cluster
  • HTTPS access to port 8000
Configuration
Field Description
Qumulo IP address
The IP address or fully-qualified domain name of the Qumulo storage
User Name
User name for the Qumulo
Password
Password used for the Qumulo
Advanced configuration
Field Description
HTTPS Port
The default is 8000.
Inventory Poll Interval (min)
Interval between inventory polls. The default is 30.
Performance Poll Interval (min)
Interval between performance polls. The default is 5.
Troubleshooting
Additional information may be found from the Support page or in the Data Collector Support Matrix.
