NetApp Backup and Recovery
Restore NetApp Backup and Recovery configuration data in a dark site
Contributors netapp-mwallis
In private mode (no internet access), NetApp Backup and Recovery stores its configuration data in the same StorageGRID or ONTAP S3 bucket used for your backups. If the Console agent host system fails, you can deploy a new Console agent and restore this data.
You can also follow these steps to replace the Console agent and restore configuration data stored on it when you use Backup and Recovery in standard mode on-premises with no cloud accounts involved (for example, when you use NetApp StorageGRID as the backup destination).
Note This procedure applies only to ONTAP volume data.
When you use NetApp Backup and Recovery in a SaaS environment with the Console agent deployed at your cloud provider or on your own internet-connected host, the system backs up and protects all important configuration data in the cloud. If you have an issue with the Console agent, create a new Console agent and add your systems. The backup details are automatically restored.
There are two types of data that are backed up:
  • NetApp Backup and Recovery database - contains a listing of all the volumes, backup files, backup policies, and configuration information.
  • Indexed Catalog files - contain detailed indexes that Search & Restore functionality uses to quickly find the volume data that you want to restore.
This data is backed up once per day at midnight, and a maximum of 7 copies of each file are retained. If the Console agent is managing multiple on-premises ONTAP systems, the NetApp Backup and Recovery files are stored in the bucket of the system that was activated first.
Tip No volume data is ever included in the NetApp Backup and Recovery database or Indexed Catalog files.
Restore NetApp Backup and Recovery data to a new Console agent
If your on-premises Console agent stops working, you'll need to install a new Console agent, and then restore the NetApp Backup and Recovery data to the new Console agent.
You'll need to perform the following tasks to return your NetApp Backup and Recovery system to a working state:
  • Install a new Console agent
  • Restore the NetApp Backup and Recovery database
  • Restore the Indexed Catalog files
  • Rediscover all of your on-premises ONTAP systems and StorageGRID systems to the NetApp Console UI
After you check that your system is working, create new backup files.
Before you begin
You'll need to access the most recent database and index backups from the StorageGRID or ONTAP S3 bucket where your backup files are being stored:
  • NetApp Backup and Recovery MySQL database file
    This file is located in the following location in the bucket netapp-backup-<GUID>/mysql_backup/, and it is named CBS_DB_Backup_<day>_<month>_<year>.sql.
  • Indexed Catalog backup zip file
    This file is located in the following location in the bucket netapp-backup-<GUID>/catalog_backup/, and it is named Indexed_Catalog_DB_Backup_<db_name>_<day>_<month>_<year>.zip.
Install a new Console agent on a new on-premises Linux host
When installing a new Console agent, download the same software version as the original agent. Changes to the NetApp Backup and Recovery database can cause newer software versions to not work with old database backups. You can upgrade the Console agent software to the most current version after restoring the Backup database.
  1. Install the Console agent on a new on-premises Linux host
  2. Log in to NetApp Console using the admin user credentials that you just created.
  1. Copy the MySQL backup from the backup location to the new Console agent host. The following example uses the file name CBS_DB_Backup_23_05_2023.sql.
  2. Copy the backup into the MySQL docker container using one of the following commands, depending on whether you are using a Docker or Podman container:
    docker cp CBS_DB_Backup_23_05_2023.sql ds_mysql_1:/.
    podman cp CBS_DB_Backup_23_05_2023.sql ds_mysql_1:/.
  3. Enter the MySQL container shell using one of the following commands, depending on whether you are using a Docker or Podman container:
    docker exec -it ds_mysql_1 sh
    podman exec -it ds_mysql_1 sh
  4. In the container shell, deploy the "env".
  5. You'll need the MySQL DB password, so copy the value of the key "MYSQL_ROOT_PASSWORD".
  6. Restore the NetApp Backup and Recovery MySQL DB using the following command:
    mysql -u root -p cloud_backup < CBS_DB_Backup_23_05_2023.sql
  7. Verify that the NetApp Backup and Recovery MySQL DB has been restored correctly using the following SQL commands:
  8. Enter the password.
    mysql> show tables;
    mysql> select * from volume;
  9. Confirm that the volumes shown are the same as those that existed in your original environment.
  1. Copy the Indexed Catalog backup ZIP file from the backup location to the /opt/application/netapp/cbs folder on the new Console agent host. The following example uses the file name Indexed_Catalog_DB_Backup_catalogdb1_23_05_2023.zip.
