NetApp Data Migrator
Create the control plane and worker VMs to access NetApp Data Migrator
Contributors netapp-pcarriga
Create the control plane virtual machine (VM) and Linux and Windows worker VMs to access NetApp Data Migrator.
Before you begin
For SMB migrations only, download the Windows Worker Installer from the NetApp Support Site.
About this task
You create the control plane VM and Linux worker VM using the images that you deployed using AWS, Azure, or Google Cloud service or OVA templates. You create the Windows worker VM using the Windows Worker Installer. The Linux worker VM supports NFS migrations and the Windows worker VM supports SMB migrations. You can create multiple worker VMs based on your needs.
Steps
  1. Use the deployed control plane image to create a control plane VM with the following recommended configuration:
    Description Recommended setting
    VM configuration
    • Image: Custom imported image for the control plane
    • Network interface card type: gVNIC
    • Size: 8 vCPU, 64 GB RAM
    • Storage: 200 GiB
      For storage planning, you should allocate approximately 1.1 GB of disk space for every one million files. You can estimate the total disk requirement by multiplying the expected number of files (in millions) by 1.1. For example, if you expect around 5 million files, the estimated disk space required for file metadata would be 5 × 1.1 GB = 5.5 GB.
      Additionally, you should allocate the following storage:
      • A extra 50 GB for Docker images, operating system storage, and other system level components
      • Provision additional buffer space to accommodate future growth and operational overhead
    Hyperscaler
    • AWS: r7i.2xlarge instance
    • Azure VM size : Standard_E8ds_v5
    • Google Cloud machine type : c3-highmem-8
  2. Use the deployed Linux worker image to create the Linux worker VM to support NFS migration with the following recommended configuration:
    VM configuration
    • Image: Custom imported image for the Linux worker
    • Size: 4 vCPU, 16 GB RAM
    • Storage: 100 GB
    Hyperscaler
    • AWS: r7i.2xlarge
  3. Create a Windows worker VM to support SMB migrations using the Windows Worker Installer:
    1. Create a Windows VM with the following recommended configuration settings:
      • Image: Windows Server 2022 Base
      • Architecture: 64bit
      • Size: 16 vCPU, 64 GB RAM
      • Ensure Remote Desktop Protocol (RDP) (3389) is open
    2. Create a remote working session using RDP.
      Learn about RDP connections.
    3. Copy and run the Windows Worker Installer on the control plane VM.
What's next?
After learning about creating the control plane and worker VMs, you can do the following:
