NetApp Data Migrator
Configure NetApp Data Migrator
Contributors netapp-pcarriga
After you install NetApp Data Migrator, you need to log in as an App Admin (administrator) using the default username and password.
Log in to NetApp Data Migrator
Log in to NetApp Data Migrator, then change your login credentials and create your first project.
Steps
  1. Open a web browser and navigate to NetApp Data Migrator:
    https://<private_IP_address>/
  2. On the Welcome page, enter the default username in Username/Email .
  3. Enter the default password in Password .
  4. Select Login.
    The Reset Password page opens.
  5. Enter a new password that meets the following security requirements:
    • Includes at least 8 characters
    • Includes at least one uppercase letter
    • Includes at least one lowercase letter
    • Includes at least one number
    • Includes at least one special character
  6. Select Reset Password. The Your Details page opens.
  7. Enter your First Name, Last Name, and Email address.
  8. Select Proceed. The Create a New Project page opens.
  9. Select Create Project, then enter the following details:
    • Project Name: Enter a descriptive name for your project.
    • Project Description (Optional): You can provide additional details about your project.
  10. Select Create.
    The new project appears in the notification bar at the top of the NetApp Data Migrator control plane.
Log out of NetApp Data Migrator
After you log out of NetApp Data Migrator, you need to use your newly created credentials (email and password) the next time you log in.
Steps
  1. Select the User icon (next to Settings).
  2. Select Logout. The Welcome page opens.
  3. In Email and Password, enter the email address and password that you registered when you logged in.
  4. Select Login.
What's next?
After learning about configuring NetApp Data Migrator, you can use NetApp Data Migrator.