  2. Unzip the "Indexed_Catalog_DB_Backup_catalogdb1_23_05_2023.zip" file using the following command:
    unzip Indexed_Catalog_DB_Backup_catalogdb1_23_05_2023.zip -d catalogdb1
  3. Run the ls command to make sure that the folder "catalogdb1" has been created and that it contains the subfolders files, versions, and snapshots.
Discover your ONTAP clusters and StorageGRID systems
  1. Discover all the on-prem ONTAP systems that were available in your previous environment. This includes the ONTAP system you have used as an S3 server.
  2. Discover your StorageGRID systems.
Set up the StorageGRID environment details
Add the details of the StorageGRID system that is associated with your ONTAP systems, as they were configured in the original Console agent setup, by using the NetApp Console APIs.
The following information applies to private mode installations starting from NetApp Console 3.9.xx. For older versions, use the following procedure: DarkSite Cloud Backup: MySQL and Indexed Catalog Backup and Restore.
You'll need to perform these steps for each system that is backing up data to StorageGRID.
  1. Extract the authorization token using the following oauth/token API.
    curl 'http://10.193.192.202/oauth/token' -X POST -H 'Accept: application/json' -H 'Accept-Language: en-US,en;q=0.5' -H 'Accept-Encoding: gzip, deflate' -H 'Content-Type: application/json' -d '{"username":"admin@netapp.com","password":"Netapp@123","grant_type":"password"}
    While the IP address, username, and password values are custom values, the account name is not. The account name is always account-DARKSITE1. Also, the username must use an email-formatted name.
    This API returns a response like the following. You can retrieve the authorization token as shown below.
    {"expires_in":21600,"access_token":"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6IjJlMGFiZjRiIn0eyJzdWIiOiJvY2NtYXV0aHwxIiwiYXVkIjpbImh0dHBzOi8vYXBpLmNsb3VkLm5ldGFwcC5jb20iXSwiaHR0cDovL2Nsb3VkLm5ldGFwcC5jb20vZnVsbF9uYW1lIjoiYWRtaW4iLCJodHRwOi8vY2xvdWQubmV0YXBwLmNvbS9lbWFpbCI6ImFkbWluQG5ldGFwcC5jb20iLCJzY29wZSI6Im9wZW5pZCBwcm9maWxlIiwiaWF0IjoxNjcyNzM2MDIzLCJleHAiOjE2NzI3NTc2MjMsImlzcyI6Imh0dHA6Ly9vY2NtYXV0aDo4NDIwLyJ9CJtRpRDY23PokyLg1if67bmgnMcYxdCvBOY-ZUYWzhrWbbY_hqUH4T-114v_pNDsPyNDyWqHaKizThdjjHYHxm56vTz_Vdn4NqjaBDPwN9KAnC6Z88WA1cJ4WRQqj5ykODNDmrv5At_f9HHp0-xVMyHqywZ4nNFalMvAh4xESc5jfoKOZc-IOQdWm4F4LHpMzs4qFzCYthTuSKLYtqSTUrZB81-o-ipvrOqSo1iwIeHXZJJV-UsWun9daNgiYd_wX-4WWJViGEnDzzwOKfUoUoe1Fg3ch--7JFkFl-rrXDOjk1sUMumN3WHV9usp1PgBE5HAcJPrEBm0ValSZcUbiA"}
  2. Extract the system ID and the X-Agent-Id using the tenancy/external/resource API.
    curl -X GET http://10.193.192.202/tenancy/external/resource?account=account-DARKSITE1 -H 'accept: application/json' -H 'authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6IjJlMGFiZjRiIn0eyJzdWIiOiJvY2NtYXV0aHwxIiwiYXVkIjpbImh0dHBzOi8vYXBpLmNsb3VkLm5ldGFwcC5jb20iXSwiaHR0cDovL2Nsb3VkLm5ldGFwcC5jb20vZnVsbF9uYW1lIjoiYWRtaW4iLCJodHRwOi8vY2xvdWQubmV0YXBwLmNvbS9lbWFpbCI6ImFkbWluQG5ldGFwcC5jb20iLCJzY29wZSI6Im9wZW5pZCBwcm9maWxlIiwiaWF0IjoxNjcyNzIyNzEzLCJleHAiOjE2NzI3NDQzMTMsImlzcyI6Imh0dHA6Ly9vY2NtYXV0aDo4NDIwLyJ9X_cQF8xttD0-S7sU2uph2cdu_kN-fLWpdJJX98HODwPpVUitLcxV28_sQhuopjWobozPelNISf7KvMqcoXc5kLDyX-yE0fH9gr4XgkdswjWcNvw2rRkFzjHpWrETgfqAMkZcAukV4DHuxogHWh6-DggB1NgPZT8A_szHinud5W0HJ9c4AaT0zC-sp81GaqMahPf0KcFVyjbBL4krOewgKHGFo_7ma_4mF39B1LCj7Vc2XvUd0wCaJvDMjwp19-KbZqmmBX9vDnYp7SSxC1hHJRDStcFgJLdJHtowweNH2829KsjEGBTTcBdO8SvIDtctNH_GAxwSgMT3zUfwaOimPw'
    This API returns a response like the following. The value under resourceIdentifier denotes the WorkingEnvironment ID, and the value under agentId denotes x-agent-id.
