NetApp Backup and Recovery
Create and manage Kubernetes backup policies in NetApp Backup and Recovery
Contributors netapp-mwallis
Use NetApp Backup and Recovery to create Kubernetes backup policies that control backup frequency, schedule, and retention.
If you import resources from SnapCenter, you might encounter some differences with policies used in SnapCenter and those used in NetApp Backup and Recovery. See Policy differences between SnapCenter and NetApp Backup and Recovery.
You can perform these policy tasks:
  • Create a local snapshot policy
  • Create a policy for replication to secondary storage
  • Create a policy for object storage settings
  • Configure advanced policy settings
  • Edit policies
  • Delete policies
View policies
  1. From the NetApp Backup and Recovery menu, select Policies.
  2. Review the policy details. For example:
    • Workload: Examples include Microsoft SQL Server, ONTAP Volumes, VMware, KVM, Hyper-V, Oracle Database, or Kubernetes.
    • Backup type: Examples include full backup and log backup.
    • Architecture: Examples include local snapshot, fan-out, cascading, disk to disk, and disk to object store.
    • Resources protected: Shows how many resources out of the total resources on that workload are protected.
    • Ransomware protection: Shows if the policy includes snapshot locking on the local snapshot, snapshot locking on secondary storage, or DataLock locking on object storage.
Create a policy
You can create policies that govern your local snapshots, replications to secondary storage, and backups to object storage. Part of your 3-2-1 strategy involves creating a snapshot of the instances, databases, applications, or VMs on the primary storage system.
Required NetApp Console role
You need both of the following:
  • Organization admin
  • Either Backup and Recovery super admin or Backup and Recovery backup admin
If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about Backup and recovery roles and privileges. Learn about NetApp Console access roles for all services.
Before you begin
If you plan to replicate to secondary storage and want to use snapshot locking on local snapshots or on remote ONTAP secondary storage, you first need to initialize the ONTAP compliance clock on the cluster level. This is a requirement for enabling snapshot locking in the policy.
For instructions on how to do this, refer to Initialize the compliance clock in ONTAP.
For information about snapshot locking in general, refer to Snapshot locking in ONTAP.
Steps
  2. From the Policies page, select Create new policy.
    The Policies page appears.
  3. Enter information in the Details section:
    • Workload type: Select Kubernetes.
    • Enter a policy name.
    • Select a Console agent from the Agent list.
  4. Enter information in the Backup architecture section. Choose the data flow for the backup from the list:
    • 3-2-1 fanout: Primary storage (disk) to secondary storage (disk) to cloud (object store). Creates multiple copies of data across different storage systems, such as ONTAP to ONTAP and ONTAP to object-store configurations. This can be a cloud provider object store or a private object store. Best for optimal data protection and disaster recovery. This option is not available for Amazon FSx for NetApp ONTAP.
    • Disk to disk: Primary storage (disk) to secondary storage (disk). The ONTAP to ONTAP data protection strategy replicates data between two ONTAP systems to ensure high availability and disaster recovery. This is typically achieved using SnapMirror, which supports both synchronous and asynchronous replication. This method keeps your data updated and available across locations for strong data protection.
    • Disk-to-object storage: Primary storage (disk) to cloud (object store). This replicates data from an ONTAP system to an object storage system. This can be a cloud provider object store or a private object store such as StorageGRID. This method is ideal for long-term data retention and archiving. This option is not available for Amazon FSx for NetApp ONTAP.
    • Local snapshots: Local snapshot on the selected volume. This creates read-only, point-in-time copies of production volumes where your workloads are running. You can use local snapshots to recover from data loss or corruption, as well as to create backups for disaster recovery purposes.
  5. Provide information for the Local snapshot settings section:
    • Select the Add schedule option to select the snapshot schedule or schedules. You can have a maximum of five schedules.
    • Snapshot frequency: Select the frequency of hourly, daily, weekly, monthly, or yearly. The yearly frequency is not available for Kubernetes workloads.
