Access the NetApp Data Migrator UI
After you deploy the control plane VM and verify that the services and pods are running successfully, access the NetApp Data Migrator UI and connect to the control plane, Linux workers, and Windows workers.
Verify that you have the control plane VM private IP address, which you obtained when you deployed the control plane VM. You use the control plane VM private IP address to access the UI.
Navigate to the control plane using a web browser:
https://<control-plane-private-ip-address>/ -
Use the default username and password to log in.
Based on your migration type, select one of the following tabs:
NFS: This option is for NFS migrations (Linux workers).
SMB: This option is for SMB migrations (Windows workers).
Follow the onscreen instructions to use the control plane to connect to the deployed worker VMs.
On the home page, select View Instruction to Setup Worker.
Check the status in the Workers section to verify that the worker is successfully connected.
After the workers are successfully connected, you can configure the NetApp Data Migrator environment and run migration jobs.
After learning about accessing the NetApp Data Migrator UI, you can configure NetApp Data Migrator.
