NetApp Ransomware Resilience
Access NetApp Ransomware Resilience
Contributors netapp-ahibbard
Access NetApp Ransomware Resilience in the NetApp Console.
To log in to the Console, you can use your NetApp Support Site credentials or you can sign up for a NetApp cloud login using your email and a password. Learn more about logging in.
Required Console role
To perform this task, you need the Super admin, Ransomware Resilience admin, or Ransomware Resilience viewer role. Learn about Ransomware Resilience roles for NetApp Console.
Steps
  1. Open a web browser and go to the Console.
    The Console login page appears.
  2. Log in to the Console.
  3. From the Console left navigation, select Protection > Ransomware Resilience.
    If this is your first time logging in to this service, the landing page appears.
    Note If you don't have a Console agent or it's not the one for this service, you need to deploy one. Learn how to set up a Console agent.
    Screenshot of the Ransomware Resilience landing page.
    Otherwise, the Ransomware Resilience dashboard appears.
    Screenshot of the Ransomware Resilience dashboard
  4. If this is your first time using Ransomware Resilience, discover workloads.