    [{"resourceIdentifier":"OnPremWorkingEnvironment-pMtZND0M","resourceType":"ON_PREM","agentId":"vB_1xShPpBtUosjD7wfBlLIhqDgIPA0wclients","resourceClass":"ON_PREM","name":"CBSFAS8300-01-02","metadata":"{\"clusterUuid\": \"2cb6cb4b-dc07-11ec-9114-d039ea931e09\"}","workspaceIds":["workspace2wKYjTy9"],"agentIds":["vB_1xShPpBtUosjD7wfBlLIhqDgIPA0wclients"]}]
  3. Update the NetApp Backup and Recovery database with the details of the StorageGRID system that is associated with the systems. Make sure that you enter the fully qualified domain name of StorageGRID, along with the access key and storage key, as shown below:
    curl -X POST 'http://10.193.192.202/account/account-DARKSITE1/providers/cloudmanager_cbs/api/v1/sg/credentials/working-environment/OnPremWorkingEnvironment-pMtZND0M' \
    > --header 'authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6IjJlMGFiZjRiIn0eyJzdWIiOiJvY2NtYXV0aHwxIiwiYXVkIjpbImh0dHBzOi8vYXBpLmNsb3VkLm5ldGFwcC5jb20iXSwiaHR0cDovL2Nsb3VkLm5ldGFwcC5jb20vZnVsbF9uYW1lIjoiYWRtaW4iLCJodHRwOi8vY2xvdWQubmV0YXBwLmNvbS9lbWFpbCI6ImFkbWluQG5ldGFwcC5jb20iLCJzY29wZSI6Im9wZW5pZCBwcm9maWxlIiwiaWF0IjoxNjcyNzIyNzEzLCJleHAiOjE2NzI3NDQzMTMsImlzcyI6Imh0dHA6Ly9vY2NtYXV0aDo4NDIwLyJ9X_cQF8xttD0-S7sU2uph2cdu_kN-fLWpdJJX98HODwPpVUitLcxV28_sQhuopjWobozPelNISf7KvMqcoXc5kLDyX-yE0fH9gr4XgkdswjWcNvw2rRkFzjHpWrETgfqAMkZcAukV4DHuxogHWh6-DggB1NgPZT8A_szHinud5W0HJ9c4AaT0zC-sp81GaqMahPf0KcFVyjbBL4krOewgKHGFo_7ma_4mF39B1LCj7Vc2XvUd0wCaJvDMjwp19-KbZqmmBX9vDnYp7SSxC1hHJRDStcFgJLdJHtowweNH2829KsjEGBTTcBdO8SvIDtctNH_GAxwSgMT3zUfwaOimPw' \
    > --header 'x-agent-id: vB_1xShPpBtUosjD7wfBlLIhqDgIPA0wclients' \
    > -d '
    > { "storage-server" : "sr630ip15.rtp.eng.netapp.com:10443", "access-key": "2ZMYOAVAS5E70MCNH9", "secret-password": "uk/6ikd4LjlXQOFnzSzP/T0zR4ZQlG0w1xgWsB" }'
Verify NetApp Backup and Recovery settings
  1. Select each ONTAP system and select View Backups next to the Backup and Recovery service in the right panel.
    You should see all backups created for your volumes.
  2. From the Restore Dashboard, under the Search & Restore section, select Indexing Settings.
    Make sure that the systems that had Indexed Cataloging enabled previously remain enabled.
  3. From the Search & Restore page, run a few catalog searches to confirm that the Indexed Catalog restore has been completed successfully.
