NetApp Data Classification
Integrate Active Directory with NetApp Data Classification
Contributors netapp-ahibbard
You can integrate a global Active Directory with NetApp Data Classification to enhance the results that Data Classification reports about file owners and which users and groups have access to your files.
When you set up certain data sources (listed below), you need to enter Active Directory credentials in order for Data Classification to scan CIFS volumes. This integration provides Data Classification with file owner and permissions details for the data that resides in those data sources. The Active Directory entered for those data sources might differ from the global Active Directory credentials you enter here. Data Classification will look in all integrated Active Directories for user and permission details.
This integration provides additional information in the following locations in Data Classification:
  • You can use the "File Owner" filter and see results in the file's metadata in the Investigation pane. Instead of the file owner containing the SID (Security IDentifier), it is populated with the actual user name.
    You can also view more details about the file owner: account name, email address, and SAM account name, or view items owned by that user.
  • You can see full file permissions for each file and directory when you select the "View all Permissions" button.
  • In the Governance dashboard, the Open Permissions panel will show a greater level of detail about your data.
Note Local user SIDs, and SIDs from unknown domains, are not translated to the actual user name.
Supported data sources
An Active Directory integration with Data Classification can identify data from within the following data sources:
  • Azure NetApp Files
  • Cloud Volumes ONTAP
  • FSx for ONTAP
  • On-premises ONTAP systems
Connect to your Active Directory server
After you've deployed Data Classification and have activated scanning on your data sources, you can integrate Data Classification with your Active Directory. Active Directory can be accessed using a DNS Server IP address or an LDAP Server IP address.
The Active Directory credentials can be read-only, but providing admin credentials ensures that Data Classification can read any data that requires elevated permissions. The credentials are stored on the Data Classification instance.
For CIFS volumes/file shares, if you want to make sure your files "last accessed times" are unchanged by Data Classification scans, the user should have Write Attributes permission. If possible, we recommend making the Active Directory configured user part of a parent group in the organization which has permissions to all files.
Requirements
  • You must have an Active Directory already set up for the users in your company.
  • You must have the information for the Active Directory:
    • DNS Server IP address, or multiple IP addresses
      or
      LDAP Server IP address, or multiple IP addresses
    • User Name and Password to access the server
    • Domain Name (Active Directory Name)
    • Whether you are using secure LDAP (LDAPS) or not
    • LDAP Server Port (typically 389 for LDAP, and 636 for secure LDAP)
  • The following ports must be open for outbound communication by the Data Classification instance:
    Protocol Port Destination Purpose
    TCP & UDP
    389
    Active Directory
    LDAP
    TCP
    636
    Active Directory
    LDAP over SSL
    TCP
    3268
    Active Directory
    Global Catalog
    TCP
    3269
    Active Directory
    Global Catalog over SSL
Steps
  1. In Data Classification, select Configuration.
  2. Switch to the Settings tab.
  3. In the Active Directory heading, select Add.
  4. In the Connect to Active Directory dialog, enter the Active Directory details then select Connect.
    You can add multiple IP addresses, if required, by selecting Add IP.
    Data Classification integrates to the Active Directory, and a new section is added to the Configuration page.
Manage your Active Directory integration
If you need to modify any values in your Active Directory integration, you must update the Active Directory configuration in Data Classification. Return to the Configuration menu in Data Classification then switch to the settings tab to make the changes.
You can also delete the integration selecting the Remove button under Active Directory.
