Create and manage Hyper-V protection groups in NetApp Backup and Recovery
Create protection groups to protect related Hyper-V VMs together and manage their backup operations in NetApp Backup and Recovery.
You can perform these protection group tasks:
Create a protection group.
View protection group details.
Back up a protection group now. See Back up Hyper-V workloads now.
Delete a protection group.
Group workloads that you want to protect together into a protection group. Create a protection group to back up and restore those workloads together.
Required NetApp Console role
Backup and Recovery super admin or Backup and Recovery backup admin role. Learn about NetApp Console access roles for all services.
Be aware that for Hyper-V workloads, the scheduled backup time is interpreted in the
time zone of the management host. See Create and manage Hyper-V backup policies in NetApp Backup and Recovery for more information.
From the NetApp Backup and Recovery menu, select Inventory.
Select a workload to view its protection details.
Select the Actions icon
> View details. -
Select the Protection groups tab.
Select Create protection group.
Enter a name for the protection group.
Select the VMs that you want to include in the protection group.
Select Next.
Select a behavior for spanning disks. Currently, Always include all spanning disks is supported.
For CIFS and SAN configurations, Backup and Recovery automatically protects every disk attached to each VM in the protection group. This includes files distributed across multiple ONTAP volumes or ONTAP storage systems (spanning disks) and files limited to a single location (non-spanning disks). -
Select Next.
Select the protection policy that you want to apply to the protection group.
Optionally, you can select Create new policy to create a new protection policy. When you select a policy, policy details appear.
When finished, select Next.
Review the configuration.
Select Create to create the protection group.
Edit a protection group
Edit a protection group to change its name or settings. You might want to edit a protection group if the resources in the group have changed.
Select a workload to view the protection details.
> View details. -
Select the protection group that you want to edit.
> Edit.The Edit protection group wizard guides you through the settings in the protection group.
Make any necessary changes on each screen of the wizard.
When finished, select Submit.
Apply an updated host time zone to an existing protection group
Scheduled backups use the Hyper-V host's time zone that is recorded when the protection group's schedule is created. If you change the host's time zone, existing protection groups continue to run on their original time zone (typically UTC) until you update their schedules.
Schedules are only re-created when you modify the protection group name, add or remove a VM, change the assigned policy, or update pre/post scripts. Saving without any changes will not update the schedules. This one-time schedule update does not start an immediate backup. |
Refresh the Hyper-V host so its current time zone is retrieved.
Edit the protection group and change its name to a different value, then save.
Deleting a protection group removes it and all associated backup schedules. You might want to delete a protection group if it is no longer needed.
> View details. -
Select the protection group that you want to delete.
> Delete. -
Review the confirmation message about deleting the associated backups and confirm the deletion.
