NetApp Backup and Recovery
Protect Oracle Database workloads with NetApp Backup and Recovery
Contributors netapp-mwallis
Use NetApp Backup and Recovery to protect Oracle Database workloads and logs with fast, space-efficient, crash-consistent, and database-consistent backups and restores. You can back up workloads to AWS S3, StorageGRID, Azure Blob, or ONTAP S3 and restore backups to an on-premises Oracle host.
Use NetApp Backup and Recovery to implement a 3-2-1 protection strategy, where you have 3 copies of your source data on 2 different storage systems along with 1 copy in the cloud. The benefits of the 3-2-1 approach include:
  • Multiple data copies protect against internal and external cybersecurity threats.
  • Using different types of media helps you recover if one type fails.
  • You can quickly restore from the onsite copy, and use the offsite copies if the onsite copy is compromised.
Oracle Data Guard support
NetApp Backup and Recovery can protect Oracle Data Guard configurations that have a single-instance primary database and one physical standby database in the mounted state.
Supported tasks
