User activity detection requirements for NetApp Ransomware Resilience
NetApp Ransomware Resilience user behavior detection enables you to respond to user-level ransomware events. You must create a set of agents to enable user behavior detection. Before enabling detection, you must ensure you meet the outlined operating system, server, and network requirements so that Ransomware Resilience can properly detect and report events.
User activity agent cloud provider support
To enable user behavior detection, you must create a user activity agent. The user activity agent is an executable environment for data collectors, which share user activity events with Ransomware Resilience.
The user activity agent can be deployed in AWS and Azure in the following regions:
| Cloud provider | Region |
AWS |
Azure |
East US |
The regional deployment of the user activity agent has no impact on the Console agent. Console agent deployment is independent of these regions. |
Operating system requirements
Suspicious user behavior detection is supported with the following operating systems:
| Operating system | Supported versions |
AlmaLinux |
9.4 (64 bit) through 9.5 (64 bit), and 10 (64 bit), including SELinux |
CentOS |
CentOS Stream 9 (64 bit) |
Debian |
11 (64 bit), 12 (64 bit), including SELinux |
OpenSUSE Leap |
15.3 (64 bit) through 15.6 (64 bit) |
Oracle Linux |
8.10 (64 bit), and 9.1 (64 bit) through 9.6 (64 bit), including SELinux |
Red Hat |
8.10 (64 bit), 9.1 (64 bit) through 9.6 (64 bit), and 10 (64 bit), including SELinux |
Rocky |
Rocky 9.4 (64 bit) through 9.6 (64 bit), including SELinux |
SUSE Enterprise Linux |
15 SP4 (64 bit) through 15 SP6 (64 bit), including SELinux |
Ubuntu |
20.04 LTS (64 bit), 22.04 LTS (64 bit) and 24.04 LTS (64 bit) |
The machine you use for the user activity agent should not be running other application-level software. A dedicated server is recommended. |
The unzip command is required for installation. The sudo su - command is required for installation, running scripts, and deinstallation.
Server requirements
The server must meet the following minimum requirements:
CPU: 4 cores
RAM: 16 GB RAM
Disk space: 36 GB free disk space
Server recommendations
Allocate extra disk space to allow for the creation of the file system. Ensure that there is at least 35 GB of free space in the file system.
If/optis a mounted folder from a NAS storage, local users must have access to this folder. User activity agent creation can fail if local users don't have the necessary permissions. -
It is recommended that you install the user activity agent on a system separate from your Ransomware Resilience environment. If you do install the agent and Ransomware Resilience on the same machine, allow for 50 to 55 GB of disk space. For Linux, allocate 25 to 30 GB of space to
/opt/netappand 25 GB tovar/log/netapp. -
It's recommended you synchronize the time on both the ONTAP system and the user activity agent machine using Network Time Protocol (NTP) or Simple Network Time Protocol (SNTP).
Sizing recommendations
When collecting user events, ensure the machine hosting the user activity agent is sized to accommodate your event rate. This means ensuring you have enough data collectors and enough CPU and RAM on the machine hosting the user activity agent to tolerate the number of events per second. To increase the number of data collectors, you may need to increase the RAM or CPU capacity. Ransomware Resilience supports up to 50 data collectors per user activity agent.
The following table provides general guidance for sizing:
| User activity agent machine configuration | Number of data collectors | Maximum event rate |
4 cores, 16GB |
10 data collectors |
20,000 events/second |
4 cores, 32GB |
20 data collectors |
You can also calculate your specific requirements. When calculating the appropriate size, it's recommended you qualify with a buffer rate of 30%. Use this formula to determine if your configuration can handle the load.
Where E is the sum of all events per second across all data collectors: E + (0.3 x E) < 20,000 events/second
Ransomware Resilience provides a script to calculate the event data rate. Learn how to calculate the event data rate in Ransomware Resilience.
Ransomware Resilience provides a script you can run on your system to calculate the event data rate. By default, the script runs for a maximum of five storage VMs. If your environment includes more than 5 SVMs, you can modify the script accordingly. Regardless of the number of SVMs, the script takes approximately five minutes to get an average event rate reading. Before running the script you must have:
The cluster IP address
The cluster admin username and password
Installed
sshpasson the Linux machine (you can install with the commandsudo yum install -y sshpass)
From the cluster hosting the user activity agent, run the script as an admin:
/opt/netapp/cloudsecure/agent/install/svm_event_rate_checker.sh -
When prompted, provide the cluster IP address, the admin username, and the admin password.
The script takes approximately five minutes to run. When it completes, the command line displays the event rate, for example "Svm svm_rate is generating 100 events/sec."
Use the event rate to calculate your sizing.
Cloud network access rules
Review the cloud network access rules for your relevant geography (Asia Pacific, Europe, or United States).
During the initial installation, replace the <site_name> with a wildcard (*) permission. After the agent is activated and fully operational, you can replace the permission with the site name. Contact your NetApp representative for the site name.
The user activity agent uses NetApp Data Insights Infrastructure technology, hence the use of cloudinsights endpoints. For more information, see Ransomware Resilience and Data Infrastructure Insights.
APAC-based user activity agent deployments
| Protocol | Port | Source | Destination | Description |
HTTPS (TCP) |
443 |
User activity agent |
Access to Ransomware Resilience |
Europe-based user activity agent deployments
HTTPS (TCP) |
443 |
US-based user activity agent deployments
HTTPS (TCP) |
443 |
In-network rules
TCP |
389(LDAP) |
LDAP Server URL |
Connect to LDAP |
HTTPS (TCP) |
443 |
Cluster or SVM management IP address (depending on SVM collector configuration) |
API communication with ONTAP |
TCP |
35000 - 55000 |
SVM data LIF IP addresses |
Communication from ONTAP to the user activity agent for FPolicy events. These ports must be opened towards the user activity agent in order for ONTAP to send events to it, including any firewall on the user activity agent itself (if present). |
TCP |
35000-55000 |
Cluster Management IP |
Communication from ONTAP cluster management IP to the user activity agent for EMS events. These ports must be opened towards the user activity agent in order for ONTAP to send EMS events to it, including any firewall on the user activity agent itself. |
SSH |
22 |
Cluster management |
Needed for CIFS/SMB user blocking. |
