Data Infrastructure Insights
Red Hat OpenShift Virtualization data collector
Contributors netapp-alavoie
The DII Red Hat OpenShift Virtualization collector will attempt to discover the OSV compute workloads running on an OpenShift Virtualization environment - this collector will not discover all Open Shift pods. This is an HTTPS REST API-based collector. It is recommended to create one collector per OSV cluster.
The authentication approach for this collector is an authentication token bound to a service account. To create both the user account and the token:
oc create sa acq-readonly-cluster-user -n default
oc adm policy add-cluster-role-to-user cluster-reader -z acq-readonly-cluster-user --rolebinding-name acq-readonly-cluster-user-binding
oc adm policy add-cluster-role-to-user cluster-monitoring-view -z acq-readonly-cluster-user --rolebinding-name acq-readonly-cluster-monitor-user-binding
Run those 3 commands and watch for any errors.
When the commands complete, run:
oc create token acq-readonly-cluster-user --duration=8760h
This will create a token bound to your user.
Note: It is recommended to set token duration. Be aware that Data collection will fail with a “Failed to connect” error following token expiration.
Finally, you may also want your OSV administrator to run:
oc cluster-info
This will return the hostname/IP address for management. Each DII OSV collector needs to be pointed at the IP/hostname for OSV management.
Terminology
For each asset type acquired by Data Infrastructure Insights, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
Disk
Virtual Disk
Host
Host
Virtual Machine
Virtual Machine
Storage Domain
Data Store
Logical Unit
LUN
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
  • IP address of the Red Hat OpenShift Virtualization server over port 6443 via REST API
  • Read-only username and password
  • RHEV Version 3.0+
Configuration
Field Description
RHEV Server IP Address
IP address of the storage system
User name
User name with admin privileges
Password for the admin privileged account
Password
Advanced configuration
Field Description
HTTPS Communication Port
Port used for HTTPS communication to RHOV. Default is 6443.
Inventory poll interval (min)
The default is 20 minutes.
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