    • Snapshot retention: Enter the number of snapshots to keep.
    • Provider: Select the storage provider that hosts the Kubernetes application resources, and enter the credentials to authenticate with the provider.
  6. Provide information for the Secondary settings section (replication to secondary storage):
    • Backup: Select the frequency of hourly, daily, weekly, monthly, or yearly.
    • Backup target: Select the target system on secondary storage for the backup.
    • Retention: Enter the number of snapshots to keep.
  7. Provide information for the Object store settings section (backup to object storage):
    Note The fields that appear differ depending on the provider and architecture selected.
    • Provider: Select the provider for your object store and enter the credentials in the appropriate fields (the credentials fields differ depending on the provider).
    • Backup target: Select a registered object storage target. Verify that the target is accessible within your backup environment.
    • IPspace: Select the IPspace to use for the backup operations. This is useful if you have multiple IPspaces and want to control which one is used for backups.
    • Schedule settings: Select the schedule that was set for the local snapshots. You can remove a schedule, but you cannot add one because the schedules are set according to the local snapshot schedules.
    • Retention copies: Enter the number of snapshots to keep.
    • Run at: Choose the ONTAP transfer schedule to back up data to object storage.
    • Tier your backups from object store to archival storage: If you choose to tier backups to archive storage (for example, AWS Glacier), select the tier option and the number of days to archive.
  8. Optionally, configure advanced settings in the policy.
    Details
    • Backup retries: To retry the job a certain number of times in case of a failure or interruption, expand the Backup retries section and enter the maximum number of snapshot and backup job retries and the retry time interval.
    Tip If the snapshot frequency is set to one hour, the maximum delay along with the retry count shouldn't exceed 45 minutes.
    • VM configuration: Select the type of backup consistency you need:
      • Crash-consistent backup: Select this option to skip VM freezing before taking a snapshot or backup. The snapshot or backup will be crash-consistent, meaning that the system memory at the time of the snapshot or backup is not captured.
      • VM-consistent backup: Select this option to freeze VMs before taking a snapshot or backup. This captures the full VM state (including memory) to provide VM-consistent protection. Optionally, in Max VMs at once, specify how many VMs Backup and Recovery can freeze and back up at the same time. If you enable the Freeze all VMs option, Backup and Recovery freezes all VMs simultaneously, starts the backups, and then thaws all VMs after all backup operations complete.
    • Partial success: Enable this option to allow a backup operation to complete successfully even if Backup and Recovery fails to back up all resources.
  9. When finished, select Done.
Edit a policy
You can edit backup architecture, backup frequency, retention policy, and other settings for a policy. For Kubernetes workload policies, you can edit schedule and retention settings only.
You can add another protection level when you edit a policy, but you cannot remove a protection level. For example, if the policy is only protecting local snapshots, you can add replication to secondary storage or backups to object storage. If you have local snapshots and replication, you can add object storage. However, if you have local snapshots, replication, and object storage, you cannot remove one of these levels.
If you are editing a policy that backs up to object storage, you can enable archival.
If you imported resources from SnapCenter, you might encounter some differences with policies used in SnapCenter and those used in NetApp Backup and Recovery. See Policy differences between SnapCenter and NetApp Backup and Recovery.
Backup and Recovery super admin or Backup and Recovery backup admin. If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about NetApp Console access roles for all services.
Steps
  1. In the NetApp Console, go to Protection > Backup and Recovery.
  2. Select the Policies option.
  3. Select the policy that you want to edit.
  4. Select the Actions Actions icon icon, and select Edit.
  5. When finished editing, select Done.
  6. In the confirmation dialog, type the policy name to confirm the changes.
    Saving the changes affects all applications that are protected by this policy.
  7. Select Done to confirm.
Delete a policy
You can delete a policy if you no longer need it.
Tip You cannot delete a policy that is associated with a workload.
Steps
  3. Select the policy that you want to delete.
  4. Select the Actions Actions icon icon, and select Delete.
  5. Confirm the action, and select Delete.
